Automated Meter Reading for Dynamic Electricity Tariffs
  • Capture meter readings from smart meters via the iMSys or alternative reading device and feed this data to the NodeRED environment.
  • Continuously update meter readings (via SendReading node) and dynamically adjust device operation according to the latest tariff information to ensure cost optimization.
  • Use the nr-eaf-amr node to query the energy supplier or aggregator's backend to retrieve the current dynamic tariffs.
  • Implement decision logic based on the BestPrice node in the flow to determine whether to activate or deactivate a device based on the retrieved tariffs.
  • If the tariff indicates lower energy costs, send a signal to switch the device on; if the tariff is higher, send a signal to switch the device off.
[{"id":"18344b3760372061","type":"tab","label":"Automated Meter Reading - with Automation","disabled":false,"info":"**Demonstrates on how to use Node-RED to transmit high frequent meter readings to a utility as required for dynamic electricity tariffs.**\r\n\r\nUse tariff information provided to switch devices on/off.","env":[]},{"id":"dbbf0f980d0f24e6","type":"inject","z":"18344b3760372061","name":"Get Tariff Information","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":200,"wires":[["4beaa3462a1036d6"]]},{"id":"db4537d3078e1451","type":"debug","z":"18344b3760372061","name":"Electricity Cost","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload.clearing.cost","targetType":"msg","statusVal":"payload.cost","statusType":"auto","x":800,"y":100,"wires":[]},{"id":"2dafa293543c34b2","type":"SendReading","z":"18344b3760372061","name":"Send Reading","eafcredentials":"61662e8477efa535","x":580,"y":100,"wires":[["db4537d3078e1451"]]},{"id":"4beaa3462a1036d6","type":"Tariff","z":"18344b3760372061","name":"Requect Prices","eafcredentials":"61662e8477efa535","x":420,"y":200,"wires":[["a58e41ef98100861"]]},{"id":"94f3bd81eb7c67c0","type":"debug","z":"18344b3760372061","name":"Device On?","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":850,"y":200,"wires":[]},{"id":"a58e41ef98100861","type":"BestPrice","z":"18344b3760372061","name":"Only lowest price","periods":"1","x":650,"y":200,"wires":[["94f3bd81eb7c67c0"]]},{"id":"8d41207a9ceb73b9","type":"inject","z":"18344b3760372061","name":"Meter Reading  in Wh (here timestamp)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"20","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":240,"y":100,"wires":[["2dafa293543c34b2"]]},{"id":"61662e8477efa535","type":"eaf-credentials","baseUrl":"http://172.29.79.193:3001","meterId":"demo","activationSecret":"","readingToken":"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJtZXRlcklkIjoiZGVtbyIsImlhdCI6MTcwMzA4MDc1NCwiZXhwIjoxNzAzNjg1NTU0LCJhdWQiOiJodHRwczovL3RhcmlmZi5zdGFkdHdlcmstbXVzdGVyc3RhZHQuZGUiLCJpc3MiOiJTdGFkdHdlcmsgTXVzdGVyc3RhZHQiLCJzdWIiOiJFQUYifQ.NDIba5NdFJGk9HXPcxeRbkbXaj1aNhCNA4bDtj-QiUSRD7TDsmyRuSyWHXe_StXFlQeXQfivIVuyyMV9mwY_u-YLI4y3Pf19cr6AGx0Lsp4AiA9EH5MSbNxE067SMIpdyrjj_AhOf1lfTRP_NHnycdeJt7J0vtjiDVz2bs5k1hoJLJfIAx62J4DIFsxEv6no8V6JAYXsW6sB39TAJT-L1dxTnbrLjvuK207mNYC26FQJ4l-lM2yfdOGox30kVKr-9H0DHMuuM9-PV_htOPAzP8kSnUpXwuuOupOy3kU-7fMSr-ZX0LjJQPp_dwQ14AjsUVNBsT0d3RQwyIXocfsk7g","name":"Demo"}]
Created 1 year, 7 months ago
  • debug (x2)
  • inject (x2)
  • energy
  • dynamic
  • tariff
  • eaf
  • stromdao
