smart pill box
1.run every 10 minutes -> read the schedule file -> convert to js object -> check if you need to take a pill in the next 10 minutes -> limit to 1 msg per 10 minutes -> send the day code -> mqtt publish to the led feed.
2.get the day of the week -> if saturday HTTP call to IFTT to send SMS to the user to fill the pill box.
  1. listen on mqtt humidity feed -> limit for one msg every 3 hours -> add the humidity to the IFTTT url -> call IFTTT to send SMS.
    1. listen on mqtt temperature feed -> limit for one msg every 3 hours -> call IFTTT to send SMS.
  2. Listen to mqtt forgot feed -> call IFTTT to send SMS.
[{"id":"68088a3e.3d3044","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"e8ec4ae.661a8b8","type":"mqtt-broker","z":"","name":"web","broker":"io.adafruit.com","port":"1883","tls":"","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"57f7b6f0.7f9648","type":"mqtt-broker","z":"","name":"local","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"870cd0fe.73dce","type":"ui_base","theme":{"name":"theme-light","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"Lucida Sans Unicode,Lucida Grande,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#0094CE","value":"#0094CE","edited":false},"page-titlebar-backgroundColor":{"value":"#0094CE","edited":false},"page-backgroundColor":{"value":"#fafafa","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#1bbfff","edited":false},"group-borderColor":{"value":"#ffffff","edited":false},"group-backgroundColor":{"value":"#ffffff","edited":false},"widget-textColor":{"value":"#111111","edited":false},"widget-backgroundColor":{"value":"#0094ce","edited":false},"widget-borderColor":{"value":"#ffffff","edited":false},"base-font":{"value":"Lucida Sans Unicode,Lucida Grande,sans-serif"}}},"site":{"name":"Smart Pill Box","hideToolbar":"false","allowSwipe":"true","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":375,"sy":100,"gx":6,"gy":6,"cx":2,"cy":2,"px":1,"py":1}}},{"id":"6408e139.2836b","type":"ui_group","z":"","name":"Home","tab":"e603b9fb.51f728","order":1,"disp":true,"width":"6","collapse":false},{"id":"e603b9fb.51f728","type":"ui_tab","z":"","name":"Home","icon":"dashboard","order":1},{"id":"d21495a0.3e9828","type":"ui_group","z":"","name":"Group 1","tab":"","order":1,"disp":true,"width":"6","collapse":false},{"id":"652078c9.37d018","type":"ui_group","name":"Group 1","tab":"","order":1,"disp":true,"width":6},{"id":"321228f7.344b78","type":"ui_group","name":"Group 2","tab":"","order":2,"disp":true,"width":6},{"id":"32001fa5.5eb03","type":"function","z":"68088a3e.3d3044","name":"getDayOfWeek","func":"var date = new Date();\nmsg.payload = date.getDay();\nreturn msg;","outputs":1,"noerr":0,"x":538,"y":379,"wires":[["193d8c2c.c2f944"]]},{"id":"63445a2.a89f6a4","type":"mqtt out","z":"68088a3e.3d3044","name":"TURNONLED","topic":"IFTT_USER/feeds/smartmed.led","qos":"0","retain":"","broker":"e8ec4ae.661a8b8","x":446,"y":622,"wires":[]},{"id":"8cadd440.faffe8","type":"file in","z":"68088a3e.3d3044","name":"Read TimesFiles","filename":"PATH_TO_FILE","format":"utf8","chunk":false,"sendError":false,"x":241,"y":426,"wires":[["4070f70.383b608"]]},{"id":"967bd7c0.9a9008","type":"mqtt in","z":"68088a3e.3d3044","name":"MQQT-Temperature","topic":"IFTT_USER/feeds/smartmed.temperature","qos":"0","broker":"e8ec4ae.661a8b8","x":1056,"y":273,"wires":[["58315669.ba8298"]]},{"id":"b4754fcf.7cc7f","type":"http request","z":"68088a3e.3d3044","name":"SendHotSMS","method":"GET","ret":"txt","url":"https://maker.ifttt.com/trigger/TEMP_EVENT/with/key/IFFT_KEY","tls":"","x":1200,"y":346,"wires":[[]]},{"id":"58315669.ba8298","type":"delay","z":"68088a3e.3d3044","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"3","rateUnits":"hour","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1117,"y":307,"wires":[["b4754fcf.7cc7f"]]},{"id":"193d8c2c.c2f944","type":"switch","z":"68088a3e.3d3044","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"7","vt":"jsonata"}],"checkall":"false","repair":false,"outputs":1,"x":562,"y":421,"wires":[["ea771cf6.356e8"]]},{"id":"ea771cf6.356e8","type":"http request","z":"68088a3e.3d3044","name":"SendFillPillsSMS","method":"GET","ret":"txt","url":"https://maker.ifttt.com/trigger/TEMP_EVENT/with/key/IFFT_KEY","tls":"","x":617,"y":454,"wires":[[]]},{"id":"55061ceb.f99484","type":"mqtt in","z":"68088a3e.3d3044","name":"MQQT-Humidity","topic":"IFTT_USER/feeds/smartmed.humidity","qos":"0","broker":"e8ec4ae.661a8b8","x":730,"y":294,"wires":[["4c87e236.0d2f4c"]]},{"id":"83f40232.7d6a1","type":"http request","z":"68088a3e.3d3044","name":"SendHumiditySMS","method":"GET","ret":"txt","url":"","tls":"","x":954,"y":414,"wires":[[]]},{"id":"4c87e236.0d2f4c","type":"delay","z":"68088a3e.3d3044","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"3","rateUnits":"hour","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":802,"y":334,"wires":[["b032b4fb.430bd8"]]},{"id":"b032b4fb.430bd8","type":"function","z":"68088a3e.3d3044","name":"AddVarToURL","func":"let humidity_level = msg.payload\nmsg.payload = {};\nmsg.url = \"https://maker.ifttt.com/trigger/HUMIDITY_EVENT/with/key/IFFT_KEY?value1=\";\nmsg.url += humidity_level + \"%\";\nmsg.method = \"GET\";\nreturn msg;","outputs":1,"noerr":0,"x":881,"y":372,"wires":[["83f40232.7d6a1"]]},{"id":"ec9ec93b.1f71d8","type":"inject","z":"68088a3e.3d3044","name":"Check Every 10 Minutes","topic":"","payload":"true","payloadType":"bool","repeat":"600","crontab":"","once":false,"onceDelay":0.1,"x":225,"y":389,"wires":[["8cadd440.faffe8"]]},{"id":"4070f70.383b608","type":"json","z":"68088a3e.3d3044","name":"","property":"payload","action":"","pretty":false,"x":269,"y":456,"wires":[["40bc379a.1cf7c8"]]},{"id":"40bc379a.1cf7c8","type":"function","z":"68088a3e.3d3044","name":"getTimeForToday","func":"var date = new Date();\nvar today = date.getDay();\nvar todayTimes = msg.payload[today];\nvar shouldTurnOnLed = false;\ntodayTimes.forEach(time =>{\n    var pillTime = new Date('1970-01-01T' + time);\n    var nowMinutes = (date.getHours() * 60) + date.getMinutes();\n    var pillMinutes =  (pillTime.getHours() * 60) + pillTime.getMinutes();\n    \n    if(nowMinutes - pillMinutes <= 10){\n        shouldTurnOnLed = true;\n    }\n});\n\nmsg.payload = {};\nmsg.payload['turnOnLed'] = shouldTurnOnLed;\nmsg.payload['day'] = today;\nreturn msg;","outputs":1,"noerr":0,"x":305,"y":489,"wires":[["5f1e8832.187b58"]]},{"id":"5f1e8832.187b58","type":"delay","z":"68088a3e.3d3044","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"10","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":339,"y":517,"wires":[["8e2a9758.8c6b28"]]},{"id":"8e2a9758.8c6b28","type":"switch","z":"68088a3e.3d3044","name":"","property":"payload.turnOnLed","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":362,"y":552,"wires":[["26e91df9.e58702"]]},{"id":"26e91df9.e58702","type":"function","z":"68088a3e.3d3044","name":"dispatchDay","func":"\nmsg.payload = msg.payload.day + \"\";\nreturn msg;","outputs":1,"noerr":0,"x":382,"y":585,"wires":[["63445a2.a89f6a4"]]},{"id":"3c000bbc.612834","type":"mqtt in","z":"68088a3e.3d3044","name":"MQQT-ForgotToTakePills","topic":"IFTT_USER/feeds/smartmed.forgot","qos":"0","broker":"e8ec4ae.661a8b8","x":1196,"y":203,"wires":[["223c19d5.c65476"]]},{"id":"223c19d5.c65476","type":"http request","z":"68088a3e.3d3044","name":"SendHotSMS","method":"GET","ret":"txt","url":"https://maker.ifttt.com/trigger/FORGOT_PILLST/with/key/IFFT_KEY","tls":"","x":1293,"y":239,"wires":[[]]}]
Created 7 years, 4 months ago
  • delay (x3)
  • file in (x1)
  • function (x4)
  • http request (x4)
  • json (x1)
  • mqtt in (x3)
  • mqtt out (x1)
  • mqtt-broker (x2)
  • switch (x2)
