Simple Webcam pic
From your Laptop Camera or Webcam, capture a picture and display in the dashboard
Needs the following Nodes to be added to the Palette
• node-red-contrib-browser-utils • node-red-dashboard • node-red-node-base64
[{"id":"e43a7ed1.97b08","type":"tab","label":"Simple Webcam","disabled":false,"info":""},{"id":"f25e3092.364ac","type":"camera","z":"e43a7ed1.97b08","name":"","x":280,"y":280,"wires":[["619a99c4.faafa8"]]},{"id":"18edd75b.945009","type":"ui_template","z":"e43a7ed1.97b08","group":"7c71c7b8.2c9fe8","name":"Pic","order":0,"width":"6","height":"6","format":"<div>\n      <img src=\"data:image/png;base64,{{msg.payload}}\">\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":770,"y":440,"wires":[[]]},{"id":"619a99c4.faafa8","type":"base64","z":"e43a7ed1.97b08","name":"","action":"","property":"payload","x":520,"y":340,"wires":[["18edd75b.945009"]]},{"id":"7c71c7b8.2c9fe8","type":"ui_group","z":"","name":"Default","tab":"fbf5c038.d632b","disp":true,"width":"6","collapse":false},{"id":"fbf5c038.d632b","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
Created 9 years, 1 month ago
  • base64 (x1)
  • camera (x1)
  • ui_group (x1)
  • ui_template (x1)
  • Webcam
  • Camera
  • Laptop
