Acurite 5n1 rtl_433 WS
Temperature and Humidity
This is just a sample on how a weather station with 433mhz rf signal can be captured using rtl_433. Thanks to the makers of contrib rtl_433.
[{"id":"7d4e594dc5220c40","type":"debug","z":"1d4eefd84d9113e8","name":"temperature","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":570,"y":80,"wires":[]},{"id":"d26592617a2ad4c0","type":"switch","z":"1d4eefd84d9113e8","name":"filter NaN values","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"NaN","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":420,"y":160,"wires":[[],["7d4e594dc5220c40","32e85dd0ed4eeee5"]]},{"id":"00c1bb048840f427","type":"function","z":"1d4eefd84d9113e8","name":"rain","func":"var x =msg.payload\nvar y = x.rain_in\nvar msg1 = {payload:y}\nreturn msg1;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":200,"wires":[["a16cb56255b03668"]]},{"id":"a16cb56255b03668","type":"switch","z":"1d4eefd84d9113e8","name":"filter null values","property":"payload","propertyType":"msg","rules":[{"t":"null"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":380,"y":260,"wires":[[],[]]},{"id":"00ecc9fd87bc6e0b","type":"function","z":"1d4eefd84d9113e8","name":"humidity","func":"var x =msg.payload\nvar y = x.humidity\nvar msg1 = {payload:y}\nreturn msg1;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":300,"wires":[["0cb151a7334ca8cc"]]},{"id":"0cb151a7334ca8cc","type":"switch","z":"1d4eefd84d9113e8","name":"filter null values","property":"payload","propertyType":"msg","rules":[{"t":"null"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":380,"y":360,"wires":[[],["2c70cb1cff0ba557"]]},{"id":"3dc353d8e36b88ad","type":"function","z":"1d4eefd84d9113e8","name":"temp F to C","func":"var x =msg.payload\nvar y= x.temperature_F\nvar msg1 = {payload:(((y)-32)*(5/9))}\nreturn msg1;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":80,"wires":[["d26592617a2ad4c0"]]},{"id":"156a627f668a509b","type":"ui_template","z":"1d4eefd84d9113e8","group":"7ccfe2f3.3fd12c","name":"gauge-style","order":1,"width":0,"height":0,"format":"<style id=\"hotNipi-gauge\">\n:root{\n    --needle-color:#001100;\n    --needle-second-color:#ff0000;\n    --red-ticks:9;\n    --sec-high-color:#ff00004f;\n    --sec-normal-color:#00ff004f;\n    --sec-low-color:#0000ff4f;\n    --sec-sub-color:#0000ff8f;\n}\n.g-container {\n    padding-top: 3px;\n    padding-bottom: 3px;\n    width: 100%;\n    height: 100%;\n    position: relative;\n    display: flex;\n    justify-content: center;\n    align-items: center;\n    user-select:none;\n}\n    \n.g-body {\n    width: 98%;\n    height: 98%;\n    border-radius: 15%;\n    position: relative;\n    display: flex;\n    align-content: center;\n    align-items: center;\n    justify-content: center;\n    box-shadow: 0px 5px 8px #00000045;\n    background: linear-gradient(0deg, rgba(78,78,78,1) 0%, rgba(215,215,215,1) 99%, rgba(236,236,236,1) 100%);\n}\n\n.g-body::before {    \n    content: \"\";\n    background-image: url(\"data:image/svg+xml;base64,PHN2ZyB4bWxucz0naHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmcnIHdpZHRoPSc1JyBoZWlnaHQ9JzUnPgogIDxyZWN0IHdpZHRoPSc1JyBoZWlnaHQ9JzUnIGZpbGw9J3doaXRlJy8+CiAgPHBhdGggZD0nTTAgNUw1IDBaTTYgNEw0IDZaTS0xIDFMMSAtMVonIHN0cm9rZT0nIzg4OCcgc3Ryb2tlLXdpZHRoPScxJy8+Cjwvc3ZnPg==\"); \n    background-repeat: repeat;\n    position: absolute;\n    top: 0px;\n    right: 0px;\n    bottom: 0px;\n    left: 0px;\n    opacity: 0.1;\n    border-radius:15%;\n}\n\n.g-sector{\n    width: 100%;\n    height: 100%;\n    position: absolute;\n    top: 50%;\n    left: 50%;\n   \n    transform-origin: 0 0;\n}\n.g-sector-high {\n    background: var(--sec-high-color);\n    transform: rotate(328deg) skew(12deg, 23deg);\n}\n.g-sector-normal {\n    background:var(--sec-normal-color);\n    transform: rotate(328deg) skew(12deg, 23deg);\n}\n.g-sector-low {\n    background:var(--sec-low-color);\n    transform: rotate(328deg) skew(12deg, 23deg);\n}\n.g-sector-sub {\n    background:var(--sec-sub-color);\n    transform: rotate(328deg) skew(12deg, 23deg);\n}\n\n.g-ring {\n    width: 94%;\n    height: 94%;\n    border-radius: 50%;\n    position: relative;\n    display: flex;\n    align-content: center;\n    align-items: center;\n    justify-content: center;\n    background: linear-gradient(180deg, rgba(78,78,78,1) 0%, rgba(215,215,215,1) 99%, rgba(236,236,236,1) 100%);\n}\n.g-plate {\n    overflow: hidden;\n    width: 93%;\n    height: 93%;\n    border-radius: 50%;\n    position: relative;\n    box-shadow: inset 0 0 15px #000000a3;\n    background: radial-gradient(circle, #dd8400 3%, rgb(196 205 209) 1%, rgb(177 183 186) 40%, rgb(191 193 194) 100%);\n}\n.g-plate-bright {\n    overflow:hidden;\n    width: 90%;\n    height: 90%;\n    border-radius: 50%;\n    position: relative;\n    box-shadow: inset 0 0 10px yellow;\n    background: radial-gradient(circle, #ed9400 3%, rgb(255, 255, 255) 1%, rgb(255, 255, 158) 40%, rgb(148, 154, 160) 100%);\n}\n\n\n.g-ticks {\n    position: absolute;\n    top:0;\n    left:0;\n    width: 100%;\n    height: 100%;\n    filter: drop-shadow(2px 4px 6px black);\n}\n.g-tick {\n    transform: rotate(calc(calc(270deg / var(--ga-tick-count)) * var(--ga-tick) - calc(calc(270deg / var(--ga-tick-count)) + 45deg)));\n    background: #000;\n    position: relative;\n    left: 0;\n    top: 50%;\n    width: 100%;\n    height: 1px;\n    margin-bottom: -1px;\n    background: linear-gradient(90deg,rgba(0,0,0,0) 0,rgba(0,0,0,0) 2%,rgb(0 0 0 / 60%) 2%,rgb(0 0 0 / 60%) 10%,rgba(0,0,0,0) 10%);\n}\n.g-subtick {\n    transform: rotate(calc(calc(270deg / var(--ga-subtick-count)) * var(--ga-tick) - calc(calc(270deg / var(--ga-subtick-count)) + 45deg)));\n    background: #000;\n    position: relative;\n    left: 0;\n    top: 50%;\n    width: 100%;\n    height: 1px;\n    margin-bottom: -1px;\n    background: linear-gradient(90deg,rgba(0,0,0,0) 0,rgba(0,0,0,0) 2%,rgb(0 0 0 / 40%) 2%,rgb(0 0 0 / 40%) 6%,rgba(0,0,0,0) 6%);\n}\n\n.g-num {\n    position: absolute;\n    top: 50%;\n    left: 50%;\n    text-align: center;\n    transform: translate(-50%, -50%) rotate(calc(calc(270deg / var(--ga-tick-count)) * var(--ga-tick) - calc(calc(270deg /\n    var(--ga-tick-count)) + 45deg))) translate(calc(-1px * var(--container-size) * var(--gn-distance))) rotate(calc(calc(270deg / var(--ga-tick-count)) * var(--ga-tick) *-1 -\n    calc(calc(270deg / var(--ga-tick-count))*-1 - 45deg)));\n}\n\n.g-nums {\n    position: absolute;\n    top: 0;\n    width: 100%;\n    height: 100%;\n    color: #000000a1;\n    font-size: calc(var(--container-size) * 20%);\n    font-weight: 500;\n    filter: drop-shadow(2px 4px 10px black);\n}\n.g-needle {\n    transform: rotate(calc(270deg * calc(var(--gauge-value, 0deg) / 100) - 45deg));\n    transition: transform 1s;\n    background: #000;\n    position: absolute;\n    left: 0;\n    top: 49%;\n    width: 100%;\n    height: 2%;\n    filter:drop-shadow(0px 1px 3px #00000080);\n    background: linear-gradient(90deg,rgba(2,0,36,0) 0,rgba(0,0,0,0) 15%,var(--needle-color) 15%,var(--needle-color) 50%,rgba(0,0,0,0) 50%);\n}\n.g-needle-second {\n    transform: rotate(calc(270deg * calc(var(--gauge-value-second, 0deg) / 100) - 45deg));\n    transition: transform 1s;\n    background: #000;\n    position: absolute;\n    left: 0;\n    top: 49%;\n    width: 100%;\n    height: 2%;\n    filter:drop-shadow(0px 1px 3px #ff000080);  \n    background: linear-gradient(90deg,rgba(2,0,36,0) 0,rgba(0,0,0,0) 15%,var(--needle-second-color) 15%,var(--needle-second-color) 50%,rgba(0,0,0,0) 50%);\n}\n.g-needle-ring {\n    position: absolute;\n    width: calc(var(--container-size) * 1.5%);\n    height: calc(var(--container-size) * 1.5%);\n    top: 50%;\n    left: 50%;\n    background: var(--needle-color);\n    border-radius: 50%;\n    transform: translate(-50%, -50%);\n    box-shadow: 0 1px 4px #0000009c;\n}\n.g-val{\n    position: absolute;\n    text-align: center;\n    left: 50%;\n    bottom: 8%;\n    width: 80px;\n    transform: translateX(-50%);\n    font-family: monospace;\n    font-size:  calc(var(--container-size) * 40%);\n    color: #000000a1;\n    filter: drop-shadow(2px 3px 2px #00000050);\n}\n\n.g-label{\n    position: absolute;\n    text-align: center;\n    left: 50%;\n    top: 58%;\n    width: 100%;\n    transform: translateX(-50%);\n    font-family: monospace;\n    font-size:  calc(var(--container-size) * 18%);\n    color: #000000a1;\n    filter: drop-shadow(2px 3px 2px #00000080);\n}\n.g-label::after{\n    content: var(--g-unit);\n    font-size: clamp(1em,calc(var(--container-size) * 40%),1.5em);\n    position: absolute;\n    left: 0;\n    top: 100%;\n    width: 100%;\n    height: 100%;\n}\n.g-rivets{\n    position: absolute;\n    left:0;\n    top:0;\n    width: 100%;\n    height: 100%;\n}\n\n.g-rivet {\n    position: absolute;\n    width: calc(var(--container-size) * 2px);\n    height: calc(var(--container-size) * 2px);\n    border-radius: 50px;\n    background: linear-gradient(135deg, #adadad 0%,#d3d3d3 51%,#d1d1d1 68%,#8c8c8c 100%);\n    box-shadow: 0px 2px 4px #000, -1px -1px 5px rgba(0,0,0,0.2);\n    border: 1px solid rgba(255,255,255,0.1);\n}\n.g-rivet:nth-child(1){\n    top:calc(var(--container-size) * 1.5px);\n    left:calc(var(--container-size) * 1.5px);\n}\n.g-rivet:nth-child(2){\n    top:calc(var(--container-size) * 1.5px);\n    right:calc(var(--container-size) * 1.5px);\n}\n.g-rivet:nth-child(3){\n    bottom:calc(var(--container-size) * 1.5px);\n    left:calc(var(--container-size) * 1.5px);\n}\n.g-rivet:nth-child(4){\n    bottom:calc(var(--container-size) * 1.5px);\n    right:calc(var(--container-size) * 1.5px);\n}\n\n.g-rivet::before {\n    content: '';\n    position: absolute;\n    left: 50%;\n    top: 50%;\n    width: calc(var(--container-size) * 10%);\n    height: calc(var(--container-size) * 10%);\n    box-shadow: inset 0px 1px 2px #222;\n    transform: translate(-50%, -50%);\n    border-radius: 50%;\n    border-bottom: 1px solid rgba(255,255,255,0.3);\n}\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","x":590,"y":240,"wires":[[]]},{"id":"2c70cb1cff0ba557","type":"ui_template","z":"1d4eefd84d9113e8","group":"e8b7cd70.90dcb","name":"Backlight","order":2,"width":"6","height":"6","format":"<div id=\"{{'gauge_'+$id}}\" class=\"g-container\" style=\"--gauge-value:0; --container-size:6; --gn-distance:14; --ga-tick-count:10; --ga-subtick-count:100; --g-unit:'%'\">\n    <div id=\"bgr\" class=\"g-body\">\n        <div class=\"g-ring\">\n            <div class=\"g-rivets\">\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n            </div>\n            <div class=\"g-plate-bright\">\n                <div class=\"g-ticks\">\n                    <div class=\"g-tick\" style=\"--ga-tick:1;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:2;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:3;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:4;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:5;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:6;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:7;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:8;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:9;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:10;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:11;\"></div>\n                </div>\n                <div class=\"g-ticks\">\n                    <div class=\"g-subtick\" style=\"--ga-tick:2;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:3;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:4;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:5;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:6;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:7;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:8;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:9;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:10;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:12;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:13;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:14;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:15;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:16;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:17;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:18;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:19;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:20;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:22;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:23;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:24;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:25;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:26;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:27;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:28;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:29;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:30;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:32;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:33;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:34;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:35;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:36;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:37;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:38;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:39;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:40;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:42;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:43;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:44;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:45;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:46;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:47;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:48;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:49;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:50;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:52;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:53;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:54;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:55;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:56;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:57;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:58;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:59;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:60;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:62;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:63;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:64;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:65;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:66;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:67;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:68;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:69;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:70;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:72;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:73;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:74;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:75;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:76;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:77;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:78;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:79;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:80;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:82;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:83;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:84;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:85;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:86;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:87;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:88;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:89;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:90;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:92;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:93;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:94;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:95;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:96;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:97;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:98;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:99;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:100;\"></div>\n                </div>\n               <div class=\"g-nums\">\n                    <div class=\"g-num\" style=\"--ga-tick:1;\" >0</div>\n                    <div class=\"g-num\" style=\"--ga-tick:2;\">10</div>\n                    <div class=\"g-num\" style=\"--ga-tick:3;\">20</div>\n                    <div class=\"g-num\" style=\"--ga-tick:4;\">30</div>\n                    <div class=\"g-num\" style=\"--ga-tick:5;\">40</div>\n                    <div class=\"g-num\" style=\"--ga-tick:6;\">50</div>\n                    <div class=\"g-num\" style=\"--ga-tick:7;\">60</div>\n                    <div class=\"g-num\" style=\"--ga-tick:8;\">70</div>\n                    <div class=\"g-num\" style=\"--ga-tick:9;\">80</div>\n                    <div class=\"g-num\" style=\"--ga-tick:10;\">90</div>\n                    <div class=\"g-num\" style=\"--ga-tick:11;\">100</div>\n                </div>\n                <div class=\"g-label\">Humidity</div>\n                <div class=\"g-needle\"></div>\n                <div class=\"g-needle-ring\"></div>\n                <div id=\"{{'gauge_val_'+$id}}\" class=\"g-val\"></div>\n            </div>\n        </div>\n    </div>\n</div>\n<script>\n(function(scope) {\n    let min = 0;\n    let max = 100;\n  scope.$watch('msg', function(msg) {\n    if (msg) {\n      // Do something when msg arrives\n        const v = Math.floor(((msg.payload - min) / (max - min)) * 100);\n        document.getElementById('gauge_'+scope.$id).style.setProperty('--gauge-value', v);\n        document.getElementById('gauge_val_'+scope.$id).innerText = v;\n    }\n   \n  });\n})(scope);\n</script>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":660,"y":320,"wires":[[]]},{"id":"32e85dd0ed4eeee5","type":"ui_template","z":"1d4eefd84d9113e8","group":"e8b7cd70.90dcb","name":"Backlight","order":2,"width":"6","height":"6","format":"<div id=\"{{'gauge_'+$id}}\" class=\"g-container\" style=\"--gauge-value:0; --container-size:6; --gn-distance:14; --ga-tick-count:10; --ga-subtick-count:100; --g-unit:'C'\">\n    <div id=\"bgr\" class=\"g-body\">\n        <div class=\"g-ring\">\n            <div class=\"g-rivets\">\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n            </div>\n            <div class=\"g-plate-bright\">\n                <div class=\"g-ticks\">\n                    <div class=\"g-tick\" style=\"--ga-tick:1;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:2;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:3;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:4;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:5;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:6;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:7;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:8;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:9;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:10;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:11;\"></div>\n                </div>\n                <div class=\"g-ticks\">\n                    <div class=\"g-subtick\" style=\"--ga-tick:2;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:3;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:4;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:5;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:6;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:7;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:8;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:9;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:10;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:12;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:13;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:14;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:15;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:16;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:17;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:18;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:19;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:20;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:22;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:23;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:24;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:25;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:26;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:27;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:28;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:29;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:30;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:32;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:33;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:34;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:35;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:36;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:37;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:38;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:39;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:40;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:42;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:43;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:44;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:45;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:46;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:47;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:48;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:49;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:50;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:52;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:53;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:54;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:55;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:56;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:57;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:58;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:59;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:60;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:62;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:63;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:64;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:65;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:66;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:67;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:68;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:69;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:70;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:72;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:73;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:74;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:75;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:76;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:77;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:78;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:79;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:80;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:82;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:83;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:84;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:85;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:86;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:87;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:88;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:89;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:90;\"></div>\n                    \n                    <div class=\"g-subtick\" style=\"--ga-tick:92;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:93;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:94;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:95;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:96;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:97;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:98;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:99;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:100;\"></div>\n                </div>\n               <div class=\"g-nums\">\n                    <div class=\"g-num\" style=\"--ga-tick:1;\" >0</div>\n                    <div class=\"g-num\" style=\"--ga-tick:2;\">10</div>\n                    <div class=\"g-num\" style=\"--ga-tick:3;\">20</div>\n                    <div class=\"g-num\" style=\"--ga-tick:4;\">30</div>\n                    <div class=\"g-num\" style=\"--ga-tick:5;\">40</div>\n                    <div class=\"g-num\" style=\"--ga-tick:6;\">50</div>\n                    <div class=\"g-num\" style=\"--ga-tick:7;\">60</div>\n                    <div class=\"g-num\" style=\"--ga-tick:8;\">70</div>\n                    <div class=\"g-num\" style=\"--ga-tick:9;\">80</div>\n                    <div class=\"g-num\" style=\"--ga-tick:10;\">90</div>\n                    <div class=\"g-num\" style=\"--ga-tick:11;\">100</div>\n                </div>\n                <div class=\"g-label\">Temperature</div>\n                <div class=\"g-needle\"></div>\n                <div class=\"g-needle-ring\"></div>\n                <div id=\"{{'gauge_val_'+$id}}\" class=\"g-val\"></div>\n            </div>\n        </div>\n    </div>\n</div>\n<script>\n(function(scope) {\n    let min = 0;\n    let max = 100;\n  scope.$watch('msg', function(msg) {\n    if (msg) {\n      // Do something when msg arrives\n        const v = Math.floor(((msg.payload - min) / (max - min)) * 100);\n        document.getElementById('gauge_'+scope.$id).style.setProperty('--gauge-value', v);\n        document.getElementById('gauge_val_'+scope.$id).innerText = v;\n    }\n   \n  });\n})(scope);\n</script>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":720,"y":200,"wires":[[]]},{"id":"7ccfe2f3.3fd12c","type":"ui_group","name":"Group 1","tab":"477b3e43.1d624","order":1,"disp":false,"width":"6","collapse":false},{"id":"e8b7cd70.90dcb","type":"ui_group","name":"Group 3","tab":"477b3e43.1d624","order":3,"disp":false,"width":"6","collapse":false},{"id":"477b3e43.1d624","type":"ui_tab","name":"CDO Weather Station Dashboard","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 1 year, 8 months ago
  • function (x3)
  • switch (x3)
  • ui_group (x2)
  • ui_template (x3)
  • Acurite
  • 5n1
  • rtl433
