GPS Tracking with Node-Red
This is a GPS tracking solution which works with a custom Android app which sends GSP data over email. This flow reads GPS tracks from the attachment of the email and stores it in SQL database and displays it in a map in the Dashboard. You can store logs for multiple users, display data based on date, split the logs to different tracks.
The flow explained in detail in this video: https://youtu.be/ywljyO74MjE
The GPS Tracker app: https://github.com/sellrik/GpsTracker
[{"id":"d695a71c.835f58","type":"tab","label":"GPS Tracking","disabled":false,"info":""},{"id":"4dac5582.33b0cc","type":"worldmap","z":"d695a71c.835f58","name":"","lat":"","lon":"","zoom":"","layer":"OSM","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"true","hiderightclick":"false","coords":"none","x":1470,"y":260,"wires":[]},{"id":"3e445839.3e2868","type":"comment","z":"d695a71c.835f58","name":"Set new POI","info":"","x":823.75,"y":32.5,"wires":[]},{"id":"46ad6d8.72df694","type":"worldmap in","z":"d695a71c.835f58","name":"","x":940,"y":100,"wires":[["fc4d8fd1.fef2e"]]},{"id":"fc4d8fd1.fef2e","type":"function","z":"d695a71c.835f58","name":"Check map event","func":"var newobject = {};\n\nif (msg.payload.action===\"point\") {\n    newobject = { lat:msg.payload.lat, lon:msg.payload.lon, name:msg.payload.point, radius:500 };\n    msg.payload = newobject;\n    return msg;    \n}\n\n","outputs":1,"noerr":0,"x":1170,"y":100,"wires":[["4dac5582.33b0cc"]]},{"id":"30f20fb3.922e8","type":"inject","z":"d695a71c.835f58","name":"","props":[{"p":"payload","v":"","vt":"str"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"","once":true,"onceDelay":"","topic":"","payload":"","payloadType":"str","x":170,"y":100,"wires":[["a643ef4.ef34c1"]]},{"id":"92d8260d.7a2b38","type":"ui_template","z":"d695a71c.835f58","group":"7a832387.7a6c6c","name":"","order":0,"width":"20","height":"12","format":"<div ng-bind-html=\"msg.payload | trusted\"></div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":540,"y":100,"wires":[[]]},{"id":"a643ef4.ef34c1","type":"template","z":"d695a71c.835f58","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<iframe src=\"/worldmap\" height=\"600px\" width=\"1000px\" style=\"border: none;\"></iframe>","x":370,"y":100,"wires":[["92d8260d.7a2b38"]]},{"id":"9b44138.b46e4f","type":"ui_dropdown","z":"d695a71c.835f58","name":"Period","label":"Period","tooltip":"","place":"","group":"a082d5ab.8a1268","order":2,"width":"0","height":"0","passthru":false,"multiple":false,"options":[{"label":"Today","value":"today","type":"str"},{"label":"Yesterday","value":"yesterday","type":"str"},{"label":"This week","value":"thisweek","type":"str"},{"label":"Last week","value":"lastweek","type":"str"},{"label":"Last 24 hours","value":"last24h","type":"str"},{"label":"Last 7 days","value":"last7d","type":"str"},{"label":"Last 30 days","value":"last30d","type":"str"}],"payload":"","topic":"period","x":150,"y":280,"wires":[["b11a2e02.87a09"]]},{"id":"b11a2e02.87a09","type":"function","z":"d695a71c.835f58","name":"SQL","func":"// This will handle any device and any attribute as long as it is in the DB\nvar p_30d  = 1000*60*60*24*30 ; //30 Days\nvar p_7d  = 1000*60*60*24*7 ; //7 Days\nvar p_1d   =  1000*60*60*24 ; // 1 Day\nvar d = new Date();\nvar current = d.getTime();\nvar today0h = d.setHours(0,0,0,0);\nvar day = d.getDay();\nvar monday0h = today0h - (day + (day === 0 ? -6:1)) * p_1d;\nvar fromdate = 0;\nvar enddate = 0;\n\nswitch(msg.topic) {\n    case \"period\":\n        switch(msg.payload) {\n            case \"today\":\n                fromdate = today0h;\n                enddate = today0h+p_1d;\n                break;\n            case \"yesterday\":\n                fromdate = today0h-p_1d;\n                enddate = today0h;\n                break;\n            case \"thisweek\":\n                fromdate = monday0h;\n                enddate = monday0h+p_7d;\n                break;\n            case \"lastweek\":\n                fromdate = monday0h-p_7d;\n                enddate = monday0h;\n                break;\n            case \"last24h\":\n                fromdate = current-p_1d;\n                enddate = current;\n                break;\n            case \"last7d\":\n                fromdate = current-p_7d;\n                enddate = current;\n                break;\n            case \"last30d\":\n                fromdate = current-p_30d;\n                enddate = current;\n                break;\n        }\n        context.set(\"fromdate\",fromdate);\n        context.set(\"enddate\",enddate);\n        break;\n    case \"date\":\n        fromdate = msg.payload;\n        enddate = msg.payload+1000*60*60*24;\n        context.set(\"fromdate\",fromdate);\n        context.set(\"enddate\",enddate);        \n        break;\n    case \"markers\":\n        context.set(\"markers\",msg.payload);\n        break;\n    case \"user\":\n        context.set(\"user\",msg.payload);\n        break;\n    case \"refresh\":\n        fromdate = context.get(\"fromdate\");\n        enddate = context.get(\"enddate\");\n        if ((fromdate===undefined) || (enddate===undefined)) {\n            return [null,{\"topic\": \"Loading data\", \"payload\": \"Period needs to be selected first\"}];;\n        }\n\n        let user = context.get(\"user\");\n        if (user===undefined) {\n            return [null,{\"topic\": \"Loading data\", \"payload\": \"User needs to be selected first\"}];;\n        }\n\n        msg.topic = \"SELECT * FROM gps WHERE deviceid='\"+user+\"' AND time >= \" + fromdate + \" AND time <= \" + enddate + \" ORDER BY time\";\n        msg.wifi = \"SELECT * FROM wifi WHERE deviceid='\"+user+\"' AND time >= \" + fromdate + \" AND time <= \" + enddate + \" ORDER BY time\";\n        node.status({fill:\"blue\",shape:\"ring\",text:\"Range: \"+fromdate+\"-\"+enddate});  \n        let markers = context.get(\"markers\");\n        if (markers!==undefined) {\n            msg.markers = markers;\n        }\n        return [msg,{\"topic\": \"Loading data\", \"payload\": \"Please wait, updating views...\"}];\n        break;\n}\n\n","outputs":2,"noerr":0,"initialize":"","finalize":"","x":390,"y":280,"wires":[["c35e0902.cc81f8","7b0fc941.9be198"],["bd7994d7.46e588"]]},{"id":"4c3d355d.c3ca0c","type":"comment","z":"d695a71c.835f58","name":"Generate map update from stored data","info":"","x":192.85714721679688,"y":232.857177734375,"wires":[]},{"id":"c35e0902.cc81f8","type":"sqlite","z":"d695a71c.835f58","mydb":"3bdf3d0e.e69262","sqlquery":"msg.topic","sql":"","name":"Database","x":640,"y":280,"wires":[["7c008fcc.6767c","6c72db2f.c7d6c4","918df09d.45bda","23966724.c5e918"]]},{"id":"7c008fcc.6767c","type":"function","z":"d695a71c.835f58","name":"Generate map routes (single track)","func":"var output = [];\nlet count = 0;\nlet lastMarker = 0;\n\nnode.status({fill:\"blue\",shape:\"ring\",text:\"Record count: \"+msg.payload.length});    \n\nif (msg.payload.length>0) {\n    \n    output.push({ \"topic\": \"map\", \"payload\": {\"command\":{\"clear\":\"GPS Track\"}}})\n\n    output.push({ \"topic\": \"map\", \"payload\": {\"name\": msg.payload[0].deviceid, \"layer\": \"GPS Track\", \"line\": [], \"command\": {lat: msg.payload[0].latitude, lon: msg.payload[0].longitude}}});\n    \n    for (var i=0; i<msg.payload.length; i++) {\n        output[1].payload.line.push([msg.payload[i].latitude,msg.payload[i].longitude]);\n        count++;\n        if (msg.markers>0) {\n            if (msg.payload[i].time - lastMarker > msg.markers) {\n                lastMarker = msg.payload[i].time;\n                \n                let now = new Date();\n                now.setTime(msg.payload[i].time);\n                let yyyy = now.getFullYear();\n                let mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\n                let dd  = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\n                let hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\n                let mmm  = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\n                let ss  = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n                // msg.payload[i].formatteddate = dd + \".\" + mm + \".\" + yyyy + \" \" + hh + \":\" + mmm + \":\" + ss ;    \n                \n                \n                output.push({\"topic\": \"map\", \"payload\": { \"name\":hh + \":\" + mmm + \":\" + ss, \"layer\": \"GPS Track\", \"lat\":msg.payload[i].latitude, \"lon\":msg.payload[i].longitude }});\n            }\n        }\n    }\n    \n    //msg.payload = output[0];\n    //return msg;\n    \n    if (output.length>0) {\n        return [output];\n    }\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":920,"y":280,"wires":[[]]},{"id":"46134c44.ce4054","type":"inject","z":"d695a71c.835f58","name":"Today","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"period","payload":"today","payloadType":"str","x":170,"y":380,"wires":[["b11a2e02.87a09"]]},{"id":"a667d8dc.2a1058","type":"ui_date_picker","z":"d695a71c.835f58","name":"Manual date","label":"Pick a date","group":"a082d5ab.8a1268","order":3,"width":0,"height":0,"passthru":true,"topic":"date","x":160,"y":340,"wires":[["b11a2e02.87a09"]]},{"id":"4747e52d.d2e79c","type":"template","z":"d695a71c.835f58","name":"Format","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<table>\n    <tr><th>Device ID</th><th>Latitude [deg]</th><th>Longtitude [deg]</th><th>Altitude [m]</th><th>Speed [km/h]</th><th>Accuracy</th><th>Time</th></tr>\n    {{#payload}}\n        <tr class=\"\">\n            <td>{{deviceid}}</td>\n            <td>{{latitude}}</td>\n            <td>{{longitude}}</td>\n            <td>{{altitude}}</td>\n            <td>{{speed}}</td>\n            <td>{{accuracy}}</td>\n            <td>{{formatteddate}}</td>\n        </tr>\n    {{/payload}}\n</table>\n","output":"str","x":1040,"y":340,"wires":[["71cf9080.b07e2"]]},{"id":"71cf9080.b07e2","type":"ui_template","z":"d695a71c.835f58","group":"7a832387.7a6c6c","name":"GPS Data","order":0,"width":"20","height":"6","format":"<div ng-bind-html=\"msg.payload\" height=\"600\" style=\"height: 300px;\"></div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1200,"y":340,"wires":[[]]},{"id":"6c72db2f.c7d6c4","type":"function","z":"d695a71c.835f58","name":"Convert dates","func":"for (var i=0; i<msg.payload.length; i++) {\n    \n    // format the unix timestamp to dd.mm.yyyy hh:mm:ss format\n    var now = new Date();\n    now.setTime(msg.payload[i].time);\n    var yyyy = now.getFullYear();\n    var mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\n    var dd  = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\n    var hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\n    var mmm  = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\n    var ss  = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n    msg.payload[i].formatteddate = dd + \".\" + mm + \".\" + yyyy + \" \" + hh + \":\" + mmm + \":\" + ss ;    \n    \n    // Recude decimal places\n    msg.payload[i].latitude = parseFloat(msg.payload[i].latitude.toFixed(8));\n    msg.payload[i].longitude = parseFloat(msg.payload[i].longitude.toFixed(8));\n    msg.payload[i].altitude = parseFloat(msg.payload[i].altitude.toFixed(1));\n    msg.payload[i].speed = parseFloat(msg.payload[i].speed.toFixed(1));\n\n\n}    \n    \n    \n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":340,"wires":[["4747e52d.d2e79c"]]},{"id":"1cd7ea33.9208a6","type":"comment","z":"d695a71c.835f58","name":"GPS Tracker email input","info":"","x":170,"y":1660,"wires":[]},{"id":"462e36f8.9d30b8","type":"e-mail in","z":"d695a71c.835f58","name":"Gmail Inbox","protocol":"IMAP","server":"imap.gmail.com","useSSL":true,"port":"993","box":"INBOX","disposition":"Delete","criteria":"_msg_","repeat":"300","fetch":"trigger","inputs":1,"x":330,"y":1740,"wires":[["727a3397.f7b00c"]]},{"id":"682b57af.9bbe28","type":"inject","z":"d695a71c.835f58","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"criteria","v":"[[\"HEADER\",\"SUBJECT\",\"GPS tracker 567\"]]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":1740,"wires":[["462e36f8.9d30b8"]]},{"id":"727a3397.f7b00c","type":"function","z":"d695a71c.835f58","name":"Extract attachment","func":"if (msg.attachments.length>0) {\n    if (msg.attachments[0].filename===\"data.json\") {\n        msg.payload = \" \"+msg.attachments[0].content;\n        return msg;\n    }\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":570,"y":1740,"wires":[["6d3d2e19.2614"]]},{"id":"6d3d2e19.2614","type":"json","z":"d695a71c.835f58","name":"","property":"payload","action":"","pretty":false,"x":760,"y":1740,"wires":[["e790665e.cf3428","773ce5a3.da712c"]]},{"id":"e790665e.cf3428","type":"function","z":"d695a71c.835f58","name":"Save to DB","func":"let deviceid = \"R16NW\";\n\nlet myssid = context.get(\"ssid\");\nif (myssid===undefined) {\n    myssid = \"\";\n}\n\nlet sql = \"\";\nlet d = new Date();\nlet epoch = d.getTime();\nlet output =[];\n\nfor (let i=0;i<msg.payload.Locations.length;i++) {\n    output.push({\"topic\": \"INSERT INTO gps (deviceid,longitude,latitude,accuracy,altitude,speed,time) \" +\n            \"VALUES ('\"+deviceid+\"',\"+msg.payload.Locations[i].Longitude+\",\"+msg.payload.Locations[i].Latitude+\",\"+msg.payload.Locations[i].Accuracy+\",\"+msg.payload.Locations[i].Altitude+\",\"+msg.payload.Locations[i].Speed+\",\"+msg.payload.Locations[i].Time+\")\", \"payload\": \"\"});\n}\n\nfor (i=0;i<msg.payload.NetworkLogs.length;i++) {\n    /*\n    // I was using this code to determine the SSID when disconnected from a network\n    if (msg.payload.NetworkLogs[i].IsConnected) {\n        myssid = msg.payload.NetworkLogs[i].SSID;\n        context.set(\"ssid\",myssid);\n    }\n    output.push({\"topic\": \"INSERT INTO wifi (deviceid,connected,ssid,time) \" +\n            \"VALUES ('\"+deviceid+\"',\"+(msg.payload.NetworkLogs[i].IsConnected ? 1 : 0)+\",'\"+myssid+\"',\"+msg.payload.NetworkLogs[i].Time+\")\", \"payload\": \"\"});\n            */\n    output.push({\"topic\": \"INSERT INTO wifi (deviceid,connected,ssid,time) \" +\n            \"VALUES ('\"+deviceid+\"',\"+(msg.payload.NetworkLogs[i].IsConnected ? 1 : 0)+\",'\"+msg.payload.NetworkLogs[i].SSID+\"',\"+msg.payload.NetworkLogs[i].Time+\")\", \"payload\": \"\"});\n}\n\nnode.status({fill:\"blue\",shape:\"ring\",text:\"Records: \"+output.length });    \nreturn [output];\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":770,"y":1860,"wires":[["c188076b.86a7b8","c6f5fd4e.81ea7"]]},{"id":"4184d771.544218","type":"sqlite","z":"d695a71c.835f58","mydb":"3bdf3d0e.e69262","sqlquery":"msg.topic","sql":"","name":"Database","x":1280,"y":1860,"wires":[[]]},{"id":"c188076b.86a7b8","type":"debug","z":"d695a71c.835f58","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":940,"y":1780,"wires":[]},{"id":"c6f5fd4e.81ea7","type":"delay","z":"d695a71c.835f58","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"50","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1040,"y":1860,"wires":[["4184d771.544218"]]},{"id":"7b0fc941.9be198","type":"debug","z":"d695a71c.835f58","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"topic","targetType":"msg","statusVal":"","statusType":"auto","x":600,"y":220,"wires":[]},{"id":"773ce5a3.da712c","type":"debug","z":"d695a71c.835f58","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1010,"y":1660,"wires":[]},{"id":"f293f1ea.e9495","type":"ui_dropdown","z":"d695a71c.835f58","name":"Markers","label":"Markers:","tooltip":"","place":"Place markers","group":"a082d5ab.8a1268","order":4,"width":"6","height":"1","passthru":false,"multiple":false,"options":[{"label":"None","value":"0","type":"str"},{"label":"Every 5 minutes","value":"300000","type":"str"},{"label":"Every 10 minutes","value":"600000","type":"str"},{"label":"Every 30 minutes","value":"1800000","type":"str"},{"label":"Every hour","value":"3600000","type":"str"}],"payload":"","topic":"markers","x":160,"y":420,"wires":[["b11a2e02.87a09"]]},{"id":"899c8e6d.f0423","type":"ui_button","z":"d695a71c.835f58","name":"","group":"a082d5ab.8a1268","order":5,"width":"3","height":"1","passthru":false,"label":"Refresh","tooltip":"","color":"","bgcolor":"","icon":"refresh","payload":"","payloadType":"str","topic":"refresh","x":160,"y":460,"wires":[["b11a2e02.87a09"]]},{"id":"9ba22012.b5d2e","type":"comment","z":"d695a71c.835f58","name":"Embed the map to the dashboard","info":"","x":170,"y":40,"wires":[]},{"id":"918df09d.45bda","type":"function","z":"d695a71c.835f58","name":"Chart","func":"var chart = [{\n    \"series\":[\"Altitude [m]\",\"Speed [km/h]\",\"Accuracy\"],\n    \"data\":[[],[],[]],\n    \"labels\":[\"\"]\n}];\n\nfor (var i=0; i<msg.payload.length; i++) {\n    chart[0].data[0].push({\"x\": msg.payload[i].time, \"y\": msg.payload[i].altitude});\n    chart[0].data[1].push({\"x\": msg.payload[i].time, \"y\": msg.payload[i].speed*3.6});\n    chart[0].data[2].push({\"x\": msg.payload[i].time, \"y\": msg.payload[i].accuracy});\n}\n\nmsg.payload = chart;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":830,"y":420,"wires":[["69dd30fe.ad2bf"]]},{"id":"69dd30fe.ad2bf","type":"ui_chart","z":"d695a71c.835f58","name":"","group":"8930f03.56e081","order":0,"width":0,"height":0,"label":"","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"x":1030,"y":420,"wires":[[]]},{"id":"23966724.c5e918","type":"function","z":"d695a71c.835f58","name":"Store data to later processing","func":"for (var i=0; i<msg.payload.length; i++) {\n    \n    // format the unix timestamp to dd.mm.yyyy hh:mm:ss format\n    var now = new Date();\n    now.setTime(msg.payload[i].time);\n    var yyyy = now.getFullYear();\n    var mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\n    var dd  = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\n    var hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\n    var mmm  = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\n    var ss  = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n    msg.payload[i].formatteddate = dd + \".\" + mm + \".\" + yyyy + \" \" + hh + \":\" + mmm + \":\" + ss ;   \n    msg.payload[i].type=\"gps\";\n}    \nflow.set(\"gpstrack\", msg.payload);    \n    \n// Get the wifi table selection logic so we can merge that with the GPS data    \nmsg.topic = msg.wifi;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":900,"y":480,"wires":[["8d9230eb.f000a"]]},{"id":"8d9230eb.f000a","type":"sqlite","z":"d695a71c.835f58","mydb":"3bdf3d0e.e69262","sqlquery":"msg.topic","sql":"","name":"Database","x":1140,"y":480,"wires":[["7a381215.8f625c"]]},{"id":"7a381215.8f625c","type":"function","z":"d695a71c.835f58","name":"Merge wifi data with gps tracks","func":"let gpstrack = flow.get(\"gpstrack\"); \nif (gpstrack===undefined) {\n    return;\n}\nif (gpstrack.length===0) {\n    return;\n}\nlet j = 0;\nfor (let i=0;i<msg.payload.length;i++) {\n    while ((j<gpstrack.length) && (gpstrack[j].time<msg.payload[i].time)) {\n        j++;\n    }\n    // format the unix timestamp to dd.mm.yyyy hh:mm:ss format\n    var now = new Date();\n    now.setTime(msg.payload[i].time);\n    var yyyy = now.getFullYear();\n    var mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\n    var dd  = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\n    var hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\n    var mmm  = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\n    var ss  = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n    msg.payload[i].formatteddate = dd + \".\" + mm + \".\" + yyyy + \" \" + hh + \":\" + mmm + \":\" + ss ;   \n    gpstrack.splice(j,0, {\"type\": \"wifi\", \"deviceid\": msg.payload[i].deviceid, \"connected\": msg.payload[i].connected, \"ssid\": msg.payload[i].ssid, \"time\": msg.payload[i].time, \"formatteddate\": msg.payload[i].formatteddate})\n}\nflow.set(\"gpstrack\", gpstrack );\nmsg.payload = gpstrack;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1390,"y":480,"wires":[["982c4437.6c6658"]]},{"id":"982c4437.6c6658","type":"function","z":"d695a71c.835f58","name":"Route Analytics","func":"function GPSdistance(lat1, lon1, lat2, lon2, unit) {\n    if ((lat1 == lat2) && (lon1 == lon2)) {\n        return 0;\n    }\n    else {\n        var radlat1 = Math.PI * lat1/180;\n        var radlat2 = Math.PI * lat2/180;\n        var theta = lon1-lon2;\n        var radtheta = Math.PI * theta/180;\n        var dist = Math.sin(radlat1) * Math.sin(radlat2) + Math.cos(radlat1) * Math.cos(radlat2) * Math.cos(radtheta);\n        if (dist > 1) {\n            dist = 1;\n        }\n        dist = Math.acos(dist);\n        dist = dist * 180/Math.PI;\n        dist = dist * 60 * 1.1515;\n        if (unit==\"K\") { dist = dist * 1.609344 }\n        if (unit==\"N\") { dist = dist * 0.8684 }\n        return dist;\n    }\n}\n\nfunction hslToHex(h, s, l) {\n  h /= 360;\n  s /= 100;\n  l /= 100;\n  let r, g, b;\n  if (s === 0) {\n    r = g = b = l; // achromatic\n  } else {\n    const hue2rgb = (p, q, t) => {\n      if (t < 0) t += 1;\n      if (t > 1) t -= 1;\n      if (t < 1 / 6) return p + (q - p) * 6 * t;\n      if (t < 1 / 2) return q;\n      if (t < 2 / 3) return p + (q - p) * (2 / 3 - t) * 6;\n      return p;\n    };\n    const q = l < 0.5 ? l * (1 + s) : l + s - l * s;\n    const p = 2 * l - q;\n    r = hue2rgb(p, q, h + 1 / 3);\n    g = hue2rgb(p, q, h);\n    b = hue2rgb(p, q, h - 1 / 3);\n  }\n  const toHex = x => {\n    const hex = Math.round(x * 255).toString(16);\n    return hex.length === 1 ? '0' + hex : hex;\n  };\n  return `#${toHex(r)}${toHex(g)}${toHex(b)}`;\n}\n\nlet gpstrack = flow.get(\"gpstrack\"); \nif (gpstrack===undefined) {\n    return;\n}\nif (gpstrack.length===0) {\n    return;\n}\n\nlet tracks = [];\nlet mode = 0;  // look for a start of a new track\nlet distance = 0.0;\nlet count = 0;\nlet speed = 0.0;\n\nfor (let i=0;i<gpstrack.length;i++) {\n    \n    // look for the start of a new track\n    if ((mode===0) && (gpstrack[i].type===\"wifi\") && (gpstrack[i].connected===0)) {\n        tracks.push({ \"start\": gpstrack[i].time, \"startdatetime\": gpstrack[i].formatteddate, \"startssid\": gpstrack[i].ssid, \"gpsdata\": []});\n        distance = 0.0;\n        count = 0;\n        speed = 0.0;\n        mode = 1; // track started\n    } else {\n    \n        // track started, this is the first GPS data\n        if ((mode===1) && (gpstrack[i].type===\"gps\") && (count===0)) {\n            count++;\n            speed+=gpstrack[i].speed;\n            tracks[tracks.length-1].gpsdata.push(gpstrack[i]);\n        } else {\n\n            // track started, this is a subsequent GPS data\n            if ((mode===1) && (gpstrack[i].type===\"gps\") && (count>0)) {\n                count++;\n                speed+=gpstrack[i].speed;\n                distance+=GPSdistance(gpstrack[i-1].latitude, gpstrack[i-1].longitude, gpstrack[i].latitude, gpstrack[i].longitude, \"K\");\n                tracks[tracks.length-1].gpsdata.push(gpstrack[i]);\n            }  else {\n    \n                // found end of track\n                if ((mode===1) && (gpstrack[i].type===\"wifi\") && (gpstrack[i].connected===1)) {\n                    speed = speed / count;\n                    tracks[tracks.length-1].count = count;\n                    tracks[tracks.length-1].speed = (speed*3.6).toFixed(2);  // convert to km/h\n                    tracks[tracks.length-1].distance = distance.toFixed(3); // in km\n                    tracks[tracks.length-1].count = count;\n                    tracks[tracks.length-1].end = gpstrack[i].time;\n                    tracks[tracks.length-1].enddatetime = gpstrack[i].formatteddate;\n                    tracks[tracks.length-1].endssid = gpstrack[i].ssid;\n                    tracks[tracks.length-1].duration = ((tracks[tracks.length-1].end-tracks[tracks.length-1].start)/1000/60).toFixed(0);\n                    mode = 0; // track ended\n                }\n            }\n        }\n    }\n}\n\n// add name and colors to the tracks\nfor (i=0;i<tracks.length;i++) {\n    tracks[i].color = hslToHex(Math.round(i*360/tracks.length), 100, 50);\n    tracks[i].name = \"Track \"+(i+1);\n}\n\n\nflow.set(\"tracks\", tracks);\nmsg.payload = tracks;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1670,"y":560,"wires":[["860f256f.2f2678","d940a455.94dc08"]]},{"id":"1be51084.ddf16f","type":"inject","z":"d695a71c.835f58","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1410,"y":560,"wires":[["982c4437.6c6658"]]},{"id":"860f256f.2f2678","type":"template","z":"d695a71c.835f58","name":"Format","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<table>\n    <tr><th>Track</th><th>Start Time</th><th>Start Wifi</th><th>Average speed</th><th>Distance</th><th>GPS positions</th><th>Duration</th><th>End Time</th><th>End Wifi</th></tr>\n    {{#payload}}\n        <tr class=\"\">\n            <td><span style=\"color:{{color}};\">{{name}}</span></td>\n            <td>{{startdatetime}}</td>\n            <td>{{startssid}}</td>\n            <td>{{speed}}</td>\n            <td>{{distance}}</td>\n            <td>{{count}}</td>\n            <td>{{duration}}</td>\n            <td>{{enddatetime}}</td>\n            <td>{{endssid}}</td>\n        </tr>\n    {{/payload}}\n</table>\n<p>Average Speed in km/h, Distance in meters, Duration in minutes</p>\n","output":"str","x":1880,"y":560,"wires":[["c044af85.3581e"]]},{"id":"c044af85.3581e","type":"ui_template","z":"d695a71c.835f58","group":"7cc9c15c.f49b6","name":"GPS Data","order":0,"width":"20","height":"6","format":"<div ng-bind-html=\"msg.payload\" height=\"300\" style=\"height: 300px;\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":2080,"y":560,"wires":[[]]},{"id":"d940a455.94dc08","type":"function","z":"d695a71c.835f58","name":"Generate map routes (separate track)","func":"var output = [];\nlet count = 0;\nlet lastMarker = 0;\nlet currentrackid = 0;\n\n\n// Generate a list of messages to delete tracks from a previous\nfor (let i=0;i<1000;i++) {\n    output.push({ \"topic\": \"map\", \"payload\": {\"command\":{\"clear\":\"Track \"+i}}});    \n}\n\nif (msg.payload.length>0) {\n    \n    \n    for (var i=0; i<msg.payload.length; i++) {\n        output.push({ \"topic\": \"map\", \"payload\": {\"name\": msg.payload[i].name, \"layer\": msg.payload[i].name, \"color\": msg.payload[i].color, \"line\": [], \"command\": {lat: msg.payload[i].gpsdata[0].latitude, lon: msg.payload[i].gpsdata[0].longitude}}});\n        lastMarker = 0;\n        currentrackid = output.length-1;\n        for (let j=1; j<msg.payload[i].gpsdata.length; j++) {\n            output[currentrackid].payload.line.push([msg.payload[i].gpsdata[j].latitude, msg.payload[i].gpsdata[j].longitude]);\n            count++;\n            if (msg.markers>0) {\n                if (msg.payload[i].gpsdata[j].time - lastMarker > msg.markers) {\n                    lastMarker = msg.payload[i].gpsdata[j].time;\n                    \n                    let now = new Date();\n                    now.setTime(msg.payload[i].gpsdata[j].time);\n                    let yyyy = now.getFullYear();\n                    let mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\n                    let dd  = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\n                    let hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\n                    let mmm  = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\n                    let ss  = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n                    // msg.payload[i].formatteddate = dd + \".\" + mm + \".\" + yyyy + \" \" + hh + \":\" + mmm + \":\" + ss ;    \n                    \n                    \n                    output.push({\"topic\": \"map\", \"payload\": { \"name\":hh + \":\" + mmm + \":\" + ss, \"layer\": msg.payload[i].name, \"color\": msg.payload[i].color, \"lat\":msg.payload[i].gpsdata[j].latitude, \"lon\":msg.payload[i].gpsdata[j].longitude }});\n                }\n            }\n        }\n    }\n    \n    //msg.payload = output[0];\n    //return msg;\n    \n    if (output.length>0) {\n        node.status({fill:\"blue\",shape:\"ring\",text:\"Tracks: \"+msg.payload.length+\", GPS data: \"+count});    \n\n        return [output];\n    }\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1850,"y":420,"wires":[["4dac5582.33b0cc"]]},{"id":"bd7994d7.46e588","type":"ui_toast","z":"d695a71c.835f58","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"","name":"","x":580,"y":360,"wires":[]},{"id":"79b59861.1ff688","type":"ui_dropdown","z":"d695a71c.835f58","name":"User","label":"User","tooltip":"Select user","place":"Select user","group":"a082d5ab.8a1268","order":1,"width":"0","height":"0","passthru":false,"multiple":false,"options":[{"label":"Test user","value":"R16NW","type":"str"}],"payload":"","topic":"user","x":170,"y":500,"wires":[["b11a2e02.87a09"]]},{"id":"9229bb5d.b8d228","type":"comment","z":"d695a71c.835f58","name":"DB Table creation SQL","info":"CREATE TABLE 'gps' ('id' INTEGER PRIMARY KEY AUTOINCREMENT NOT NULL, 'deviceid' TEXT, 'longitude' REAL, 'latitude' REAL, 'accuracy' REAL, 'altitude' REAL, 'speed' REAL, 'time' INTEGER)\n\nCREATE TABLE 'wifi' ('id' INTEGER PRIMARY KEY AUTOINCREMENT NOT NULL, 'deviceid' TEXT, 'connected' BOOLEAN, 'ssid' TEXT,'time' INTEGER)","x":130,"y":160,"wires":[]},{"id":"7a832387.7a6c6c","type":"ui_group","z":"","name":"Map","tab":"f76c8797.584da8","order":1,"disp":true,"width":"20","collapse":false},{"id":"a082d5ab.8a1268","type":"ui_group","z":"","name":"History","tab":"f76c8797.584da8","order":3,"disp":true,"width":"6","collapse":false},{"id":"3bdf3d0e.e69262","type":"sqlitedb","z":"","db":"/home/pi/sqlite/tracker","mode":"RWC"},{"id":"8930f03.56e081","type":"ui_group","z":"","name":"Speed, Altitude, Accuracy chart","tab":"f76c8797.584da8","order":4,"disp":true,"width":"20","collapse":false},{"id":"7cc9c15c.f49b6","type":"ui_group","z":"","name":"Tracks","tab":"f76c8797.584da8","order":5,"disp":true,"width":"20","collapse":false},{"id":"f76c8797.584da8","type":"ui_tab","z":"","name":"GPS Tracker","icon":"gps_fixed","order":21}]
Created 6 years, 5 months ago
Rating:
  • comment (x5)
  • debug (x3)
  • delay (x1)
  • function (x11)
  • inject (x4)
  • json (x1)
  • template (x3)
  • gps
  • tracking
