Lyngdorf IP Control
Add Lyngdorf IP address to TCP Out.
[{"id":"5966d0f0d467ef9e","type":"tab","label":"Flow 3","disabled":false,"info":"","env":[]},{"id":"af647ef6a355fd42","type":"ha-button","z":"5966d0f0d467ef9e","name":"Lyngdorf Volume Up","version":0,"debugenabled":false,"outputs":1,"entityConfig":"5d910a745be198d1","outputProperties":[{"property":"payload","propertyType":"msg","value":"!VOL+","valueType":"str"}],"x":230,"y":320,"wires":[["f061fe52ab293768"]]},{"id":"2a1c7b26c6c65418","type":"tcp out","z":"5966d0f0d467ef9e","name":"Lyngdorf MP-60","host":"","port":"84","beserver":"client","base64":false,"end":false,"tls":"","x":1000,"y":660,"wires":[]},{"id":"b605cd96eee3d5ef","type":"ha-button","z":"5966d0f0d467ef9e","name":"Lyngdorf Volume Down","version":0,"debugenabled":false,"outputs":1,"entityConfig":"ee4e354c92509e6e","outputProperties":[{"property":"payload","propertyType":"msg","value":"!VOL-","valueType":"str"}],"x":240,"y":360,"wires":[["f061fe52ab293768"]]},{"id":"fb17d81301ecf0de","type":"ha-button","z":"5966d0f0d467ef9e","name":"Lyngdorf Mute","version":0,"debugenabled":false,"outputs":1,"entityConfig":"e1a046f661657c30","outputProperties":[{"property":"payload","propertyType":"msg","value":"!MUTE","valueType":"str"}],"x":220,"y":400,"wires":[["f061fe52ab293768"]]},{"id":"4e0e8c6776f7c06d","type":"ha-button","z":"5966d0f0d467ef9e","name":"Lyngdorf On","version":0,"debugenabled":false,"outputs":1,"entityConfig":"3ffc2d92acd7c555","outputProperties":[{"property":"payload","propertyType":"msg","value":"!POWERONMAIN","valueType":"str"}],"x":210,"y":460,"wires":[["f061fe52ab293768"]]},{"id":"3a864e4c724ed357","type":"ha-button","z":"5966d0f0d467ef9e","name":"Lyngdorf Off","version":0,"debugenabled":false,"outputs":1,"entityConfig":"e2644e34ed8d51d2","outputProperties":[{"property":"payload","propertyType":"msg","value":"!POWEROFFMAIN","valueType":"str"}],"x":210,"y":500,"wires":[["f061fe52ab293768"]]},{"id":"1980c9d47c0e67d4","type":"ha-button","z":"5966d0f0d467ef9e","name":"HDMI 1","version":0,"debugenabled":false,"outputs":1,"entityConfig":"dfed4cefe2a8c9a6","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(0)","valueType":"str"}],"x":190,"y":680,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"97772c5a4098a0bb","type":"ha-button","z":"5966d0f0d467ef9e","name":"HDMI 2","version":0,"debugenabled":false,"outputs":1,"entityConfig":"38044f8605db3665","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(1)","valueType":"str"}],"x":190,"y":720,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"952fa744b70c7a5a","type":"ha-button","z":"5966d0f0d467ef9e","name":"HDMI 3","version":0,"debugenabled":false,"outputs":1,"entityConfig":"fe10b5e114030842","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(2)","valueType":"str"}],"x":190,"y":760,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"086a4bcf7a5deb83","type":"ha-button","z":"5966d0f0d467ef9e","name":"HDMI 4","version":0,"debugenabled":false,"outputs":1,"entityConfig":"04cf31179b8df516","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(3)","valueType":"str"}],"x":190,"y":800,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"6c5a87c535d34c59","type":"ha-button","z":"5966d0f0d467ef9e","name":"Streaming","version":0,"debugenabled":false,"outputs":1,"entityConfig":"c0cbfe004dac2190","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(5)","valueType":"str"}],"x":200,"y":1360,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"f061fe52ab293768","type":"function","z":"5966d0f0d467ef9e","name":"Carriage Return","func":"//Adds mandatory carriage return for each command\nmsg.payload = msg.payload + \"\\r\";\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":560,"wires":[["2a1c7b26c6c65418"]]},{"id":"559d19ceafe5f1b1","type":"delay","z":"5966d0f0d467ef9e","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":580,"y":1040,"wires":[["d44245cb4878f640"]]},{"id":"d44245cb4878f640","type":"function","z":"5966d0f0d467ef9e","name":"Set Volume","func":"//Sets a specific volume for each source\n//Format: XXX = XX.X (ex: -395 = -39.5)\nif (msg.payload == \"!SRC(0)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(1)\") { \n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(2)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(3)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(4)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(5)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(6)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(7)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(8)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(9)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(10)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(11)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(12)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(13)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(14)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse if (msg.payload == \"!SRC(15)\") {\n    msg.payload = \"!VOL(-400)\" + \"\\r\";\n}\nelse {\n    msg.payload = \"!VOL(-350)\" +\"\\r\";\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":760,"wires":[["2a1c7b26c6c65418"]]},{"id":"5db262adbca509e1","type":"ha-button","z":"5966d0f0d467ef9e","name":"Arrow Down","version":0,"debugenabled":false,"outputs":1,"entityConfig":"1b7da7993cd1204e","outputProperties":[{"property":"payload","propertyType":"msg","value":"!DIRD","valueType":"str"}],"x":470,"y":20,"wires":[["f061fe52ab293768"]]},{"id":"d440d5ee90834318","type":"ha-button","z":"5966d0f0d467ef9e","name":"Arrow Left","version":0,"debugenabled":false,"outputs":1,"entityConfig":"08078337bd6dfdfb","outputProperties":[{"property":"payload","propertyType":"msg","value":"!DIRL","valueType":"str"}],"x":460,"y":60,"wires":[["f061fe52ab293768"]]},{"id":"5b6494f1bf671baf","type":"ha-button","z":"5966d0f0d467ef9e","name":"Arrow Right","version":0,"debugenabled":false,"outputs":1,"entityConfig":"9fab8566cbb406e0","outputProperties":[{"property":"payload","propertyType":"msg","value":"!DIRR","valueType":"str"}],"x":470,"y":100,"wires":[["f061fe52ab293768"]]},{"id":"5687e6b75042dd91","type":"ha-button","z":"5966d0f0d467ef9e","name":"Arrow Up","version":0,"debugenabled":false,"outputs":1,"entityConfig":"b2e4a5476c3d00a9","outputProperties":[{"property":"payload","propertyType":"msg","value":"!DIRU","valueType":"str"}],"x":460,"y":140,"wires":[["f061fe52ab293768"]]},{"id":"70e2a1af3ed1ff2f","type":"ha-button","z":"5966d0f0d467ef9e","name":"Enter","version":0,"debugenabled":false,"outputs":1,"entityConfig":"6eeef5d78e618a37","outputProperties":[{"property":"payload","propertyType":"msg","value":"!ENTER","valueType":"str"}],"x":450,"y":200,"wires":[["f061fe52ab293768"]]},{"id":"ef0de4cce3c8a3ad","type":"ha-button","z":"5966d0f0d467ef9e","name":"Exit","version":0,"debugenabled":false,"outputs":1,"entityConfig":"8f41e83dcc637e1a","outputProperties":[{"property":"payload","propertyType":"msg","value":"!EXIT","valueType":"str"}],"x":450,"y":240,"wires":[["f061fe52ab293768"]]},{"id":"7c7f92fc91e7a380","type":"ha-button","z":"5966d0f0d467ef9e","name":"Info","version":0,"debugenabled":false,"outputs":1,"entityConfig":"b22ab5f0cd5a5023","outputProperties":[{"property":"payload","propertyType":"msg","value":"!INFO","valueType":"str"}],"x":450,"y":280,"wires":[["f061fe52ab293768"]]},{"id":"0e97edd185abb8a9","type":"ha-button","z":"5966d0f0d467ef9e","name":"Menu","version":0,"debugenabled":false,"outputs":1,"entityConfig":"ad29f2765f870ceb","outputProperties":[{"property":"payload","propertyType":"msg","value":"!MENU","valueType":"str"}],"x":450,"y":320,"wires":[["f061fe52ab293768"]]},{"id":"2dab68cab39d05a6","type":"ha-button","z":"5966d0f0d467ef9e","name":"Setup","version":0,"debugenabled":false,"outputs":1,"entityConfig":"fb1657b36354e062","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SETUP","valueType":"str"}],"x":450,"y":360,"wires":[["f061fe52ab293768"]]},{"id":"65d6e6b3cdb87b68","type":"ha-button","z":"5966d0f0d467ef9e","name":"HDMI 5","version":0,"debugenabled":false,"outputs":1,"entityConfig":"e968fc400d3d822d","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(4)","valueType":"str"}],"x":190,"y":840,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"bc4f8d98a35b14b1","type":"ha-button","z":"5966d0f0d467ef9e","name":"SPDIF 1","version":0,"debugenabled":false,"outputs":1,"entityConfig":"4a4bda957e923066","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(7)","valueType":"str"}],"x":200,"y":920,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"2338a95656607871","type":"ha-button","z":"5966d0f0d467ef9e","name":"SPDIF 2","version":0,"debugenabled":false,"outputs":1,"entityConfig":"28807cda5dbad9c4","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(8)","valueType":"str"}],"x":200,"y":960,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"a4b199cf2cbf106a","type":"ha-button","z":"5966d0f0d467ef9e","name":"SPDIF 3","version":0,"debugenabled":false,"outputs":1,"entityConfig":"716c9d5988a9e56d","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(9)","valueType":"str"}],"x":200,"y":1000,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"4bb84bfb90b22117","type":"ha-button","z":"5966d0f0d467ef9e","name":"SPDIF 4","version":0,"debugenabled":false,"outputs":1,"entityConfig":"28254382695c9e5f","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(10)","valueType":"str"}],"x":200,"y":1040,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"3cb178cc303427dd","type":"ha-button","z":"5966d0f0d467ef9e","name":"SPDIF 5","version":0,"debugenabled":false,"outputs":1,"entityConfig":"14d5287ca9fb5d38","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(11)","valueType":"str"}],"x":200,"y":1080,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"33c070926e5fe949","type":"ha-button","z":"5966d0f0d467ef9e","name":"SPDIF 6","version":0,"debugenabled":false,"outputs":1,"entityConfig":"22497cb52370045e","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(12)","valueType":"str"}],"x":200,"y":1120,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"5008d94105731ba6","type":"ha-button","z":"5966d0f0d467ef9e","name":"SPDIF 7","version":0,"debugenabled":false,"outputs":1,"entityConfig":"f7cebcc4cf102da9","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(13)","valueType":"str"}],"x":200,"y":1160,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"ddec60ab96bc1270","type":"ha-button","z":"5966d0f0d467ef9e","name":"SPDIF 8","version":0,"debugenabled":false,"outputs":1,"entityConfig":"330aa21b71d47569","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(14)","valueType":"str"}],"x":200,"y":1200,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"02b4455e6a68d7e1","type":"ha-button","z":"5966d0f0d467ef9e","name":"USB","version":0,"debugenabled":false,"outputs":1,"entityConfig":"5d7f1f2d3dfcb470","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(15)","valueType":"str"}],"x":190,"y":1280,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"79a2ceaa92efb803","type":"ha-button","z":"5966d0f0d467ef9e","name":"ARC","version":0,"debugenabled":false,"outputs":1,"entityConfig":"99acd332d37422d6","outputProperties":[{"property":"payload","propertyType":"msg","value":"!SRC(6)","valueType":"str"}],"x":190,"y":1320,"wires":[["f061fe52ab293768","559d19ceafe5f1b1"]]},{"id":"1d62065fbd847699","type":"ha-button","z":"5966d0f0d467ef9e","name":"Audio Mode+","version":0,"debugenabled":false,"outputs":1,"entityConfig":"d0a1379465be526c","outputProperties":[{"property":"payload","propertyType":"msg","value":"!AUDMODE+","valueType":"str"}],"x":210,"y":560,"wires":[["f061fe52ab293768"]]},{"id":"428b8214741b08f3","type":"ha-button","z":"5966d0f0d467ef9e","name":"Audio Mode-","version":0,"debugenabled":false,"outputs":1,"entityConfig":"cc5a618a44f4435e","outputProperties":[{"property":"payload","propertyType":"msg","value":"!AUDMODE-","valueType":"str"}],"x":210,"y":600,"wires":[["f061fe52ab293768"]]},{"id":"5d910a745be198d1","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Volume Up","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Volume Up"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":true},{"id":"ee4e354c92509e6e","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Volume Down","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Volume Down"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":true},{"id":"e1a046f661657c30","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Mute","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Mute"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"3ffc2d92acd7c555","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Power On","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Power On"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"e2644e34ed8d51d2","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Power Off","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Power Off"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"dfed4cefe2a8c9a6","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"HDMI 1","version":"6","entityType":"button","haConfig":[{"property":"name","value":"HDMI 1"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"38044f8605db3665","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"HDMI 2","version":"6","entityType":"button","haConfig":[{"property":"name","value":"HDMI 2"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"fe10b5e114030842","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"HDMI 3","version":"6","entityType":"button","haConfig":[{"property":"name","value":"HDMI 3"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"04cf31179b8df516","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"HDMI 4","version":"6","entityType":"button","haConfig":[{"property":"name","value":"HDMI 4"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"c0cbfe004dac2190","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Streaming","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Streaming"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"1b7da7993cd1204e","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Arrow Down","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Arrow Down"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"08078337bd6dfdfb","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Arrow Left","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Arrow Left"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"9fab8566cbb406e0","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Arrow Right","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Arrow Right"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"b2e4a5476c3d00a9","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Arrow Up","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Arrow Up"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"6eeef5d78e618a37","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Enter","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Enter"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"8f41e83dcc637e1a","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Exit","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Exit"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"b22ab5f0cd5a5023","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Info","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Info"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"ad29f2765f870ceb","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Menu","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Menu"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"fb1657b36354e062","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"Setup","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Setup"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"e968fc400d3d822d","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"HDMI 5","version":"6","entityType":"button","haConfig":[{"property":"name","value":"HDMI 5"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"4a4bda957e923066","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"SPDIF 1","version":"6","entityType":"button","haConfig":[{"property":"name","value":"SPDIF 1"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"28807cda5dbad9c4","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"SPDIF 2","version":"6","entityType":"button","haConfig":[{"property":"name","value":"SPDIF 2"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"716c9d5988a9e56d","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"SPDIF 3","version":"6","entityType":"button","haConfig":[{"property":"name","value":"SPDIF 3"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"28254382695c9e5f","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"SPDIF 4","version":"6","entityType":"button","haConfig":[{"property":"name","value":"SPDIF 4"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"14d5287ca9fb5d38","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"SPDIF 5","version":"6","entityType":"button","haConfig":[{"property":"name","value":"SPDIF 5"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"22497cb52370045e","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"SPDIF 6","version":"6","entityType":"button","haConfig":[{"property":"name","value":"SPDIF 6"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"f7cebcc4cf102da9","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"SPDIF 7","version":"6","entityType":"button","haConfig":[{"property":"name","value":"SPDIF 7"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"330aa21b71d47569","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"SPDIF 8","version":"6","entityType":"button","haConfig":[{"property":"name","value":"SPDIF 8"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"5d7f1f2d3dfcb470","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"USB","version":"6","entityType":"button","haConfig":[{"property":"name","value":"USB"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"99acd332d37422d6","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"ARC","version":"6","entityType":"button","haConfig":[{"property":"name","value":"ARC"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"d0a1379465be526c","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"AudioMode+","version":"6","entityType":"button","haConfig":[{"property":"name","value":"AudioMode+"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"cc5a618a44f4435e","type":"ha-entity-config","server":"48d0db86.733674","deviceConfig":"2d47479e48eaacbf","name":"AudioMode-","version":"6","entityType":"button","haConfig":[{"property":"name","value":"AudioMode-"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"48d0db86.733674","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","areaSelector":"id","deviceSelector":"friendlyName","statusSeparator":"","enableGlobalContextStore":false},{"id":"2d47479e48eaacbf","type":"ha-device-config","name":"Lyngdorf","hwVersion":"","manufacturer":"Node-RED","model":"MP-60","swVersion":""}]
Created 3 years, 1 month ago
  • delay (x1)
  • function (x2)
  • tcp out (x1)
  • ha-button (x32)
  • ha-device-config (x1)
  • ha-entity-config (x32)
  • server (x1)
  • Lyngdorf
