Send FRITZ!Box call list as CSV file via e-mail V2.0.
FRITZ!Box call list as CSV file via e-mail.
The FRITZ!Box shows a maximum of 400 entries in the call list. For a regular, automatic backup of them, I have developed the following flow.
Flow
Customization to your own system
  • Match the inject node with the parameters for the FRITZ!Box, regarding the frequency and number of data.
  • Match the configuration of the Fritz Box.
  • Perhaps change the parameters in the node "Parameters".
  • Configure the parameters to send the email.
Homepage
Update:
V2.0: Replaced node fastcsv with csv.
[{"id":"5954d7e4.e1f548","type":"e-mail","z":"e294d8d7.17e738","server":"mail.gmx.net","port":"465","secure":true,"tls":true,"name":"[email protected]","dname":"","x":590,"y":1540,"wires":[]},{"id":"ed6806cf.8f69c","type":"fritzbox-calllist","z":"e294d8d7.17e738","device":"","name":"","action":"GetCallList","listurl":"NewCallListURL","max":"400","maxdays":"8","x":350,"y":1460,"wires":[["5f57a0d7.424b88"]]},{"id":"c362a96b.6d28d8","type":"json","z":"e294d8d7.17e738","name":"","property":"payload.Call","action":"obj","pretty":false,"x":130,"y":1540,"wires":[["5a5d832a.effcec"]]},{"id":"db45ac56.b7ed08","type":"change","z":"e294d8d7.17e738","name":"Parameter","rules":[{"t":"set","p":"attachments","pt":"msg","to":"{\t   \"filename\":\"FRITZ!Box Anrufliste.csv\",\t   \"content\": msg.payload,\t   \"contentType\":\"text/plain\"\t}","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"\"FRITZ!Box Anrufliste vom \" & $now()","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":1540,"wires":[["5954d7e4.e1f548"]]},{"id":"5f57a0d7.424b88","type":"change","z":"e294d8d7.17e738","name":"","rules":[{"t":"move","p":"payload.Call","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":1460,"wires":[["c362a96b.6d28d8"]]},{"id":"5938121b.4af2fc","type":"inject","z":"e294d8d7.17e738","name":"Mo. 0:00","props":[{"p":"payload"}],"repeat":"","crontab":"00 00 * * 1","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":1460,"wires":[["ed6806cf.8f69c"]]},{"id":"5a5d832a.effcec","type":"csv","z":"e294d8d7.17e738","name":"","sep":";","hdrin":true,"hdrout":"all","multi":"one","ret":"\\n","temp":"Id,Type,Caller,Called,CalledNumber,Name,Numbertype,Device,Port,Date,Duration,Count,Path","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":250,"y":1540,"wires":[["db45ac56.b7ed08"]]}]
Created 5 years, 10 months ago
  • change (x2)
  • csv (x1)
  • json (x1)
  • FRITZ!Box
  • csv
  • call-list
  • e-mail
  • send
