Smartschool api
An example of connecting to the Smartschool API to list all the classes from you platform.
[{"id":"07540ab70182f259","type":"soap request plus","z":"d982d4ea6f48f24a","name":"Opvragen api Smartschool","topic":"","wsdl":"1fce51fb263530b5","method":"getClassListJson","x":240,"y":200,"wires":[["eded377c860ba422"],[]]},{"id":"f34823d9e45b49b3","type":"debug","z":"d982d4ea6f48f24a","name":"debug 9","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":420,"wires":[]},{"id":"eded377c860ba422","type":"json","z":"d982d4ea6f48f24a","name":"","property":"payload.return.$value","action":"","pretty":false,"x":170,"y":340,"wires":[["94f88e1f8be26c19","4a532da0095d54be"]]},{"id":"94f88e1f8be26c19","type":"debug","z":"d982d4ea6f48f24a","name":"debug 10","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.return.$value[0].name","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":340,"wires":[]},{"id":"4a532da0095d54be","type":"change","z":"d982d4ea6f48f24a","name":"omzetten naar bruikbare info","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.return.$value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":420,"wires":[["f34823d9e45b49b3","81cce0786aa9574f"]]},{"id":"86a28cbfe7083556","type":"inject","z":"d982d4ea6f48f24a","name":"insert accesscode","props":[{"p":"payload"},{"p":"payload.accesscode","v":"WebservicesCodevanSmartschool","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{}","payloadType":"json","x":190,"y":60,"wires":[["07540ab70182f259"]]},{"id":"81cce0786aa9574f","type":"split","z":"d982d4ea6f48f24a","name":"split naar bericht per klas","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"payload","x":290,"y":700,"wires":[["2fd310611512843d"]]},{"id":"2fd310611512843d","type":"debug","z":"d982d4ea6f48f24a","name":"debug 11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":660,"y":500,"wires":[]},{"id":"1fce51fb263530b5","type":"soap-config-plus","wsdl":"https://NaamSchool.smartschool.be/Webservices/V3?wsdl","auth":"0","user":"","pass":"","key":"","cert":"","token":""}]
Created 2 years, 9 months ago
  • change (x1)
  • debug (x3)
  • json (x1)
  • split (x1)
  • soap request plus (x1)
  • soap-config-plus (x1)
  • Smartschool
  • Belgian
  • Education
