Add Zwave node
#Requirements
  • node-red-contrib-openzwave nodes
  • openzwavev > 1.3 Since OZW 1.3 the BeginControllerCommand command is deprecated. This flow uses the new API with the addNode` command. Find a list of all management commands here )
#Configuration
  • Set your zwave controller node to each zwave nodes
  • Configure zwave message filter node if you only want to certain messages.
  • Set the log file location. Defaults to /var/tmp/zwave/zwave.log
  • The inject node is used to send the addNode command. This command uses 1 parameter. Set it to true of false if your device requires Security. Read the documentation linked above or consult your devices manual.
  • Add your device while the controller is waiting. Power cycling or pressing a button 3 times (e.g. Fibaro Wallplug).
  • Any zwave message is written to debug and a file. Clear the file between each use as it keeps appending new mesages.
[{"id":"cab36242.710898","type":"zwave-in","z":"66319146.7c706","name":"Listen","controller":"","x":497,"y":400,"wires":[["c7b8d6b8.bcb98"]]},{"id":"4842cdfa.bf8bcc","type":"zwave-out","z":"66319146.7c706","name":"","controller":"","x":738,"y":285,"wires":[["29bd088d.e60d8","dfb22a42.24bc08"]]},{"id":"9cb98c3c.082298","type":"inject","z":"66319146.7c706","name":"Add Node","topic":"addNode","payload":"{\"args\": [false]}","payloadType":"str","repeat":"","crontab":"","once":false,"x":512,"y":286,"wires":[["4842cdfa.bf8bcc"]]},{"id":"29bd088d.e60d8","type":"debug","z":"66319146.7c706","name":"zwave log","active":true,"console":"false","complete":"true","x":952,"y":401,"wires":[]},{"id":"c7b8d6b8.bcb98","type":"function","z":"66319146.7c706","name":"Process/Filter","func":"// Insert your own filtering here.\nreturn msg;","outputs":1,"noerr":0,"x":712,"y":399,"wires":[["29bd088d.e60d8","dfb22a42.24bc08"]]},{"id":"dfb22a42.24bc08","type":"file","z":"66319146.7c706","name":"","filename":"var/tmp/zwave/zwave.log","appendNewline":true,"createDir":true,"overwriteFile":"false","x":1003,"y":489,"wires":[]}]
Created 9 years, 5 months ago
  • file (x1)
  • zwave-in (x1)
  • zwave-out (x1)
  • zwave
