victron time to full
this flow is for victron venus os devices to display time to full when charging on the node red dashboard. some configuration required.
[{"id":"e203a909ffa59ebd","type":"tab","label":"Charging time to full","disabled":true,"info":"","env":[]},{"id":"eb75af28ad840318","type":"join","z":"e203a909ffa59ebd","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1250,"y":180,"wires":[["fceba906605df11a"]]},{"id":"fceba906605df11a","type":"calculator","z":"e203a909ffa59ebd","name":"calculate time to full","inputMsgField":"payload","outputMsgField":"payload","operation":"div","constant":"","round":true,"decimals":"2","x":1590,"y":160,"wires":[["3d862470441d2c63"]]},{"id":"8bd8b8ad73bf883d","type":"calculator","z":"e203a909ffa59ebd","name":"average the results","inputMsgField":"payload","outputMsgField":"payload","operation":"avg","constant":"","round":true,"decimals":"2","x":2110,"y":160,"wires":[["ca09ab7cd4b41b4d","b264b0fe0c5df6db"]]},{"id":"3d862470441d2c63","type":"join","z":"e203a909ffa59ebd","name":"averaging interval","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"30","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1830,"y":160,"wires":[["8bd8b8ad73bf883d"]]},{"id":"4801cd44d0b60e1c","type":"comment","z":"e203a909ffa59ebd","name":"set averaging time","info":"set this time to the averaging interval desired","x":1830,"y":120,"wires":[]},{"id":"ca09ab7cd4b41b4d","type":"debug","z":"e203a909ffa59ebd","name":"calculated time debug","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":2360,"y":80,"wires":[]},{"id":"b264b0fe0c5df6db","type":"ui_gauge","z":"e203a909ffa59ebd","name":"time to full","group":"29f036985f65b357","order":6,"width":"4","height":"4","gtype":"gage","title":"Charge Time To Full","label":"HRS","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","className":"","x":2330,"y":240,"wires":[]},{"id":"c90502c053fd5e5a","type":"calculator","z":"e203a909ffa59ebd","name":"charge efficiency","inputMsgField":"payload","outputMsgField":"payload","operation":"div","constant":"0.98","round":false,"decimals":0,"x":810,"y":200,"wires":[["0f404c062b30301c"]]},{"id":"6cfc43ef1f1618da","type":"change","z":"e203a909ffa59ebd","name":"","rules":[{"t":"set","p":"complete","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":100,"wires":[["eb75af28ad840318"]]},{"id":"0f404c062b30301c","type":"change","z":"e203a909ffa59ebd","name":"","rules":[{"t":"set","p":"parts","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":200,"wires":[["eb75af28ad840318"]]},{"id":"312905188c1808d8","type":"switch","z":"e203a909ffa59ebd","name":"compare to tail current","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"1","vt":"num"},{"t":"lte","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":420,"y":120,"wires":[["6cfc43ef1f1618da"],["6ef1bfb3ce396579"]]},{"id":"6ef1bfb3ce396579","type":"change","z":"e203a909ffa59ebd","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":140,"wires":[["b264b0fe0c5df6db","6cfc43ef1f1618da"]]},{"id":"3e466949e5f1abc7","type":"inject","z":"e203a909ffa59ebd","name":"Full @ ?? soc","props":[{"p":"payload"}],"repeat":"5","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"100","payloadType":"num","x":180,"y":320,"wires":[["b397915dadbb9d91"]]},{"id":"c09da9d4af91eb62","type":"change","z":"e203a909ffa59ebd","name":"","rules":[{"t":"set","p":"complete","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":380,"wires":[["b397915dadbb9d91"]]},{"id":"b397915dadbb9d91","type":"join","z":"e203a909ffa59ebd","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":290,"y":200,"wires":[["27d3ccf69afa09ad"]]},{"id":"27d3ccf69afa09ad","type":"calculator","z":"e203a909ffa59ebd","name":"","inputMsgField":"payload","outputMsgField":"payload","operation":"sub","constant":"","round":true,"decimals":"2","x":440,"y":200,"wires":[["6ed55cb77fd11b42"]]},{"id":"6ed55cb77fd11b42","type":"calculator","z":"e203a909ffa59ebd","name":"Multiplier","inputMsgField":"payload","outputMsgField":"payload","operation":"mult","constant":"4.2","round":true,"decimals":"2","x":600,"y":200,"wires":[["c90502c053fd5e5a"]]},{"id":"2b3a3272c866360d","type":"victron-input-system","z":"e203a909ffa59ebd","service":"com.victronenergy.system","path":"/Dc/Battery/Soc","serviceObj":{"service":"com.victronenergy.system","name":"com.victronenergy.system","paths":[{"path":"/Ac/ActiveIn/Source","type":"enum","name":"AC-Input","enum":{"0":"Not available","1":"Grid","2":"Generator","3":"Shore","240":"Inverting"}},{"path":"/Ac/Consumption/L1/Power","type":"float","name":"AC Consumption L1 (W)"},{"path":"/Ac/Consumption/L2/Power","type":"float","name":"AC Consumption L2 (W)"},{"path":"/Ac/Consumption/L3/Power","type":"float","name":"AC Consumption L3 (W)"},{"path":"/Ac/Genset/DeviceType","type":"float","name":"Genset Device Type","enum":{}},{"path":"/Ac/Genset/L1/Power","type":"float","name":"Genset L1 (W)"},{"path":"/Ac/Genset/L2/Power","type":"float","name":"Genset L2 (W)"},{"path":"/Ac/Genset/L3/Power","type":"float","name":"Genset L3 (W)"},{"path":"/Ac/Genset/NumberOfPhases","type":"integer","name":"Genset Number Of Phases"},{"path":"/Ac/Grid/DeviceType","type":"float","name":"Grid Device Type"},{"path":"/Ac/Grid/L1/Power","type":"float","name":"Grid L1 (W)"},{"path":"/Ac/Grid/L2/Power","type":"float","name":"Grid L2 (W)"},{"path":"/Ac/Grid/L3/Power","type":"float","name":"Grid L3 (W)"},{"path":"/Ac/Grid/NumberOfPhases","type":"integer","name":"Grid Number Of Phases"},{"path":"/Ac/PvOnGenset/L1/Power","type":"float","name":"PV Power AC-tied on Generator L1"},{"path":"/Ac/PvOnGenset/L2/Power","type":"float","name":"PV Power AC-tied on Generator L2"},{"path":"/Ac/PvOnGenset/L3/Power","type":"float","name":"PV Power AC-tied on Generator L3"},{"path":"/Ac/PvOnGenset/NumberOfPhases","type":"integer","name":"PV Power AC-tied on Generator Number Of Phases"},{"path":"/Ac/PvOnGrid/L1/Power","type":"float","name":"PV - AC-coupled on input L1 (W)"},{"path":"/Ac/PvOnGrid/L2/Power","type":"float","name":"PV - AC-coupled on input L2 (W)"},{"path":"/Ac/PvOnGrid/L3/Power","type":"float","name":"PV - AC-coupled on input L3 (W)"},{"path":"/Ac/PvOnGrid/NumberOfPhases","type":"integer","name":"PV - AC-coupled on input Number Of Phases"},{"path":"/Ac/PvOnOutput/L1/Power","type":"float","name":"PV - AC-coupled on output L1 (W)"},{"path":"/Ac/PvOnOutput/L2/Power","type":"float","name":"PV - AC-coupled on output L2 (W)"},{"path":"/Ac/PvOnOutput/L3/Power","type":"float","name":"PV - AC-coupled on output L3 (W)"},{"path":"/Ac/PvOnOutput/NumberOfPhases","type":"integer","name":"PV - AC-coupled on output Number Of Phases"},{"path":"/Buzzer/State","type":"float","name":"Buzzer State","enum":{"0":"Off","1":"On"}},{"path":"/Dc/Battery/ConsumedAmphours","type":"float","name":"Battery Consumed Amphours (Ah)"},{"path":"/Dc/Battery/Current","type":"float","name":"Battery current (A)"},{"path":"/Dc/Battery/Power","type":"float","name":"Battery Power (W)"},{"path":"/Dc/Battery/Soc","type":"float","name":"Battery State of Charge (%)"},{"path":"/Dc/Battery/State","type":"enum","name":"Battery state","enum":{"0":"idle","1":"charging","2":"discharging"}},{"path":"/Dc/Battery/Temperature","type":"float","name":"Battery temperature (C)"},{"path":"/Dc/Battery/TimeToGo","type":"float","name":"Battery Time to Go (h)"},{"path":"/Dc/Battery/Voltage","type":"float","name":"Battery voltage (V)"},{"path":"/Dc/Charger/Power","type":"integer","name":"AC-Chargers - power (W)"},{"path":"/Dc/Pv/Current","type":"float","name":"MPPTs - current (A)"},{"path":"/Dc/Pv/Power","type":"float","name":"MPPTs - power (W)"},{"path":"/Dc/System/Power","type":"float","name":"DC System (W)"},{"path":"/Dc/Vebus/Current","type":"float","name":"VE.Bus charge current (A)"},{"path":"/Dc/Vebus/Power","type":"float","name":"VE.Bus charge power (W)"},{"path":"/Serial","type":"string","name":"Serial (System)"},{"path":"/SystemType","type":"string","name":"System type"},{"path":"/Timers/TimeOff","type":"float","name":"Time off (s)"},{"path":"/Timers/TimeOnGenerator","type":"float","name":"Time generator (s)"},{"path":"/Timers/TimeOnGrid","type":"float","name":"Time grid (s)"},{"path":"/Timers/TimeOnInverter","type":"float","name":"Time inverting (s)"}]},"pathObj":{"path":"/Dc/Battery/Soc","type":"float","name":"Battery State of Charge (%)"},"initial":"","name":"SOC","x":150,"y":360,"wires":[["c09da9d4af91eb62"]]},{"id":"a7b19ede7b1d41bb","type":"victron-input-battery","z":"e203a909ffa59ebd","service":"com.victronenergy.battery.ttyS7","path":"/Dc/0/Current","serviceObj":{"service":"com.victronenergy.battery.ttyS7","name":"Battery Bank","paths":[{"path":"/Alarms/Alarm","type":"enum","name":"Alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighStarterVoltage","type":"enum","name":"High starter-voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighTemperature","type":"enum","name":"High battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighVoltage","type":"enum","name":"High voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowSoc","type":"enum","name":"Low state-of-charge alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowStarterVoltage","type":"enum","name":"Low starter-voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowTemperature","type":"enum","name":"Low battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowVoltage","type":"enum","name":"Low voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/MidVoltage","type":"enum","name":"Mid-voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/ConsumedAmphours","type":"float","name":"Consumed Amphours (Ah)"},{"path":"/Dc/0/Current","type":"float","name":"Current (A)"},{"path":"/Dc/0/MidVoltage","type":"float","name":"Mid-point voltage of the battery bank (V)"},{"path":"/Dc/0/MidVoltageDeviation","type":"float","name":"Mid-point deviation of the battery bank (%)"},{"path":"/Dc/0/Temperature","type":"float","name":"Battery temperature (C)"},{"path":"/Dc/0/Voltage","type":"float","name":"Voltage (V)"},{"path":"/Dc/1/Voltage","type":"float","name":"Starter battery voltage (V)"},{"path":"/History/AutomaticSyncs","type":"float","name":"Automatic syncs (count)"},{"path":"/History/AverageDischarge","type":"float","name":"Average discharge (Ah)"},{"path":"/History/ChargeCycles","type":"float","name":"Charge cycles (count)"},{"path":"/History/ChargedEnergy","type":"float","name":"Charged Energy (kWh)"},{"path":"/History/DeepestDischarge","type":"float","name":"Deepest discharge (Ah)"},{"path":"/History/DischargedEnergy","type":"float","name":"Discharged Energy (kWh)"},{"path":"/History/FullDischarges","type":"float","name":"Full discharges (count)"},{"path":"/History/HighStarterVoltageAlarms","type":"float","name":"High starter voltage alarms (count)"},{"path":"/History/HighVoltageAlarms","type":"float","name":"High voltage alarms (count)"},{"path":"/History/LastDischarge","type":"float","name":"Last discharge (Ah)"},{"path":"/History/LowStarterVoltageAlarms","type":"float","name":"Low starter voltage alarms (count)"},{"path":"/History/LowVoltageAlarms","type":"float","name":"Low voltage alarms (count)"},{"path":"/History/MaximumStarterVoltage","type":"float","name":"Maximum starter voltage (V DC)"},{"path":"/History/MaximumVoltage","type":"float","name":"Maximum voltage (V DC)"},{"path":"/History/MinimumStarterVoltage","type":"float","name":"Minimum starter voltage (V DC)"},{"path":"/History/MinimumVoltage","type":"float","name":"Minimum voltage (V DC)"},{"path":"/History/TimeSinceLastFullCharge","type":"float","name":"Time since last full charge (seconds)"},{"path":"/History/TotalAhDrawn","type":"float","name":"Total Ah drawn (Ah)"},{"path":"/Relay/0/State","type":"enum","name":"Relay status","enum":{"0":"Open","1":"Closed"}},{"path":"/Soc","type":"float","name":"State of charge (%)"},{"path":"/TimeToGo","type":"float","name":"Time to go (h)"}]},"pathObj":{"path":"/Dc/0/Current","type":"float","name":"Current (A)"},"initial":"","name":"Battery Current","x":180,"y":120,"wires":[["312905188c1808d8"]]},{"id":"bb0c5334dda98e98","type":"comment","z":"e203a909ffa59ebd","name":"set Multiplier","info":"set multiply constant value to 1% of total battery bank amp hr capacity","x":610,"y":240,"wires":[]},{"id":"37458c5940982485","type":"comment","z":"e203a909ffa59ebd","name":"set charge efficiency","info":"set charge efficiency multiplier constant value to battery bank charge efficiency value. usually around 1.01 to 1.04 for lithium, higher for lead acid/agm","x":790,"y":240,"wires":[]},{"id":"30030b18b0f3594c","type":"comment","z":"e203a909ffa59ebd","name":"Time to full","info":"","x":120,"y":80,"wires":[]},{"id":"ac284dc4f2f7b556","type":"comment","z":"e203a909ffa59ebd","name":"set full soc","info":"set this value to the desired full soc level. usually 100 but some may want it lower to lengthen battery life","x":140,"y":280,"wires":[]},{"id":"29f036985f65b357","type":"ui_group","name":"Battery Bank","tab":"be33ae3fb7d3c370","order":3,"disp":true,"width":"8","collapse":false,"className":""},{"id":"be33ae3fb7d3c370","type":"ui_tab","name":"Batteries","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 3 years, 6 months ago
  • change (x4)
  • comment (x5)
  • join (x3)
  • switch (x1)
  • calculator (x5)
  • ui_gauge (x1)
  • ui_group (x1)
  • victron-input-battery (x1)
  • victron-input-system (x1)
  • victron
  • venus
  • cerbo
