wzzyds-notetest
Describe what the flow does and how it is used.
This uses GitHub Flavoured Markdown for formatting. Use the preview tab to see how it looks.
[{"id":"4bb2db21255600f8","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"9e58624.7faaba","type":"mqtt out","z":"4bb2db21255600f8","name":"","topic":"esp32/output","qos":"","retain":"","broker":"10e78a89.5b4fd5","x":399,"y":1008,"wires":[]},{"id":"abf7079a.653be8","type":"mqtt in","z":"4bb2db21255600f8","name":"","topic":"esp32/temperature","qos":"2","broker":"10e78a89.5b4fd5","inputs":0,"x":273,"y":915,"wires":[["cc79021b.9a751","21eae8f8.2971b8"]]},{"id":"83cf37cf.c76988","type":"ui_switch","z":"4bb2db21255600f8","name":"","label":"Output","tooltip":"","group":"61285987.c20328","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","topicType":"str","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","animate":true,"className":"","x":258,"y":1008,"wires":[["9e58624.7faaba"]]},{"id":"cc79021b.9a751","type":"debug","z":"4bb2db21255600f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":882,"wires":[]},{"id":"21eae8f8.2971b8","type":"ui_chart","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":0,"width":0,"height":0,"label":"Temperature","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"x":470,"y":942,"wires":[[]]},{"id":"d2e5c19b3de388a9","type":"mqtt in","z":"4bb2db21255600f8","name":"","topic":"esp32/aX","qos":"2","datatype":"auto-detect","broker":"10e78a89.5b4fd5","nl":false,"rap":true,"rh":0,"inputs":0,"x":240,"y":62,"wires":[["10f0639e203cfb24","0669d89871520277"]]},{"id":"10f0639e203cfb24","type":"ui_gauge","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":3,"width":0,"height":0,"gtype":"gage","title":"aX","label":"","format":"{{value}}","min":"-360","max":"360","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":450,"y":82,"wires":[]},{"id":"0669d89871520277","type":"debug","z":"4bb2db21255600f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":20,"wires":[]},{"id":"bf19cc54bf127612","type":"mqtt in","z":"4bb2db21255600f8","name":"","topic":"esp32/aY","qos":"2","datatype":"auto-detect","broker":"10e78a89.5b4fd5","nl":false,"rap":true,"rh":0,"inputs":0,"x":240,"y":180,"wires":[["907571ba39635c91","ccb757205bebe546"]]},{"id":"907571ba39635c91","type":"ui_gauge","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":3,"width":0,"height":0,"gtype":"gage","title":"aY","label":"","format":"{{value}}","min":"-360","max":"360","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":450,"y":200,"wires":[]},{"id":"ccb757205bebe546","type":"debug","z":"4bb2db21255600f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":138,"wires":[]},{"id":"2b7260d84ed15855","type":"mqtt in","z":"4bb2db21255600f8","name":"","topic":"esp32/aZ","qos":"2","datatype":"auto-detect","broker":"10e78a89.5b4fd5","nl":false,"rap":true,"rh":0,"inputs":0,"x":240,"y":300,"wires":[["914a62257f484c2b","36ed2c805e29d93f"]]},{"id":"914a62257f484c2b","type":"ui_gauge","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":3,"width":0,"height":0,"gtype":"gage","title":"aZ","label":"","format":"{{value}}","min":"-360","max":"360","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":450,"y":320,"wires":[]},{"id":"36ed2c805e29d93f","type":"debug","z":"4bb2db21255600f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":258,"wires":[]},{"id":"7fc799cf4355d8ad","type":"mqtt in","z":"4bb2db21255600f8","name":"","topic":"esp32/distance","qos":"2","datatype":"auto-detect","broker":"10e78a89.5b4fd5","nl":false,"rap":true,"rh":0,"inputs":0,"x":260,"y":782,"wires":[["4497fad18cb571ed","42a99d3195cfb004"]]},{"id":"4497fad18cb571ed","type":"ui_gauge","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":3,"width":0,"height":0,"gtype":"gage","title":"Distance","label":"cm","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":460,"y":802,"wires":[]},{"id":"42a99d3195cfb004","type":"debug","z":"4bb2db21255600f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":740,"wires":[]},{"id":"9d99795e9414c119","type":"mqtt in","z":"4bb2db21255600f8","name":"","topic":"esp32/gX","qos":"2","datatype":"auto-detect","broker":"10e78a89.5b4fd5","nl":false,"rap":true,"rh":0,"inputs":0,"x":240,"y":420,"wires":[["438d2a886a8894a9","1435558fa304e5b5"]]},{"id":"438d2a886a8894a9","type":"ui_gauge","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":3,"width":0,"height":0,"gtype":"gage","title":"gX","label":"","format":"{{value}}","min":"-360","max":"360","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":450,"y":440,"wires":[]},{"id":"1435558fa304e5b5","type":"debug","z":"4bb2db21255600f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":378,"wires":[]},{"id":"81ab57d3d7870e0f","type":"mqtt in","z":"4bb2db21255600f8","name":"","topic":"esp32/gY","qos":"2","datatype":"auto-detect","broker":"10e78a89.5b4fd5","nl":false,"rap":true,"rh":0,"inputs":0,"x":240,"y":540,"wires":[["e0b86ff4bc089f89","158204299d27de9e"]]},{"id":"e0b86ff4bc089f89","type":"ui_gauge","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":3,"width":0,"height":0,"gtype":"gage","title":"gY","label":"","format":"{{value}}","min":"-360","max":"360","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":450,"y":560,"wires":[]},{"id":"158204299d27de9e","type":"debug","z":"4bb2db21255600f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":498,"wires":[]},{"id":"f8b6d7223da17c76","type":"mqtt in","z":"4bb2db21255600f8","name":"","topic":"esp32/gZ","qos":"2","datatype":"auto-detect","broker":"10e78a89.5b4fd5","nl":false,"rap":true,"rh":0,"inputs":0,"x":240,"y":660,"wires":[["c9a5629da0df9a90","ac1c6ff1cf14afb1"]]},{"id":"c9a5629da0df9a90","type":"ui_gauge","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":3,"width":0,"height":0,"gtype":"gage","title":"gZ","label":"","format":"{{value}}","min":"-360","max":"360","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":450,"y":680,"wires":[]},{"id":"ac1c6ff1cf14afb1","type":"debug","z":"4bb2db21255600f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":470,"y":618,"wires":[]},{"id":"c09de41c5c072ea1","type":"ui_button","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":9,"width":0,"height":0,"passthru":false,"label":"Forward","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"Forward","payloadType":"str","topic":"topic","topicType":"msg","x":720,"y":60,"wires":[["0f4a71ee21f06a41","0d4f1e13623369e5"]]},{"id":"a067711bac552b64","type":"ui_button","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":10,"width":0,"height":0,"passthru":false,"label":"Backward","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"Backward","payloadType":"str","topic":"topic","topicType":"msg","x":720,"y":220,"wires":[["154a3a1fdebf2b47","2f1b75d62dc3679f"]]},{"id":"1a2c2050c428a13b","type":"ui_button","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":11,"width":0,"height":0,"passthru":false,"label":"Left","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"Left","payloadType":"str","topic":"topic","topicType":"msg","x":710,"y":320,"wires":[["b00e1864fb0c1bbf","973504b77d5275b9"]]},{"id":"02d782e88b248604","type":"ui_button","z":"4bb2db21255600f8","name":"","group":"61285987.c20328","order":12,"width":0,"height":0,"passthru":false,"label":"Right","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"Right","payloadType":"str","topic":"topic","topicType":"msg","x":710,"y":420,"wires":[["9564dacaef85db31","edf1da6ad9595db1"]]},{"id":"0f4a71ee21f06a41","type":"mqtt out","z":"4bb2db21255600f8","name":"","topic":"esp32/direction","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"10e78a89.5b4fd5","x":940,"y":80,"wires":[]},{"id":"154a3a1fdebf2b47","type":"mqtt out","z":"4bb2db21255600f8","name":"","topic":"esp32/direction","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"10e78a89.5b4fd5","x":940,"y":220,"wires":[]},{"id":"b00e1864fb0c1bbf","type":"mqtt out","z":"4bb2db21255600f8","name":"","topic":"esp32/direction","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"10e78a89.5b4fd5","x":940,"y":340,"wires":[]},{"id":"9564dacaef85db31","type":"mqtt out","z":"4bb2db21255600f8","name":"","topic":"esp32/direction","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"10e78a89.5b4fd5","x":940,"y":460,"wires":[]},{"id":"0d4f1e13623369e5","type":"debug","z":"4bb2db21255600f8","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":920,"y":20,"wires":[]},{"id":"2f1b75d62dc3679f","type":"debug","z":"4bb2db21255600f8","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":920,"y":160,"wires":[]},{"id":"973504b77d5275b9","type":"debug","z":"4bb2db21255600f8","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":920,"y":300,"wires":[]},{"id":"edf1da6ad9595db1","type":"debug","z":"4bb2db21255600f8","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":920,"y":420,"wires":[]},{"id":"10e78a89.5b4fd5","type":"mqtt-broker","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"61285987.c20328","type":"ui_group","name":"Main","tab":"e7c46d5e.a1283","order":1,"disp":true,"width":"6","collapse":false},{"id":"e7c46d5e.a1283","type":"ui_tab","name":"Dashboard","icon":"dashboard"}]
