Timerange Switch / time of day, day of the week
Have a look at https://discourse.nodered.org/t/two-subflows-i-made-a-timerange-switch-and-a-scheduler-dashboard-integratable/24586 for examples and more info.
Lets through or blocks a payload based on a time range. This can either be configured through the enviroment variables in the node ui or as described below with a message that has an override topic. If in range the msg will be passed to the first output and otherwise to the second. The start and stop time needs to be defined in an hh:mm format. There is also a week array. The week starts on monday so 4 for example is Thursday. Payload will only be passed on days that are in the array. Out of time range payloads will be redirected to the second output. The schedule can be overriden by injecting a message with the topic of "override" that contains a msg.payload object with the keys of "start","stop","days" like this:
    "start": "10:00",
    "stop": "14:00",
    "days": [
        1,
        2,
        3,
        4,
        5,
        6,
        7
Start and stop need to be strings in the hh:mm format and days an array of numbers as described above. The override can be deleted by injecting a msg.payload string "reset".
inputoutput1output2statusis in range?injectdisplay rulecheck for override
timerange
[{"id":"7cc13ada.b6712c","type":"subflow","name":"timerange","info":"Lets through or blocks a payload\nbased on a time range. This can\neither be configured through the\nenviroment variables in the node ui\nor as described below with a message\nthat has an override topic.\nIf in range the msg will be passed\nto the first output and otherwise\nto the second.\nThe start and stop time needs\nto be defined in an hh:mm format.\nThere is also a week array. The week\nstarts on monday so 4 for example is\nThursday. Payload will only be passed\non days that are in the array.\nOut of time range payloads will\nbe redirected to the second output.\nThe schedule can be overriden by injecting\na message with the topic of \"override\"\nthat contains a ```msg.payload``` object with the\nkeys of \"start\",\"stop\",\"days\" like\nthis:\n```\n{\n    \"start\": \"10:00\",\n    \"stop\": \"14:00\",\n    \"days\": [\n        1,\n        2,\n        3,\n        4,\n        5,\n        6,\n        7\n    ]\n}\n```\nStart and stop need to be strings in the hh:mm\nformat and days an array of numbers as\ndescribed above.\nThe override can be deleted by injecting a\nmsg.payload string \"reset\".","category":"","in":[{"x":100,"y":100,"wires":[{"id":"da7f7d3f.da5af"}]}],"out":[{"x":620,"y":60,"wires":[{"id":"694ce0e1.4bee58","port":0}]},{"x":620,"y":140,"wires":[{"id":"694ce0e1.4bee58","port":1}]}],"env":[{"name":"start","type":"str","value":"00:00","ui":{"icon":"font-awesome/fa-arrow-right","label":{"en-US":"from hh:mm"},"type":"input","opts":{"types":["str"]}}},{"name":"stop","type":"str","value":"00:00","ui":{"icon":"font-awesome/fa-circle","label":{"en-US":"until hh:mm"},"type":"input","opts":{"types":["str"]}}},{"name":"days","type":"json","value":"[1,2,3,4,5,6,7]","ui":{"icon":"font-awesome/fa-calendar","label":{"en-US":"days"},"type":"input","opts":{"types":["json"]}}}],"color":"#C7E9C0","inputLabels":["payload input"],"outputLabels":["in time range","out of time range"],"icon":"node-red/switch.svg","status":{"x":480,"y":200,"wires":[{"id":"1bc56c04.ca0a3c","port":0}]}},{"id":"694ce0e1.4bee58","type":"function","z":"7cc13ada.b6712c","name":"is in range?","func":"const schedule = flow.get(\"schedule\");\nlet start = env.get(\"start\");\nlet stop = env.get(\"stop\");\nlet days = env.get(\"days\");\nif(schedule !== undefined){\n    start = schedule.start;\n    stop = schedule.stop;\n    days = schedule.days;\n}\nconst time = new Date();\nlet day = time.getDay();\nif(day === 0) day = 7;\nlet hour = String(time.getHours());\nlet minute = String(time.getMinutes());\nif(hour.length == 1) hour = \"0\" + hour;\nif(minute.length == 1) minute = \"0\" + minute;\nconst hmtime = hour + \":\" + minute;\nif(days.includes(day)){\n    if(start == stop){\n        return [msg, null];\n    } else if(start > stop){\n        if(hmtime >= start || hmtime < stop){\n            return [msg, null];\n        } else {\n            return [null, msg];\n        }\n    } else if(hmtime >= start && hmtime < stop){\n        return [msg, null];\n    } else {\n        return [null, msg];\n    }\n} else {\n    return null;\n}","outputs":2,"noerr":0,"x":450,"y":100,"wires":[[],[]]},{"id":"94dc9c00.0f576","type":"inject","z":"7cc13ada.b6712c","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":170,"y":200,"wires":[["1bc56c04.ca0a3c"]]},{"id":"1bc56c04.ca0a3c","type":"function","z":"7cc13ada.b6712c","name":"display rule","func":"const schedule = flow.get(\"schedule\");\nif(typeof schedule == \"object\"){\n    const start = schedule.start;\n    const stop = schedule.stop;\n    const days = String(schedule.days).replace(/1/g,\"Mo\").replace(/2/g,\"Tu\").replace(/3/g,\"We\").replace(/4/g,\"Th\").replace(/5/g,\"Fr\").replace(/6/g,\"Sa\").replace(/7/g,\"Su\");\n    msg.payload = \"override: \" + start + \"-\" + stop + \"/\" + days;\n} else {\n    const start = env.get(\"start\");\n    const stop = env.get(\"stop\");\n    const days = String(env.get(\"days\")).replace(/1/g,\"Mo\").replace(/2/g,\"Tu\").replace(/3/g,\"We\").replace(/4/g,\"Th\").replace(/5/g,\"Fr\").replace(/6/g,\"Sa\").replace(/7/g,\"Su\");\n    const override = false;\n    msg.payload = start + \"-\" + stop + \"/\" + days;\n}\nreturn msg;","outputs":1,"noerr":0,"x":350,"y":200,"wires":[[]]},{"id":"da7f7d3f.da5af","type":"function","z":"7cc13ada.b6712c","name":"check for override","func":"if(msg.topic == \"override\"){\n    flow.set(\"schedule\",msg.payload);\n    return [null, msg];\n} else if (msg.payload == \"reset\"){\n    let reset;\n    flow.set(\"schedule\",reset);\n    return [null, msg];\n} else {\n    return [msg, null];\n}","outputs":2,"noerr":0,"x":250,"y":100,"wires":[["694ce0e1.4bee58"],["1bc56c04.ca0a3c"]]}]
Collection Info
prev
Created 5 years, 8 months ago
Rating: 5 3
  • function (x3)
  • subflow (x1)
  • switch
  • subflow
  • timerange
  • day
  • time
  • weekday
  • schedule
