Multiple Adaptive Card Sample 2
works with tekos.co platform. This is some Adaptive Card displayed on tekos chat rooms
[{"id":"c9f65f0f.c3fed","type":"function","z":"8eb50c91.720f5","name":"Stock","func":"msg.roomId = \"!LAMIpamyCBxUOVQhii:m.tekos.co\"\n// specicy your room ID\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"sidebar\": true,\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"type\": \"AdaptiveCard\",\n    \"version\": \"1.3\",\n    \"speak\": \"Amazon stock is trading at $62.30 a share, which is down .32%\",\n    \"body\": [\n        {\n            \"type\": \"Image\",\n            \"url\": \"https://www.marketplace.org/wp-content/uploads/2019/07/ama2.png\",\n            \"size\": \"Large\",\n            \"horizontalAlignment\": \"Center\"\n        },\n        {\n            \"type\": \"Container\",\n            \"items\": [\n                {\n                    \"type\": \"TextBlock\",\n                    \"text\": \"Amazon.com, Inc. (NASDAQ: AMZN)\",\n                    \"size\": \"Medium\",\n                    \"isSubtle\": true\n                },\n                {\n                    \"type\": \"TextBlock\",\n                    \"text\": \"September 19, 4:00 PM EST\",\n                    \"isSubtle\": true\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"spacing\": \"None\",\n            \"items\": [\n                {\n                    \"type\": \"ColumnSet\",\n                    \"columns\": [\n                        {\n                            \"type\": \"Column\",\n                            \"width\": \"stretch\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"text\": \"75.30\",\n                                    \"size\": \"ExtraLarge\"\n                                },\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"text\": \"▼ 0.20 (0.32%)\",\n                                    \"size\": \"Small\",\n                                    \"color\": \"Attention\",\n                                    \"spacing\": \"None\"\n                                }\n                            ]\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"width\": \"auto\",\n                            \"items\": [\n                                {\n                                    \"type\": \"FactSet\",\n                                    \"facts\": [\n                                        {\n                                            \"title\": \"Open\",\n                                            \"value\": \"62.24\"\n                                        },\n                                        {\n                                            \"title\": \"High\",\n                                            \"value\": \"62.98\"\n                                        },\n                                        {\n                                            \"title\": \"Low\",\n                                            \"value\": \"62.20\"\n                                        }\n                                    ]\n                                }\n                            ]\n                        }\n                    ]\n                }\n            ]\n        }\n    ],\n    \"backgroundImage\": {\n        \"horizontalAlignment\": \"Right\",\n        \"verticalAlignment\": \"Center\"\n    },\n    \"verticalContentAlignment\": \"Bottom\"\n}\n\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":490,"y":680,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"7bf58ef.f2a347","type":"function","z":"8eb50c91.720f5","name":"Setup form","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"version\": \"1.0\",\n    \"type\": \"AdaptiveCard\",\n    \"speak\": \"<s>Your flight is confirmed for you and 3 other passengers from San Francisco to Amsterdam on Friday, October 10 8:30 AM</s>\",\n    \"body\": [\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"Passengers\",\n            \"weight\": \"bolder\",\n            \"isSubtle\": false\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"Sarah Hum\",\n            \"separator\": true\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"Jeremy Goldberg\",\n            \"spacing\": \"none\"\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"Evan Litvak\",\n            \"spacing\": \"none\"\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"2 Stops\",\n            \"weight\": \"bolder\",\n            \"spacing\": \"medium\"\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"Fri, October 10 8:30 AM\",\n            \"weight\": \"bolder\",\n            \"spacing\": \"none\"\n        },\n        {\n            \"type\": \"ColumnSet\",\n            \"separator\": true,\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"San Francisco\",\n                            \"isSubtle\": true\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"size\": \"extraLarge\",\n                            \"color\": \"accent\",\n                            \"text\": \"SFO\",\n                            \"spacing\": \"none\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": \"auto\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"&nbsp;\"\n                        },\n                        {\n                            \"type\": \"Image\",\n                            \"url\": \"https://adaptivecards.io/content/airplane.png\",\n                            \"size\": \"small\",\n                            \"spacing\": \"none\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"right\",\n                            \"text\": \"Amsterdam\",\n                            \"isSubtle\": true\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"right\",\n                            \"size\": \"extraLarge\",\n                            \"color\": \"accent\",\n                            \"text\": \"AMS\",\n                            \"spacing\": \"none\"\n                        }\n                    ]\n                }\n            ]\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"Non-Stop\",\n            \"weight\": \"bolder\",\n            \"spacing\": \"medium\"\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"Fri, October 18 9:50 PM\",\n            \"weight\": \"bolder\",\n            \"spacing\": \"none\"\n        },\n        {\n            \"type\": \"ColumnSet\",\n            \"separator\": true,\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Amsterdam\",\n                            \"isSubtle\": true\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"size\": \"extraLarge\",\n                            \"color\": \"accent\",\n                            \"text\": \"AMS\",\n                            \"spacing\": \"none\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": \"auto\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"&nbsp;\"\n                        },\n                        {\n                            \"type\": \"Image\",\n                            \"url\": \"https://adaptivecards.io/content/airplane.png\",\n                            \"size\": \"small\",\n                            \"spacing\": \"none\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"right\",\n                            \"text\": \"San Francisco\",\n                            \"isSubtle\": true\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"right\",\n                            \"size\": \"extraLarge\",\n                            \"color\": \"accent\",\n                            \"text\": \"SFO\",\n                            \"spacing\": \"none\"\n                        }\n                    ]\n                }\n            ]\n        },\n        {\n            \"type\": \"ColumnSet\",\n            \"spacing\": \"medium\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"width\": \"1\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Total\",\n                            \"size\": \"medium\",\n                            \"isSubtle\": true\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"right\",\n                            \"text\": \"$4,032.54\",\n                            \"size\": \"medium\",\n                            \"weight\": \"bolder\"\n                        }\n                    ]\n                }\n            ]\n        }\n    ]\n}\n\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":510,"y":840,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"8a3fb1bb.9dbd","type":"debug","z":"8eb50c91.720f5","name":"success","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1060,"y":1040,"wires":[]},{"id":"8a1963ba.dd98c","type":"function","z":"8eb50c91.720f5","name":"Form","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"type\": \"AdaptiveCard\",\n    \"version\": \"1.0\",\n    \"body\": [\n        {\n            \"type\": \"TextBlock\",\n            \"size\": \"Medium\",\n            \"weight\": \"Bolder\",\n            \"text\": \"Input.Text elements\",\n            \"horizontalAlignment\": \"Center\"\n        },\n        {\n            \"type\": \"Input.Text\",\n            \"placeholder\": \"Name\",\n            \"style\": \"text\",\n            \"maxLength\": 0,\n            \"id\": \"SimpleVal\"\n        },\n        {\n            \"type\": \"Input.Text\",\n            \"placeholder\": \"Homepage\",\n            \"style\": \"Url\",\n            \"maxLength\": 0,\n            \"id\": \"UrlVal\"\n        },\n        {\n            \"type\": \"Input.Text\",\n            \"placeholder\": \"Email\",\n            \"style\": \"Email\",\n            \"maxLength\": 0,\n            \"id\": \"EmailVal\"\n        },\n        {\n            \"type\": \"Input.Text\",\n            \"placeholder\": \"Phone\",\n            \"style\": \"Tel\",\n            \"maxLength\": 0,\n            \"id\": \"TelVal\"\n        },\n        {\n            \"type\": \"Input.Text\",\n            \"placeholder\": \"Comments\",\n            \"style\": \"text\",\n            \"isMultiline\": true,\n            \"maxLength\": 0,\n            \"id\": \"MultiLineVal\"\n        },\n        {\n            \"type\": \"Input.Number\",\n            \"placeholder\": \"Quantity\",\n            \"min\": -5,\n            \"max\": 5,\n            \"id\": \"NumVal\"\n        },\n        {\n            \"type\": \"Input.Date\",\n            \"placeholder\": \"Due Date\",\n            \"id\": \"DateVal\",\n            \"value\": \"2017-09-20\"\n        },\n        {\n            \"type\": \"Input.Time\",\n            \"placeholder\": \"Start time\",\n            \"id\": \"TimeVal\",\n            \"value\": \"16:59\"\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"size\": \"Medium\",\n            \"weight\": \"Bolder\",\n            \"text\": \"Input.ChoiceSet\",\n            \"horizontalAlignment\": \"Center\"\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"What color do you want? (compact)\"\n        },\n        {\n            \"type\": \"Input.ChoiceSet\",\n            \"id\": \"CompactSelectVal\",\n            \"value\": \"1\",\n            \"choices\": [\n                {\n                    \"title\": \"Red\",\n                    \"value\": \"1\"\n                },\n                {\n                    \"title\": \"Green\",\n                    \"value\": \"2\"\n                },\n                {\n                    \"title\": \"Blue\",\n                    \"value\": \"3\"\n                }\n            ]\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"What color do you want? (expanded)\"\n        },\n        {\n            \"type\": \"Input.ChoiceSet\",\n            \"id\": \"SingleSelectVal\",\n            \"style\": \"expanded\",\n            \"value\": \"1\",\n            \"choices\": [\n                {\n                    \"title\": \"Red\",\n                    \"value\": \"1\"\n                },\n                {\n                    \"title\": \"Green\",\n                    \"value\": \"2\"\n                },\n                {\n                    \"title\": \"Blue\",\n                    \"value\": \"3\"\n                }\n            ]\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"What colors do you want? (multiselect)\"\n        },\n        {\n            \"type\": \"Input.ChoiceSet\",\n            \"id\": \"MultiSelectVal\",\n            \"isMultiSelect\": true,\n            \"value\": \"1,3\",\n            \"choices\": [\n                {\n                    \"title\": \"Red\",\n                    \"value\": \"1\"\n                },\n                {\n                    \"title\": \"Green\",\n                    \"value\": \"2\"\n                },\n                {\n                    \"title\": \"Blue\",\n                    \"value\": \"3\"\n                }\n            ]\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"size\": \"Medium\",\n            \"weight\": \"Bolder\",\n            \"text\": \"Input.Toggle\",\n            \"horizontalAlignment\": \"Center\"\n        },\n        {\n            \"type\": \"Input.Toggle\",\n            \"title\": \"I accept the terms and conditions (True/False)\",\n            \"id\": \"AcceptsTerms\",\n            \"value\": \"false\",\n            \"wrap\": false\n        },\n        {\n            \"type\": \"Input.Toggle\",\n            \"title\": \"Red cars are better than other cars\",\n            \"valueOn\": \"RedCars\",\n            \"valueOff\": \"NotRedCars\",\n            \"id\": \"ColorPreference\",\n            \"value\": \"NotRedCars\",\n            \"wrap\": false\n        }\n    ],\n    \"actions\": [\n        {\n            \"type\": \"Action.Submit\",\n            \"title\": \"Submit\",\n            \"data\": {\n                \"id\": \"1234567890\"\n            }\n        },\n        {\n            \"type\": \"Action.ShowCard\",\n            \"title\": \"Show Card\",\n            \"card\": {\n                \"type\": \"AdaptiveCard\",\n                \"body\": [\n                    {\n                        \"type\": \"Input.Text\",\n                        \"placeholder\": \"enter comment\",\n                        \"style\": \"text\",\n                        \"maxLength\": 0,\n                        \"id\": \"CommentVal\"\n                    }\n                ],\n                \"actions\": [\n                    {\n                        \"type\": \"Action.Submit\",\n                        \"title\": \"OK\"\n                    }\n                ],\n                \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\"\n            }\n        }\n    ]\n}\n\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":490,"y":900,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"4e3fa984.6512e8","type":"function","z":"8eb50c91.720f5","name":"Stock","func":"msg.roomId = \"!LAMIpamyCBxUOVQhii:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"sidebar\": true,\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"type\": \"AdaptiveCard\",\n    \"version\": \"1.0\",\n    \"speak\": \"Microsoft stock is trading at $62.30 a share, which is down .32%\",\n    \"body\": [\n        {\n            \"type\": \"Container\",\n            \"items\": [\n                {\n                    \"type\": \"TextBlock\",\n                    \"text\": \"Microsoft Corp (NASDAQ: MSFT)\",\n                    \"size\": \"medium\",\n                    \"isSubtle\": true\n                },\n                {\n                    \"type\": \"TextBlock\",\n                    \"text\": \"September 19, 4:00 PM EST\",\n                    \"isSubtle\": true\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"spacing\": \"none\",\n            \"items\": [\n                {\n                    \"type\": \"ColumnSet\",\n                    \"columns\": [\n                        {\n                            \"type\": \"Column\",\n                            \"width\": \"stretch\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"text\": \"75.30\",\n                                    \"size\": \"extraLarge\"\n                                },\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"text\": \"▼ 0.20 (0.32%)\",\n                                    \"size\": \"small\",\n                                    \"color\": \"attention\",\n                                    \"spacing\": \"none\"\n                                }\n                            ]\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"width\": \"auto\",\n                            \"items\": [\n                                {\n                                    \"type\": \"FactSet\",\n                                    \"facts\": [\n                                        {\n                                            \"title\": \"Open\",\n                                            \"value\": \"62.24\"\n                                        },\n                                        {\n                                            \"title\": \"High\",\n                                            \"value\": \"62.98\"\n                                        },\n                                        {\n                                            \"title\": \"Low\",\n                                            \"value\": \"62.20\"\n                                        }\n                                    ]\n                                }\n                            ]\n                        }\n                    ]\n                }\n            ]\n        }\n    ]\n}\n\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":490,"y":940,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"3778d8c0.7f66d8","type":"function","z":"8eb50c91.720f5","name":"weather","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"type\": \"AdaptiveCard\",\n    \"version\": \"1.0\",\n    \"speak\": \"<s>The forecast for Seattle January 20 is mostly clear with a High of 51 degrees and Low of 40 degrees</s>\",\n    \"body\": [\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"Seattle, WA\",\n            \"size\": \"Large\",\n            \"isSubtle\": true\n        },\n        {\n            \"type\": \"TextBlock\",\n            \"text\": \"September 18, 7:30 AM\",\n            \"spacing\": \"None\"\n        },\n        {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"width\": \"auto\",\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"url\": \"https://webstockreview.net/images/clipart-rain-snow-mix-6.gif\",\n                            \"size\": \"Small\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": \"auto\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"42\",\n                            \"size\": \"ExtraLarge\",\n                            \"spacing\": \"None\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": \"stretch\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"°F\",\n                            \"weight\": \"Bolder\",\n                            \"spacing\": \"Small\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": \"stretch\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Hi 51\",\n                            \"horizontalAlignment\": \"Left\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Lo 40\",\n                            \"horizontalAlignment\": \"Left\",\n                            \"spacing\": \"None\"\n                        }\n                    ]\n                }\n            ]\n        }\n    ]\n}\n\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":500,"y":980,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"4763d5fc.4f1c9c","type":"function","z":"8eb50c91.720f5","name":"flight","func":"msg.roomId = \"!vVfVbxkpmPymVvFkjo:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"projected\": true,\n    \"adaptiveCard\":{\n    \"type\": \"AdaptiveCard\",\n    \"body\": [\n        {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"Container\",\n                            \"backgroundImage\": \"http://messagecardplayground.azurewebsites.net/assets/TxP_Background.png\",\n                            \"items\": [\n                                {\n                                    \"type\": \"Image\",\n                                    \"horizontalAlignment\": \"Center\",\n                                    \"url\": \"https://messagecardplayground.azurewebsites.net/assets/TxP_Flight.png\"\n                                }\n                            ],\n                            \"bleed\": true\n                        },\n                        {\n                            \"type\": \"Container\",\n                            \"spacing\": \"None\",\n                            \"style\": \"emphasis\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"size\": \"ExtraLarge\",\n                                    \"weight\": \"Lighter\",\n                                    \"color\": \"Accent\",\n                                    \"text\": \"Flight to Paris\",\n                                    \"wrap\": true\n                                },\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"spacing\": \"Small\",\n                                    \"text\": \"Delta Air Lines flight 8471\",\n                                    \"wrap\": true\n                                },\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"spacing\": \"None\",\n                                    \"text\": \"Confirmation code: ABCDEF\",\n                                    \"wrap\": true\n                                },\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"spacing\": \"None\",\n                                    \"text\": \"10 hours 45 minutes\",\n                                    \"wrap\": true\n                                }\n                            ],\n                            \"bleed\": true,\n                            \"height\": \"stretch\"\n                        }\n                    ],\n                    \"width\": 45,\n                    \"height\": \"stretch\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"Container\",\n                            \"height\": \"stretch\",\n                            \"items\": [\n                                {\n                                    \"type\": \"ColumnSet\",\n                                    \"columns\": [\n                                        {\n                                            \"type\": \"Column\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"TextBlock\",\n                                                    \"size\": \"ExtraLarge\",\n                                                    \"weight\": \"Lighter\",\n                                                    \"text\": \"BLR\"\n                                                }\n                                            ],\n                                            \"width\": \"auto\"\n                                        },\n                                        {\n                                            \"type\": \"Column\",\n                                            \"verticalContentAlignment\": \"Center\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"Image\",\n                                                    \"url\": \"https://messagecardplayground.azurewebsites.net/assets/graydot2x2.png\",\n                                                    \"width\": \"10000px\",\n                                                    \"height\": \"2px\"\n                                                }\n                                            ],\n                                            \"width\": \"stretch\"\n                                        },\n                                        {\n                                            \"type\": \"Column\",\n                                            \"spacing\": \"Small\",\n                                            \"verticalContentAlignment\": \"Center\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"Image\",\n                                                    \"url\": \"https://messagecardplayground.azurewebsites.net/assets/smallairplane.png\",\n                                                    \"height\": \"16px\"\n                                                }\n                                            ],\n                                            \"width\": \"auto\"\n                                        },\n                                        {\n                                            \"type\": \"Column\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"TextBlock\",\n                                                    \"horizontalAlignment\": \"Right\",\n                                                    \"size\": \"ExtraLarge\",\n                                                    \"weight\": \"Lighter\",\n                                                    \"text\": \"CDG\"\n                                                }\n                                            ],\n                                            \"width\": \"auto\"\n                                        }\n                                    ]\n                                },\n                                {\n                                    \"type\": \"ColumnSet\",\n                                    \"columns\": [\n                                        {\n                                            \"type\": \"Column\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"TextBlock\",\n                                                    \"size\": \"Medium\",\n                                                    \"text\": \"1:55 AM\"\n                                                }\n                                            ],\n                                            \"width\": 1\n                                        },\n                                        {\n                                            \"type\": \"Column\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"TextBlock\",\n                                                    \"horizontalAlignment\": \"Right\",\n                                                    \"size\": \"Medium\",\n                                                    \"text\": \"8:10 AM\"\n                                                }\n                                            ],\n                                            \"width\": 1\n                                        }\n                                    ]\n                                },\n                                {\n                                    \"type\": \"ColumnSet\",\n                                    \"spacing\": \"None\",\n                                    \"columns\": [\n                                        {\n                                            \"type\": \"Column\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"TextBlock\",\n                                                    \"text\": \"November 12, 2017\",\n                                                    \"isSubtle\": true,\n                                                    \"wrap\": true\n                                                }\n                                            ],\n                                            \"width\": 1\n                                        },\n                                        {\n                                            \"type\": \"Column\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"TextBlock\",\n                                                    \"horizontalAlignment\": \"Right\",\n                                                    \"text\": \"November 12, 2017\",\n                                                    \"isSubtle\": true,\n                                                    \"wrap\": true\n                                                }\n                                            ],\n                                            \"width\": 1\n                                        }\n                                    ]\n                                },\n                                {\n                                    \"type\": \"ColumnSet\",\n                                    \"spacing\": \"None\",\n                                    \"columns\": [\n                                        {\n                                            \"type\": \"Column\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"TextBlock\",\n                                                    \"text\": \"Bengaluru\",\n                                                    \"isSubtle\": true\n                                                }\n                                            ],\n                                            \"width\": 1\n                                        },\n                                        {\n                                            \"type\": \"Column\",\n                                            \"items\": [\n                                                {\n                                                    \"type\": \"TextBlock\",\n                                                    \"horizontalAlignment\": \"Right\",\n                                                    \"text\": \"Paris\",\n                                                    \"isSubtle\": true\n                                                }\n                                            ],\n                                            \"width\": 1\n                                        }\n                                    ],\n                                    \"height\": \"stretch\"\n                                },\n                                {\n                                    \"type\": \"ActionSet\",\n                                    \"separator\": true,\n                                    \"actions\": [\n                                        {\n                                            \"type\": \"Action.Submit\",\n                                            \"title\": \"Check in\",\n                                            \"style\": \"positive\"\n                                        },\n                                        {\n                                            \"type\": \"Action.Submit\",\n                                            \"title\": \"View in calendar\"\n                                        }\n                                    ],\n                                    \"spacing\": \"Medium\"\n                                }\n                            ]\n                        }\n                    ],\n                    \"width\": 55\n                }\n            ],\n            \"height\": \"stretch\"\n        }\n    ],\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"version\": \"1.0\"\n}\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":490,"y":1020,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"751d3d1d.9278e4","type":"function","z":"8eb50c91.720f5","name":"expense","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n    \"type\": \"AdaptiveCard\",\n    \"body\": [\n        {\n            \"type\": \"Container\",\n            \"style\": \"emphasis\",\n            \"items\": [\n                {\n                    \"type\": \"ColumnSet\",\n                    \"columns\": [\n                        {\n                            \"type\": \"Column\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"size\": \"Large\",\n                                    \"weight\": \"Bolder\",\n                                    \"text\": \"**EXPENSE APPROVAL**\"\n                                }\n                            ],\n                            \"width\": \"stretch\"\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"items\": [\n                                {\n                                    \"type\": \"Image\",\n                                    \"url\": \"https://adaptivecards.io/content/pending.png\",\n                                    \"height\": \"30px\",\n                                    \"altText\": \"Pending\"\n                                }\n                            ],\n                            \"width\": \"auto\"\n                        }\n                    ]\n                }\n            ],\n            \"bleed\": true\n        },\n        {\n            \"type\": \"Container\",\n            \"items\": [\n                {\n                    \"type\": \"ColumnSet\",\n                    \"columns\": [\n                        {\n                            \"type\": \"Column\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"size\": \"ExtraLarge\",\n                                    \"text\": \"Trip to UAE\",\n                                    \"wrap\": true\n                                },\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"spacing\": \"Small\",\n                                    \"size\": \"Small\",\n                                    \"weight\": \"Bolder\",\n                                    \"color\": \"Accent\",\n                                    \"text\": \"[ER-13052](https://adaptivecards.io)\"\n                                }\n                            ],\n                            \"width\": \"stretch\"\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"items\": [\n                                {\n                                    \"type\": \"ActionSet\",\n                                    \"actions\": [\n                                        {\n                                            \"type\": \"Action.OpenUrl\",\n                                            \"title\": \"EXPORT AS PDF\",\n                                            \"url\": \"https://adaptivecards.io\"\n                                        }\n                                    ]\n                                }\n                            ],\n                            \"width\": \"auto\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"FactSet\",\n                    \"spacing\": \"Large\",\n                    \"facts\": [\n                        {\n                            \"title\": \"Submitted By\",\n                            \"value\": \"**Matt Hidinger**  [email protected]\"\n                        },\n                        {\n                            \"title\": \"Duration\",\n                            \"value\": \"2019/06/19 - 2019/06/25\"\n                        },\n                        {\n                            \"title\": \"Submitted On\",\n                            \"value\": \"2019/04/14\"\n                        },\n                        {\n                            \"title\": \"Reimbursable Amount\",\n                            \"value\": \"$ 404.30\"\n                        },\n                        {\n                            \"title\": \"Awaiting approval from\",\n                            \"value\": \"**Thomas**  [email protected]\"\n                        },\n                        {\n                            \"title\": \"Submitted to\",\n                            \"value\": \"**David**   [email protected]\"\n                        }\n                    ]\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"spacing\": \"Large\",\n            \"style\": \"emphasis\",\n            \"items\": [\n                {\n                    \"type\": \"ColumnSet\",\n                    \"columns\": [\n                        {\n                            \"type\": \"Column\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"weight\": \"Bolder\",\n                                    \"text\": \"DATE\"\n                                }\n                            ],\n                            \"width\": \"auto\"\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"spacing\": \"Large\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"weight\": \"Bolder\",\n                                    \"text\": \"CATEGORY\"\n                                }\n                            ],\n                            \"width\": \"stretch\"\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"weight\": \"Bolder\",\n                                    \"text\": \"AMOUNT\"\n                                }\n                            ],\n                            \"width\": \"auto\"\n                        }\n                    ]\n                }\n            ],\n            \"bleed\": true\n        },\n        {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"06/19\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"spacing\": \"Medium\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Air Travel Expense\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"stretch\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"$ 300\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"id\": \"chevronDown1\",\n                    \"spacing\": \"Small\",\n                    \"verticalContentAlignment\": \"Center\",\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"selectAction\": {\n                                \"type\": \"Action.ToggleVisibility\",\n                                \"title\": \"collapse\",\n                                \"targetElements\": [\n                                    \"cardContent1\",\n                                    \"chevronUp1\",\n                                    \"chevronDown1\"\n                                ]\n                            },\n                            \"url\": \"https://adaptivecards.io/content/down.png\",\n                            \"width\": \"20px\",\n                            \"altText\": \"collapsed\"\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"id\": \"chevronUp1\",\n                    \"isVisible\": false,\n                    \"spacing\": \"Small\",\n                    \"verticalContentAlignment\": \"Center\",\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"selectAction\": {\n                                \"type\": \"Action.ToggleVisibility\",\n                                \"title\": \"expand\",\n                                \"targetElements\": [\n                                    \"cardContent1\",\n                                    \"chevronUp1\",\n                                    \"chevronDown1\"\n                                ]\n                            },\n                            \"url\": \"https://adaptivecards.io/content/up.png\",\n                            \"width\": \"20px\",\n                            \"altText\": \"expanded\"\n                        }\n                    ],\n                    \"width\": \"auto\"\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"id\": \"cardContent1\",\n            \"isVisible\": false,\n            \"items\": [\n                {\n                    \"type\": \"Container\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"* Leg 1 on Tue, Jun 19th, 2019 at 6:00 AM.\",\n                            \"isSubtle\": true,\n                            \"wrap\": true\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"* Leg 2 on Tue,Jun 19th, 2019 at 7:15 PM.\",\n                            \"isSubtle\": true,\n                            \"wrap\": true\n                        },\n                        {\n                            \"type\": \"Container\",\n                            \"items\": [\n                                {\n                                    \"type\": \"Input.Text\",\n                                    \"id\": \"comment1\",\n                                    \"placeholder\": \"Add your comment here.\"\n                                }\n                            ]\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Container\",\n                    \"items\": [\n                        {\n                            \"type\": \"ColumnSet\",\n                            \"columns\": [\n                                {\n                                    \"type\": \"Column\",\n                                    \"items\": [\n                                        {\n                                            \"type\": \"ActionSet\",\n                                            \"actions\": [\n                                                {\n                                                    \"type\": \"Action.Submit\",\n                                                    \"title\": \"Send\",\n                                                    \"data\": {\n                                                        \"id\": \"_qkQW8dJlUeLVi7ZMEzYVw\",\n                                                        \"action\": \"comment\",\n                                                        \"lineItem\": 1\n                                                    }\n                                                }\n                                            ]\n                                        }\n                                    ],\n                                    \"width\": \"auto\"\n                                }\n                            ]\n                        }\n                    ]\n                }\n            ]\n        },\n        {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"Center\",\n                            \"text\": \"06/19\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"spacing\": \"Medium\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Auto Mobile Expense\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"stretch\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"$ 100\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"id\": \"chevronDown2\",\n                    \"spacing\": \"Small\",\n                    \"verticalContentAlignment\": \"Center\",\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"selectAction\": {\n                                \"type\": \"Action.ToggleVisibility\",\n                                \"title\": \"collapse\",\n                                \"targetElements\": [\n                                    \"cardContent2\",\n                                    \"chevronUp2\",\n                                    \"chevronDown2\"\n                                ]\n                            },\n                            \"url\": \"https://adaptivecards.io/content/down.png\",\n                            \"width\": \"20px\",\n                            \"altText\": \"collapsed\"\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"id\": \"chevronUp2\",\n                    \"isVisible\": false,\n                    \"spacing\": \"Small\",\n                    \"verticalContentAlignment\": \"Center\",\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"selectAction\": {\n                                \"type\": \"Action.ToggleVisibility\",\n                                \"title\": \"expand\",\n                                \"targetElements\": [\n                                    \"cardContent2\",\n                                    \"chevronUp2\",\n                                    \"chevronDown2\"\n                                ]\n                            },\n                            \"url\": \"https://adaptivecards.io/content/up.png\",\n                            \"width\": \"20px\",\n                            \"altText\": \"expanded\"\n                        }\n                    ],\n                    \"width\": \"auto\"\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"id\": \"cardContent2\",\n            \"isVisible\": false,\n            \"items\": [\n                {\n                    \"type\": \"Container\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"* Contoso Car Rentrals, Tues 6/19 at 7:00 AM\",\n                            \"isSubtle\": true,\n                            \"wrap\": true\n                        },\n                        {\n                            \"type\": \"Container\",\n                            \"items\": [\n                                {\n                                    \"type\": \"Input.Text\",\n                                    \"id\": \"comment2\",\n                                    \"placeholder\": \"Add your comment here.\"\n                                }\n                            ]\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Container\",\n                    \"items\": [\n                        {\n                            \"type\": \"ColumnSet\",\n                            \"columns\": [\n                                {\n                                    \"type\": \"Column\",\n                                    \"items\": [\n                                        {\n                                            \"type\": \"ActionSet\",\n                                            \"actions\": [\n                                                {\n                                                    \"type\": \"Action.Submit\",\n                                                    \"title\": \"Send\",\n                                                    \"data\": {\n                                                        \"id\": \"_qkQW8dJlUeLVi7ZMEzYVw\",\n                                                        \"action\": \"comment\",\n                                                        \"lineItem\": 2\n                                                    }\n                                                }\n                                            ]\n                                        }\n                                    ],\n                                    \"width\": \"auto\"\n                                }\n                            ]\n                        }\n                    ]\n                }\n            ]\n        },\n        {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"Center\",\n                            \"text\": \"06/25\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"spacing\": \"Medium\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Air Travel Expense\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"stretch\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"$ 4.30\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"id\": \"chevronDown3\",\n                    \"spacing\": \"Small\",\n                    \"verticalContentAlignment\": \"Center\",\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"selectAction\": {\n                                \"type\": \"Action.ToggleVisibility\",\n                                \"title\": \"collapse\",\n                                \"targetElements\": [\n                                    \"cardContent3\",\n                                    \"chevronUp3\",\n                                    \"chevronDown3\"\n                                ]\n                            },\n                            \"url\": \"https://adaptivecards.io/content/down.png\",\n                            \"width\": \"20px\",\n                            \"altText\": \"collapsed\"\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"id\": \"chevronUp3\",\n                    \"isVisible\": false,\n                    \"spacing\": \"Small\",\n                    \"verticalContentAlignment\": \"Center\",\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"selectAction\": {\n                                \"type\": \"Action.ToggleVisibility\",\n                                \"title\": \"expand\",\n                                \"targetElements\": [\n                                    \"cardContent3\",\n                                    \"chevronUp3\",\n                                    \"chevronDown3\"\n                                ]\n                            },\n                            \"url\": \"https://adaptivecards.io/content/up.png\",\n                            \"width\": \"20px\",\n                            \"altText\": \"expanded\"\n                        }\n                    ],\n                    \"width\": \"auto\"\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"id\": \"cardContent3\",\n            \"isVisible\": false,\n            \"items\": [\n                {\n                    \"type\": \"Container\",\n                    \"items\": [\n                        {\n                            \"type\": \"Input.Text\",\n                            \"id\": \"comment3\",\n                            \"placeholder\": \"Add your comment here.\"\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Container\",\n                    \"items\": [\n                        {\n                            \"type\": \"ColumnSet\",\n                            \"columns\": [\n                                {\n                                    \"type\": \"Column\",\n                                    \"items\": [\n                                        {\n                                            \"type\": \"ActionSet\",\n                                            \"actions\": [\n                                                {\n                                                    \"type\": \"Action.Submit\",\n                                                    \"title\": \"Send\",\n                                                    \"data\": {\n                                                        \"id\": \"_qkQW8dJlUeLVi7ZMEzYVw\",\n                                                        \"action\": \"comment\",\n                                                        \"lineItem\": 3\n                                                    }\n                                                }\n                                            ]\n                                        }\n                                    ],\n                                    \"width\": \"auto\"\n                                }\n                            ]\n                        }\n                    ]\n                }\n            ]\n        },\n        {\n            \"type\": \"ColumnSet\",\n            \"spacing\": \"Large\",\n            \"separator\": true,\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"Right\",\n                            \"text\": \"Total Expense Amount \\t\",\n                            \"wrap\": true\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"Right\",\n                            \"text\": \"Non-reimbursable Amount\",\n                            \"wrap\": true\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"horizontalAlignment\": \"Right\",\n                            \"text\": \"Advance Amount\",\n                            \"wrap\": true\n                        }\n                    ],\n                    \"width\": \"stretch\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"404.30\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"(-) 0.00 \\t\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"(-) 0.00 \\t\"\n                        }\n                    ],\n                    \"width\": \"auto\"\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": \"auto\"\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"style\": \"emphasis\",\n            \"items\": [\n                {\n                    \"type\": \"ColumnSet\",\n                    \"columns\": [\n                        {\n                            \"type\": \"Column\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"horizontalAlignment\": \"Right\",\n                                    \"text\": \"Amount to be Reimbursed\",\n                                    \"wrap\": true\n                                }\n                            ],\n                            \"width\": \"stretch\"\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"weight\": \"Bolder\",\n                                    \"text\": \"$ 404.30\"\n                                }\n                            ],\n                            \"width\": \"auto\"\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"width\": \"auto\"\n                        }\n                    ]\n                }\n            ],\n            \"bleed\": true\n        },\n        {\n            \"type\": \"Container\",\n            \"items\": [\n                {\n                    \"type\": \"ColumnSet\",\n                    \"columns\": [\n                        {\n                            \"type\": \"Column\",\n                            \"id\": \"chevronDown4\",\n                            \"selectAction\": {\n                                \"type\": \"Action.ToggleVisibility\",\n                                \"title\": \"show history\",\n                                \"targetElements\": [\n                                    \"cardContent4\",\n                                    \"chevronUp4\",\n                                    \"chevronDown4\"\n                                ]\n                            },\n                            \"verticalContentAlignment\": \"Center\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"horizontalAlignment\": \"Right\",\n                                    \"color\": \"Accent\",\n                                    \"text\": \"Show history\",\n                                    \"wrap\": true\n                                }\n                            ],\n                            \"width\": 1\n                        },\n                        {\n                            \"type\": \"Column\",\n                            \"id\": \"chevronUp4\",\n                            \"isVisible\": false,\n                            \"selectAction\": {\n                                \"type\": \"Action.ToggleVisibility\",\n                                \"title\": \"hide history\",\n                                \"targetElements\": [\n                                    \"cardContent4\",\n                                    \"chevronUp4\",\n                                    \"chevronDown4\"\n                                ]\n                            },\n                            \"verticalContentAlignment\": \"Center\",\n                            \"items\": [\n                                {\n                                    \"type\": \"TextBlock\",\n                                    \"horizontalAlignment\": \"Right\",\n                                    \"color\": \"Accent\",\n                                    \"text\": \"Hide history\",\n                                    \"wrap\": true\n                                }\n                            ],\n                            \"width\": 1\n                        }\n                    ]\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"id\": \"cardContent4\",\n            \"isVisible\": false,\n            \"items\": [\n                {\n                    \"type\": \"Container\",\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"* Expense submitted by **Matt** on Wed, Apr 14th, 2019\",\n                            \"isSubtle\": true,\n                            \"wrap\": true\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"* Expense approved by **Thomas** on Thu, Apr 15th, 2019\",\n                            \"isSubtle\": true,\n                            \"wrap\": true\n                        }\n                    ]\n                }\n            ]\n        },\n        {\n            \"type\": \"Container\",\n            \"items\": [\n                {\n                    \"type\": \"ActionSet\",\n                    \"actions\": [\n                        {\n                            \"type\": \"Action.Submit\",\n                            \"title\": \"Approve\",\n                            \"style\": \"positive\",\n                            \"data\": {\n                                \"id\": \"_qkQW8dJlUeLVi7ZMEzYVw\",\n                                \"action\": \"approve\"\n                            }\n                        },\n                        {\n                            \"type\": \"Action.ShowCard\",\n                            \"title\": \"Reject\",\n                            \"style\": \"destructive\",\n                            \"card\": {\n                                \"type\": \"AdaptiveCard\",\n                                \"body\": [\n                                    {\n                                        \"type\": \"Input.Text\",\n                                        \"id\": \"RejectCommentID\",\n                                        \"placeholder\": \"Please specify an appropriate reason for rejection.\",\n                                        \"isMultiline\": true\n                                    }\n                                ],\n                                \"actions\": [\n                                    {\n                                        \"type\": \"Action.Submit\",\n                                        \"title\": \"Send\",\n                                        \"data\": {\n                                            \"id\": \"_qkQW8dJlUeLVi7ZMEzYVw\",\n                                            \"action\": \"reject\"\n                                        }\n                                    }\n                                ]\n                            }\n                        }\n                    ]\n                }\n            ]\n        }\n    ],\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"version\": \"1.2\",\n    \"fallbackText\": \"This card requires Adaptive Cards v1.2 support to be rendered properly.\"\n}\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":500,"y":1060,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"93b1806e.6c13d","type":"function","z":"8eb50c91.720f5","name":"video","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"type\": \"AdaptiveCard\",\n    \"version\": \"1.1\",\n    \"fallbackText\": \"This card requires Media to be viewed. Ask your platform to update to Adaptive Cards v1.1 for this and more!\",\n    \"body\": [\n        {\n            \"type\": \"Media\",\n            \"poster\": \"https://adaptivecards.io/content/poster-video.png\",\n            \"sources\": [\n                {\n                    \"mimeType\": \"video/mp4\",\n                    \"url\": \"https://adaptivecardsblob.blob.core.windows.net/assets/AdaptiveCardsOverviewVideo.mp4\"\n                }\n            ]\n        }\n    ],\n    \"actions\": [\n        {\n            \"type\": \"Action.OpenUrl\",\n            \"title\": \"Learn more\",\n            \"url\": \"https://adaptivecards.io\"\n        }\n    ]\n}\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":470,"y":1160,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"a96ab949.7c57c8","type":"function","z":"8eb50c91.720f5","name":"restau","func":"msg.roomId = \"!zZaVoBslVaVZoGPjzv:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"composer\": true,\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"type\": \"AdaptiveCard\",\n    \"version\": \"1.0\",\n    \"body\": [\n        {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"width\": 2,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"PIZZA\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Tom's Pie\",\n                            \"weight\": \"bolder\",\n                            \"size\": \"extraLarge\",\n                            \"spacing\": \"none\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"4.2 ★★★☆ (93) · $$\",\n                            \"isSubtle\": true,\n                            \"spacing\": \"none\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"**Matt H. said** \\\"I'm compelled to give this place 5 stars due to the number of times I've chosen to eat here this past year!\\\"\",\n                            \"size\": \"small\",\n                            \"wrap\": true\n                        }\n                    ]\n                },\n                {\n      \"type\": \"ChartComponent\",\n      \"title\": \"Please wait...\",\n      \"value\": {\n        type: 'bar',\n        data: {\n            labels: ['Red', 'Blue', 'Yellow', 'Green', 'Purple', 'Orange'],\n            datasets: [{\n                label: '# of Votes',\n                data: [12, 19, 3, 5, 2, 3],\n                backgroundColor: [\n                    'rgba(255, 99, 132, 0.2)',\n                    'rgba(54, 162, 235, 0.2)',\n                    'rgba(255, 206, 86, 0.2)',\n                    'rgba(75, 192, 192, 0.2)',\n                    'rgba(153, 102, 255, 0.2)',\n                    'rgba(255, 159, 64, 0.2)'\n                ],\n                borderColor: [\n                    'rgba(255, 99, 132, 1)',\n                    'rgba(54, 162, 235, 1)',\n                    'rgba(255, 206, 86, 1)',\n                    'rgba(75, 192, 192, 1)',\n                    'rgba(153, 102, 255, 1)',\n                    'rgba(255, 159, 64, 1)'\n                ],\n                borderWidth: 1\n            }]\n        },\n        options: {\n            scales: {\n                yAxes: [{\n                    ticks: {\n                        beginAtZero: true\n                    }\n                }]\n            }\n        }\n    }\n    },\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"url\": \"https://picsum.photos/300?image=882\",\n                            \"size\": \"auto\"\n                        }\n                    ]\n                }\n            ]\n        }\n    ],\n    \"actions\": [\n        {\n            \"type\": \"Action.OpenUrl\",\n            \"title\": \"More Info\",\n            \"url\": \"https://www.youtube.com/watch?v=dQw4w9WgXcQ\"\n        }\n    ]\n}\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":450,"y":1200,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"162b9a4.9a15b66","type":"function","z":"8eb50c91.720f5","name":"car","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"type\": \"AdaptiveCard\",\n    \"version\": \"1.0\",\n    \"body\": [\n        {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Spopin Cool\",\n                            \"spacing\": \"Large\",\n                            \"horizontalAlignment\": \"Left\",\n                            \"height\": \"stretch\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Audi A4\",\n                            \"weight\": \"Bolder\",\n                            \"size\": \"ExtraLarge\",\n                            \"spacing\": \"None\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"10€/j · 4.2 ★★★☆ (93)\",\n                            \"isSubtle\": true,\n                            \"spacing\": \"None\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"**2018** Berline 5p, Essence\",\n                            \"size\": \"Small\",\n                            \"wrap\": true\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"url\": \"https://www.car-revs-daily.com/wp-content/uploads/Car-Revs-Daily.com-2014-Honda-CR-Z-66.gif\",\n                            \"size\": \"auto\"\n                        }\n                    ]\n                }\n            ]\n        }\n    ],\n    \"actions\": [\n        {\n            \"type\": \"Action.OpenUrl\",\n            \"title\": \"Louer\",\n            \"url\": \"https://www.youtube.com/watch?v=dQw4w9WgXcQ\",\n            \"style\": \"positive\"\n        }\n    ]\n}\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":490,"y":1280,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"e1c6454e.772618","type":"http request","z":"8eb50c91.720f5","name":"","method":"POST","ret":"txt","paytoqs":false,"url":"","tls":"","persist":false,"proxy":"","authType":"","x":840,"y":1040,"wires":[["8a3fb1bb.9dbd"]]},{"id":"9de51130.01eb5","type":"function","z":"8eb50c91.720f5","name":"car","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"type\": \"AdaptiveCard\",\n    \"version\": \"1.0\",\n    \"body\": [\n        {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Spopin Cool\",\n                            \"spacing\": \"Large\",\n                            \"horizontalAlignment\": \"Left\",\n                            \"height\": \"stretch\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Audi A4\",\n                            \"weight\": \"Bolder\",\n                            \"size\": \"ExtraLarge\",\n                            \"spacing\": \"None\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"10€/j · 4.2 ★★★☆ (93)\",\n                            \"isSubtle\": true,\n                            \"spacing\": \"None\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"**2018** Berline 5p, Essence\",\n                            \"size\": \"Small\",\n                            \"wrap\": true\n                        }\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"url\": \"https://www.car-revs-daily.com/wp-content/uploads/Car-Revs-Daily.com-2014-Honda-CR-Z-66.gif\",\n                            \"size\": \"auto\"\n                        }\n                    ]\n                }\n            ]\n        },\n            {\n            \"type\": \"ColumnSet\",\n            \"columns\": [\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Spopin Cool\",\n                            \"spacing\": \"Large\",\n                            \"horizontalAlignment\": \"Left\",\n                            \"height\": \"stretch\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"Audi A4\",\n                            \"weight\": \"Bolder\",\n                            \"size\": \"ExtraLarge\",\n                            \"spacing\": \"None\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"10€/j · 4.2 ★★★☆ (93)\",\n                            \"isSubtle\": true,\n                            \"spacing\": \"None\"\n                        },\n                        {\n                            \"type\": \"TextBlock\",\n                            \"text\": \"**2018** Berline 5p, Essence\",\n                            \"size\": \"Small\",\n                            \"wrap\": true\n                        },{\n      \"type\": \"ChartComponent\",\n      \"title\": \"Please wait...\",\n      \"value\": {\n        type: 'bar',\n        data: {\n            labels: ['Red', 'Blue', 'Yellow', 'Green', 'Purple', 'Orange'],\n            datasets: [{\n                label: '# of Votes',\n                data: [12, 19, 3, 5, 2, 3],\n                backgroundColor: [\n                    'rgba(255, 99, 132, 0.2)',\n                    'rgba(54, 162, 235, 0.2)',\n                    'rgba(255, 206, 86, 0.2)',\n                    'rgba(75, 192, 192, 0.2)',\n                    'rgba(153, 102, 255, 0.2)',\n                    'rgba(255, 159, 64, 0.2)'\n                ],\n                borderColor: [\n                    'rgba(255, 99, 132, 1)',\n                    'rgba(54, 162, 235, 1)',\n                    'rgba(255, 206, 86, 1)',\n                    'rgba(75, 192, 192, 1)',\n                    'rgba(153, 102, 255, 1)',\n                    'rgba(255, 159, 64, 1)'\n                ],\n                borderWidth: 1\n            }]\n        },\n        options: {\n            scales: {\n                yAxes: [{\n                    ticks: {\n                        beginAtZero: true\n                    }\n                }]\n            }\n        }\n    }\n    },\n                    ]\n                },\n                {\n                    \"type\": \"Column\",\n                    \"width\": 1,\n                    \"items\": [\n                        {\n                            \"type\": \"Image\",\n                            \"url\": \"https://www.car-revs-daily.com/wp-content/uploads/Car-Revs-Daily.com-2014-Honda-CR-Z-66.gif\",\n                            \"size\": \"auto\"\n                        }\n                    ]\n                }\n            ]\n        }\n    ],\n    \n    \"actions\": [\n        {\n      \"type\": \"Action.Stripe\",\n      \"title\": \"Payer\",\n      \"text\": \"missing params\",\n      \"key\":\"pk_test_uFwFmjGxwDPkDjaqjhnBPAEo00pfLZjjoY\",\n      \"session_id\":\"cs_test_fldnTJF7UeMIAAw2eaJ0Iht7kk9WSNYAh2xuzFa6mplvYkH387THHkKW\"\n        }\n    ]\n}\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":510,"y":1320,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"ae075e6e.8e191","type":"function","z":"8eb50c91.720f5","name":"stats","func":"msg.roomId = \"!LAMIpamyCBxUOVQhii:m.tekos.co\"\n\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"projected\": true,\n    \"adaptiveCard\":{\n  \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n  \"type\": \"AdaptiveCard\",\n  \"version\": \"1.0\",\n  \"body\": [\n    {\n      \"speak\": \"Tom's Pie is a Pizza restaurant which is rated 9.3 by customers.\",\n      \"type\": \"ColumnSet\",\n      \"columns\": [\n        {\n          \"type\": \"Column\",\n          \"width\": 2,\n          \"items\": [\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"PIZZA\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"Tom's Pie\",\n              \"weight\": \"bolder\",\n              \"size\": \"extraLarge\",\n              \"spacing\": \"none\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"4.2 ★★★☆ (93) · $$\",\n              \"isSubtle\": true,\n              \"spacing\": \"none\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"**Matt H. said** \\\"I'm compelled to give this place 5 stars due to the number of times I've chosen to eat here this past year!\\\"\",\n              \"size\": \"small\",\n              \"wrap\": true\n            }\n            \n              ]\n            },\n        {\n          \"type\": \"Column\",\n          \"width\": 1,\n          \"items\": [\n            {\n              \"type\": \"Image\",\n              \"url\": \"https://picsum.photos/300?image=882\",\n              \"size\": \"auto\"\n            }\n          ]\n        }\n      ]\n    },\n    {\n      \"type\": \"ChartComponent\",\n      \"title\": \"Please wait...\",\n      \"value\": {\n        type: 'doughnut',\n    data: {\n      labels: [\"Africa\", \"Asia\", \"Europe\", \"Latin America\", \"North America\"],\n      datasets: [\n        {\n          label: \"Population (millions)\",\n          backgroundColor: [\"#3e95cd\", \"#8e5ea2\",\"#3cba9f\",\"#e8c3b9\",\"#c45850\"],\n          data: [2478,5267,734,784,433]\n        }\n      ]\n    },\n    options: {\n      title: {\n        display: true,\n        text: 'Predicted world population (millions) in 2050'\n      }\n    }\n    }\n    }\n  ],\n  \"actions\": [\n \n    {\n      \"type\": \"Action.Cloudinary\",\n      \"title\": \"cloudinary\",\n      \"language\": \"fr\",\n      \"upload_text\": \"Télécharger 1 photo\",\n      \"cloudname\": \"digi-technologies\",\n      \"uploadpreset\": \"frvxsfj7\",\n      \"posturl\": \"https://spopin-dev.tekos.co/billing/contract/imagecompteur1/5ebac9ff0657f00012a7a0c8\",\n      \"buttontext\": \"Je choisis ma photo\",\n    },\n    {\n      \"type\": \"Action.Stripe\",\n      \"title\": \"Payer\",\n      \"text\": \"Hello world!\",\n      \"key\":\"pk_test_uFwFmjGxwDPkDjaqjhnBPAEo00pfLZjjoY\",\n      \"session_id\":\"cs_test_fldnTJF7UeMIAAw2eaJ0Iht7kk9WSNYAh2xuzFa6mplvYkH387THHkKW\"\n  }\n  ]\n}\n}\n\n\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"x":510,"y":1380,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"ff0ae399.d25f2","type":"function","z":"8eb50c91.720f5","name":"stats2","func":"msg.roomId = \"!LAMIpamyCBxUOVQhii:m.tekos.co\"\n\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n  \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n  \"type\": \"AdaptiveCard\",\n  \"version\": \"1.0\",\n  \"body\": [\n    {\n      \"speak\": \"Tom's Pie is a Pizza restaurant which is rated 9.3 by customers.\",\n      \"type\": \"ColumnSet\",\n      \"columns\": [\n        {\n          \"type\": \"Column\",\n          \"width\": 2,\n          \"items\": [\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"**Matt H. said** \\\"I'm compelled to give this place 5 stars due to the number of times I've chosen to eat here this past year!\\\"\",\n              \"size\": \"small\",\n              \"wrap\": true\n            }\n            \n              ]\n            }\n      ]\n    },\n{\n    type: 'doughnut',\n    data: {\n      labels: [\"Africa\", \"Asia\", \"Europe\", \"Latin America\", \"North America\"],\n      datasets: [\n        {\n          label: \"Population (millions)\",\n          backgroundColor: [\"#3e95cd\", \"#8e5ea2\",\"#3cba9f\",\"#e8c3b9\",\"#c45850\"],\n          data: [2478,5267,734,784,433]\n        }\n      ]\n    },\n    options: {\n      title: {\n        display: true,\n        text: 'Predicted world population (millions) in 2050'\n      }\n    }\n}\n  ],\n  \"actions\": [\n \n    {\n      \"type\": \"Action.Cloudinary\",\n      \"title\": \"cloudinary\",\n      \"language\": \"fr\",\n      \"upload_text\": \"Télécharger 1 photo\",\n      \"cloudname\": \"digi-technologies\",\n      \"uploadpreset\": \"frvxsfj7\",\n      \"posturl\": \"https://spopin-dev.tekos.co/billing/contract/imagecompteur1/5ebac9ff0657f00012a7a0c8\",\n      \"buttontext\": \"Je choisis ma photo\",\n    },\n    {\n      \"type\": \"Action.Stripe\",\n      \"title\": \"Payer\",\n      \"text\": \"Hello world!\",\n      \"key\":\"pk_test_uFwFmjGxwDPkDjaqjhnBPAEo00pfLZjjoY\",\n      \"session_id\":\"cs_test_fldnTJF7UeMIAAw2eaJ0Iht7kk9WSNYAh2xuzFa6mplvYkH387THHkKW\"\n  }\n  ]\n}\n}\n\n\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"x":470,"y":1240,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"7b2e1b0a.c0d2b4","type":"function","z":"8eb50c91.720f5","name":"Setup form","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"composer\": true,\n    \"adaptiveCard\":{\n  \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n  \"type\": \"AdaptiveCard\",\n  \"version\": \"1.0\",\n  \"body\": [\n    {\n      \"speak\": \"Tom's Pie is a Pizza restaurant which is rated 9.3 by customers.\",\n      \"type\": \"ColumnSet\",\n      \"columns\": [\n        {\n          \"type\": \"Column\",\n          \"width\": 2,\n          \"items\": [\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"**Matt H. said** \\\"I'm compelled to give this place 5 stars due to the number of times I've chosen to eat here this past year!\\\"\",\n              \"size\": \"small\",\n              \"wrap\": true\n            }\n            \n              ]\n            }\n      ]\n    },\n    {\n      \"type\": \"UploadComponent\",\n      \"id\":\"xyz\",\n      \"title\": \"Please wait...\",\n      \"value\": \"https://node-dev.tekos.co/uppload/images\"\n  },\n{\n    type: 'doughnut',\n    data: {\n      labels: [\"Africa\", \"Asia\", \"Europe\", \"Latin America\", \"North America\"],\n      datasets: [\n        {\n          label: \"Population (millions)\",\n          backgroundColor: [\"#3e95cd\", \"#8e5ea2\",\"#3cba9f\",\"#e8c3b9\",\"#c45850\"],\n          data: [2478,5267,734,784,433]\n        }\n      ]\n    },\n    options: {\n      title: {\n        display: true,\n        text: 'Predicted world population (millions) in 2050'\n      }\n    }\n}\n  ],\n  \"actions\": [\n    {\n      \"type\": \"Action.Stripe\",\n      \"title\": \"Payer\",\n      \"text\": \"Hello world!\",\n      \"key\":\"pk_test_uFwFmjGxwDPkDjaqjhnBPAEo00pfLZjjoY\",\n      \"session_id\":\"cs_test_fldnTJF7UeMIAAw2eaJ0Iht7kk9WSNYAh2xuzFa6mplvYkH387THHkKW\"\n  }\n  ]\n}\n}\n\n\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"x":510,"y":800,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"ba10c05b.0e04c","type":"function","z":"8eb50c91.720f5","name":"candles","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n  \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n  \"type\": \"AdaptiveCard\",\n  \"version\": \"1.0\",\n  \"body\": [\n    {\n      \"speak\": \"Tom's Pie is a Pizza restaurant which is rated 9.3 by customers.\",\n      \"type\": \"ColumnSet\",\n      \"columns\": [\n        {\n          \"type\": \"Column\",\n          \"width\": 2,\n          \"items\": [\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"PIZZA\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"Tom's Pie\",\n              \"weight\": \"bolder\",\n              \"size\": \"extraLarge\",\n              \"spacing\": \"none\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"4.2 ★★★☆ (93) · $$\",\n              \"isSubtle\": true,\n              \"spacing\": \"none\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"**Matt H. said** \\\"I'm compelled to give this place 5 stars due to the number of times I've chosen to eat here this past year!\\\"\",\n              \"size\": \"small\",\n              \"wrap\": true\n            }\n            \n              ]\n            },\n        {\n          \"type\": \"Column\",\n          \"width\": 1,\n          \"items\": [\n            {\n              \"type\": \"Image\",\n              \"url\": \"https://picsum.photos/300?image=882\",\n              \"size\": \"auto\"\n            }\n          ]\n        }\n      ]\n    },\n{\n\ttype: 'candlestick',\n\tdata: {\n\t\tdatasets: [{\n\t\t\tlabel: 'CHRT - Chart.js Corporation',\n//\t\t\tdata: getRandomData(initialDateStr, barCount)\n\t\t}]\n\t},\n\toptions: {\n\t\tscales: {\n\t\t\tx: {\n\t\t\t\tafterBuildTicks: function(scale) {\n\t\t\t\t\tconst majorUnit = scale._majorUnit;\n\t\t\t\t\tconst ticks = scale.ticks;\n\t\t\t\t\tconst firstTick = ticks[0];\n\t\t\t\t\tlet i, ilen, val, tick, currMajor, lastMajor;\n\n\t\t\t\t\tval = luxon.DateTime.fromMillis(ticks[0].value);\n\t\t\t\t\tif ((majorUnit === 'minute' && val.second === 0)\n\t\t\t\t\t\t\t|| (majorUnit === 'hour' && val.minute === 0)\n\t\t\t\t\t\t\t|| (majorUnit === 'day' && val.hour === 9)\n\t\t\t\t\t\t\t|| (majorUnit === 'month' && val.day <= 3 && val.weekday === 1)\n\t\t\t\t\t\t\t|| (majorUnit === 'year' && val.month === 0)) {\n\t\t\t\t\t\tfirstTick.major = true;\n\t\t\t\t\t} else {\n\t\t\t\t\t\tfirstTick.major = false;\n\t\t\t\t\t}\n\t\t\t\t\tlastMajor = val.get(majorUnit);\n\n\t\t\t\t\tfor (i = 1, ilen = ticks.length; i < ilen; i++) {\n\t\t\t\t\t\ttick = ticks[i];\n\t\t\t\t\t\tval = luxon.DateTime.fromMillis(tick.value);\n\t\t\t\t\t\tcurrMajor = val.get(majorUnit);\n\t\t\t\t\t\ttick.major = currMajor !== lastMajor;\n\t\t\t\t\t\tlastMajor = currMajor;\n\t\t\t\t\t}\n\t\t\t\t\treturn ticks;\n\t\t\t\t}\n\t\t\t}\n\t\t}\n\t}}\n  ],\n  \"actions\": [\n\n    {\n      \"type\": \"Action.Stripe\",\n      \"title\": \"Payer\",\n      \"text\": \"Hello world!\",\n      \"key\":\"pk_test_uFwFmjGxwDPkDjaqjhnBPAEo00pfLZjjoY\",\n      \"session_id\":\"cs_test_fldnTJF7UeMIAAw2eaJ0Iht7kk9WSNYAh2xuzFa6mplvYkH387THHkKW\"\n  }\n  ]\n}\n}\n\n\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"x":520,"y":1440,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"d5c87e9b.21347","type":"function","z":"8eb50c91.720f5","name":"--","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n  \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n  \"type\": \"AdaptiveCard\",\n  \"version\": \"1.0\",\n  \"body\": [\n    {\n      \"speak\": \"Tom's Pie is a Pizza restaurant which is rated 9.3 by customers.\",\n      \"type\": \"ColumnSet\",\n      \"columns\": [\n        {\n          \"type\": \"Column\",\n          \"width\": 2,\n          \"items\": [\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"PIZZA\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"Tom's Pie\",\n              \"weight\": \"bolder\",\n              \"size\": \"extraLarge\",\n              \"spacing\": \"none\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"4.2 ★★★☆ (93) · $$\",\n              \"isSubtle\": true,\n              \"spacing\": \"none\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"**Matt H. said** \\\"I'm compelled to give this place 5 stars due to the number of times I've chosen to eat here this past year!\\\"\",\n              \"size\": \"small\",\n              \"wrap\": true\n            }\n            \n              ]\n            },\n        {\n          \"type\": \"Column\",\n          \"width\": 1,\n          \"items\": [\n            {\n              \"type\": \"Image\",\n              \"url\": \"https://picsum.photos/300?image=882\",\n              \"size\": \"auto\"\n            }\n          ]\n        }\n      ]\n    },\n{\n\ttype: 'candlestick',\n\tdata: {\n\t\tdatasets: [{\n\t\t\tlabel: 'CHRT - Chart.js Corporation',\n\t\t\tdata: getRandomData(initialDateStr, barCount)\n\t\t}]\n\t},\n\toptions: {\n\t\tscales: {\n\t\t\tx: {\n\t\t\t\tafterBuildTicks: function(scale) {\n\t\t\t\t\tconst majorUnit = scale._majorUnit;\n\t\t\t\t\tconst ticks = scale.ticks;\n\t\t\t\t\tconst firstTick = ticks[0];\n\t\t\t\t\tlet i, ilen, val, tick, currMajor, lastMajor;\n\n\t\t\t\t\tval = luxon.DateTime.fromMillis(ticks[0].value);\n\t\t\t\t\tif ((majorUnit === 'minute' && val.second === 0)\n\t\t\t\t\t\t\t|| (majorUnit === 'hour' && val.minute === 0)\n\t\t\t\t\t\t\t|| (majorUnit === 'day' && val.hour === 9)\n\t\t\t\t\t\t\t|| (majorUnit === 'month' && val.day <= 3 && val.weekday === 1)\n\t\t\t\t\t\t\t|| (majorUnit === 'year' && val.month === 0)) {\n\t\t\t\t\t\tfirstTick.major = true;\n\t\t\t\t\t} else {\n\t\t\t\t\t\tfirstTick.major = false;\n\t\t\t\t\t}\n\t\t\t\t\tlastMajor = val.get(majorUnit);\n\n\t\t\t\t\tfor (i = 1, ilen = ticks.length; i < ilen; i++) {\n\t\t\t\t\t\ttick = ticks[i];\n\t\t\t\t\t\tval = luxon.DateTime.fromMillis(tick.value);\n\t\t\t\t\t\tcurrMajor = val.get(majorUnit);\n\t\t\t\t\t\ttick.major = currMajor !== lastMajor;\n\t\t\t\t\t\tlastMajor = currMajor;\n\t\t\t\t\t}\n\t\t\t\t\treturn ticks;\n\t\t\t\t}\n\t\t\t}\n\t\t}\n\t}}\n  ],\n  \"actions\": [\n\n    {\n      \"type\": \"Action.Stripe\",\n      \"title\": \"Payer\",\n      \"text\": \"Hello world!\",\n      \"key\":\"pk_test_uFwFmjGxwDPkDjaqjhnBPAEo00pfLZjjoY\",\n      \"session_id\":\"cs_test_fldnTJF7UeMIAAw2eaJ0Iht7kk9WSNYAh2xuzFa6mplvYkH387THHkKW\"\n  }\n  ]\n}\n}\n\n\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"x":505.0173645019531,"y":1492.67724609375,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"7254d5b3.9e3abc","type":"function","z":"8eb50c91.720f5","name":"annotation ?","func":"msg.roomId = \"!WftKgGpsCEMbOXvEMb:m.tekos.co\"\n\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n    \"adaptiveCard\":{\n  \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n  \"type\": \"AdaptiveCard\",\n  \"version\": \"1.0\",\n  \"body\": [\n    {\n      \"speak\": \"Tom's Pie is a Pizza restaurant which is rated 9.3 by customers.\",\n      \"type\": \"ColumnSet\",\n      \"columns\": [\n        {\n          \"type\": \"Column\",\n          \"width\": 2,\n          \"items\": [\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"PIZZA\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"Tom's Pie\",\n              \"weight\": \"bolder\",\n              \"size\": \"extraLarge\",\n              \"spacing\": \"none\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"4.2 ★★★☆ (93) · $$\",\n              \"isSubtle\": true,\n              \"spacing\": \"none\"\n            },\n            {\n              \"type\": \"TextBlock\",\n              \"text\": \"**Matt H. said** \\\"I'm compelled to give this place 5 stars due to the number of times I've chosen to eat here this past year!\\\"\",\n              \"size\": \"small\",\n              \"wrap\": true\n            }\n            \n              ]\n            },\n        {\n          \"type\": \"Column\",\n          \"width\": 1,\n          \"items\": [\n            {\n              \"type\": \"Image\",\n              \"url\": \"https://picsum.photos/300?image=882\",\n              \"size\": \"auto\"\n            }\n          ]\n        }\n      ]\n    },\n    {\n      \"type\": \"ChartComponent\",\n      \"title\": \"Please wait...\",\n      \"value\": {\n        type: 'doughnut',\n    data: {\n      labels: [\"Africa\", \"Asia\", \"Europe\", \"Latin America\", \"North America\"],\n      datasets: [\n        {\n          label: \"Population (millions)\",\n          backgroundColor: [\"#3e95cd\", \"#8e5ea2\",\"#3cba9f\",\"#e8c3b9\",\"#c45850\"],\n          data: [2478,5267,734,784,433]\n        }\n      ]\n    },\n    options: {\n      title: {\n        display: true,\n        text: 'Predicted world population (millions) in 2050'\n      }\n    }\n    }\n    }\n  ],\n  \"actions\": [\n \n    {\n      \"type\": \"Action.Cloudinary\",\n      \"title\": \"cloudinary\",\n      \"language\": \"fr\",\n      \"upload_text\": \"Télécharger 1 photo\",\n      \"cloudname\": \"digi-technologies\",\n      \"uploadpreset\": \"frvxsfj7\",\n      \"posturl\": \"https://spopin-dev.tekos.co/billing/contract/imagecompteur1/5ebac9ff0657f00012a7a0c8\",\n      \"buttontext\": \"Je choisis ma photo\",\n    },\n    {\n      \"type\": \"Action.Stripe\",\n      \"title\": \"Payer\",\n      \"text\": \"Hello world!\",\n      \"key\":\"pk_test_uFwFmjGxwDPkDjaqjhnBPAEo00pfLZjjoY\",\n      \"session_id\":\"cs_test_fldnTJF7UeMIAAw2eaJ0Iht7kk9WSNYAh2xuzFa6mplvYkH387THHkKW\"\n  }\n  ]\n}\n}\n\n\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"x":530,"y":1540,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"25d86054.0a3d3","type":"function","z":"8eb50c91.720f5","name":"button for composer","func":"msg.roomId = \"!vuokOWexnWBKlcvOYP:m.tekos.co\"\n\nmsg.url = \"https://\"+env.get(\"BASE_URL\")+\"/_matrix/client/r0/rooms/\"+msg.roomId+\"/send/m.room.message?access_token=\"+env.get(\"TEKOS_BOT_TOKEN\");\nmsg.payload={\n    \"body\": \"\",\n    \"msgtype\": \"m.text\",\n     \"composer\": true,\n    \"adaptiveCard\":\n    {\n    \"type\": \"AdaptiveCard\",\n    \"body\": [\n        {\n            \"type\": \"TextBlock\",\n            \"size\": \"Medium\",\n            \"weight\": \"Bolder\",\n            \"text\": \"Select a value\"\n        }\n    ],\n    \"actions\": [\n        {\n            \"type\": \"Action.OpenUrl\",\n            \"title\": \"Button 2\",\n            \"url\": \"https://tekos.co\",\n            \"style\": \"destructive\"\n        },\n        {\n            \"type\": \"Action.Submit\",\n            \"title\": \"Button 3\",\n                 \"data\":{\n         \"postback\":\"hello world\"\n     }\n        }\n    ],\n    \"$schema\": \"http://adaptivecards.io/schemas/adaptive-card.json\",\n    \"version\": \"1.2\"\n}\n\n\n}\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":520,"y":740,"wires":[["e1c6454e.772618"]],"icon":"node-red/debug.svg"},{"id":"84742093.1726c","type":"inject","z":"8eb50c91.720f5","name":"wire me","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":1000,"wires":[["c9f65f0f.c3fed"]]}]
Created 5 years, 1 month ago
  • function (x18)
  • http request (x1)
