Philips-TV remote / JointSpace API
Philips-TV Remote
A simple remote control via the dashboard, using the Philips jointSPACE-API.
Dashboard
For correct functioning, the IPs in the HTTP nodes must be adapted.
jointSPACE
jointSPACE API Documentation V1
jointSPACE API Documentation V2.2
Homepage
[{"id":"88a7a6e4.16ea08","type":"http request","z":"8b970bec.9dc298","name":"","method":"POST","ret":"txt","paytoqs":false,"url":"http://192.168.178.51:1925/1/audio/volume","tls":"","proxy":"","authType":"","x":1670,"y":520,"wires":[[]]},{"id":"f4bb522a.eb622","type":"rbe","z":"8b970bec.9dc298","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":1510,"y":520,"wires":[["88a7a6e4.16ea08"]]},{"id":"ce6c54a7.954ab","type":"function","z":"8b970bec.9dc298","name":"jointSPACE Send Key","func":"node.status({fill:\"yellow\",shape:\"dot\", text: msg.payload});\n\nmsg.payload = {\n    \"key\": msg.payload\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":1080,"y":680,"wires":[["66ba3bab.069fcc"]]},{"id":"e210e67a.a0d178","type":"ui_button","z":"8b970bec.9dc298","name":"button, VolumeUp","group":"950dae1d.43b6a","order":4,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"volume_up","payload":"VolumeUp","payloadType":"str","topic":"","x":190,"y":620,"wires":[["ce6c54a7.954ab"]]},{"id":"a64a18bf.09422","type":"ui_button","z":"8b970bec.9dc298","name":"button, VolumeDown","group":"950dae1d.43b6a","order":7,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"volume_down","payload":"VolumeDown","payloadType":"str","topic":"","x":200,"y":580,"wires":[["ce6c54a7.954ab"]]},{"id":"f89d8c81.74bd58","type":"ui_button","z":"8b970bec.9dc298","name":"button, ChannelStepUp","group":"950dae1d.43b6a","order":6,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"keyboard_arrow_up","payload":"ChannelStepUp","payloadType":"str","topic":"","x":210,"y":760,"wires":[["ce6c54a7.954ab"]]},{"id":"f11247ba.bc084","type":"ui_button","z":"8b970bec.9dc298","name":"button, ChannelStepDown","group":"950dae1d.43b6a","order":9,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"keyboard_arrow_down","payload":"ChannelStepDown","payloadType":"str","topic":"","x":220,"y":800,"wires":[["ce6c54a7.954ab"]]},{"id":"37918255.684fa6","type":"ui_button","z":"8b970bec.9dc298","name":"button, CursorUp","group":"950dae1d.43b6a","order":14,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"keyboard_arrow_up","payload":"CursorUp","payloadType":"str","topic":"","x":550,"y":920,"wires":[["ce6c54a7.954ab"]]},{"id":"9bc7c006.41a5b","type":"ui_button","z":"8b970bec.9dc298","name":"button, CursorDown","group":"950dae1d.43b6a","order":20,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"keyboard_arrow_down","payload":"CursorDown","payloadType":"str","topic":"","x":560,"y":1000,"wires":[["ce6c54a7.954ab"]]},{"id":"416a7127.44a098","type":"ui_button","z":"8b970bec.9dc298","name":"button, CursorLeft","group":"950dae1d.43b6a","order":16,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"keyboard_arrow_left","payload":"CursorLeft","payloadType":"str","topic":"","x":330,"y":960,"wires":[["ce6c54a7.954ab"]]},{"id":"a0f28a5c.98eca8","type":"ui_button","z":"8b970bec.9dc298","name":"button, CursorRight","group":"950dae1d.43b6a","order":18,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"keyboard_arrow_right","payload":"CursorRight","payloadType":"str","topic":"","x":780,"y":960,"wires":[["ce6c54a7.954ab"]]},{"id":"cb5b25fe.67c1b8","type":"ui_button","z":"8b970bec.9dc298","name":"button, Confirm","group":"950dae1d.43b6a","order":17,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"done","payload":"Confirm","payloadType":"str","topic":"","x":540,"y":960,"wires":[["ce6c54a7.954ab"]]},{"id":"db40aff2.029fe8","type":"ui_button","z":"8b970bec.9dc298","name":"button, Standby","group":"950dae1d.43b6a","order":3,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"#fff","bgcolor":"#800707","icon":"power_settings_new","payload":"Standby","payloadType":"str","topic":"","x":180,"y":680,"wires":[["f7f16a6.fe75218"]]},{"id":"11191797.0f3608","type":"ui_button","z":"8b970bec.9dc298","name":"button, Mute","group":"950dae1d.43b6a","order":10,"width":2,"height":1,"passthru":false,"label":"Mute","tooltip":"","color":"","bgcolor":"","icon":"volume_mute","payload":"Mute","payloadType":"str","topic":"","x":170,"y":840,"wires":[["ce6c54a7.954ab"]]},{"id":"3ee83997.e930a6","type":"ui_button","z":"8b970bec.9dc298","name":"button, Home","group":"950dae1d.43b6a","order":1,"width":2,"height":1,"passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"home","payload":"Home","payloadType":"str","topic":"","x":180,"y":720,"wires":[["ce6c54a7.954ab"]]},{"id":"7699172a.4bb5e","type":"http request","z":"8b970bec.9dc298","name":"","method":"POST","ret":"txt","paytoqs":false,"url":"http://192.168.178.51:1925/1/input/key","tls":"","proxy":"","authType":"","x":1670,"y":680,"wires":[[]]},{"id":"f7f16a6.fe75218","type":"ui_toast","z":"8b970bec.9dc298","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"Cancel","topic":"Rückfrage","name":"","x":350,"y":680,"wires":[["7740ca8.2d63a34"]]},{"id":"7740ca8.2d63a34","type":"change","z":"8b970bec.9dc298","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"OK","fromt":"str","to":"Standby","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Cancel","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":680,"wires":[["ce6c54a7.954ab"]]},{"id":"96a1d922.3ae3e8","type":"ui_button","z":"8b970bec.9dc298","name":"button, VolumeDown -5","group":"950dae1d.43b6a","order":8,"width":2,"height":1,"passthru":false,"label":" - 5","tooltip":"","color":"","bgcolor":"","icon":"volume_down","payload":"","payloadType":"num","topic":"-","x":210,"y":540,"wires":[["f3845e72.f3534"]]},{"id":"f3845e72.f3534","type":"http request","z":"8b970bec.9dc298","name":"","method":"GET","ret":"obj","paytoqs":false,"url":"http://192.168.178.51:1925/1/audio/volume","tls":"","proxy":"","authType":"","x":770,"y":520,"wires":[["e53072b7.7d38f8"]]},{"id":"adabf75c.d303b8","type":"ui_button","z":"8b970bec.9dc298","name":"button, VolumeUp + 5","group":"950dae1d.43b6a","order":5,"width":2,"height":1,"passthru":false,"label":"+ 5","tooltip":"","color":"","bgcolor":"","icon":"volume_up","payload":"","payloadType":"num","topic":"+","x":200,"y":500,"wires":[["f3845e72.f3534"]]},{"id":"e53072b7.7d38f8","type":"function","z":"8b970bec.9dc298","name":"jointSPACE Volume +- 5","func":"if (msg.topic == \"+\") {\n    msg.payload = {\n    \"muted\":  msg.payload.muted,\n    \"current\": msg.payload.current + 5 }\n} else if (msg.topic == \"-\") {\n    msg.payload = {\n    \"muted\":  msg.payload.muted,\n    \"current\": msg.payload.current - 5 }\n}\nreturn msg;","outputs":1,"noerr":0,"x":990,"y":520,"wires":[["f4bb522a.eb622"]]},{"id":"66ba3bab.069fcc","type":"delay","z":"8b970bec.9dc298","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"3","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1460,"y":680,"wires":[["7699172a.4bb5e"]]},{"id":"950dae1d.43b6a","type":"ui_group","z":"","name":"Fernbedienung","tab":"7db32cb0.3e5104","order":1,"disp":true,"width":"6","collapse":true},{"id":"7db32cb0.3e5104","type":"ui_tab","z":"","name":"TV","icon":"tv","order":12,"disabled":false,"hidden":false}]
Created 6 years, 9 months ago
Updated 6 years, 8 months ago
  • change (x1)
  • delay (x1)
  • function (x2)
  • http request (x3)
  • rbe (x1)
  • ui_button (x14)
  • ui_group (x1)
  • ui_toast (x1)
  • JointSpace
  • TV
  • Philips
  • Remote
