Trigger an Alexa Alarm (IOBroker) now ( if you can say a GV of the time it is now to MQTT or by other mean))
* For my part i am sending a replacement variable $$time from HomeSeer via MQTT.
With this Flow you can trigger an alexa alarm NOw (2 sec delay) ( if you can send a replacement variable of the time it is now from MQTT or by any other mean)...
Se here :
https://discourse.nodered.org/t/timestamp-to-current-date-and-time/873/3
You have to enter a time format like this HH:MM:SEC in 24h format ex: 15:23:22. Or in 12h format with AM and PM at the end ex: 11:22:33 PM.
What you need :
Iobroker **** IoBroker Alexa Adapter.
  • the nodes node-red's going to ask you.
[{"id":"25072fa1.be223","type":"tab","label":"alexa Alarm","disabled":false,"info":""},{"id":"690a2da0.6e9004","type":"ioBroker out","z":"25072fa1.be223","name":"Bedroom Echo","topic":"alexa2.0.Echo-Devices.xxxxxx078376xxxAlarm.New","ack":"false","autoCreate":"false","x":620,"y":20,"wires":[]},{"id":"2bb087e0.340048","type":"moment","z":"25072fa1.be223","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":"2","adjType":"seconds","adjDir":"add","format":"","locale":"POSIX","output":"payload","outputType":"msg","outTz":"America/Toronto","x":320,"y":20,"wires":[["ea894b50.7cf738"]]},{"id":"ea894b50.7cf738","type":"string","z":"25072fa1.be223","name":"","methods":[{"name":"between","params":[{"type":"str","value":"T"},{"type":"str","value":"."}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":470,"y":20,"wires":[["690a2da0.6e9004"]]},{"id":"6699cbeb.e58484","type":"string","z":"25072fa1.be223","name":"","methods":[{"name":"between","params":[{"type":"str","value":"T"},{"type":"str","value":"."}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":470,"y":80,"wires":[["aad5205b.84e25"]]},{"id":"5d3ff33e.6790dc","type":"moment","z":"25072fa1.be223","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":"2","adjType":"seconds","adjDir":"add","format":"","locale":"POSIX","output":"payload","outputType":"msg","outTz":"America/Toronto","x":320,"y":80,"wires":[["6699cbeb.e58484"]]},{"id":"7411f4e.7d1900c","type":"string","z":"25072fa1.be223","name":"","methods":[{"name":"between","params":[{"type":"str","value":"T"},{"type":"str","value":"."}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":470,"y":140,"wires":[["457c64f2.34c90c"]]},{"id":"a2caff6d.286c8","type":"moment","z":"25072fa1.be223","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":"2","adjType":"seconds","adjDir":"add","format":"","locale":"POSIX","output":"payload","outputType":"msg","outTz":"America/Toronto","x":320,"y":140,"wires":[["7411f4e.7d1900c"]]},{"id":"c118f76f.6bdda8","type":"string","z":"25072fa1.be223","name":"","methods":[{"name":"between","params":[{"type":"str","value":"T"},{"type":"str","value":"."}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":470,"y":200,"wires":[["66e3fa9.0627104"]]},{"id":"46d80856.cd5488","type":"moment","z":"25072fa1.be223","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":"2","adjType":"seconds","adjDir":"add","format":"","locale":"POSIX","output":"payload","outputType":"msg","outTz":"America/Toronto","x":320,"y":200,"wires":[["c118f76f.6bdda8"]]},{"id":"ad08da1.dc99c28","type":"string","z":"25072fa1.be223","name":"","methods":[{"name":"between","params":[{"type":"str","value":"T"},{"type":"str","value":"."}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":470,"y":260,"wires":[["e2ec2144.19cb"]]},{"id":"6db9f09f.307d","type":"moment","z":"25072fa1.be223","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":"2","adjType":"seconds","adjDir":"add","format":"","locale":"POSIX","output":"payload","outputType":"msg","outTz":"America/Toronto","x":320,"y":260,"wires":[["ad08da1.dc99c28"]]},{"id":"573341d.8cf0bc","type":"string","z":"25072fa1.be223","name":"","methods":[{"name":"between","params":[{"type":"str","value":"T"},{"type":"str","value":"."}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":470,"y":320,"wires":[["69fa9d1b.87e874"]]},{"id":"b62b0b06.781388","type":"moment","z":"25072fa1.be223","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":"2","adjType":"seconds","adjDir":"add","format":"","locale":"POSIX","output":"payload","outputType":"msg","outTz":"America/Toronto","x":320,"y":320,"wires":[["573341d.8cf0bc"]]},{"id":"4d6826a4.581848","type":"string","z":"25072fa1.be223","name":"","methods":[{"name":"between","params":[{"type":"str","value":"T"},{"type":"str","value":"."}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":470,"y":380,"wires":[["b20cb272.828ac"]]},{"id":"801a9350.45681","type":"moment","z":"25072fa1.be223","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":"2","adjType":"seconds","adjDir":"add","format":"","locale":"POSIX","output":"payload","outputType":"msg","outTz":"America/Toronto","x":320,"y":380,"wires":[["4d6826a4.581848"]]},{"id":"1d0a7476.5add6c","type":"string","z":"25072fa1.be223","name":"","methods":[{"name":"between","params":[{"type":"str","value":"T"},{"type":"str","value":"."}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":470,"y":440,"wires":[["690a2da0.6e9004"]]},{"id":"db09beff.f9c67","type":"moment","z":"25072fa1.be223","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":"2","adjType":"seconds","adjDir":"add","format":"","locale":"POSIX","output":"payload","outputType":"msg","outTz":"America/Toronto","x":320,"y":440,"wires":[["1d0a7476.5add6c"]]},{"id":"5d4966bb.d5d508","type":"mqtt in","z":"25072fa1.be223","name":"","topic":"","qos":"2","datatype":"auto","broker":"","x":50,"y":120,"wires":[[]]},{"id":"3391ce34.4944e2","type":"comment","z":"25072fa1.be223","name":"Or","info":"","x":50,"y":180,"wires":[]},{"id":"1e0c8d5b.812203","type":"http in","z":"25072fa1.be223","name":"","url":"","method":"get","upload":false,"x":50,"y":20,"wires":[[]]},{"id":"aad5205b.84e25","type":"ioBroker out","z":"25072fa1.be223","name":"Add new Alarm","topic":"alexa2.0.Echo-Devices.xxxxxx078376xxxAlarm.New","ack":"false","autoCreate":"false","x":640,"y":80,"wires":[]},{"id":"457c64f2.34c90c","type":"ioBroker out","z":"25072fa1.be223","name":"Add new Alarm","topic":"alexa2.0.Echo-Devices.xxxxxx078376xxxAlarm.New","ack":"false","autoCreate":"false","x":640,"y":140,"wires":[]},{"id":"66e3fa9.0627104","type":"ioBroker out","z":"25072fa1.be223","name":"LivingRoom Echo","topic":"alexa2.0.Echo-Devices.xxxxxx078376xxxAlarm.New","ack":"false","autoCreate":"false","x":650,"y":200,"wires":[]},{"id":"e2ec2144.19cb","type":"ioBroker out","z":"25072fa1.be223","name":"Add new Alarm","topic":"alexa2.0.Echo-Devices.xxxxxx078376xxxAlarm.New","ack":"false","autoCreate":"false","x":640,"y":260,"wires":[]},{"id":"69fa9d1b.87e874","type":"ioBroker out","z":"25072fa1.be223","name":"Add new Alarm","topic":"alexa2.0.Echo-Devices.xxxxxx078376xxxAlarm.New","ack":"false","autoCreate":"false","x":640,"y":320,"wires":[]},{"id":"b20cb272.828ac","type":"ioBroker out","z":"25072fa1.be223","name":"Add new Alarm","topic":"alexa2.0.Echo-Devices.xxxxxx078376xxxAlarm.New","ack":"false","autoCreate":"false","x":640,"y":360,"wires":[]},{"id":"db63d5d.7cfa428","type":"comment","z":"25072fa1.be223","name":"Or","info":"","x":50,"y":60,"wires":[]},{"id":"9dcb2216.746c6","type":"change","z":"25072fa1.be223","name":"Payload now","rules":[{"t":"set","p":"payload","pt":"msg","to":"$now()\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":110,"y":280,"wires":[[]]},{"id":"9176374.3bd78c8","type":"inject","z":"25072fa1.be223","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":80,"y":220,"wires":[["9dcb2216.746c6"]]}]
  • change (x1)
  • comment (x2)
  • http in (x1)
  • mqtt in (x1)
  • ioBroker out (x7)
  • moment (x8)
  • string (x8)
  • Alexa
  • echo
  • iobroker
  • Alarm
  • Homeseer
  • tts
