Get MIDI Input from the Browser
Using Web-Midi in Chrome to capture Midi Input
[{"id":"2e9160b.e4fe9a","type":"tab","label":"WebMidi","disabled":false,"info":""},{"id":"e97da89a.80bc68","type":"inject","z":"2e9160b.e4fe9a","name":"","topic":"","payload":"{\"topic\":\"midi/test\",\"payload\":\"100\"}","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":300,"wires":[["f1f7b660.30d318"]]},{"id":"c9bcd68.6791e28","type":"http response","z":"2e9160b.e4fe9a","name":"","statusCode":"200","headers":{},"x":860,"y":400,"wires":[]},{"id":"d54b6395.9592c","type":"http in","z":"2e9160b.e4fe9a","name":"","url":"/webmidi","method":"get","upload":false,"swaggerDoc":"","x":130,"y":400,"wires":[["7ccfa9a7.99464"]],"info":"<http://localhost:1880/webmidi>"},{"id":"7ccfa9a7.99464","type":"template","z":"2e9160b.e4fe9a","name":"","field":"payload","fieldType":"msg","format":"html","syntax":"plain","template":"<html>\n    <head>\n        <script src=\"https://cdn.jsdelivr.net/npm/[email protected]\"></script>\n    </head>\n    <body>\n        \n         <h1>Please connect your midi device</h1>\n         <ul id=\"log\"></ul>\n         \n         <script>\n         \n            var socket = new WebSocket(`ws://${document.location.host}/ws/webmidi`);\n            \n            function log(msg) {\n                document.getElementById(\"log\").insertAdjacentHTML('afterbegin', `<li>${msg}</li>`);\n            }\n            \n            function send(obj) {\n                socket.send(JSON.stringify(obj));\n            }\n             \n            socket.onopen = function () {\n                log(\"Websocket opened\");\n            };\n            \n            socket.onerror = function (errorEvent) {\n                log(\"Error! Websocket closed\");\n            };\n            \n            WebMidi.enable(function (err) {\n\n                if (err) {\n                    log(\"WebMidi could not be enabled.\");\n                    return;\n                } \n  \n                log(\"WebMidi enabled!\");\n                console.log(WebMidi.inputs);\n                console.log(WebMidi.outputs);\n                \n                //get the first midi input device\n                let input = WebMidi.inputs[0];\n                \n                input.addListener('noteon', 'all',\n                    function(e) {\n                        log(`Key Down: ${e.note.name} (Octave ${e.note.octave})`);\n                        send({ payload: e.note, topic: 'midi/noteon' });\n                    }\n                );\n                \n                input.addListener('noteoff', 'all',\n                    function (e) {\n                        log(`Key Up: ${e.note.name} (Octave ${e.note.octave})`);\n                        send({ payload: e.note, topic: 'midi/noteoff' });\n                    }\n                );\n       \n                input.addListener('controlchange', 'all',\n                    function (e) {\n                        log(`Controller ${e.controller.number}:  ${e.value} `);\n                        console.log(\"Received 'controlchange' message.\", e);\n                        send({ payload: {number: e.controller.number, value: e.value}, topic: 'midi/controlchange' });\n                    }\n                );\n                \n                         \n                input.addListener('pitchbend', 'all',\n                    function (e) {\n                        log(\"Received Pitch Bend ...\");\n                        console.log(\"Pitch Bend:\", e);\n                    }\n                );\n                \n  \n            });\n             \n         </script>\n         \n    </body>\n</html>","output":"str","x":540,"y":400,"wires":[["c9bcd68.6791e28"]]},{"id":"f1f7b660.30d318","type":"websocket out","z":"2e9160b.e4fe9a","name":"","server":"","client":"6e66e176.fce898","x":610,"y":300,"wires":[]},{"id":"c1710c75.68d528","type":"comment","z":"2e9160b.e4fe9a","name":"test the websocket connection","info":"","x":190,"y":260,"wires":[]},{"id":"1f189d98.f7242a","type":"comment","z":"2e9160b.e4fe9a","name":"website to send midi input to server","info":"<http://localhost:1880/webmidi>","x":200,"y":360,"wires":[]},{"id":"3e940c66.56c2fc","type":"websocket in","z":"2e9160b.e4fe9a","name":"","server":"c1ead446.0e336","client":"","x":140,"y":200,"wires":[["41b78993.6020d"]]},{"id":"2f0fe21e.143206","type":"comment","z":"2e9160b.e4fe9a","name":"receive webmidi via websocket","info":"","x":190,"y":160,"wires":[]},{"id":"41b78993.6020d","type":"debug","z":"2e9160b.e4fe9a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":830,"y":200,"wires":[]},{"id":"6e66e176.fce898","type":"websocket-client","z":"","path":"ws://localhost:1880/ws/webmidi","tls":"","wholemsg":"false"},{"id":"c1ead446.0e336","type":"websocket-listener","z":"","path":"/ws/webmidi","wholemsg":"true"}]
Created 5 years, 9 months ago
Updated 5 years, 4 months ago
  • comment (x3)
  • http in (x1)
  • http response (x1)
  • template (x1)
  • websocket in (x1)
  • websocket out (x1)
  • websocket-client (x1)
  • websocket-listener (x1)
  • MIDI
  • WebMidi
  • Chrome
  • Input
  • Interaction
