ZOOZ - ZEN32 Scene Controller - Subflow
This Subflow processes Button events for the Zooz ZEN32 Scene Controller.
35 Outputs.
It needs input from "events - all" with "zwave_js_value_notification" as the Entity Type.
Made for and tested with the ZEN32 Scene Controller, but it should work for other Zooz switches that allow scenes.
Update - 23-APR-2022 - Subflow updated and tested with Firmware 10.0
[{"id":"bc32d04764594dca","type":"subflow","name":"ZEN32 Scenes","info":"","category":"","in":[{"x":40,"y":120,"wires":[{"id":"06ce5d08da1f53bb"}]}],"out":[{"x":580,"y":40,"wires":[{"id":"c72e7d0f0d14389c","port":0},{"id":"c72e7d0f0d14389c","port":7}]},{"x":590,"y":80,"wires":[{"id":"c72e7d0f0d14389c","port":1},{"id":"c72e7d0f0d14389c","port":8}]},{"x":590,"y":120,"wires":[{"id":"c72e7d0f0d14389c","port":2},{"id":"c72e7d0f0d14389c","port":9}]},{"x":590,"y":160,"wires":[{"id":"c72e7d0f0d14389c","port":3},{"id":"c72e7d0f0d14389c","port":10}]},{"x":590,"y":200,"wires":[{"id":"c72e7d0f0d14389c","port":4},{"id":"c72e7d0f0d14389c","port":11}]},{"x":830,"y":40,"wires":[{"id":"c72e7d0f0d14389c","port":5},{"id":"c72e7d0f0d14389c","port":12}]},{"x":840,"y":100,"wires":[{"id":"c72e7d0f0d14389c","port":6},{"id":"c72e7d0f0d14389c","port":13}]},{"x":580,"y":260,"wires":[{"id":"7758e3e7ca4d370f","port":0},{"id":"7758e3e7ca4d370f","port":7}]},{"x":590,"y":300,"wires":[{"id":"7758e3e7ca4d370f","port":1},{"id":"7758e3e7ca4d370f","port":8}]},{"x":590,"y":340,"wires":[{"id":"7758e3e7ca4d370f","port":2},{"id":"7758e3e7ca4d370f","port":9}]},{"x":590,"y":380,"wires":[{"id":"7758e3e7ca4d370f","port":3},{"id":"7758e3e7ca4d370f","port":10}]},{"x":590,"y":420,"wires":[{"id":"7758e3e7ca4d370f","port":4},{"id":"7758e3e7ca4d370f","port":11}]},{"x":830,"y":260,"wires":[{"id":"7758e3e7ca4d370f","port":5},{"id":"7758e3e7ca4d370f","port":12}]},{"x":840,"y":320,"wires":[{"id":"7758e3e7ca4d370f","port":6},{"id":"7758e3e7ca4d370f","port":13}]},{"x":580,"y":480,"wires":[{"id":"ec12c29947a86482","port":0},{"id":"ec12c29947a86482","port":7}]},{"x":590,"y":520,"wires":[{"id":"ec12c29947a86482","port":1},{"id":"ec12c29947a86482","port":8}]},{"x":590,"y":560,"wires":[{"id":"ec12c29947a86482","port":2},{"id":"ec12c29947a86482","port":9}]},{"x":590,"y":600,"wires":[{"id":"ec12c29947a86482","port":3},{"id":"ec12c29947a86482","port":10}]},{"x":590,"y":640,"wires":[{"id":"ec12c29947a86482","port":4},{"id":"ec12c29947a86482","port":11}]},{"x":830,"y":480,"wires":[{"id":"ec12c29947a86482","port":5},{"id":"ec12c29947a86482","port":12}]},{"x":840,"y":540,"wires":[{"id":"ec12c29947a86482","port":6},{"id":"ec12c29947a86482","port":13}]},{"x":580,"y":700,"wires":[{"id":"be89ca4f6422e9d5","port":0},{"id":"be89ca4f6422e9d5","port":7}]},{"x":590,"y":740,"wires":[{"id":"be89ca4f6422e9d5","port":1},{"id":"be89ca4f6422e9d5","port":8}]},{"x":590,"y":780,"wires":[{"id":"be89ca4f6422e9d5","port":2},{"id":"be89ca4f6422e9d5","port":9}]},{"x":590,"y":820,"wires":[{"id":"be89ca4f6422e9d5","port":3},{"id":"be89ca4f6422e9d5","port":10}]},{"x":590,"y":860,"wires":[{"id":"be89ca4f6422e9d5","port":4},{"id":"be89ca4f6422e9d5","port":11}]},{"x":830,"y":700,"wires":[{"id":"be89ca4f6422e9d5","port":5},{"id":"be89ca4f6422e9d5","port":12}]},{"x":840,"y":760,"wires":[{"id":"be89ca4f6422e9d5","port":6},{"id":"be89ca4f6422e9d5","port":13}]},{"x":590,"y":920,"wires":[{"id":"77398b27e581da5e","port":0},{"id":"77398b27e581da5e","port":7}]},{"x":600,"y":960,"wires":[{"id":"77398b27e581da5e","port":1},{"id":"77398b27e581da5e","port":8}]},{"x":600,"y":1000,"wires":[{"id":"77398b27e581da5e","port":2},{"id":"77398b27e581da5e","port":9}]},{"x":600,"y":1040,"wires":[{"id":"77398b27e581da5e","port":3},{"id":"77398b27e581da5e","port":10}]},{"x":600,"y":1080,"wires":[{"id":"77398b27e581da5e","port":4},{"id":"77398b27e581da5e","port":11}]},{"x":840,"y":920,"wires":[{"id":"77398b27e581da5e","port":5},{"id":"77398b27e581da5e","port":12}]},{"x":850,"y":980,"wires":[{"id":"77398b27e581da5e","port":6},{"id":"77398b27e581da5e","port":13}]}],"env":[],"meta":{},"color":"#DDAA99","outputLabels":["Button 1 - TAP","Button 1 - TAP x 2","Button 1 - TAP x 3","Button 1 - TAP x 4","Button 1 - TAP x 5","Button 1 - HOLD","Button 1 - RELEASE","Button 2 - TAP","Button 2 - TAP x 2","Button 2 - TAP x 3","Button 2 - TAP x 4","Button 2 - TAP x 5","Button 2 - HOLD","Button 2 - RELEASE","Button 3 - TAP","Button 3 - TAP x 2","Button 3 - TAP x 3","Button 3 - TAP x 4","Button 3 - TAP x 5","Button 3 - HOLD","Button 3 - RELEASE","Button 4 - TAP","Button 4 - TAP x 2","Button 4 - TAP x 3","Button 4 - TAP x 4","Button 4 - TAP x 5","Button 4 - HOLD","Button 4 - RELEASE","Main Button - TAP","Main Button - TAP x 2","Main Button - TAP x 3","Main Button - TAP x 4","Main Button - TAP x 5","Main Button - HOLD","Main Button - RElEASE"]},{"id":"06ce5d08da1f53bb","type":"switch","z":"bc32d04764594dca","name":"Scene ID","property":"payload.event.label","propertyType":"msg","rules":[{"t":"eq","v":"Scene 001","vt":"str"},{"t":"eq","v":"Scene 002","vt":"str"},{"t":"eq","v":"Scene 003","vt":"str"},{"t":"eq","v":"Scene 004","vt":"str"},{"t":"eq","v":"Scene 005","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":100,"y":360,"wires":[["c72e7d0f0d14389c"],["7758e3e7ca4d370f"],["ec12c29947a86482"],["be89ca4f6422e9d5"],["77398b27e581da5e"]]},{"id":"c72e7d0f0d14389c","type":"switch","z":"bc32d04764594dca","name":"Button 1","property":"payload.event.value","propertyType":"msg","rules":[{"t":"eq","v":"KeyPressed","vt":"str"},{"t":"eq","v":"KeyPressed2x","vt":"str"},{"t":"eq","v":"KeyPressed3x","vt":"str"},{"t":"eq","v":"KeyPressed4x","vt":"str"},{"t":"eq","v":"KeyPressed5x","vt":"str"},{"t":"eq","v":"KeyHeldDown","vt":"str"},{"t":"eq","v":"KeyReleased","vt":"str"},{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":14,"x":340,"y":120,"wires":[[],[],[],[],[],[],[],[],[],[],[],[],[],[]],"outputLabels":["TAP x 1","TAP x 2","TAP x 3","TAP x 4","TAP x 5","HOLD","RELEASE",null,null,null,null,null,null,null]},{"id":"7758e3e7ca4d370f","type":"switch","z":"bc32d04764594dca","name":"Button 2","property":"payload.event.value","propertyType":"msg","rules":[{"t":"eq","v":"KeyPressed","vt":"str"},{"t":"eq","v":"KeyPressed2x","vt":"str"},{"t":"eq","v":"KeyPressed3x","vt":"str"},{"t":"eq","v":"KeyPressed4x","vt":"str"},{"t":"eq","v":"KeyPressed5x","vt":"str"},{"t":"eq","v":"KeyHeldDown","vt":"str"},{"t":"eq","v":"KeyReleased","vt":"str"},{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":14,"x":340,"y":340,"wires":[[],[],[],[],[],[],[],[],[],[],[],[],[],[]],"outputLabels":["TAP x 1","TAP x 2","TAP x 3","TAP x 4","TAP x 5","HOLD","RELEASE",null,null,null,null,null,null,null]},{"id":"ec12c29947a86482","type":"switch","z":"bc32d04764594dca","name":"Button 3","property":"payload.event.value","propertyType":"msg","rules":[{"t":"eq","v":"KeyPressed","vt":"str"},{"t":"eq","v":"KeyPressed2x","vt":"str"},{"t":"eq","v":"KeyPressed3x","vt":"str"},{"t":"eq","v":"KeyPressed4x","vt":"str"},{"t":"eq","v":"KeyPressed5x","vt":"str"},{"t":"eq","v":"KeyHeldDown","vt":"str"},{"t":"eq","v":"KeyReleased","vt":"str"},{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":14,"x":340,"y":560,"wires":[[],[],[],[],[],[],[],[],[],[],[],[],[],[]],"outputLabels":["TAP x 1","TAP x 2","TAP x 3","TAP x 4","TAP x 5","HOLD","RELEASE",null,null,null,null,null,null,null]},{"id":"be89ca4f6422e9d5","type":"switch","z":"bc32d04764594dca","name":"Button 4","property":"payload.event.value","propertyType":"msg","rules":[{"t":"eq","v":"KeyPressed","vt":"str"},{"t":"eq","v":"KeyPressed2x","vt":"str"},{"t":"eq","v":"KeyPressed3x","vt":"str"},{"t":"eq","v":"KeyPressed4x","vt":"str"},{"t":"eq","v":"KeyPressed5x","vt":"str"},{"t":"eq","v":"KeyHeldDown","vt":"str"},{"t":"eq","v":"KeyReleased","vt":"str"},{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":14,"x":340,"y":780,"wires":[[],[],[],[],[],[],[],[],[],[],[],[],[],[]],"outputLabels":["TAP x 1","TAP x 2","TAP x 3","TAP x 4","TAP x 5","HOLD","RELEASE",null,null,null,null,null,null,null]},{"id":"77398b27e581da5e","type":"switch","z":"bc32d04764594dca","name":"Main Button","property":"payload.event.value","propertyType":"msg","rules":[{"t":"eq","v":"KeyPressed","vt":"str"},{"t":"eq","v":"KeyPressed2x","vt":"str"},{"t":"eq","v":"KeyPressed3x","vt":"str"},{"t":"eq","v":"KeyPressed4x","vt":"str"},{"t":"eq","v":"KeyPressed5x","vt":"str"},{"t":"eq","v":"KeyHeldDown","vt":"str"},{"t":"eq","v":"KeyReleased","vt":"str"},{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":14,"x":350,"y":1000,"wires":[[],[],[],[],[],[],[],[],[],[],[],[],[],[]],"outputLabels":["TAP x 1","TAP x 2","TAP x 3","TAP x 4","TAP x 5","HOLD","RELEASE",null,null,null,null,null,null,null]}]
Created 3 years, 9 months ago
Updated 3 years, 4 months ago
Rating: 4 4
  • switch (x6)
  • subflow (x1)
  • zen32
  • zooz
  • scene-controller
  • zwave_js
  • zooz-zen32
  • zwavejs
  • scene
  • scenes
  • zen
  • zooz-scene
