node-red-flow-mididings
A Node Red Flow that provide a UI for mididings
Presentation
This flow allow the control of mididings with the OSC protocol. It is the Node Red version of my Flaskdings application. If you are a programmer you may use Flaskings instead which is dynamic and faster. If you are not a programmer, you may use this flow and you can change the UI as you want and there is very few javascript code. However, the Node Red UI is a static layout of 16 scenes and 32 subscenes and can be extend if you want in the flow editor.
Source
Dependencies
  • node-red-contrib-osc
  • node-red-dashboard
Support MIDIDINGS
  • Contributors and PR are welcome to improve node-red-flow-mididings and keep MIDIDINGS ALIVE
Mididings ressources
[{"id":"1312daf792117c43","type":"tab","label":"mididings-nav","disabled":false,"info":"","env":[]},{"id":"2c1bfe41f3bf4501","type":"udp in","z":"1312daf792117c43","name":"","iface":"","port":"56419","ipv":"udp4","multicast":"false","group":"","datatype":"buffer","x":400,"y":1020,"wires":[["62e115079a64058c"]]},{"id":"62e115079a64058c","type":"osc","z":"1312daf792117c43","name":"","path":"","metadata":false,"x":550,"y":1020,"wires":[["623462e011237301","40a7f8b5845bd66e"]]},{"id":"2d165e2675c65c29","type":"comment","z":"1312daf792117c43","name":"Receiving messages on UDP port 56419","info":"","x":460,"y":980,"wires":[]},{"id":"6ea870b4d54824c1","type":"osc","z":"1312daf792117c43","name":"","path":"","metadata":false,"x":3450,"y":1060,"wires":[["2437206f4cb8ae44","a01b9b56ebcd4222"]]},{"id":"2437206f4cb8ae44","type":"udp out","z":"1312daf792117c43","name":"","addr":"127.0.0.1","iface":"","port":"56418","ipv":"udp4","outport":"","base64":false,"multicast":"false","x":3680,"y":1040,"wires":[]},{"id":"b4165695f3c75e96","type":"comment","z":"1312daf792117c43","name":"mididings commands","info":"","x":1880,"y":860,"wires":[]},{"id":"6cfa4a9dceea8af6","type":"ui_button","z":"1312daf792117c43","name":"","group":"b1df786c93ec53f2","order":59,"width":4,"height":1,"passthru":true,"label":"Next scene","tooltip":"","color":"","bgcolor":"dodgerblue","className":"","icon":"","payload":"","payloadType":"str","topic":"/mididings/next_scene","topicType":"str","x":2110,"y":1080,"wires":[["961f7f104d693837"]]},{"id":"a01b9b56ebcd4222","type":"debug","z":"1312daf792117c43","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":3630,"y":1100,"wires":[]},{"id":"961f7f104d693837","type":"change","z":"1312daf792117c43","name":"RemovePayload","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2440,"y":1060,"wires":[["f2910af4bf638bae"]]},{"id":"f4f18f04dde02efb","type":"ui_button","z":"1312daf792117c43","name":"","group":"b1df786c93ec53f2","order":56,"width":4,"height":1,"passthru":true,"label":"Previous scene","tooltip":"","color":"","bgcolor":"dodgerblue","className":"","icon":"","payload":"","payloadType":"str","topic":"/mididings/prev_scene","topicType":"str","x":2100,"y":1040,"wires":[["961f7f104d693837"]]},{"id":"037f26983a0fa8d3","type":"ui_button","z":"1312daf792117c43","name":"","group":"b1df786c93ec53f2","order":58,"width":4,"height":1,"passthru":true,"label":"Next Sub-Scene","tooltip":"","color":"","bgcolor":"blue","className":"","icon":"","payload":"","payloadType":"str","topic":"/mididings/next_subscene","topicType":"str","x":2100,"y":1000,"wires":[["961f7f104d693837"]]},{"id":"2e09ed47c0d034d4","type":"ui_button","z":"1312daf792117c43","name":"","group":"b1df786c93ec53f2","order":57,"width":4,"height":1,"passthru":true,"label":"Previous Sub-Scene","tooltip":"","color":"","bgcolor":"blue","className":"navigator","icon":"","payload":"","payloadType":"str","topic":"/mididings/prev_subscene","topicType":"str","x":2080,"y":960,"wires":[["961f7f104d693837"]]},{"id":"ee6455110066a842","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1860,"y":1000,"wires":[["037f26983a0fa8d3"]]},{"id":"4c9e601e4a7cc9da","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1860,"y":1040,"wires":[["f4f18f04dde02efb"]]},{"id":"bb3151c1543a8793","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1860,"y":1080,"wires":[["6cfa4a9dceea8af6"]]},{"id":"88baf02c36c1e5d3","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1860,"y":1120,"wires":[["dd55d635fefad12b"]]},{"id":"dd55d635fefad12b","type":"ui_button","z":"1312daf792117c43","name":"","group":"b1df786c93ec53f2","order":5,"width":2,"height":1,"passthru":true,"label":"Quit","tooltip":"","color":"black","bgcolor":"orange","className":"","icon":"close","payload":"","payloadType":"str","topic":"/mididings/quit","topicType":"str","x":2130,"y":1120,"wires":[["961f7f104d693837"]]},{"id":"a895b8e1a44923be","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1860,"y":1160,"wires":[["407e326d9c99bbc4"]]},{"id":"407e326d9c99bbc4","type":"ui_button","z":"1312daf792117c43","name":"","group":"b1df786c93ec53f2","order":3,"width":2,"height":1,"passthru":true,"label":"Restart","tooltip":"","color":"white","bgcolor":"green","className":"","icon":"refresh","payload":"","payloadType":"str","topic":"/mididings/restart","topicType":"str","x":2120,"y":1160,"wires":[["961f7f104d693837"]]},{"id":"184c3a26dd92639b","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1860,"y":1200,"wires":[["82e8f99a61613c9b"]]},{"id":"82e8f99a61613c9b","type":"ui_button","z":"1312daf792117c43","name":"Panic","group":"b1df786c93ec53f2","order":2,"width":2,"height":1,"passthru":true,"label":"Panic","tooltip":"","color":"black","bgcolor":"yellow","className":"","icon":"warning","payload":"","payloadType":"str","topic":"/mididings/panic","topicType":"str","x":2130,"y":1200,"wires":[["961f7f104d693837"]]},{"id":"623462e011237301","type":"switch","z":"1312daf792117c43","name":"","property":"raw.address","propertyType":"msg","rules":[{"t":"eq","v":"/mididings/data_offset","vt":"str"},{"t":"eq","v":"/mididings/begin_scenes","vt":"str"},{"t":"eq","v":"/mididings/add_scene","vt":"str"},{"t":"eq","v":"/mididings/end_scenes","vt":"str"},{"t":"eq","v":"/mididings/current_scene","vt":"str"}],"checkall":"false","repair":false,"outputs":5,"x":710,"y":1020,"wires":[["3f424f46c2eb2c71","ae1b4e3d847c09fa"],["2c2785bdfe0fd4c2"],["84f7e6a4ecbdb4af"],[],["63088dd9806b5b82"]],"outputLabels":["offset","","","",""]},{"id":"40a7f8b5845bd66e","type":"debug","z":"1312daf792117c43","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"raw","targetType":"msg","statusVal":"","statusType":"auto","x":720,"y":1100,"wires":[]},{"id":"3f424f46c2eb2c71","type":"change","z":"1312daf792117c43","name":"Set Data Offset","rules":[{"t":"set","p":"data_offset","pt":"flow","to":"raw.args","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":960,"y":940,"wires":[[]]},{"id":"c3bee066ccb688a9","type":"ui_text","z":"1312daf792117c43","d":true,"group":"b1df786c93ec53f2","order":1,"width":24,"height":1,"name":"","label":"switching to scene","format":"{{msg.raw.args[0]}}.{{msg.raw.args[1]}} : {{msg.scene_name}}","layout":"row-left","className":"","x":1190,"y":1140,"wires":[]},{"id":"2c2785bdfe0fd4c2","type":"change","z":"1312daf792117c43","name":"Init Scenes","rules":[{"t":"set","p":"scenes","pt":"flow","to":"[]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":950,"y":1020,"wires":[[]]},{"id":"84f7e6a4ecbdb4af","type":"function","z":"1312daf792117c43","name":"Add Scene","func":"// Get scenes\nvar scenes = flow.get('scenes')\n\n// Add scene to collection\nscenes.push(msg.raw.args)\n\n// Add collection to flow context\nflow.set('scenes', scenes)\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":950,"y":1060,"wires":[[]]},{"id":"dd74fb1266214629","type":"catch","z":"1312daf792117c43","name":"","scope":null,"uncaught":false,"x":360,"y":820,"wires":[["de83f726a3bf1fcc"]]},{"id":"63088dd9806b5b82","type":"function","z":"1312daf792117c43","name":"Current Scene","func":"\nflow.set('current_scene', msg.raw.args)\n\n//offset = flow.get('data_offset');\nscenes = flow.get('scenes');\n\nindex = msg.raw.args[0]-1;          // Scene ID\nsub_index = msg.raw.args[1]+1;      // Sub Scene ID\n\nhas_subscene = scenes[index].length > 2;\n//flow.set('has_subscene', has_subscene)\n\nname=scenes[index][1];\n\nif (has_subscene)\n    name = name + ' / ' + scenes[index][sub_index];\n\n//flow.set('scene_name', name);\n\nmsg.scene_name = name;\nmsg.cur_scene = msg.raw.args[0];\nmsg.cur_subscene = msg.raw.args[1];\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":1100,"wires":[["c3bee066ccb688a9","12382a6f3dacf290","e91a308e54973520"]]},{"id":"f1a6ba3d654a58b0","type":"ui_button","z":"1312daf792117c43","name":"","group":"b1df786c93ec53f2","order":4,"width":2,"height":1,"passthru":true,"label":"Query","tooltip":"","color":"","bgcolor":"blue","className":"btn1","icon":"get_app","payload":"","payloadType":"str","topic":"/mididings/query","topicType":"str","x":2130,"y":920,"wires":[["961f7f104d693837"]]},{"id":"5ec242bce38e62e6","type":"switch","z":"1312daf792117c43","name":"Scene ID","property":"index","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"},{"t":"eq","v":"6","vt":"num"},{"t":"eq","v":"7","vt":"num"},{"t":"eq","v":"8","vt":"num"},{"t":"eq","v":"9","vt":"num"},{"t":"eq","v":"10","vt":"num"},{"t":"eq","v":"11","vt":"num"},{"t":"eq","v":"12","vt":"num"},{"t":"eq","v":"13","vt":"num"},{"t":"eq","v":"14","vt":"num"},{"t":"eq","v":"15","vt":"num"},{"t":"eq","v":"16","vt":"num"}],"checkall":"false","repair":false,"outputs":16,"x":2240,"y":620,"wires":[["d501d685b219e1ce"],["1c3a4f626c130791"],["349a6b2a6cd9077a"],["662c61f199db5fa9"],["5f3fc5de26a346c4"],["2a7f315efa65fc73"],["4becda50deed56fd"],["0a1822044332b849"],["e9ef4b43460a6bfb"],["c9373cbce18ce5b0"],["7a6346683d93d330"],["254ce3675bdd28eb"],["07421bdfb01e3402"],["afc01eb781b7f962"],["38ac675bdc9b75a6"],["8d88201241980044"]]},{"id":"d501d685b219e1ce","type":"ui_button","z":"1312daf792117c43","name":"Scene 1","group":"b1df786c93ec53f2","order":7,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"1","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":340,"wires":[["f260310473736f34"]]},{"id":"f260310473736f34","type":"link out","z":"1312daf792117c43","name":"Submit Scene to OSC","mode":"link","links":["1f2dd22c6e3891b8","904a3ed8846f25af"],"x":3035,"y":680,"wires":[]},{"id":"f10ce8d60a335ff4","type":"ui_button","z":"1312daf792117c43","name":"SubScene1","group":"b1df786c93ec53f2","order":9,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"1","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1160,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"1c3a4f626c130791","type":"ui_button","z":"1312daf792117c43","name":"Scene 2","group":"b1df786c93ec53f2","order":8,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"2","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":380,"wires":[["f260310473736f34"]]},{"id":"349a6b2a6cd9077a","type":"ui_button","z":"1312daf792117c43","name":"Scene 3","group":"b1df786c93ec53f2","order":13,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"3","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":420,"wires":[["f260310473736f34"]]},{"id":"662c61f199db5fa9","type":"ui_button","z":"1312daf792117c43","name":"Scene 4","group":"b1df786c93ec53f2","order":14,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"4","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":460,"wires":[["f260310473736f34"]]},{"id":"5f3fc5de26a346c4","type":"ui_button","z":"1312daf792117c43","name":"Scene 5","group":"b1df786c93ec53f2","order":19,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"5","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":500,"wires":[["f260310473736f34"]]},{"id":"2a7f315efa65fc73","type":"ui_button","z":"1312daf792117c43","name":"Scene 6","group":"b1df786c93ec53f2","order":20,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"6","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":540,"wires":[["f260310473736f34"]]},{"id":"4becda50deed56fd","type":"ui_button","z":"1312daf792117c43","name":"Scene 7","group":"b1df786c93ec53f2","order":25,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"7","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":580,"wires":[["f260310473736f34"]]},{"id":"0a1822044332b849","type":"ui_button","z":"1312daf792117c43","name":"Scene 8","group":"b1df786c93ec53f2","order":26,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"8","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":620,"wires":[["f260310473736f34"]]},{"id":"e9ef4b43460a6bfb","type":"ui_button","z":"1312daf792117c43","name":"Scene 9","group":"b1df786c93ec53f2","order":31,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"9","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":660,"wires":[["f260310473736f34"]]},{"id":"c9373cbce18ce5b0","type":"ui_button","z":"1312daf792117c43","name":"Scene 10","group":"b1df786c93ec53f2","order":32,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"10","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":700,"wires":[["f260310473736f34"]]},{"id":"7a6346683d93d330","type":"ui_button","z":"1312daf792117c43","name":"Scene 11","group":"b1df786c93ec53f2","order":37,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"11","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":740,"wires":[["f260310473736f34"]]},{"id":"254ce3675bdd28eb","type":"ui_button","z":"1312daf792117c43","name":"Scene 12","group":"b1df786c93ec53f2","order":38,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"12","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":780,"wires":[["f260310473736f34"]]},{"id":"07421bdfb01e3402","type":"ui_button","z":"1312daf792117c43","name":"Scene 13","group":"b1df786c93ec53f2","order":43,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"13","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":820,"wires":[["f260310473736f34"]]},{"id":"afc01eb781b7f962","type":"ui_button","z":"1312daf792117c43","name":"Scene 14","group":"b1df786c93ec53f2","order":44,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"14","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":860,"wires":[["f260310473736f34"]]},{"id":"38ac675bdc9b75a6","type":"ui_button","z":"1312daf792117c43","name":"Scene 15","group":"b1df786c93ec53f2","order":49,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"15","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":900,"wires":[["f260310473736f34"]]},{"id":"8d88201241980044","type":"ui_button","z":"1312daf792117c43","name":"Scene 16","group":"b1df786c93ec53f2","order":50,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"16","payloadType":"num","topic":"/mididings/switch_scene","topicType":"str","x":2540,"y":940,"wires":[["f260310473736f34"]]},{"id":"f7af91922b5d4b84","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1860,"y":920,"wires":[["f1a6ba3d654a58b0"]]},{"id":"8d05641d122b8a1c","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1860,"y":960,"wires":[["2e09ed47c0d034d4"]]},{"id":"bb9a2a7bfdc29653","type":"switch","z":"1312daf792117c43","name":"","property":"index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"},{"t":"eq","v":"6","vt":"num"},{"t":"eq","v":"7","vt":"num"},{"t":"eq","v":"8","vt":"num"},{"t":"eq","v":"9","vt":"num"},{"t":"eq","v":"10","vt":"num"},{"t":"eq","v":"11","vt":"num"},{"t":"eq","v":"12","vt":"num"},{"t":"eq","v":"13","vt":"num"},{"t":"eq","v":"14","vt":"num"},{"t":"eq","v":"15","vt":"num"},{"t":"eq","v":"16","vt":"num"},{"t":"eq","v":"17","vt":"num"},{"t":"eq","v":"18","vt":"num"},{"t":"eq","v":"19","vt":"num"},{"t":"eq","v":"20","vt":"num"},{"t":"eq","v":"21","vt":"num"},{"t":"eq","v":"22","vt":"num"},{"t":"eq","v":"23","vt":"num"},{"t":"eq","v":"24","vt":"num"},{"t":"eq","v":"25","vt":"num"},{"t":"eq","v":"26","vt":"num"},{"t":"eq","v":"27","vt":"num"},{"t":"eq","v":"28","vt":"num"},{"t":"eq","v":"29","vt":"num"},{"t":"eq","v":"30","vt":"num"},{"t":"eq","v":"31","vt":"num"},{"t":"eq","v":"32","vt":"num"},{"t":"eq","v":"33","vt":"num"}],"checkall":"false","repair":false,"outputs":34,"x":2230,"y":1700,"wires":[[],[],["f10ce8d60a335ff4"],["8296524908244f4b"],["6019d00cb2f861f5"],["8c533540afaafbb0"],["df0f01e08db8d0e4"],["70b8df970fcaa687"],["1416217ee1dc3b2c"],["130c3ccf5a703a5e"],["20a18886ccbfd18b"],["29e2797bcdf79a4e"],["bd87abb6d91c8449"],["db577ef5126fe0f3"],["b6c6a234a8daa7d1"],["f40bcb47e4db3ff2"],["a4f93019c6825c1e"],["010fbf7689776445"],["800496188cd7de44"],["82b0f3de414feb6d"],["50eba8223d9e9a47"],["081263a8ec5b1b86"],["4e0adf0eceec7f3d"],["0d08a94a2c678c6c"],["34900bce0fb13649"],["3e15ec20c8a9cf3f"],["69cea060c474a75c"],["a094198acddda241"],["f841b8919e5035e2"],["690a75f7ac428d06"],["82d9dd7eaf82933a"],["2485dc131243dda9"],["2e5d966baef7503d"],["f969487c45528122"]]},{"id":"8296524908244f4b","type":"ui_button","z":"1312daf792117c43","name":"SubScene2","group":"b1df786c93ec53f2","order":10,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"2","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1200,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"6019d00cb2f861f5","type":"ui_button","z":"1312daf792117c43","name":"SubScene3","group":"b1df786c93ec53f2","order":11,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"3","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1240,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"8c533540afaafbb0","type":"ui_button","z":"1312daf792117c43","name":"SubScene4","group":"b1df786c93ec53f2","order":12,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"4","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1280,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"df0f01e08db8d0e4","type":"ui_button","z":"1312daf792117c43","name":"SubScene5","group":"b1df786c93ec53f2","order":15,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"5","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1320,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"70b8df970fcaa687","type":"ui_button","z":"1312daf792117c43","name":"SubScene6","group":"b1df786c93ec53f2","order":16,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"6","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1360,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"1416217ee1dc3b2c","type":"ui_button","z":"1312daf792117c43","name":"SubScene7","group":"b1df786c93ec53f2","order":17,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"7","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1400,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"130c3ccf5a703a5e","type":"ui_button","z":"1312daf792117c43","name":"SubScene8","group":"b1df786c93ec53f2","order":18,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"8","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1440,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"20a18886ccbfd18b","type":"ui_button","z":"1312daf792117c43","name":"SubScene9","group":"b1df786c93ec53f2","order":21,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"9","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1480,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"29e2797bcdf79a4e","type":"ui_button","z":"1312daf792117c43","name":"SubScene10","group":"b1df786c93ec53f2","order":22,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"10","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1520,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"bd87abb6d91c8449","type":"ui_button","z":"1312daf792117c43","name":"SubScene11","group":"b1df786c93ec53f2","order":23,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"11","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1560,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"db577ef5126fe0f3","type":"ui_button","z":"1312daf792117c43","name":"SubScene12","group":"b1df786c93ec53f2","order":24,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"12","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1600,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"b6c6a234a8daa7d1","type":"ui_button","z":"1312daf792117c43","name":"SubScene13","group":"b1df786c93ec53f2","order":27,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1640,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"f40bcb47e4db3ff2","type":"ui_button","z":"1312daf792117c43","name":"SubScene14","group":"b1df786c93ec53f2","order":28,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"14","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1680,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"a4f93019c6825c1e","type":"ui_button","z":"1312daf792117c43","name":"SubScene15","group":"b1df786c93ec53f2","order":29,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"15","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1720,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"010fbf7689776445","type":"ui_button","z":"1312daf792117c43","name":"SubScene16","group":"b1df786c93ec53f2","order":30,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"16","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1760,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"800496188cd7de44","type":"ui_button","z":"1312daf792117c43","name":"SubScene17","group":"b1df786c93ec53f2","order":33,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"17","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1800,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"82b0f3de414feb6d","type":"ui_button","z":"1312daf792117c43","name":"SubScene18","group":"b1df786c93ec53f2","order":34,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"18","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1840,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"50eba8223d9e9a47","type":"ui_button","z":"1312daf792117c43","name":"SubScene19","group":"b1df786c93ec53f2","order":35,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"19","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1880,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"081263a8ec5b1b86","type":"ui_button","z":"1312daf792117c43","name":"SubScene20","group":"b1df786c93ec53f2","order":36,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"20","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1920,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"4e0adf0eceec7f3d","type":"ui_button","z":"1312daf792117c43","name":"SubScene21","group":"b1df786c93ec53f2","order":39,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"21","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":1960,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"0d08a94a2c678c6c","type":"ui_button","z":"1312daf792117c43","name":"SubScene22","group":"b1df786c93ec53f2","order":40,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"22","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2000,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"34900bce0fb13649","type":"ui_button","z":"1312daf792117c43","name":"SubScene23","group":"b1df786c93ec53f2","order":41,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"23","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2040,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"3e15ec20c8a9cf3f","type":"ui_button","z":"1312daf792117c43","name":"SubScene24","group":"b1df786c93ec53f2","order":42,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"24","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2080,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"69cea060c474a75c","type":"ui_button","z":"1312daf792117c43","name":"SubScene25","group":"b1df786c93ec53f2","order":45,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"25","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2120,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"a094198acddda241","type":"ui_button","z":"1312daf792117c43","name":"SubScene26","group":"b1df786c93ec53f2","order":46,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"26","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2160,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"f841b8919e5035e2","type":"ui_button","z":"1312daf792117c43","name":"SubScene27","group":"b1df786c93ec53f2","order":47,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"27","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2200,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"690a75f7ac428d06","type":"ui_button","z":"1312daf792117c43","name":"SubScene28","group":"b1df786c93ec53f2","order":48,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"28","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2240,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"82d9dd7eaf82933a","type":"ui_button","z":"1312daf792117c43","name":"SubScene29","group":"b1df786c93ec53f2","order":51,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"29","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2280,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"2485dc131243dda9","type":"ui_button","z":"1312daf792117c43","name":"SubScene30","group":"b1df786c93ec53f2","order":52,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"30","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2320,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"2e5d966baef7503d","type":"ui_button","z":"1312daf792117c43","name":"SubScene31","group":"b1df786c93ec53f2","order":53,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"31","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2360,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"f969487c45528122","type":"ui_button","z":"1312daf792117c43","name":"SubScene32","group":"b1df786c93ec53f2","order":54,"width":4,"height":1,"passthru":false,"label":"{{msg.name}}","tooltip":"","color":"","bgcolor":"{{color}}","className":"","icon":"","payload":"32","payloadType":"num","topic":"/mididings/switch_subscene","topicType":"str","x":2550,"y":2400,"wires":[["c5dc9aa1d7c5d5b9"]]},{"id":"c5dc9aa1d7c5d5b9","type":"link out","z":"1312daf792117c43","name":"Submit Subscene to OSC","mode":"link","links":["1f2dd22c6e3891b8"],"x":3055,"y":1720,"wires":[]},{"id":"b2913fb149518993","type":"ui_template","z":"1312daf792117c43","group":"b1df786c93ec53f2","name":"Global Style","order":60,"width":0,"height":0,"format":"<style>\n.md-button {\n  border-radius: 10px 10px  10px  10px;\n  font-size: 20px;\n  text-transform: none !important;\n}\n/*\n.nr-dashboard-widget-current_scene\n{\n    font-size: 40px !important;\n}\n\n.nr-dashboard-theme .nr-dashboard-button .md-button\n{\n    background-color: black;\n}\n*/\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","className":"","x":370,"y":780,"wires":[[]]},{"id":"73f11e2d7e2928ae","type":"ui_text","z":"1312daf792117c43","group":"b1df786c93ec53f2","order":55,"width":8,"height":1,"name":"Credentials (placeholder)","label":"","format":"github.com/stefets/node-red-flow-mididings","layout":"row-center","className":"","x":410,"y":860,"wires":[]},{"id":"e91a308e54973520","type":"ui_text","z":"1312daf792117c43","group":"b1df786c93ec53f2","order":6,"width":16,"height":1,"name":"Set Title","label":"<font size=30>{{msg.cur_scene}}.{{msg.cur_subscene}}","format":"<font size=30>/{{msg.scene_name}}","layout":"row-left","className":"","x":1160,"y":1060,"wires":[]},{"id":"ae1b4e3d847c09fa","type":"function","z":"1312daf792117c43","name":"SetBaseStyle","func":"color = \"black\";\n\nvar colors = [];\n\nfor (let i = 0; i < 16; i++) {\n  colors[i] = color;\n}\n\n// Scenes X 16 \nflow.set(\"scene_colors\", colors)\n\n// Subscene X 34\ncolors = [];\n\n for (let i = 0; i < 34; i++) {\n  colors[i] = color;  \n }\n \nflow.set(\"subscene_colors\", colors);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":980,"wires":[[]]},{"id":"535050366e7e47d6","type":"inject","z":"1312daf792117c43","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":720,"y":940,"wires":[["ae1b4e3d847c09fa"]]},{"id":"1c4438da1f91a38c","type":"split","z":"1312daf792117c43","name":"SplitStyleX16","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":1750,"y":620,"wires":[["19efe55a5f0ec2c6"]]},{"id":"b48998b507089cbb","type":"function","z":"1312daf792117c43","name":"Style.Init","func":"\nmsg.payload=flow.get('scene_colors')\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1580,"y":620,"wires":[["1c4438da1f91a38c"]]},{"id":"12382a6f3dacf290","type":"delay","z":"1312daf792117c43","name":"Wait for current scene","pauseType":"delay","timeout":"125","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1380,"y":1100,"wires":[["b48998b507089cbb","c90ad3589d1a079e"]]},{"id":"19efe55a5f0ec2c6","type":"function","z":"1312daf792117c43","name":"SetSelectedSceneUI","func":"\nindex = msg.parts.index+1;\n\nscenes = flow.get('scenes')\ncurrent = flow.get('current_scene');\ncurrentSceneId=current[0];\n\nmsg.name = \"\";\nmsg.index=index;\nif (currentSceneId == index) {\n    msg.color='gray';\n}\nelse\n    msg.color=msg.payload;\n\nif (msg.parts.index < scenes.length)\n    // Scene name\n    msg.name = scenes[index-1][1];\nelse\n    msg.enabled = false;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1980,"y":620,"wires":[["5ec242bce38e62e6"]]},{"id":"de83f726a3bf1fcc","type":"debug","z":"1312daf792117c43","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":510,"y":820,"wires":[]},{"id":"c90ad3589d1a079e","type":"function","z":"1312daf792117c43","name":"SubStyle.Init","func":"\nmsg.payload=flow.get('subscene_colors')\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1590,"y":1700,"wires":[["6dfac3dea7c6e179"]]},{"id":"6dfac3dea7c6e179","type":"split","z":"1312daf792117c43","name":"SplitStyleX32","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":1770,"y":1700,"wires":[["ee9dab3b8f186c58"]]},{"id":"ee9dab3b8f186c58","type":"function","z":"1312daf792117c43","name":"SetSelectedSubSceneUI","func":"// 1 to 32\nmsg.index = msg.parts.index;\nmsg.color = msg.payload;\ncurrent = flow.get('current_scene');\n\nsceneID=current[0];     //  \nsubScendId=current[1];  //  \n\nscenes = flow.get('scenes');\n\nscene=scenes[sceneID-1];\nmsg.name=scene[msg.index]\n\nif (subScendId === msg.index-1) {\n    msg.color='gray';\n}\nelse\n    msg.color=msg.payload;\n    \nmsg.enabled = true;\nif (msg.index < scene.length)\n    // SubScene name\n    msg.name = scene[msg.index];\nelse\n    msg.enabled = false;\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1990,"y":1700,"wires":[["bb9a2a7bfdc29653","df2ccd401dde1f0d"]]},{"id":"df2ccd401dde1f0d","type":"debug","z":"1312daf792117c43","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":2250,"y":1340,"wires":[]},{"id":"1f2dd22c6e3891b8","type":"link in","z":"1312daf792117c43","name":"Send OSC message","links":["c5dc9aa1d7c5d5b9","f260310473736f34","f2910af4bf638bae"],"x":3255,"y":1060,"wires":[["6ea870b4d54824c1"]]},{"id":"f2910af4bf638bae","type":"link out","z":"1312daf792117c43","name":"MididingsCommands","mode":"link","links":["1f2dd22c6e3891b8"],"x":3045,"y":1060,"wires":[]},{"id":"b1df786c93ec53f2","type":"ui_group","name":"The Node Red Flow for mididindgs","tab":"231f06ce466e9ede","order":1,"disp":true,"width":"24","collapse":false,"className":""},{"id":"231f06ce466e9ede","type":"ui_tab","name":"MIDIDINGS","icon":"dashboard","order":5,"disabled":false,"hidden":false}]
Created 3 years, 4 months ago
  • catch (x1)
  • change (x3)
  • comment (x2)
  • debug (x4)
  • delay (x1)
  • function (x7)
  • inject (x9)
  • link in (x1)
  • link out (x3)
  • split (x2)
  • switch (x3)
  • udp in (x1)
  • udp out (x1)
  • osc (x2)
  • ui_button (x56)
  • ui_group (x1)
  • ui_template (x1)
  • ui_text (x3)
  • osc
  • mididings
  • midi
