Create GOM XML transfer file from CSV files
This flow will create XML files in GOM Inspect Exchange Format from CSV input files.
alt tag
CSV node can be substituted for any source that can provide an array of JavaScript objects with structure defined in mapping node (database, streaming source, etc.).
Generated XML is conforming to the 2019.1 version of the open data format.
There are only two nodes you need to modify:
  • Start node - enter the path to directory with CSV files.
  • Mapping template - You need to specify how columns in your CSV map to GOM elements, i.e., x field will map to CSV column called “coord-x.”
See our blog post for details.
Testing
You can use following CSV file to test the flow. Generated XML was tested on GOM Inspect 2019 and 2020.
Released under MIT License
Copyright (c) 2020 Kenso Software, LLC
[{"id":"f7dd5695.c01598","type":"tab","label":"Create GOM XML from CSV","disabled":false,"info":"Generate GOM Inspect XML from any CSV file. Visit https://blog.kensobi.com/ for details."},{"id":"1b562d91.3c71f2","type":"csv","z":"f7dd5695.c01598","name":"Parse CSV","sep":",","hdrin":true,"hdrout":"none","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":410,"y":180,"wires":[["8e65dad6.c56f98"]]},{"id":"279275b9.82370a","type":"template","z":"f7dd5695.c01598","name":"Point nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <point id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n            </geometry>\n            <result>\n                <x checked=\"1\">\n                    <tolerance lower_limit=\"{{x_lower}}\" upper_limit=\"{{x_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{x}}\"></nominal_scalar>\n                </x>\n                <y checked=\"1\">\n                    <tolerance lower_limit=\"{{y_lower}}\" upper_limit=\"{{y_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{y}}\"></nominal_scalar>\n                </y>\n                <z checked=\"1\">\n                    <tolerance lower_limit=\"{{z_lower}}\" upper_limit=\"{{z_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{z}}\"></nominal_scalar>\n                </z>\n              </result>\n        </point>\n{{/isValid}}","output":"str","x":840,"y":260,"wires":[["c68c47a0.751e98"]]},{"id":"1e4f4efe.b471f1","type":"inject","z":"f7dd5695.c01598","name":"Start","props":[{"p":"dirPath","v":"/filedrop","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":120,"wires":[["64d8b16.886585"]]},{"id":"d5695b04.0654c8","type":"file in","z":"f7dd5695.c01598","name":"Read file","filename":"","format":"utf8","chunk":false,"sendError":false,"encoding":"utf8","x":260,"y":180,"wires":[["1b562d91.3c71f2"]]},{"id":"2bae1ead.b9bae2","type":"switch","z":"f7dd5695.c01598","name":"","property":"type","propertyType":"msg","rules":[{"t":"eq","v":"","vt":"str"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"point\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"line\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"circle\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"plane\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"ellipse\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"slotted_hole\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"rectangular_hole\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"sphere\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"cylinder\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"cone\"))","vt":"jsonata"},{"t":"eq","v":"$trim($lookup(mapping.typeValueMap, \"polygon_hole\"))","vt":"jsonata"},{"t":"else"}],"checkall":"true","repair":false,"outputs":13,"x":370,"y":440,"wires":[[],["e9ee423a.1d424"],["aaad5d23.1aba6"],["b3c448c1.039078"],["40c4aac2.219344"],["93522995.db5938"],["bdb2504c.00e47"],["9dc86af7.5cff28"],["9a8acae.3fa1838"],["a8825505.fe89f8"],["153b0dac.70c4c2"],["3481aa97.f1ab66"],["be5a4fc2.acc38"]]},{"id":"bb1a43c8.8430a","type":"template","z":"f7dd5695.c01598","name":"Circle nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <circle id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <radius>{{radius}}</radius>\n            </geometry>\n            <result>\n                <diameter checked=\"1\">\n                  <tolerance lower_limit=\"{{diameter_lower}}\" upper_limit=\"{{diameter_upper}}\"></tolerance>\n                  <nominal_scalar value=\"{{diameter}}\"></nominal_scalar>\n                </diameter>\n                \n                <x checked=\"1\">\n                    <tolerance lower_limit=\"{{x_lower}}\" upper_limit=\"{{x_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{x}}\"></nominal_scalar>\n                </x>\n                <y checked=\"1\">\n                    <tolerance lower_limit=\"{{y_lower}}\" upper_limit=\"{{y_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{y}}\"></nominal_scalar>\n                </y>\n                <z checked=\"1\">\n                    <tolerance lower_limit=\"{{z_lower}}\" upper_limit=\"{{z_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{z}}\"></nominal_scalar>\n                </z>\n              </result>\n        </circle>\n{{/isValid}}","output":"str","x":840,"y":340,"wires":[["c68c47a0.751e98"]]},{"id":"39667f17.e7d8f","type":"split","z":"f7dd5695.c01598","name":"Split by line","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":150,"y":360,"wires":[["f7d28600.84dae8"]]},{"id":"c68c47a0.751e98","type":"join","z":"f7dd5695.c01598","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1130,"y":420,"wires":[["1b978377.8469dd"]]},{"id":"8e65dad6.c56f98","type":"template","z":"f7dd5695.c01598","name":"Mapping template","field":"mapping","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n    \"name\": \"name\",\n    \"x\": \"coord-x\",\n    \"y\": \"coord-y\",\n    \"z\": \"coord-z\",\n    \"x2\": \"coord-x2\",\n    \"y2\": \"coord-y2\",\n    \"z2\": \"coord-z2\",\n    \"x3\": \"coord-x3\",\n    \"y3\": \"coord-y3\",\n    \"z3\": \"coord-z3\",\n    \"normal_x\": \"normal-x\",\n    \"normal_y\": \"normal-y\",\n    \"normal_z\": \"normal-z\",\n    \"dir_x\": \"dir-x\",\n    \"dir_y\": \"dir-y\",\n    \"dir_z\": \"dir-z\",\n    \"radius\": \"radius\",\n    \"radius2\": \"radius2\",\n    \"edge_radius\": \"edge-radius\",\n    \"num_points\": \"num-points\",\n    \"angle\": \"angle\",\n    \"distance\": \"distance\",\n    \"length\": \"length\",\n    \"width\": \"width\",\n    \"height\": \"height\",\n    \"orientation\": \"orientation\",\n    \"type\": \"type\",\n    \"typeValueMap\": {\n        \"point\": \"point\",\n        \"line\": \"line\",\n        \"plane\": \"plane\",\n        \"circle\": \"circle\",\n        \"ellipse\": \"ellipse\",\n        \"slotted_hole\": \"slotted hole\",\n        \"rectangular_hole\": \"rectangular hole\",\n        \"sphere\": \"sphere\",\n        \"cylinder\": \"cylinder\",\n        \"cone\": \"cone\",\n        \"polygon_hole\": \"polygon hole\"\n    },\n    \"x_lower\": \"tol-x-lower\",\n    \"x_upper\": \"tol-x-upper\",\n    \"y_lower\": \"tol-y-lower\",\n    \"y_upper\": \"tol-y-upper\",\n    \"z_lower\": \"tol-z-lower\",\n    \"z_upper\": \"tol-z-upper\",\n    \"diameter_lower\": \"tol-diameter-lower\",\n    \"diameter_upper\": \"tol-diameter-upper\",\n    \"length_lower\": \"tol-length-lower\",\n    \"length_upper\": \"tol-length-upper\",\n    \"width_lower\": \"tol-width-lower\",\n    \"width_upper\": \"tol-width-upper\"\n}","output":"json","x":590,"y":180,"wires":[["39667f17.e7d8f"]]},{"id":"e9ee423a.1d424","type":"template","z":"f7dd5695.c01598","name":"Point actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <point id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n            </geometry>\n            <result></result>\n        </point>\n{{/isValid}}","output":"str","x":590,"y":260,"wires":[["279275b9.82370a"]]},{"id":"b3c448c1.039078","type":"template","z":"f7dd5695.c01598","name":"Circle actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <circle id=\"{{elementId}}\" name=\"{{name}}\">\n              <state>ok</state>\n              <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <radius>{{radius}}</radius>\n              </geometry>\n              <result></result>\n        </circle>\n{{/isValid}}","output":"str","x":590,"y":340,"wires":[["bb1a43c8.8430a"]]},{"id":"aaad5d23.1aba6","type":"template","z":"f7dd5695.c01598","name":"Line actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <line id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                \t<pos1 x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos1>\n                \t<pos2 x=\"{{x2}}\" y=\"{{y2}}\" z=\"{{z2}}\"></pos2>\n                \t<dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n            </geometry>\n        </line>\n{{/isValid}}","output":"str","x":590,"y":300,"wires":[["6f398baa.36eef4"]]},{"id":"6f398baa.36eef4","type":"template","z":"f7dd5695.c01598","name":"Line nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <line id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                \t<pos1 x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos1>\n                \t<pos2 x=\"{{x2}}\" y=\"{{y2}}\" z=\"{{z2}}\"></pos2>\n                \t<dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n            </geometry>\n            <result></result>\n        </line>\n{{/isValid}}","output":"str","x":830,"y":300,"wires":[["c68c47a0.751e98"]]},{"id":"1b978377.8469dd","type":"template","z":"f7dd5695.c01598","name":"Create GOM XML","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<gom>\n    <header>\n        <version>2019.1</version>\n        <length_unit>mm</length_unit>\n        <angle_unit>deg</angle_unit>\n    </header>\n    <nominal>\n{{#payload}}{{{nominal}}}{{/payload}}\n    </nominal>\n    <measured>\n{{#payload}}{{{measured}}}{{/payload}}\n    </measured>\n</gom>\n","output":"str","x":1310,"y":420,"wires":[["4aee38d3.c6c228"]]},{"id":"48b211f0.ee47f","type":"file","z":"f7dd5695.c01598","name":"Save GOM XML","filename":"","appendNewline":false,"createDir":true,"overwriteFile":"true","encoding":"utf8","x":1300,"y":580,"wires":[[]]},{"id":"be5a4fc2.acc38","type":"template","z":"f7dd5695.c01598","name":"Bad values","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"","output":"str","x":590,"y":700,"wires":[["c68c47a0.751e98"]]},{"id":"f7d28600.84dae8","type":"change","z":"f7dd5695.c01598","name":"Map columns","rules":[{"t":"set","p":"name","pt":"msg","to":"$trim($lookup(payload, mapping.name))\t","tot":"jsonata"},{"t":"set","p":"x","pt":"msg","to":"$lookup(payload, mapping.x)","tot":"jsonata"},{"t":"set","p":"y","pt":"msg","to":"$lookup(payload, mapping.y)","tot":"jsonata"},{"t":"set","p":"z","pt":"msg","to":"$lookup(payload, mapping.z)","tot":"jsonata"},{"t":"set","p":"type","pt":"msg","to":"$trim($lookup(payload, mapping.type))","tot":"jsonata"},{"t":"set","p":"elementId","pt":"msg","to":"$substring($string($random()), 2, 10)","tot":"jsonata"},{"t":"set","p":"isValid","pt":"msg","to":"($boolean(x) or x=0) and ($boolean(y) or y=0) and ($boolean(z) or z=0) and $boolean(name)","tot":"jsonata"},{"t":"set","p":"radius","pt":"msg","to":"$lookup(payload, mapping.radius)","tot":"jsonata"},{"t":"set","p":"dir_x","pt":"msg","to":"$lookup(payload, mapping.dir_x)","tot":"jsonata"},{"t":"set","p":"dir_y","pt":"msg","to":"$lookup(payload, mapping.dir_y)","tot":"jsonata"},{"t":"set","p":"dir_z","pt":"msg","to":"$lookup(payload, mapping.dir_z)","tot":"jsonata"},{"t":"set","p":"x2","pt":"msg","to":"$lookup(payload, mapping.x2)","tot":"jsonata"},{"t":"set","p":"y2","pt":"msg","to":"$lookup(payload, mapping.y2)","tot":"jsonata"},{"t":"set","p":"z2","pt":"msg","to":"$lookup(payload, mapping.z2)","tot":"jsonata"},{"t":"set","p":"x_lower","pt":"msg","to":"$lookup(payload, mapping.x_lower)","tot":"jsonata"},{"t":"set","p":"x_upper","pt":"msg","to":"$lookup(payload, mapping.x_upper)","tot":"jsonata"},{"t":"set","p":"y_lower","pt":"msg","to":"$lookup(payload, mapping.y_lower)","tot":"jsonata"},{"t":"set","p":"y_upper","pt":"msg","to":"$lookup(payload, mapping.y_upper)","tot":"jsonata"},{"t":"set","p":"z_lower","pt":"msg","to":"$lookup(payload, mapping.z_lower)","tot":"jsonata"},{"t":"set","p":"z_upper","pt":"msg","to":"$lookup(payload, mapping.z_upper)","tot":"jsonata"},{"t":"set","p":"diameter_lower","pt":"msg","to":"$lookup(payload, mapping.diameter_lower)","tot":"jsonata"},{"t":"set","p":"diameter_upper","pt":"msg","to":"$lookup(payload, mapping.diameter_upper)","tot":"jsonata"},{"t":"set","p":"diameter","pt":"msg","to":"radius * 2","tot":"jsonata"},{"t":"set","p":"height","pt":"msg","to":"$lookup(payload, mapping.height)","tot":"jsonata"},{"t":"set","p":"width","pt":"msg","to":"$lookup(payload, mapping.width)","tot":"jsonata"},{"t":"set","p":"orientation","pt":"msg","to":"$lookup(payload, mapping.orientation)","tot":"jsonata"},{"t":"set","p":"length","pt":"msg","to":"$lookup(payload, mapping.length)","tot":"jsonata"},{"t":"set","p":"distance","pt":"msg","to":"$lookup(payload, mapping.distance)","tot":"jsonata"},{"t":"set","p":"normal_x","pt":"msg","to":"$lookup(payload, mapping.normal_x)","tot":"jsonata"},{"t":"set","p":"normal_y","pt":"msg","to":"$lookup(payload, mapping.normal_y)","tot":"jsonata"},{"t":"set","p":"normal_z","pt":"msg","to":"$lookup(payload, mapping.normal_z)","tot":"jsonata"},{"t":"set","p":"radius2","pt":"msg","to":"$lookup(payload, mapping.radius2)","tot":"jsonata"},{"t":"set","p":"x3","pt":"msg","to":"$lookup(payload, mapping.x3)","tot":"jsonata"},{"t":"set","p":"y3","pt":"msg","to":"$lookup(payload, mapping.y3)","tot":"jsonata"},{"t":"set","p":"z3","pt":"msg","to":"$lookup(payload, mapping.z3)","tot":"jsonata"},{"t":"set","p":"width_lower","pt":"msg","to":"$lookup(payload, mapping.width_lower)","tot":"jsonata"},{"t":"set","p":"width_upper","pt":"msg","to":"$lookup(payload, mapping.width_upper)","tot":"jsonata"},{"t":"set","p":"length_lower","pt":"msg","to":"$lookup(payload, mapping.length_lower)","tot":"jsonata"},{"t":"set","p":"length_upper","pt":"msg","to":"$lookup(payload, mapping.length_upper)","tot":"jsonata"},{"t":"set","p":"edge_radius","pt":"msg","to":"$lookup(payload, mapping.edge_radius)","tot":"jsonata"},{"t":"set","p":"angle","pt":"msg","to":"$lookup(payload, mapping.angle)","tot":"jsonata"},{"t":"set","p":"num_points","pt":"msg","to":"$lookup(payload, mapping.num_points)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":440,"wires":[["c89b1cf3.8ed8b"]]},{"id":"40c4aac2.219344","type":"template","z":"f7dd5695.c01598","name":"Plane actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <plane id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <length>{{length}}</length>\n                <width>{{width}}</width>\n                <orientation>{{orientation}}</orientation>\n            </geometry>\n            <result></result>\n        </plane>\n{{/isValid}}","output":"str","x":590,"y":380,"wires":[["c68f496b.f085a8"]]},{"id":"c68f496b.f085a8","type":"template","z":"f7dd5695.c01598","name":"Plane nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <plane id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <length>{{length}}</length>\n                <width>{{width}}</width>\n                <orientation>{{orientation}}</orientation>\n            </geometry>\n            <result></result>\n        </plane>\n{{/isValid}}","output":"str","x":840,"y":380,"wires":[["c68c47a0.751e98"]]},{"id":"93522995.db5938","type":"template","z":"f7dd5695.c01598","name":"Ellipse actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <ellipse id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                    <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                \t<pos1 x=\"{{x2}}\" y=\"{{y2}}\" z=\"{{z2}}\"></pos1>\n                \t<pos2 x=\"{{x3}}\" y=\"{{y3}}\" z=\"{{z3}}\"></pos2>\n                \t<dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                \t<normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                    <inner_radius>{{radius}}</inner_radius>\n                    <outer_radius>{{radius2}}</outer_radius>\n            </geometry>\n        </ellipse>\n{{/isValid}}","output":"str","x":590,"y":420,"wires":[["fcaa700d.390ac"]]},{"id":"fcaa700d.390ac","type":"template","z":"f7dd5695.c01598","name":"Ellipse nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <ellipse id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <pos1 x=\"{{x2}}\" y=\"{{y2}}\" z=\"{{z2}}\"></pos1>\n                <pos2 x=\"{{x3}}\" y=\"{{y3}}\" z=\"{{z3}}\"></pos2>\n                <dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <inner_radius>{{radius}}</inner_radius>\n                <outer_radius>{{radius2}}</outer_radius>\n            </geometry>\n            <result></result>\n        </ellipse>\n{{/isValid}}","output":"str","x":840,"y":420,"wires":[["c68c47a0.751e98"]]},{"id":"bdb2504c.00e47","type":"template","z":"f7dd5695.c01598","name":"Slotted Hole actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <slotted_hole id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <length>{{length}}</length>\n                <width>{{width}}</width>\n            </geometry>\n        </slotted_hole>\n{{/isValid}}","output":"str","x":610,"y":460,"wires":[["caa5473f.1bfc08"]]},{"id":"caa5473f.1bfc08","type":"template","z":"f7dd5695.c01598","name":"Slotted Hole nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <slotted_hole id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <length>{{length}}</length>\n                <width>{{width}}</width>\n            </geometry>\n            <result>\n                {{#width}}\n                <width checked=\"1\">\n                  <tolerance lower_limit=\"{{width_lower}}\" upper_limit=\"{{width_upper}}\"></tolerance>\n                  <nominal_scalar value=\"{{width}}\"></nominal_scalar>\n                </width>\n                {{/width}}\n                <x checked=\"1\">\n                    <tolerance lower_limit=\"{{x_lower}}\" upper_limit=\"{{x_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{x}}\"></nominal_scalar>\n                </x>\n                <y checked=\"1\">\n                    <tolerance lower_limit=\"{{y_lower}}\" upper_limit=\"{{y_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{y}}\"></nominal_scalar>\n                </y>\n                <z checked=\"1\">\n                    <tolerance lower_limit=\"{{z_lower}}\" upper_limit=\"{{z_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{z}}\"></nominal_scalar>\n                </z>\n              </result>\n        </slotted_hole>\n{{/isValid}}","output":"str","x":860,"y":460,"wires":[["c68c47a0.751e98"]]},{"id":"c89b1cf3.8ed8b","type":"change","z":"f7dd5695.c01598","name":"Set defaults","rules":[{"t":"set","p":"x_lower","pt":"msg","to":"$exists(x_lower) ? x_lower : -1","tot":"jsonata"},{"t":"set","p":"x_upper","pt":"msg","to":"$exists(x_upper) ? x_upper: 1","tot":"jsonata"},{"t":"set","p":"y_lower","pt":"msg","to":"$exists(y_lower) ? y_lower : -1","tot":"jsonata"},{"t":"set","p":"y_upper","pt":"msg","to":"$exists(y_upper) ? y_upper: 1","tot":"jsonata"},{"t":"set","p":"z_lower","pt":"msg","to":"$exists(z_lower) ? z_lower : -1","tot":"jsonata"},{"t":"set","p":"z_upper","pt":"msg","to":"$exists(z_upper) ? z_upper: 1","tot":"jsonata"},{"t":"set","p":"width_lower","pt":"msg","to":"$exists(width_lower) ? width_lower: -1","tot":"jsonata"},{"t":"set","p":"width_upper","pt":"msg","to":"$exists(width_upper) ? width_upper: 1","tot":"jsonata"},{"t":"set","p":"normal_x","pt":"msg","to":"$exists(normal_x) ? normal_x: 1","tot":"jsonata"},{"t":"set","p":"normal_y","pt":"msg","to":"$exists(normal_y) ? normal_y: 0","tot":"jsonata"},{"t":"set","p":"normal_z","pt":"msg","to":"$exists(normal_z) ? normal_z: 0","tot":"jsonata"},{"t":"set","p":"edge_radius","pt":"msg","to":"$exists(edge_radius) ? edge_radius: 0","tot":"jsonata"},{"t":"set","p":"diameter_lower","pt":"msg","to":"$exists(diameter_lower) ? diameter_lower: -1","tot":"jsonata"},{"t":"set","p":"diameter_upper","pt":"msg","to":"$exists(diameter_upper) ? diameter_upper: 1","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":520,"wires":[["2bae1ead.b9bae2"]]},{"id":"9dc86af7.5cff28","type":"template","z":"f7dd5695.c01598","name":"Rectangular Hole actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <rectangular_hole id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <length>{{length}}</length>\n                <width>{{width}}</width>\n                <edge_radius>{{edge_radius}}</edge_radius>\n            </geometry>\n        </rectangular_hole>\n{{/isValid}}","output":"str","x":630,"y":500,"wires":[["b7d71c64.53edb"]]},{"id":"b7d71c64.53edb","type":"template","z":"f7dd5695.c01598","name":"Rectangular Hole nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <rectangular_hole id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <length>{{length}}</length>\n                <width>{{width}}</width>\n                <edge_radius>{{edge_radius}}</edge_radius>\n            </geometry>\n            <result>\n                {{#width}}\n                <width checked=\"1\">\n                  <tolerance lower_limit=\"{{width_lower}}\" upper_limit=\"{{width_upper}}\"></tolerance>\n                  <nominal_scalar value=\"{{width}}\"></nominal_scalar>\n                </width>\n                {{/width}}\n                <x checked=\"1\">\n                    <tolerance lower_limit=\"{{x_lower}}\" upper_limit=\"{{x_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{x}}\"></nominal_scalar>\n                </x>\n                <y checked=\"1\">\n                    <tolerance lower_limit=\"{{y_lower}}\" upper_limit=\"{{y_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{y}}\"></nominal_scalar>\n                </y>\n                <z checked=\"1\">\n                    <tolerance lower_limit=\"{{z_lower}}\" upper_limit=\"{{z_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{z}}\"></nominal_scalar>\n                </z>\n              </result>\n        </rectangular_hole>\n{{/isValid}}","output":"str","x":870,"y":500,"wires":[["c68c47a0.751e98"]]},{"id":"9a8acae.3fa1838","type":"template","z":"f7dd5695.c01598","name":"Sphere actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <sphere id=\"{{elementId}}\" name=\"{{name}}\">\n              <state>ok</state>\n              <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <radius>{{radius}}</radius>\n              </geometry>\n              <result></result>\n        </sphere>\n{{/isValid}}","output":"str","x":600,"y":540,"wires":[["7c9ad7db.813728"]]},{"id":"7c9ad7db.813728","type":"template","z":"f7dd5695.c01598","name":"Sphere nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <sphere id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <radius>{{radius}}</radius>\n            </geometry>\n            <result>\n                <diameter checked=\"1\">\n                  <tolerance lower_limit=\"{{diameter_lower}}\" upper_limit=\"{{diameter_upper}}\"></tolerance>\n                  <nominal_scalar value=\"{{diameter}}\"></nominal_scalar>\n                </diameter>\n                \n                <x checked=\"1\">\n                    <tolerance lower_limit=\"{{x_lower}}\" upper_limit=\"{{x_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{x}}\"></nominal_scalar>\n                </x>\n                <y checked=\"1\">\n                    <tolerance lower_limit=\"{{y_lower}}\" upper_limit=\"{{y_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{y}}\"></nominal_scalar>\n                </y>\n                <z checked=\"1\">\n                    <tolerance lower_limit=\"{{z_lower}}\" upper_limit=\"{{z_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{z}}\"></nominal_scalar>\n                </z>\n              </result>\n        </sphere>\n{{/isValid}}","output":"str","x":840,"y":540,"wires":[["c68c47a0.751e98"]]},{"id":"a8825505.fe89f8","type":"template","z":"f7dd5695.c01598","name":"Cylinder actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <cylinder id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                \t<pos1 x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos1>\n                \t<pos2 x=\"{{x2}}\" y=\"{{y2}}\" z=\"{{z2}}\"></pos2>\n                \t<dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                \t<radius>{{radius}}</radius>\n                \t<length>{{length}}</length>\n            </geometry>\n        </cylinder >\n{{/isValid}}","output":"str","x":600,"y":580,"wires":[["5025f50e.8d431c"]]},{"id":"5025f50e.8d431c","type":"template","z":"f7dd5695.c01598","name":"Cylinder nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <cylinder id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                \t<pos1 x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos1>\n                \t<pos2 x=\"{{x2}}\" y=\"{{y2}}\" z=\"{{z2}}\"></pos2>\n                \t<dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                \t<radius>{{radius}}</radius>\n                \t<length>{{length}}</length>\n            </geometry>\n            <result>\n                <diameter checked=\"1\">\n                  <tolerance lower_limit=\"{{diameter_lower}}\" upper_limit=\"{{diameter_upper}}\"></tolerance>\n                  <nominal_scalar value=\"{{diameter}}\"></nominal_scalar>\n                </diameter>\n              </result>\n        </cylinder>\n{{/isValid}}","output":"str","x":850,"y":580,"wires":[["c68c47a0.751e98"]]},{"id":"153b0dac.70c4c2","type":"template","z":"f7dd5695.c01598","name":"Cone actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <cone id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                \t<pos1 x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos1>\n                \t<pos2 x=\"{{x2}}\" y=\"{{y2}}\" z=\"{{z2}}\"></pos2>\n                \t<dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                \t<radius1>{{radius}}</radius1>\n                \t<radius2>{{radius2}}</radius2>\n                \t<angle>{{angle}}</angle>\n            </geometry>\n        </cone >\n{{/isValid}}","output":"str","x":590,"y":620,"wires":[["6f9c9236.9581fc"]]},{"id":"6f9c9236.9581fc","type":"template","z":"f7dd5695.c01598","name":"Cone nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <cone id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                \t<pos1 x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos1>\n                \t<pos2 x=\"{{x2}}\" y=\"{{y2}}\" z=\"{{z2}}\"></pos2>\n                \t<dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                \t<radius1>{{radius}}</radius1>\n                \t<radius2>{{radius2}}</radius2>\n                \t<angle>{{angle}}</angle>\n            </geometry>\n            <result></result>\n        </cone>\n{{/isValid}}","output":"str","x":840,"y":620,"wires":[["c68c47a0.751e98"]]},{"id":"3481aa97.f1ab66","type":"template","z":"f7dd5695.c01598","name":"Polygon Hole actual","field":"payload.measured","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <polygon_hole id=\"{{elementId}}\" name=\"{{name}}\">\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <num_points>{{num_points}}</num_points>\n                <inner_radius>{{radius}}</inner_radius>\n            </geometry>\n        </polygon_hole>\n{{/isValid}}","output":"str","x":620,"y":660,"wires":[["81822ed3.55f2"]]},{"id":"81822ed3.55f2","type":"template","z":"f7dd5695.c01598","name":"Polygon Hole nominal","field":"payload.nominal","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{#isValid}}\n        <polygon_hole id=\"{{elementId}}0\" name=\"{{name}}\">\n            <actual>{{elementId}}</actual>\n            <state>ok</state>\n            <geometry>\n                <pos x=\"{{x}}\" y=\"{{y}}\" z=\"{{z}}\"></pos>\n                <dir x=\"{{dir_x}}\" y=\"{{dir_y}}\" z=\"{{dir_z}}\"></dir>\n                <normal x=\"{{normal_x}}\" y=\"{{normal_y}}\" z=\"{{normal_z}}\"></normal>\n                <num_points>{{num_points}}</num_points>\n                <inner_radius>{{radius}}</inner_radius>\n            </geometry>\n            <result>\n                <x checked=\"1\">\n                    <tolerance lower_limit=\"{{x_lower}}\" upper_limit=\"{{x_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{x}}\"></nominal_scalar>\n                </x>\n                <y checked=\"1\">\n                    <tolerance lower_limit=\"{{y_lower}}\" upper_limit=\"{{y_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{y}}\"></nominal_scalar>\n                </y>\n                <z checked=\"1\">\n                    <tolerance lower_limit=\"{{z_lower}}\" upper_limit=\"{{z_upper}}\"></tolerance>\n                    <nominal_scalar value=\"{{z}}\"></nominal_scalar>\n                </z>\n              </result>\n        </polygon_hole>\n{{/isValid}}","output":"str","x":860,"y":660,"wires":[["c68c47a0.751e98"]]},{"id":"64d8b16.886585","type":"fs-ops-dir","z":"f7dd5695.c01598","name":"List CSV files in dir","path":"dirPath","pathType":"msg","filter":"*.csv","filterType":"str","dir":"payload","dirType":"msg","x":290,"y":120,"wires":[["f13ce5e1.c1b1e8"]]},{"id":"f13ce5e1.c1b1e8","type":"split","z":"f7dd5695.c01598","name":"Split files","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":460,"y":120,"wires":[["cecf1bbc.577608"]]},{"id":"cecf1bbc.577608","type":"change","z":"f7dd5695.c01598","name":"Set part settings","rules":[{"t":"set","p":"filename","pt":"msg","to":"$join([dirPath,payload], '/')\t","tot":"jsonata"},{"t":"delete","p":"parts","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":120,"wires":[["d5695b04.0654c8"]]},{"id":"4aee38d3.c6c228","type":"change","z":"f7dd5695.c01598","name":"XML file name","rules":[{"t":"set","p":"filename","pt":"msg","to":"$replace(filename, '.csv', '.xml')","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1310,"y":500,"wires":[["48b211f0.ee47f"]]}]
Created 6 years, 4 months ago
Rating: 4 1
  • change (x4)
  • csv (x1)
  • file (x1)
  • file in (x1)
  • join (x1)
  • split (x2)
  • switch (x1)
  • template (x25)
  • fs-ops-dir (x1)
  • GOM
  • XML
  • measurement
  • CSV
  • metrology
  • import
  • inspection
  • characteristic
  • feature
  • part
