Node red via plc Delta DVP 12SE with Modbus
programing Pump controller stastion using Node red via plc Delta DVP 12SE with Modbus protocol.
[{"id":"cd21fa8d.ed8198","type":"tab","label":"Center Station","disabled":false,"info":"Modbus serverIP address:192.168.1.10 port 502, you have to use yours\nPLC bits and coils: M, X, Y.\nPLC registers: D, T, C.\nFunctions: FC1, FC2, FC3."},{"id":"6983a4d.ab2885c","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write m10 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2058","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":410,"y":100,"wires":[[],[]]},{"id":"678daa54.855704","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write m11 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2059","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":410,"y":200,"wires":[[],[]]},{"id":"ff5a19ec.a23128","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write m16 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2064","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":410,"y":280,"wires":[[],[]]},{"id":"8d1d937d.6e09c","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write m17 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2065","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":410,"y":360,"wires":[[],[]]},{"id":"6efa6c60.4cc3e4","type":"modbus-read","z":"cd21fa8d.ed8198","name":"Y0 lamp pump","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"1280","quantity":"1","rate":"500","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"a0737e46.57122","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":220,"y":480,"wires":[["97e7fdd5.dcbbc"],["64e97d0e.b8fe04"]]},{"id":"64e97d0e.b8fe04","type":"modbus-response","z":"cd21fa8d.ed8198","name":"","registerShowMax":20,"x":450,"y":540,"wires":[]},{"id":"76ed59c.39a64a8","type":"modbus-read","z":"cd21fa8d.ed8198","name":"Y1 lamp solenoild","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"1281","quantity":"1","rate":"500","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"a0737e46.57122","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":240,"y":660,"wires":[["66519109.d4d5"],["c5a498da.1518b8"]]},{"id":"c5a498da.1518b8","type":"modbus-response","z":"cd21fa8d.ed8198","name":"","registerShowMax":20,"x":520,"y":700,"wires":[]},{"id":"8799ae8b.1f6b8","type":"ui_led","z":"cd21fa8d.ed8198","group":"849ef9ac.e33228","order":6,"width":0,"height":0,"label":"Solenoild","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"grey","value":"false","valueType":"bool"},{"color":"green","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":750,"y":680,"wires":[]},{"id":"8757e58b.4e8dd8","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write d580 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4676","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":780,"wires":[[],[]]},{"id":"1636162e.da84ba","type":"ui_numeric","z":"cd21fa8d.ed8198","name":"","label":"Set hight level","tooltip":"","group":"849ef9ac.e33228","order":9,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":210,"y":786,"wires":[["8757e58b.4e8dd8"]]},{"id":"f2f592c7.355e1","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write d582 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4678","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":840,"wires":[[],[]]},{"id":"3fb35db7.a1a2a2","type":"ui_numeric","z":"cd21fa8d.ed8198","name":"","label":"Set low level","tooltip":"","group":"849ef9ac.e33228","order":10,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":200,"y":846,"wires":[["f2f592c7.355e1"]]},{"id":"3ca6f7e4.841578","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write d310 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4406","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":920,"wires":[[],[]]},{"id":"1117b424.f3282c","type":"ui_numeric","z":"cd21fa8d.ed8198","name":"","label":"Tần số","tooltip":"","group":"849ef9ac.e33228","order":11,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":180,"y":926,"wires":[["3ca6f7e4.841578"]]},{"id":"622ca49f.d9b65c","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write d502 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4598","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":980,"wires":[[],[]]},{"id":"59b11c55.bab9b4","type":"ui_numeric","z":"cd21fa8d.ed8198","name":"","label":"Kp","tooltip":"","group":"849ef9ac.e33228","order":12,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":180,"y":986,"wires":[["622ca49f.d9b65c"]]},{"id":"523e86d3.f408f8","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write d504 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4600","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":1040,"wires":[[],[]]},{"id":"3b078c61.d51ed4","type":"ui_numeric","z":"cd21fa8d.ed8198","name":"","label":"Ti","tooltip":"","group":"849ef9ac.e33228","order":13,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":180,"y":1046,"wires":[["523e86d3.f408f8"]]},{"id":"c4d4b75c.163e38","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write d506 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4602","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":420,"y":1100,"wires":[[],[]]},{"id":"972530d2.55c33","type":"ui_numeric","z":"cd21fa8d.ed8198","name":"","label":"Td","tooltip":"","group":"849ef9ac.e33228","order":14,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":160,"y":1106,"wires":[["c4d4b75c.163e38"]]},{"id":"166ff414.447cfc","type":"ui_template","z":"cd21fa8d.ed8198","group":"849ef9ac.e33228","name":"Start Pump","order":1,"width":0,"height":0,"format":"<div class=\"momentary0\">\n   <md-button> Start Pump</md-button>\n</div>\n\n<script>\n\n(function($scope) {\n    \n$('.momentary0').on('touchstart mousedown', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\": true});\n});\n\n$('.momentary0').on('touchend mouseup', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\":false });\n});\n    \n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":200,"y":100,"wires":[["6983a4d.ab2885c"]]},{"id":"b99a9f12.e4df5","type":"ui_template","z":"cd21fa8d.ed8198","group":"849ef9ac.e33228","name":"Stop Pump","order":2,"width":0,"height":0,"format":"<div class=\"momentary1\">\n   <md-button> Stop Pump</md-button>\n</div>\n\n<script>\n\n(function($scope) {\n    \n$('.momentary1').on('touchstart mousedown', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\": true});\n});\n\n$('.momentary1').on('touchend mouseup', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\":false });\n});\n    \n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":210,"y":200,"wires":[["678daa54.855704"]]},{"id":"dc3226d0.c88bd8","type":"ui_template","z":"cd21fa8d.ed8198","group":"849ef9ac.e33228","name":"Start Solenoild","order":3,"width":0,"height":0,"format":"<div class=\"momentary2\">\n   <md-button> Start Solenoild</md-button>\n</div>\n\n<script>\n\n(function($scope) {\n    \n$('.momentary2').on('touchstart mousedown', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\": true});\n});\n\n$('.momentary2').on('touchend mouseup', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\":false });\n});\n    \n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":220,"y":280,"wires":[["ff5a19ec.a23128"]]},{"id":"373615ce.c6985a","type":"ui_template","z":"cd21fa8d.ed8198","group":"849ef9ac.e33228","name":"Stop Solenoild","order":4,"width":0,"height":0,"format":"<div class=\"momentary3\">\n   <md-button> Stop Solenoild</md-button>\n</div>\n\n<script>\n\n(function($scope) {\n    \n$('.momentary3').on('touchstart mousedown', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\": true});\n});\n\n$('.momentary3').on('touchend mouseup', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"payload\":false });\n});\n    \n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":220,"y":360,"wires":[["8d1d937d.6e09c"]]},{"id":"ae274748.ba7ec8","type":"ui_led","z":"cd21fa8d.ed8198","group":"849ef9ac.e33228","order":5,"width":0,"height":0,"label":"Pump","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"grey","value":"false","valueType":"bool"},{"color":"green","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":730,"y":500,"wires":[]},{"id":"97e7fdd5.dcbbc","type":"function","z":"cd21fa8d.ed8198","name":"read coil status","func":"var x = [0,0,0,0,0,0,0,0];\nvar msg_o = [msg,msg,msg,msg,msg,msg,msg,msg,];\n\n    x[0] = msg.payload[0];\n    \n    if(x[0]==true){\n        msg_o[0] = {payload: true};\n    }\n    else{\n        msg_o[0] = {payload: false};\n    }\n    \n\n\n\nreturn msg_o[0];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":440,"wires":[["33f7a1d8.fece1e","ae274748.ba7ec8"]]},{"id":"33f7a1d8.fece1e","type":"debug","z":"cd21fa8d.ed8198","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":650,"y":400,"wires":[]},{"id":"66519109.d4d5","type":"function","z":"cd21fa8d.ed8198","name":"read coil status","func":"var x = [0,0,0,0,0,0,0,0];\nvar msg_o = [msg,msg,msg,msg,msg,msg,msg,msg,];\n\n    x[0] = msg.payload[0];\n    \n    if(x[0]==true){\n        msg_o[0] = {payload: true};\n    }\n    else{\n        msg_o[0] = {payload: false};\n    }\n    \n\n\n\nreturn msg_o[0];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":480,"y":620,"wires":[["701b70de.1cca8","8799ae8b.1f6b8"]]},{"id":"701b70de.1cca8","type":"debug","z":"cd21fa8d.ed8198","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":600,"wires":[]},{"id":"5132be22.7bfa","type":"modbus-write","z":"cd21fa8d.ed8198","name":"write D0 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4096","quantity":"1","server":"a0737e46.57122","emptyMsgOnFail":false,"keepMsgProperties":false,"x":400,"y":1360,"wires":[[],[]]},{"id":"e2fe0c19.d46d8","type":"ui_numeric","z":"cd21fa8d.ed8198","name":"","label":"Test D0","tooltip":"","group":"849ef9ac.e33228","order":8,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":160,"y":1366,"wires":[["5132be22.7bfa"]]},{"id":"a0737e46.57122","type":"modbus-client","name":"modbus TCP client","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.1.10","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":false,"reconnectTimeout":"2000","parallelUnitIdsAllowed":false},{"id":"849ef9ac.e33228","type":"ui_group","name":"Center Station","tab":"80f737c5.0293f8","order":1,"disp":true,"width":"6","collapse":false},{"id":"80f737c5.0293f8","type":"ui_tab","name":"Đại Học Kỹ THuật Công Nghiệp Thái Nguyên","icon":"dashboard","disabled":false,"hidden":false}]
Created 6 years ago
  • debug (x2)
  • function (x2)
  • modbus-client (x1)
  • modbus-read (x2)
  • modbus-response (x2)
  • modbus-write (x11)
  • ui_group (x1)
  • ui_led (x2)
  • ui_numeric (x7)
  • ui_template (x4)
  • PLC
  • delta
  • dvp-12se
  • modbus
  • pump
