online.wonderware.com REST api in json format
node-red-to-online.wonderware.com
This is a node-red example of sending data to online.wonderware.com's REST API using the JSON format.
It is an intentionnally simple example (without caching, queueing, buffering, store-forward, etc.).
Note: the below image doesn't show at flows.nodered.org nor the does the "view at github" link in the upper right corner because it somehow created a gist.github.com instead of regular github entry and those don't seem to be able to host screen shots.
If you want to see the below screenshot view it on: https://github.com/jtmoderate876/node-red-to-online.wonderware.com
screen shot of example
[{"id":"bc6012ce.56132","type":"tab","label":"Wonderware Simple","disabled":false,"info":"A simplified version connecting data to\nonline.wonderware.com\n\nThis version writes data as it is received and\ndoesnt' have the caching and remote timestamp\nfeatures."},{"id":"1c7fc5bb.ba3d6a","type":"comment","z":"bc6012ce.56132","name":"Sample flow to send data to online.wonderware.com with emphasis on SIMPLICITY","info":"This will assume a topic name is a tagname\nand msg.payload is the value. For example:\nmsg.topic = \"tapia.home.familyroom.temperature\"\nmsg.value = 72.5\n\n\n/*\nWonderware example from online.wonderware.com\n{\n  \"data\": [\n    {\n      \"dateTime\": \"2017-03-20T12:21:12.199Z\",\n      \"Reactor3.Level\": 1.51860072870498,\n      \"Reactor3.Temp\": 27.1360543141452,\n      \"Reactor3.InletValve\": 0,\n      \"Reactor3.Step\": 7,\n      \"Line3.Units\": 1518,\n      \"Line3.Product\": \"BRN\"\n    }\n  ]\n}\n*/\n","x":310,"y":40,"wires":[]},{"id":"54df6fdf.75846","type":"credentials","z":"bc6012ce.56132","name":"Wonderware Bearer Token","props":[{"value":"Authorization","type":"msg"}],"x":300,"y":200,"wires":[["f00d388d.8e2c58"]]},{"id":"ec9a140f.a03568","type":"inject","z":"bc6012ce.56132","name":"","topic":"my.temperature","payload":"11.1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":280,"wires":[["8470175.b6ee8e8"]]},{"id":"bf33b6e0.861318","type":"inject","z":"bc6012ce.56132","name":"","topic":"my.temperature","payload":"22.2","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":320,"wires":[["8470175.b6ee8e8"]]},{"id":"794cdbc9.120694","type":"function","z":"bc6012ce.56132","name":"Wonderware JSON format","func":"/*\ninput message should contain:\nmsg.timestamp ie 1514764800000 is an epoch milliseconds timestamp representing 2018.01.01. at 00:00:00.000\n (if msg.timestamp does not exist then \"now\" will be used)\n for simplicity, we assumed a single value payload (not a multivariable payload object):\n    msg.payload ie 72.1 or any string or number representing the value for the topic\n    msg.topic ie diningroom/temperature\n*/\n//use timestamp if it exists otherwise default to now\n// this works and is efficient but I'm leaning toward \"non-function\", flow-based solutions\nif ((typeof msg.timestamp !== 'undefined')){dtstring = new Date(msg.timestamp).toISOString();} \nelse {dtstring = new Date().toISOString();}\n\nvar obj = {};\nobj[\"dateTime\"] = dtstring;\nobj[msg.topic] = msg.payload;\n\nvar data = {\"data\":[]};\ndata.data.push(obj);\nmsg.payload=data;\n//msg.payload = JSON.stringify( {\"data\":[{}]},null,\"\\t\");\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":620,"y":140,"wires":[["9fde961b.618f58"]]},{"id":"f00d388d.8e2c58","type":"function","z":"bc6012ce.56132","name":"prepare htttp","func":"/* Example of syntax (replace token with real one):\nmsg.headers = {\n    \"Authorization\" : \"Bearer aThisIsMyFakeTokenYoursWillBeLonger-AjsTIEvRKKQ\",\n    \"Content-type\" : \"application/json\"\n    };\nmsg.url = \"https://online.wonderware.com/apis/upload/datasource\";\nmsg.method = \"POST\";\n*/\n\nmsg.headers = {\n    \"Content-type\" : \"application/json\"\n};\nmsg.url = \"https://online.wonderware.com/apis/upload/datasource\";\nmsg.method = \"POST\";\n\n//move Athorization inside headers:\nmsg.headers.Authorization = msg.Authorization;  //copy Authorization to be under headers\ndelete msg.Authorization;                       // and remove from old location\nreturn msg;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":510,"y":200,"wires":[["486b4641.981d08"]]},{"id":"486b4641.981d08","type":"http request","z":"bc6012ce.56132","name":"","method":"use","ret":"txt","url":"","tls":"","x":670,"y":200,"wires":[["4e361617.8aea98"]]},{"id":"8470175.b6ee8e8","type":"switch","z":"bc6012ce.56132","name":"","property":"timestamp","propertyType":"msg","rules":[{"t":"null"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":110,"y":140,"wires":[["d66335f2.9a7498"],["2b09b6c9.f641fa"]]},{"id":"d66335f2.9a7498","type":"change","z":"bc6012ce.56132","name":"","rules":[{"t":"set","p":"timestamp","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":120,"wires":[["2b09b6c9.f641fa"]]},{"id":"2b09b6c9.f641fa","type":"function","z":"bc6012ce.56132","name":"merge","func":"\nreturn msg;","outputs":1,"noerr":0,"x":430,"y":140,"wires":[["794cdbc9.120694"]]},{"id":"6829b272.75473c","type":"comment","z":"bc6012ce.56132","name":"XXXXXXXX  add a timestamp if there isn't one XXXXXXXX","info":"","x":270,"y":80,"wires":[]},{"id":"4e361617.8aea98","type":"debug","z":"bc6012ce.56132","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":810,"y":200,"wires":[]},{"id":"9fde961b.618f58","type":"json","z":"bc6012ce.56132","name":"","property":"payload","action":"","pretty":false,"x":810,"y":140,"wires":[["54df6fdf.75846"]]},{"id":"ea4862fa.ba67b","type":"comment","z":"bc6012ce.56132","name":"JSON OBJ > JSON STRING","info":"","x":740,"y":100,"wires":[]}]
Created 8 years, 6 months ago
Updated 8 years ago
  • change (x1)
  • comment (x3)
  • function (x3)
  • http request (x1)
  • inject (x2)
  • json (x1)
  • switch (x1)
  • wonderware
  • online
  • insight
  • aveva
  • json
  • rest
  • api
  • historian
