Convert string to number
Use one of the subflows to convert a string to a number with a certain precision.
[{"id":"b93e45af3c94722f","type":"subflow","name":"x","info":"","category":"","in":[{"x":60,"y":70,"wires":[{"id":"dc2a255c78f08d30"}]}],"out":[{"x":360,"y":70,"wires":[{"id":"dc2a255c78f08d30","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"dc2a255c78f08d30","type":"change","z":"b93e45af3c94722f","name":"Convert to 0","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t\t","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$round(msg.payload, 0)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":210,"y":70,"wires":[[]]},{"id":"85f954b04cbf1a86","type":"subflow","name":"0.x","info":"","category":"","in":[{"x":60,"y":70,"wires":[{"id":"94cb59f282c2c911"}]}],"out":[{"x":370,"y":70,"wires":[{"id":"94cb59f282c2c911","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"94cb59f282c2c911","type":"change","z":"85f954b04cbf1a86","name":"Convert to 0.x","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t\t","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$round(msg.payload, 1)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":70,"wires":[[]]},{"id":"67f230edb50925f4","type":"subflow","name":"0.xxx","info":"","category":"","in":[{"x":60,"y":75,"wires":[{"id":"1fc82f706034e994"},{"id":"40c79a60976a1ca5"}]}],"out":[{"x":315,"y":75,"wires":[{"id":"1fc82f706034e994","port":0},{"id":"40c79a60976a1ca5","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"1fc82f706034e994","type":"function","z":"67f230edb50925f4","d":true,"name":"0.xxx","func":"msg.payload = msg.payload.toFixed(3);\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":190,"y":75,"wires":[[]]},{"id":"40c79a60976a1ca5","type":"change","z":"67f230edb50925f4","name":"Convert to 0.xxx","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t\t","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$round(msg.payload, 3)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":180,"y":160,"wires":[[]]},{"id":"3f235640b7cb44a9","type":"subflow","name":"0.xx","info":"","category":"","in":[{"x":60,"y":75,"wires":[{"id":"87ed2ab53564d859"},{"id":"57918fca3037144d"}]}],"out":[{"x":315,"y":75,"wires":[{"id":"57918fca3037144d","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"87ed2ab53564d859","type":"function","z":"3f235640b7cb44a9","d":true,"name":"0.xx","func":"msg.payload = msg.payload.toFixed(2);\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":185,"y":75,"wires":[[]]},{"id":"57918fca3037144d","type":"change","z":"3f235640b7cb44a9","name":"Convert to 0.xx","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t\t","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$round(msg.payload, 2)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":210,"y":160,"wires":[[]]},{"id":"71c787c4d13f368f","type":"tab","label":"Convert string to number","disabled":false,"info":"","env":[]},{"id":"1fc367c9d04e30fb","type":"change","z":"71c787c4d13f368f","name":"Convert to number","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":950,"y":210,"wires":[["2b09fc1390e99d20"]]},{"id":"f6d82b6fb4d308ea","type":"inject","z":"71c787c4d13f368f","name":"\"15.2222\"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"\"15.2222\"","payloadType":"jsonata","x":680,"y":180,"wires":[["1fc367c9d04e30fb","0630728fb822617b","5e722dbbf5e1c438","a6682807a4f8cbae","86c5b6ec27dc3c23","2b09fc1390e99d20"]]},{"id":"2b09fc1390e99d20","type":"debug","z":"71c787c4d13f368f","name":"debug 34","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1260,"y":180,"wires":[]},{"id":"0630728fb822617b","type":"subflow:3f235640b7cb44a9","z":"71c787c4d13f368f","name":"","x":940,"y":370,"wires":[["2b09fc1390e99d20"]]},{"id":"5e722dbbf5e1c438","type":"subflow:67f230edb50925f4","z":"71c787c4d13f368f","name":"","x":940,"y":410,"wires":[["2b09fc1390e99d20"]]},{"id":"a6682807a4f8cbae","type":"subflow:85f954b04cbf1a86","z":"71c787c4d13f368f","name":"0.x","x":940,"y":330,"wires":[["2b09fc1390e99d20"]]},{"id":"86c5b6ec27dc3c23","type":"subflow:b93e45af3c94722f","z":"71c787c4d13f368f","name":"","x":940,"y":290,"wires":[["2b09fc1390e99d20"]]}]
Created 9 months, 2 weeks ago
  • change (x5)
  • function (x2)
  • subflow (x4)
  • subflow:3f235640b7cb44a9 (x1)
  • subflow:67f230edb50925f4 (x1)
  • subflow:85f954b04cbf1a86 (x1)
  • subflow:b93e45af3c94722f (x1)
  • string
  • number
  • precision
