IKEA Tradfri Dimmer in NodeRED
I'm recreating the original functionality of the IKEA TRADFRI Wireless Dimmer in NodeRed so you could use the button with any NodeRED enabled devices, not just IKEA ones! enter image description here
Instructions: You can read all set up instructions here
Features:
  • ON|OFF toggle
  • Brightness UP|DOWN
  • Custom increment step
Settings
  • Step increment brightness by X
More about me:
[{"id":"67f9a36c.f4a1fc","type":"subflow","name":"Dimmer Settings","info":"","category":"","in":[{"x":400,"y":80,"wires":[{"id":"67fe2056.d8cd7"}]}],"out":[{"x":620,"y":80,"wires":[{"id":"67fe2056.d8cd7","port":0}]}],"env":[{"name":"Step","type":"num","value":"30"}],"color":"#3FADB5","icon":"node-red/cog.svg"},{"id":"67fe2056.d8cd7","type":"function","z":"67f9a36c.f4a1fc","name":"Step","func":"var x = env.get(\"Step\"); \nflow.set(\"$parent.Step\", x);\n\nmsg.payload = \"Your brightness increment has been set to: \" + x;\n\nreturn msg;","outputs":1,"noerr":0,"x":510,"y":80,"wires":[[]]},{"id":"b940d21c.1fff3","type":"tab","label":"IKEA Dimmer in NodeRED","disabled":false,"info":"I'm recreating the original functionality of the IKEA TRADFRI Wireless Dimmer in NodeRed so you could use the button with any NodeRED enabled devices, not just IKEA ones!\n![enter image description here](https://notenoughtech.com/wp-content/uploads/2019/11/YouTube-Thumb-4.jpg)\n\n**Instructions:**\nYou can read all [set up instructions here](https://notenoughtech.com/featured/ikea-tradfri-wireless-dimmer-in-nodered/)\n\n---\n\n**Features**:\n\n-   ON|OFF toggle\n-   Brightness UP|DOWN\n-   Custom increment step\n\n---\n# Settings\n - **Step** increment brightness by X "},{"id":"c786b38d.959c2","type":"switch","z":"b940d21c.1fff3","name":"Messages","property":"payload.click","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"},{"t":"eq","v":"brightness_stop","vt":"str"},{"t":"eq","v":"brightness_up","vt":"str"},{"t":"eq","v":"brightness_down","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":310,"y":320,"wires":[["e6af827.9be108"],["d39b4454.a0cc78"],["d9fd37b3.5511c8"],["dc0cf8a0.604028","359b8cf5.78b704"],["cebc76c0.d58538","359b8cf5.78b704"]]},{"id":"dc0cf8a0.604028","type":"function","z":"b940d21c.1fff3","name":"Brightness up","func":"var step = flow.get(\"Step\");\nvar brightness =  flow.get(\"IKEA_bulb1_brightness\");\n\nif(brightness > 0){\n    brightness = brightness + step;\n    flow.set(\"IKEA_bulb1_brightness\", brightness);\n\t}\n\t\nif(brightness >= 255){\n    brightness = 254;\n    flow.set('press', false);\n    flow.set(\"IKEA_bulb1_brightness\", brightness);\n    }\n\nmsg.payload = {\"state\":\"ON\",\n               \"brightness\":brightness};\nreturn msg;","outputs":1,"noerr":0,"x":500,"y":560,"wires":[["aab4e92d.c91e28","51644345.67539c"]]},{"id":"cebc76c0.d58538","type":"function","z":"b940d21c.1fff3","name":"Brightness down","func":"var step = flow.get(\"Step\");\nvar brightness =  flow.get(\"IKEA_bulb1_brightness\");\n\nif(brightness <= 255){\n    brightness = brightness - step; \n    flow.set(\"IKEA_bulb1_brightness\", brightness);\n\t}\n\t\nif(brightness <= 0){\n    brightness = 1;\n    flow.set('press', false);\n    flow.set(\"IKEA_bulb1_brightness\", brightness);\n    }\n\nmsg.payload = {\"state\":\"ON\",\n               \"brightness\":brightness};\nreturn msg;","outputs":1,"noerr":0,"x":500,"y":600,"wires":[["aab4e92d.c91e28","bf17a32.3347d6"]]},{"id":"b132cd47.5361c","type":"switch","z":"b940d21c.1fff3","name":"Control loop","property":"press","propertyType":"flow","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":870,"y":740,"wires":[["cebc76c0.d58538"]]},{"id":"420aac7b.c64574","type":"switch","z":"b940d21c.1fff3","name":"Control loop","property":"press","propertyType":"flow","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":870,"y":780,"wires":[["dc0cf8a0.604028"]]},{"id":"51644345.67539c","type":"delay","z":"b940d21c.1fff3","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":570,"y":780,"wires":[["420aac7b.c64574"]]},{"id":"bf17a32.3347d6","type":"delay","z":"b940d21c.1fff3","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":570,"y":740,"wires":[["b132cd47.5361c"]]},{"id":"b94acd19.7caef","type":"comment","z":"b940d21c.1fff3","name":"loop every 500 ms","info":"","x":570,"y":700,"wires":[]},{"id":"7f69520d.788e3c","type":"comment","z":"b940d21c.1fff3","name":"increase/decrease brightness","info":"","x":500,"y":520,"wires":[]},{"id":"359b8cf5.78b704","type":"change","z":"b940d21c.1fff3","name":"start","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":360,"wires":[["30695df.bdaa9a2"]]},{"id":"d9fd37b3.5511c8","type":"change","z":"b940d21c.1fff3","name":"stop","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":400,"wires":[["30695df.bdaa9a2"]]},{"id":"30695df.bdaa9a2","type":"change","z":"b940d21c.1fff3","name":"Control the loop","rules":[{"t":"set","p":"press","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":375,"wires":[[]]},{"id":"99938687.36ff98","type":"comment","z":"b940d21c.1fff3","name":"start/stop loop","info":"","x":690,"y":345,"wires":[]},{"id":"da10d307.eded8","type":"mqtt in","z":"b940d21c.1fff3","name":"IKEA Light","topic":"zigbee2mqtt/ikeabulbc1","qos":"2","datatype":"json","broker":"eca6af44.5297b","x":120,"y":180,"wires":[["8a13f8be.ca9058"]]},{"id":"aab4e92d.c91e28","type":"mqtt out","z":"b940d21c.1fff3","name":"IKEA Light Control","topic":"zigbee2mqtt/ikeabulbc1/set","qos":"","retain":"","broker":"eca6af44.5297b","x":950,"y":260,"wires":[]},{"id":"4ac241f7.278ac","type":"debug","z":"b940d21c.1fff3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":730,"y":180,"wires":[]},{"id":"394c130c.943f4c","type":"mqtt out","z":"b940d21c.1fff3","name":"IKEA Light Status","topic":"zigbee2mqtt/ikeabulbc1/get","qos":"","retain":"","broker":"eca6af44.5297b","x":450,"y":120,"wires":[]},{"id":"e79a3c52.ae408","type":"inject","z":"b940d21c.1fff3","name":"","topic":"","payload":"{\"state\":\"\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":120,"wires":[["394c130c.943f4c"]]},{"id":"e6af827.9be108","type":"function","z":"b940d21c.1fff3","name":"ON","func":"msg.payload = { \"state\":\"ON\"};\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":260,"wires":[["aab4e92d.c91e28"]]},{"id":"d39b4454.a0cc78","type":"function","z":"b940d21c.1fff3","name":"OFF","func":"msg.payload = { \"state\":\"OFF\"};\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":300,"wires":[["aab4e92d.c91e28"]]},{"id":"8a13f8be.ca9058","type":"delay","z":"b940d21c.1fff3","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":390,"y":180,"wires":[["523a3a9a.7d63f4"]]},{"id":"523a3a9a.7d63f4","type":"function","z":"b940d21c.1fff3","name":"Update","func":"\nflow.set(\"IKEA_bulb1_brightness\", msg.payload.brightness);\n\nreturn msg;","outputs":1,"noerr":0,"x":560,"y":180,"wires":[["4ac241f7.278ac"]]},{"id":"79841cb4.d328e4","type":"inject","z":"b940d21c.1fff3","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":60,"wires":[["c5ad66b8.e13328"]]},{"id":"c5ad66b8.e13328","type":"subflow:67f9a36c.f4a1fc","z":"b940d21c.1fff3","name":"","env":[],"x":320,"y":60,"wires":[["865a0e53.ef584"]]},{"id":"865a0e53.ef584","type":"debug","z":"b940d21c.1fff3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":510,"y":60,"wires":[]},{"id":"c10f24b5.2fcc78","type":"mqtt in","z":"b940d21c.1fff3","name":"IKEA Button","topic":"zigbee2mqtt/ikeadimmerbronze","qos":"1","datatype":"json","broker":"eca6af44.5297b","x":90,"y":320,"wires":[["c786b38d.959c2"]]},{"id":"eca6af44.5297b","type":"mqtt-broker","z":"","name":"MQTT","broker":"dockerpi.local","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Created 7 years, 7 months ago
Updated 7 years, 5 months ago
  • change (x3)
  • comment (x3)
  • debug (x2)
  • delay (x3)
  • function (x6)
  • inject (x2)
  • mqtt in (x2)
  • mqtt out (x2)
  • mqtt-broker (x1)
  • switch (x3)
  • subflow (x1)
  • subflow:67f9a36c.f4a1fc (x1)
  • IKEA
  • Tradfri
  • Dimmer
  • Button
  • Toggle
  • Zigbee
  • lights
