Using JSONATA to query objects
This example shows how you can store an object in a flow variable and then query it using jsonata. This would normally require function nodes but is now possible using jsonata.
[{"id":"d001dc53.264018","type":"template","z":"82c1ad52.7a898","name":"","field":"payload","fieldType":"msg","format":"yaml","syntax":"mustache","template":"canada:\n    fruits:\n        - bleuet\n        - framboise\n    légumes:\n        - tomate\n        - patate\n        - navet\nmexique:\n    fruits:\n        - café\n        - orange\n    légumes:\n        - avocats","output":"str","x":370,"y":100,"wires":[["9e173897.ccab38"]]},{"id":"a631ad2e.febf2","type":"inject","z":"82c1ad52.7a898","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"x":190,"y":100,"wires":[["d001dc53.264018"]]},{"id":"9e173897.ccab38","type":"yaml","z":"82c1ad52.7a898","name":"","x":510,"y":100,"wires":[["588f9990.21743"]]},{"id":"588f9990.21743","type":"change","z":"82c1ad52.7a898","name":"","rules":[{"t":"set","p":"food","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":100,"wires":[[]]},{"id":"5d6a8619.27e0c8","type":"inject","z":"82c1ad52.7a898","name":"","topic":"","payload":"repas","payloadType":"flow","repeat":"","crontab":"","once":false,"x":180,"y":300,"wires":[["3f38369a.fed952"]]},{"id":"3f38369a.fed952","type":"debug","z":"82c1ad52.7a898","name":"","active":true,"console":"false","complete":"false","x":690,"y":300,"wires":[]},{"id":"249e58ed.5231b8","type":"inject","z":"82c1ad52.7a898","name":"","topic":"","payload":"mexique","payloadType":"str","repeat":"","crontab":"","once":false,"x":180,"y":380,"wires":[["6d5ef611.7e4c9"]]},{"id":"6d5ef611.7e4c9","type":"change","z":"82c1ad52.7a898","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$lookup($flowContext('food'), payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":380,"wires":[["3f38369a.fed952"]]},{"id":"799e8f63.f79ab8","type":"inject","z":"82c1ad52.7a898","name":"","topic":"","payload":"canada","payloadType":"str","repeat":"","crontab":"","once":false,"x":170,"y":420,"wires":[["6d5ef611.7e4c9"]]},{"id":"ea873589.6832e8","type":"inject","z":"82c1ad52.7a898","name":"","topic":"","payload":"[\"mexique\", \"fruits\"]","payloadType":"json","repeat":"","crontab":"","once":false,"x":210,"y":520,"wires":[["cc133563.e5759"]]},{"id":"cc133563.e5759","type":"change","z":"82c1ad52.7a898","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$lookup($flowContext('food'), payload[0]) ~> $lookup(payload[1])","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":520,"wires":[["3f38369a.fed952"]]},{"id":"c19fefdd.daac4","type":"inject","z":"82c1ad52.7a898","name":"","topic":"","payload":"[\"canada\", \"légumes\"]","payloadType":"json","repeat":"","crontab":"","once":false,"x":220,"y":560,"wires":[["cc133563.e5759"]]},{"id":"b434fc1b.4f748","type":"comment","z":"82c1ad52.7a898","name":"Create a complex stucture","info":"","x":210,"y":40,"wires":[]},{"id":"f15b4ee9.993e7","type":"comment","z":"82c1ad52.7a898","name":"Filter the structure","info":"","x":190,"y":240,"wires":[]}]
Created 9 years, 4 months ago
  • change (x3)
  • comment (x2)
  • inject (x6)
  • template (x1)
  • yaml (x1)
  • jsonata
