Node-RED flows with GPS multiunit SORACOM edition
Node-RED flow using GPS Multiunit SORACOM Edition. Each sub flow has the following functionality.
  • World map: Plot the current location on world map.
  • Dashboard: Show temperature, humidity, and battery level.
  • Direction: Show the direction of GPS multiunit.
  • Monitor: Monitor the current location. Once the out of bounds data was detected, send data to MQTT broker.
This site explains how to use GPS multiunit SORACOM Edition. This site explains how to send data to Node-RED server with SORACOM beam.
GPSマルチユニット SORACOM Editionを利用したNode-REDのフローです。サブフローごとに以下のことができます。
  • World map:地図上に現在位置をプロットします。
  • Dashbord:温湿度とバッテリーの状態を表示します。
  • Direction:GPSマルチユニットの向きを表示します。
  • Monitor:位置情報を監視し、範囲外の位置を検出した場合MQTTブローカーにデータを送信します。
GPSマルチユニット SORACOM Editionを利用する手順はこちらを、 SORACOM Beamを利用してNode-REDサーバへデータを送信する手順については、こちらを参考にしてください。
[{"id":"87d6c779.359978","type":"tab","label":"GPS","disabled":false,"info":""},{"id":"462baeec.62b32","type":"subflow","name":"Monitor","info":"","category":"","in":[{"x":140,"y":120,"wires":[{"id":"b5a3fb96.c072c8"}]}],"out":[],"env":[],"color":"#DDAA99"},{"id":"9adbcc70.51bb9","type":"subflow","name":"Direction","info":"","category":"","in":[{"x":80,"y":140,"wires":[{"id":"6efd1ae7.4c8924"}]}],"out":[],"env":[],"color":"#DDAA99"},{"id":"1aaec155.5f990f","type":"subflow","name":"Dashboard","info":"","category":"","in":[{"x":200,"y":260,"wires":[{"id":"e296aa06.de2ef8"},{"id":"9d3bb96b.efa558"},{"id":"debf08b3.80fa28"}]}],"out":[],"env":[],"color":"#DDAA99"},{"id":"e65cea23.dee568","type":"subflow","name":"World map","info":"","category":"","in":[{"x":140,"y":80,"wires":[{"id":"d323a060.c059"}]}],"out":[],"env":[],"color":"#DDAA99"},{"id":"61d03c95.0a2db4","type":"ui_tab","z":"","name":"GPS multiunit SORACOM Edition","icon":"dashboard","disabled":false,"hidden":false},{"id":"ec8d0081.dc226","type":"ui_group","z":"","name":"","tab":"61d03c95.0a2db4","order":1,"disp":true,"width":"12","collapse":false},{"id":"655b93d0.a8770c","type":"ui_base","theme":{"name":"theme-light","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#0094CE","value":"#0094CE","edited":false},"page-titlebar-backgroundColor":{"value":"#0094CE","edited":false},"page-backgroundColor":{"value":"#fafafa","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#1bbfff","edited":false},"group-borderColor":{"value":"#ffffff","edited":false},"group-backgroundColor":{"value":"#ffffff","edited":false},"widget-textColor":{"value":"#111111","edited":false},"widget-backgroundColor":{"value":"#0094ce","edited":false},"widget-borderColor":{"value":"#ffffff","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey"}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","lockMenu":"false","allowTempTheme":"true","dateFormat":"YYYY/MM/DD","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"687033c3.e5588c","type":"ui_group","name":"Group 2","tab":"61d03c95.0a2db4","order":2,"disp":true,"width":6},{"id":"76f14af8.3ee784","type":"mqtt-broker","z":"462baeec.62b32","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"bf2ccd43.9c498","type":"mqtt-broker","z":"","name":"","broker":"localhost","port":"1883","tls":"","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"bd49f0e9.6add4","type":"mqtt-broker","z":"","name":"remote","broker":"52.69.55.196","port":"1883","tls":"","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"c7f47902.e6e668","type":"http in","z":"87d6c779.359978","name":"","url":"/gps","method":"post","upload":false,"swaggerDoc":"","x":100,"y":100,"wires":[["31944a1b.e44156","3ddbced.78fcf32"]]},{"id":"31944a1b.e44156","type":"http response","z":"87d6c779.359978","name":"HTTP response","statusCode":"","headers":{},"x":320,"y":160,"wires":[]},{"id":"2b9dcfbc.cf716","type":"ui_gauge","z":"1aaec155.5f990f","name":"","group":"ec8d0081.dc226","order":3,"width":"6","height":"6","gtype":"gage","title":"Temperature","label":"units","format":"{{value}}","min":0,"max":"40","colors":["#00b500","#e6e600","#ca3838"],"seg1":"30","seg2":"35","x":650,"y":180,"wires":[]},{"id":"ca6b77a0.fb9298","type":"ui_gauge","z":"1aaec155.5f990f","name":"","group":"ec8d0081.dc226","order":2,"width":"6","height":"6","gtype":"gage","title":"Humidity","label":"units","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"35","seg2":"70","x":640,"y":260,"wires":[]},{"id":"e296aa06.de2ef8","type":"change","z":"1aaec155.5f990f","name":"temperature","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.temp","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":180,"wires":[["2b9dcfbc.cf716","1a2b2ecb.f1d971"]]},{"id":"9d3bb96b.efa558","type":"change","z":"1aaec155.5f990f","name":"humidity","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.humi","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":260,"wires":[["ca6b77a0.fb9298"]]},{"id":"1a2b2ecb.f1d971","type":"ui_chart","z":"1aaec155.5f990f","name":"","group":"ec8d0081.dc226","order":1,"width":0,"height":0,"label":"Temperature chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":670,"y":120,"wires":[[]]},{"id":"debf08b3.80fa28","type":"change","z":"1aaec155.5f990f","name":"battery level","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.bat","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":340,"wires":[["93d2baae.fa2a98"]]},{"id":"93d2baae.fa2a98","type":"ui_gauge","z":"1aaec155.5f990f","name":"","group":"ec8d0081.dc226","order":4,"width":"6","height":"3","gtype":"gage","title":"Battery Level","label":"units","format":"{{value}}","min":"0","max":"3","colors":["#ca3838","#e6e600","#00b500"],"seg1":"1","seg2":"2","x":650,"y":340,"wires":[]},{"id":"85ec862e.ffee28","type":"subflow:462baeec.62b32","z":"87d6c779.359978","name":"","x":720,"y":280,"wires":[]},{"id":"682a7074.08d2f","type":"subflow:1aaec155.5f990f","z":"87d6c779.359978","name":"","env":[],"x":730,"y":160,"wires":[]},{"id":"d87d346b.9eec58","type":"subflow:9adbcc70.51bb9","z":"87d6c779.359978","name":"","env":[],"x":720,"y":220,"wires":[]},{"id":"7aac7196.7c2eb","type":"switch","z":"9adbcc70.51bb9","name":"check laying","property":"payload.z","propertyType":"msg","rules":[{"t":"lt","v":"-800","vt":"num"},{"t":"gt","v":"800","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":290,"y":320,"wires":[["59b7f6ce.bfbbb8"],["680ef2b3.3c8bac"]]},{"id":"441721ce.48536","type":"debug","z":"9adbcc70.51bb9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":280,"wires":[]},{"id":"59b7f6ce.bfbbb8","type":"change","z":"9adbcc70.51bb9","name":"Lay","rules":[{"t":"set","p":"payload","pt":"msg","to":"Direction: Lay","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":280,"wires":[["441721ce.48536"]]},{"id":"6efd1ae7.4c8924","type":"switch","z":"9adbcc70.51bb9","name":"check standing","property":"payload.x","propertyType":"msg","rules":[{"t":"gt","v":"800","vt":"num"},{"t":"lt","v":"-800","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":280,"y":140,"wires":[["d97ee6ab.7a6478"],["43d10de7.999a44"],["7aac7196.7c2eb"]]},{"id":"e22a4baa.df4e28","type":"debug","z":"9adbcc70.51bb9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":80,"wires":[]},{"id":"d97ee6ab.7a6478","type":"change","z":"9adbcc70.51bb9","name":"Stand","rules":[{"t":"set","p":"payload","pt":"msg","to":"Direction: Stand","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":80,"wires":[["e22a4baa.df4e28"]]},{"id":"69c106a5.c1ab68","type":"debug","z":"9adbcc70.51bb9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":140,"wires":[]},{"id":"43d10de7.999a44","type":"change","z":"9adbcc70.51bb9","name":"Stand upside down","rules":[{"t":"set","p":"payload","pt":"msg","to":"Direction: Stand upside down","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":140,"wires":[["69c106a5.c1ab68"]]},{"id":"728daab1.c8dc24","type":"debug","z":"9adbcc70.51bb9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":340,"wires":[]},{"id":"680ef2b3.3c8bac","type":"change","z":"9adbcc70.51bb9","name":"Lay upside down","rules":[{"t":"set","p":"payload","pt":"msg","to":"Direction: Lay upside down","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":340,"wires":[["728daab1.c8dc24"]]},{"id":"45aa24bf.0d399c","type":"subflow:e65cea23.dee568","z":"87d6c779.359978","name":"","env":[],"x":730,"y":100,"wires":[]},{"id":"a6c04b17.225768","type":"worldmap","z":"e65cea23.dee568","name":"","lat":"","lon":"","zoom":"","layer":"","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"false","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"none","showgrid":"false","path":"/worldmap","x":480,"y":80,"wires":[]},{"id":"d323a060.c059","type":"change","z":"e65cea23.dee568","name":"Add name","rules":[{"t":"set","p":"payload.name","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":80,"wires":[["a6c04b17.225768"]]},{"id":"3ddbced.78fcf32","type":"soracom_gps_multiunit","z":"87d6c779.359978","property":"payload","name":"","x":350,"y":100,"wires":[["45aa24bf.0d399c","682a7074.08d2f","d87d346b.9eec58","85ec862e.ffee28"]]},{"id":"86266cae.2a0a4","type":"inject","z":"87d6c779.359978","name":"For test","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"payload\":\"eyJsYXQiOjUxLjAyNDUzNSwibG9uIjotMS4zOTk2MDEsImJhdCI6MywicnMiOjAsInRlbXAiOjI3LjAsImh1bWkiOjU5LjcsIngiOjAuMCwieSI6MC4wLCJ6IjotMTAyNC4wLCJ0eXBlIjoxfQo=\"}","payloadType":"json","x":190,"y":500,"wires":[["30ab4d6b.711492"]]},{"id":"30ab4d6b.711492","type":"soracom_gps_multiunit","z":"87d6c779.359978","property":"payload","name":"","x":460,"y":500,"wires":[["42f8b7e9.a8a208"]]},{"id":"42f8b7e9.a8a208","type":"debug","z":"87d6c779.359978","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":680,"y":500,"wires":[]},{"id":"facd2911.430828","type":"aedes broker","z":"462baeec.62b32","name":"","mqtt_port":1883,"mqtt_ws_port":"","cert":"","key":"","certname":"","keyname":"","dburl":"","usetls":false,"x":210,"y":200,"wires":[[]]},{"id":"10cbb752.ec1f59","type":"mqtt out","z":"462baeec.62b32","name":"Notify to Raspberry Pi","topic":"oob_notification","qos":"1","retain":"","broker":"bf2ccd43.9c498","x":540,"y":120,"wires":[]},{"id":"b5a3fb96.c072c8","type":"geofence","z":"462baeec.62b32","name":"","mode":"circle","inside":"true","rad":0,"points":[],"centre":{"latitude":0,"longitude":0},"x":310,"y":120,"wires":[["10cbb752.ec1f59"]]}]
Created 6 years, 8 months ago
  • change (x8)
  • debug (x5)
  • http in (x1)
  • http response (x1)
  • mqtt out (x1)
  • mqtt-broker (x3)
  • switch (x2)
  • SORACOM
  • GPS
