Get Strava activity and stats
This is a sample flow to display strava activities and stats in the UI. Include the last track as image.
One flow with http request. Two flows with strava api access token.
Modify the design with CSS. Insert your api token and your athlete id in the marked nodes.
[{"id":"6150bb62.28c0f4","type":"html","z":"b8c0412b.95d0a","name":"","property":"payload","outproperty":"payload","tag":"#activity-totals","ret":"html","as":"single","x":727.87890625,"y":358.5859375,"wires":[["1ac9e2ce.0abd1d"]]},{"id":"ad51c440.72c268","type":"ui_template","z":"b8c0412b.95d0a","group":"37541ec6.84e1a2","name":"Month ride totals","order":2,"width":"0","height":"0","format":"<div><h3>Current month</h3></div>\n<div ng-bind-html=\"msg.payload\"></div>\n\n<style>\n    {{msg.style}}\n</style>\n\n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1069.9921875,"y":357.59368896484375,"wires":[["f9bd8b33.c8ba18"]]},{"id":"b1f41f83.88fce","type":"function","z":"b8c0412b.95d0a","name":"","func":"sec = msg.payload.ytd_ride_totals.moving_time;\nhr = Math.floor(sec / 3600);\nmin = Math.floor((sec % 3600) / 60);\ndistance =  Math.floor(msg.payload.ytd_ride_totals.distance/1000);\nelevation = Math.floor(msg.payload.ytd_ride_totals.elevation_gain);\n\n\nmsg.payload = {\n  ytd_ride_totals: {\n    distance: distance,\n    elevation: elevation,\n    moving_time: {\n      hr: hr,\n      min: min,\n    },\n  }\n}\n\nreturn msg;\n\n\n\n\n\n","outputs":1,"noerr":0,"x":698.9765625,"y":443.66400146484375,"wires":[["1622bf4a.bd0471"]]},{"id":"2d81246d.a0236c","type":"ui_template","z":"b8c0412b.95d0a","group":"37541ec6.84e1a2","name":"Years ride totals","order":3,"width":"0","height":"0","format":"<div>\n    <h3>Total rides this Year</h3>\n    <ul class=\"inline-stats\" id=\"activity-totals\">\n        <li>\n            <strong>{{msg.payload.ytd_ride_totals.distance}}<abbr class=\"unit\" title=\"Kilometer\">km</abbr></strong><div class=\"label\">DISTANCE</div>\n        </li>\n        <li>\n            <strong>{{msg.payload.ytd_ride_totals.moving_time.hr}}<abbr class=\"unit\" title=\"Stunde\">h</abbr> {{msg.payload.ytd_ride_totals.moving_time.min}}<abbr class=\"unit\" title=\"Minute\">min</abbr></strong>\n            <div class=\"label\">TIME</div>\n        </li>\n        <li>\n            <strong>{{msg.payload.ytd_ride_totals.elevation}}<abbr class=\"unit\" title=\"Meter\">m</abbr></strong><div class=\"label\">ELEVATION</div>\n        </li>\n    </ul>\n</div>\n<style>\n    {{msg.style}}\n</style>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1046.4765625,"y":442.66400146484375,"wires":[["f9bd8b33.c8ba18"]]},{"id":"1ac9e2ce.0abd1d","type":"template","z":"b8c0412b.95d0a","name":"css","field":"style","fieldType":"msg","format":"css","syntax":"mustache","template":"\n.nr-dashboard-template li {\n    display:inline-block;\n    list-style-type: none;\n    font-size: 16px;\n    font-weight: 300;\n    color: #99999e;\n    overflow: auto;\n    padding: 5px;\n}\n\n.nr-dashboard-template {\n    height: auto !important;\n    text-align: center;\n}\n\n\n\n\n\n","output":"str","x":907.4765625,"y":357.66400146484375,"wires":[["ad51c440.72c268"]]},{"id":"1622bf4a.bd0471","type":"template","z":"b8c0412b.95d0a","name":"css","field":"style","fieldType":"msg","format":"css","syntax":"mustache","template":"#activity-totals{\n    padding: 5px;\n}\n\nabbr {\n    text-decoration: none;\n}\n\n\n","output":"str","x":858.4765625,"y":442.66400146484375,"wires":[["2d81246d.a0236c"]]},{"id":"b072f7f6.d06958","type":"function","z":"b8c0412b.95d0a","name":"","func":"moving_time = msg.payload[0].moving_time;\nhr = Math.floor(moving_time / 3600);\nmin = Math.floor((moving_time % 3600) / 60);\nsec = Math.floor(moving_time % 60);\ndistance =  (msg.payload[0].distance/1000).toFixed(2);\n\nelevation = Math.floor(msg.payload[0].total_elevation_gain);\nname = msg.payload[0].name;\nkudos = msg.payload[0].kudos_count;\nheartrate = msg.payload[0].average_heartrate;\ntemp = msg.payload[0].average_temp;\npolyline = msg.payload[0].map.summary_polyline;\n\nurl = \"https://maps.googleapis.com/maps/api/staticmap?size=400x400&path=weight:3%7Ccolor:0xFC4C02FF%7Cenc:\";\nurl += polyline;\n\nmsg.payload = {\n  last_ride: {\n    name: name,\n    distance: distance,\n    elevation: elevation,\n    heartrate: heartrate,\n    kudos: kudos,\n    temp: temp,\n    moving_time: {\n      hr: hr,\n      min: min,\n      sec: sec,\n    },\n    polyline : polyline,\n    url : url,\n  }\n}\n\nreturn msg;\n\n\n\n\n\n","outputs":1,"noerr":0,"x":711.4765625,"y":283.66400146484375,"wires":[["9545f926.d18a98"]]},{"id":"9545f926.d18a98","type":"template","z":"b8c0412b.95d0a","name":"css","field":"style","fieldType":"msg","format":"css","syntax":"mustache","template":"#last-ride{\n    padding: 5px;\n    }\n\nabbr {\n    text-decoration: none;\n    }\n\nh3 {\n    color: #99999e;\n    }\n    \n\n.map-image {\n    max-width: 100%;\n    max-height: 100%;\n    }\n\n.nr-dashboard-cardcontainer>* {\n    position: initial;\n}\n\n#Übersicht_Strava_cards > md-card {\n    height: auto;  \n}\n","output":"str","x":877.4765625,"y":283.66400146484375,"wires":[["3ae40a44.671106"]]},{"id":"563d93a5.7d1bbc","type":"comment","z":"b8c0412b.95d0a","name":"insert api token and athlete id","info":"","x":259,"y":402,"wires":[]},{"id":"cf22f6ec.6c4f48","type":"http request","z":"b8c0412b.95d0a","name":"last activity","method":"GET","ret":"obj","url":"https://www.strava.com/api/v3/athlete/activities?per_page=1&access_token={{{token}}}","tls":"","x":521.0000610351562,"y":283,"wires":[["b072f7f6.d06958"]]},{"id":"88a2eed.c2a931","type":"inject","z":"b8c0412b.95d0a","name":"inject","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":109,"y":280.0000305175781,"wires":[["7aef6c4e.2b5c84"]]},{"id":"463a3222.03569c","type":"http request","z":"b8c0412b.95d0a","name":"","method":"GET","ret":"txt","url":"https://www.strava.com/athletes/{{{athlete_id}}}","tls":"","x":505.3867492675781,"y":358.90631103515625,"wires":[["6150bb62.28c0f4"]]},{"id":"26c51787.305518","type":"http request","z":"b8c0412b.95d0a","name":"athletes stats","method":"GET","ret":"obj","url":"https://www.strava.com/api/v3/athletes/{{{athlete_id}}}/stats?access_token={{{token}}}","tls":"","x":510.98046875,"y":443.9961242675781,"wires":[["b1f41f83.88fce"]]},{"id":"f9bd8b33.c8ba18","type":"debug","z":"b8c0412b.95d0a","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1289,"y":355,"wires":[]},{"id":"7aef6c4e.2b5c84","type":"change","z":"b8c0412b.95d0a","name":"credentials","rules":[{"t":"set","p":"token","pt":"msg","to":"<strava token>","tot":"str"},{"t":"set","p":"athlete_id","pt":"msg","to":"<athlete id>","tot":"str"},{"t":"set","p":"google_api_key","pt":"msg","to":"<google api key>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":304,"y":348,"wires":[["cf22f6ec.6c4f48","463a3222.03569c","26c51787.305518"]]},{"id":"3ae40a44.671106","type":"ui_template","z":"b8c0412b.95d0a","group":"37541ec6.84e1a2","name":"Last Ride","order":1,"width":"0","height":"0","format":"<div>\n    <h3>{{msg.payload.last_ride.name}}</h3>\n    <div class=\"picture\">\n    <img class=\"map-image\" ng-src=\"https://maps.googleapis.com/maps/api/staticmap?key={{msg.google_api_key}}&size=400x400&path=weight:3%7Ccolor:0xFC4C02FF%7Cenc:{{msg.payload.last_ride.polyline}}\" alt=\"Image\"/>\n    </div>\n    <div>\n        <ul class=\"inline-stats\" id=\"last-ride\">\n            <li>\n                <strong>{{msg.payload.last_ride.distance}}<abbr class=\"unit\" title=\"Kilometer\">km</abbr></strong><div class=\"label\">DISTANCE</div>\n            </li>\n            <li>\n                <strong>{{msg.payload.last_ride.moving_time.hr}}<abbr class=\"unit\" title=\"Hours\">h</abbr>\n                {{msg.payload.last_ride.moving_time.min}}<abbr class=\"unit\" title=\"Minutes\">m</abbr>\n                {{msg.payload.last_ride.moving_time.sec}}<abbr class=\"unit\" title=\"Seconds\">s</abbr>\n                </strong>\n                <div class=\"label\">TIME</div>\n            </li>\n            <li>\n                <strong>{{msg.payload.last_ride.elevation}}<abbr class=\"unit\" title=\"Meter\">m</abbr></strong><div class=\"label\">ELEVATION</div>\n            </li>\n            <li>\n                <strong>{{msg.payload.last_ride.kudos}}</strong><div class=\"label\">KUDOS</div>\n            </li>        \n            <li>\n                <strong>{{msg.payload.last_ride.temp}}<abbr class=\"unit\" title=\"Grad Celsius\">°C</abbr></strong><div class=\"label\">TEMPERATURE</div>\n            </li>        \n    </ul>\n    </div>\n</div>\n<style>\n    {{msg.style}}\n</style>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1054,"y":283,"wires":[["f9bd8b33.c8ba18"]]},{"id":"37541ec6.84e1a2","type":"ui_group","z":"","name":"Strava","tab":"5d86edbf.ced464","order":2,"disp":true,"width":"6","collapse":false},{"id":"5d86edbf.ced464","type":"ui_tab","z":"","name":"Übersicht","icon":"dashboard","order":1}]
Created 9 years ago
  • change (x1)
  • function (x2)
  • html (x1)
  • http request (x3)
  • template (x3)
  • ui_group (x1)
  • ui_template (x3)
  • strava
  • template
  • api
  • request
  • css
