Sample flow for analog alarm monitoring system
This is a sample flow demonstrating usage of node-red-contrib-analog-alarm-monitor node.
This node is used for monitoring analog alarms that occur in process control and is useful for monitoring parameters like temperature, pressure, RH, Flow speed, RPM etc.
This node expects numberical input obtained from PLC - or from MQTT topic.
This sample takes input from MODBUS node for monitoring voltage count
[{"id":"eb97df44403320ac","type":"tab","label":"analog","disabled":false,"info":"","env":[]},{"id":"70387482f5d44110","type":"analog-alarm","z":"eb97df44403320ac","name":"Shop Floor Voltage","hiLimit":"242","hihiLimit":"250","loLimit":"238","loloLimit":"230","deadband":"2","areaName":"Shop Floor","alarmDescription":"Shop Floor Voltage","x":670,"y":120,"wires":[["5317a0edd4041749"]],"icon":"font-awesome/fa-bell-o"},{"id":"e586ec4182aae656","type":"modbus-read","z":"eb97df44403320ac","name":"SDM 120 Voltage","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"showWarnings":true,"unitid":"1","dataType":"InputRegister","adr":"0","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"b69d19ed.84d768","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":160,"y":120,"wires":[["efc8e3998bdc2f21"],[]]},{"id":"efc8e3998bdc2f21","type":"energy-meter","z":"eb97df44403320ac","name":"","x":370,"y":120,"wires":[["70387482f5d44110"]]},{"id":"5317a0edd4041749","type":"debug","z":"eb97df44403320ac","name":"Output","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":930,"y":120,"wires":[]},{"id":"da67d93d5e97977f","type":"comment","z":"eb97df44403320ac","name":"Sample Analog Alarm Handling ","info":"(c) Bufferstack.IO Analytics Technology LLP","x":210,"y":40,"wires":[]},{"id":"83828aee394ba88b","type":"comment","z":"eb97df44403320ac","name":"This node will start operations only if boolean input true with topic - enable is sent to it","info":"Send this signal from PLC\n\n(c) Bufferstack.IO Analytics Technology LLP, 2023 ","x":710,"y":200,"wires":[]},{"id":"b69d19ed.84d768","type":"modbus-client","name":"Serial_2400_8_N_1","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":true,"queueLogEnabled":false,"failureLogEnabled":false,"tcpHost":"10.10.100.254","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"","unit_id":"1","commandDelay":"30","clientTimeout":"2000","reconnectOnTimeout":true,"reconnectTimeout":"5000","parallelUnitIdsAllowed":false}]
