flespi device disconnected more than 10s - telegram notification
Sometimes it is useful to know that some of your devices are disconnected from flespi servers or unavailable for a long time.
This example shows how quickly and easily it is possible to set up a notification using NodeRed that devices are not available for more than 10 seconds.
You can freely change the response time or change how to notify you.
For example, it may not be a telegram bot, but a REST API request to some service.
[{"id":"47285342.2138ec","type":"tab","label":"Disconnected device","disabled":false,"info":""},{"id":"d2781dc0.2e318","type":"mqtt in","z":"47285342.2138ec","name":"","topic":"flespi/state/gw/devices/+/connected","qos":"2","datatype":"utf8","broker":"b76fa1b5.ce51","x":220,"y":220,"wires":[["84bf212f.09e3f"]]},{"id":"c18064a9.df40f8","type":"debug","z":"47285342.2138ec","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":670,"y":80,"wires":[]},{"id":"84bf212f.09e3f","type":"trigger","z":"47285342.2138ec","name":"Wait for it (c) Barney (10s)","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"10","extend":true,"overrideDelay":false,"units":"s","reset":"true","bytopic":"topic","topic":"topic","outputs":1,"x":490,"y":220,"wires":[["6a9a1525.6ec80c"]]},{"id":"cfc279b2.2358d8","type":"telegram sender","z":"47285342.2138ec","name":"","bot":"6eaebea0.ccff3","haserroroutput":false,"outputs":1,"x":950,"y":220,"wires":[[]]},{"id":"f5d183b1.7b7fa","type":"telegram receiver","z":"47285342.2138ec","name":"","bot":"6eaebea0.ccff3","saveDataDir":"","filterCommands":false,"x":170,"y":80,"wires":[["71890518.2a56bc"],["71890518.2a56bc"]]},{"id":"6a9a1525.6ec80c","type":"function","z":"47285342.2138ec","name":"Prepre telegram message","func":"var id = msg.topic.split('/')[4]\nvar chats = flow.get('chats') || {}\nvar messages = []\nfor (var chatId in chats) {\n    messages.push({topic: msg.topic, payload: {content: `Device ${id} offline for a long time.`, type: 'message', chatId: chatId}})\n}\nreturn [messages];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":730,"y":220,"wires":[["cfc279b2.2358d8"]]},{"id":"71890518.2a56bc","type":"function","z":"47285342.2138ec","name":"Subscribe/Unsubscribe commands","func":"var chats = flow.get('chats') || {}\nif (msg.payload.content === '/subscribe') {\n    chats[msg.payload.chatId] = true\n}\nif (msg.payload.content === '/unsubscribe') {\n    delete chats[msg.payload.chatId]\n}\nflow.set('chats', chats)\nreturn msg;","outputs":1,"noerr":0,"initialize":"flow.set('chats', {})","finalize":"","x":440,"y":80,"wires":[["c18064a9.df40f8"]]},{"id":"59599288.5080ec","type":"comment","z":"47285342.2138ec","name":"Please use /subscribe bot command after each restart.","info":"","x":280,"y":140,"wires":[],"icon":"node-red/alert.svg"},{"id":"b76fa1b5.ce51","type":"mqtt-broker","name":"","broker":"mqtt.flespi.io","port":"1883","clientid":"noderedtest","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"6eaebea0.ccff3","type":"telegram bot","botname":"Telegram notify bot","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","botpath":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false}]
Created 5 years ago
Rating: 5 1
  • function (x2)
  • mqtt in (x1)
  • mqtt-broker (x1)
  • trigger (x1)
  • telegram
  • flespi
  • device
  • notification
  • disconnected
