Customised Apex Chart in Dashboard
Apex Chart in Dashboard using Ui_template Node
[{"id":"94892351e8e1ca4f","type":"ui_template","z":"f0ae706f0b39513f","g":"a511ccb853b13640","group":"a2d9ac75438797b7","name":"Apex-Chart with Multiple Y Axis","order":1,"width":30,"height":8,"format":"<script src=\"https://cdn.jsdelivr.net/npm/apexcharts\"></script>\n<div id=\"chart\"></div>\n\n<script>\n\n(function(scope)\n                {scope.$watch('msg', function(msg)\n                    {if (msg){var options =\n                        {series: msg.payload,\n                        chart:{type: 'area',stacked: false,height: 355,background:'#000',zoom:\n                                {type: 'x',enabled: true,autoScaleYaxis: true},\n                            toolbar:{autoSelected: 'zoom'}},\n                        dataLabels: {enabled: true,enabledOnSeries: [0,1],formatter: function (val, opts) {return val},},\n                        markers:{size: 2,},\n                        theme: {mode: 'dark'},\n                        colors: ['#FA2E2E', '#FF9800', '#546E7A', '#E91E63', '#FF9800'],\n                \n                title: {text: msg.charttitle,align: 'center',margin: 10,offsetX: 0,offsetY: -10,floating: false,style: {fontSize:30,fontWeight: 'bold',fontFamily: undefined,color: 'yellow'},},\n                stroke:{width: [8,0,2],curve: ['smooth', 'smooth', 'smooth']},\n                yaxis:[\n                {labels:{formatter: function (val){return val.toFixed(1);},},title: { text: \"Title-1\", style: {color: \"#FA2E2E\"}},},\n                {labels:{formatter: function (val){return val.toFixed(0);},},title: { text: \"Title-2\", style: {color: \"#FF9800\"}},},\n                {labels:{formatter: function (val){return val.toFixed(1);},},title: { text: \"Title-3\", style: {color: \"#546E7A\"}},},],\n\n                xaxis: {lines: {show: false,},type: 'gradient',datetimeUTC: false,labels: {format: 'dd/MMM HH:mm',},},\n                tooltip: {enabled: true,style: {fontSize: '12px',fontFamily: undefined},x: {show: true,format: 'dd/MMM HH:mm',},\n                row: {colors: undefined,opacity: 0.5},\n                column: {colors: undefined,opacity: 0.5},\n                padding: {top: 0,right: 0,bottom: 0,left: 0},},\n                    grid: {show: true,borderColor: '#ffffff',strokeDashArray: 0,position: 'back',\n                    xaxis: {lines: {show: false}},   \n                    yaxis: {lines: {show: false}},\n                    row: {colors: undefined,opacity: 0.5},  \n                    column: {colors: undefined,opacity: 0.5},  \n                    padding: {top: 0,right: 0,bottom: 0,left: 0},}};\n\n\nsetTimeout( ()=> {if(scope.chart){scope.chart.updateOptions(options)}else {scope.chart = new ApexCharts(document.querySelector(\"#chart\"), options);scope.chart.render();}}, 1000)}});})(scope);\n\n</script>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","className":"","x":760,"y":120,"wires":[[]]},{"id":"8c9886312704c689","type":"inject","z":"f0ae706f0b39513f","g":"a511ccb853b13640","name":"","props":[{"p":"payload"},{"p":"charttitle","v":"Title Goes here","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"name\":\"Yield\",\"type\":\"line\",\"data\":[{\"x\":\"2022-05\",\"y\":97.92},{\"x\":\"2022-06\",\"y\":98.52},{\"x\":\"2022-07\",\"y\":98.88},{\"x\":\"2022-08\",\"y\":98.66},{\"x\":\"2022-10\",\"y\":99.47},{\"x\":\"2022-11\",\"y\":98.32},{\"x\":\"2022-12\",\"y\":98.89},{\"x\":\"2023-01\",\"y\":98.7},{\"x\":\"2023-02\",\"y\":99.91},{\"x\":\"2023-03\",\"y\":98.72},{\"x\":\"2023-04\",\"y\":96.91},{\"x\":\"2023-05\",\"y\":96.2},{\"x\":\"2023-06\",\"y\":100.1},{\"x\":\"2023-07\",\"y\":98.83}]},{\"name\":\"Total Cases\",\"type\":\"column\",\"data\":[{\"x\":\"2022-05\",\"y\":6993},{\"x\":\"2022-06\",\"y\":8585},{\"x\":\"2022-07\",\"y\":9532},{\"x\":\"2022-08\",\"y\":8062},{\"x\":\"2022-10\",\"y\":7761},{\"x\":\"2022-11\",\"y\":7778},{\"x\":\"2022-12\",\"y\":4740},{\"x\":\"2023-01\",\"y\":6763},{\"x\":\"2023-02\",\"y\":5095},{\"x\":\"2023-03\",\"y\":8025},{\"x\":\"2023-04\",\"y\":6913},{\"x\":\"2023-05\",\"y\":5207},{\"x\":\"2023-06\",\"y\":6297},{\"x\":\"2023-07\",\"y\":8582}]},{\"name\":\"Loss Qty\",\"type\":\"area\",\"data\":[{\"x\":\"2022-05\",\"y\":-1602.6},{\"x\":\"2022-06\",\"y\":-1391},{\"x\":\"2022-07\",\"y\":-1162.4},{\"x\":\"2022-08\",\"y\":-1180.4},{\"x\":\"2022-10\",\"y\":-443.2},{\"x\":\"2022-11\",\"y\":-1435.6},{\"x\":\"2022-12\",\"y\":-572},{\"x\":\"2023-01\",\"y\":-959.6},{\"x\":\"2023-02\",\"y\":-49},{\"x\":\"2023-03\",\"y\":-1126},{\"x\":\"2023-04\",\"y\":-2381.83},{\"x\":\"2023-05\",\"y\":-2218.92},{\"x\":\"2023-06\",\"y\":65.26},{\"x\":\"2023-07\",\"y\":-1098.57}]}]","payloadType":"json","x":280,"y":240,"wires":[["94892351e8e1ca4f"]]},{"id":"7ec1374684484253","type":"ui_button","z":"f0ae706f0b39513f","g":"a511ccb853b13640","name":"","group":"3c4ffa4110cd59c8","order":1,"width":"3","height":"1","passthru":false,"label":"Clear","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"[]","payloadType":"json","topic":"topic","topicType":"msg","x":260,"y":60,"wires":[["94892351e8e1ca4f"]]},{"id":"9747d50d74971dc9","type":"change","z":"f0ae706f0b39513f","g":"a511ccb853b13640","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{\"name\":\"Series-1\",\"type\":\"line\",\"data\":[{\"x\":\"2022-05\",\"y\":97.92},{\"x\":\"2022-06\",\"y\":98.52},{\"x\":\"2022-07\",\"y\":98.88},{\"x\":\"2022-08\",\"y\":98.66},{\"x\":\"2022-10\",\"y\":99.47},{\"x\":\"2022-11\",\"y\":98.32},{\"x\":\"2022-12\",\"y\":98.89},{\"x\":\"2023-01\",\"y\":98.7},{\"x\":\"2023-02\",\"y\":99.91},{\"x\":\"2023-03\",\"y\":98.72},{\"x\":\"2023-04\",\"y\":96.91},{\"x\":\"2023-05\",\"y\":96.2},{\"x\":\"2023-06\",\"y\":100.1},{\"x\":\"2023-07\",\"y\":98.83}]},{\"name\":\"Series-2\",\"type\":\"column\",\"data\":[{\"x\":\"2022-05\",\"y\":6993},{\"x\":\"2022-06\",\"y\":8585},{\"x\":\"2022-07\",\"y\":9532},{\"x\":\"2022-08\",\"y\":8062},{\"x\":\"2022-10\",\"y\":7761},{\"x\":\"2022-11\",\"y\":7778},{\"x\":\"2022-12\",\"y\":4740},{\"x\":\"2023-01\",\"y\":6763},{\"x\":\"2023-02\",\"y\":5095},{\"x\":\"2023-03\",\"y\":8025},{\"x\":\"2023-04\",\"y\":6913},{\"x\":\"2023-05\",\"y\":5207},{\"x\":\"2023-06\",\"y\":6297},{\"x\":\"2023-07\",\"y\":8582}]},{\"name\":\"Series-3\",\"type\":\"area\",\"data\":[{\"x\":\"2022-05\",\"y\":-1602.6},{\"x\":\"2022-06\",\"y\":-1391},{\"x\":\"2022-07\",\"y\":-1162.4},{\"x\":\"2022-08\",\"y\":-1180.4},{\"x\":\"2022-10\",\"y\":-443.2},{\"x\":\"2022-11\",\"y\":-1435.6},{\"x\":\"2022-12\",\"y\":-572},{\"x\":\"2023-01\",\"y\":-959.6},{\"x\":\"2023-02\",\"y\":-49},{\"x\":\"2023-03\",\"y\":-1126},{\"x\":\"2023-04\",\"y\":-2381.83},{\"x\":\"2023-05\",\"y\":-2218.92},{\"x\":\"2023-06\",\"y\":65.26},{\"x\":\"2023-07\",\"y\":-1098.57}]}]","tot":"json"},{"t":"set","p":"charttitle","pt":"msg","to":"Place Chart Title Here","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":120,"wires":[["94892351e8e1ca4f"]]},{"id":"dae53b72edc705e4","type":"ui_button","z":"f0ae706f0b39513f","g":"a511ccb853b13640","name":"","group":"3c4ffa4110cd59c8","order":1,"width":"3","height":"1","passthru":false,"label":"Refresh","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":270,"y":120,"wires":[["9747d50d74971dc9"]]},{"id":"a2d9ac75438797b7","type":"ui_group","name":"CHART","tab":"0a734ef04f43c77a","order":2,"disp":false,"width":"30","collapse":false,"className":""},{"id":"3c4ffa4110cd59c8","type":"ui_group","name":"VARIABLES","tab":"0a734ef04f43c77a","order":1,"disp":false,"width":"30","collapse":false,"className":""},{"id":"0a734ef04f43c77a","type":"ui_tab","name":"APEX","icon":"dashboard","order":16,"disabled":false,"hidden":false}]
Collection Info
Created 1 year, 9 months ago
  • change (x1)
  • ui_button (x2)
  • ui_group (x2)
  • ui_template (x1)
  • Apex
  • ui_template
  • dashboard
  • charts
  • multiple_axis
