SMA-Tripower-5.0---Active-Power-Control
This flow "SMA Settings" can be used as a starting point to reduce the generated power of your inverter. It makes use of the inverters modbus. You should enable the TCP modbus first en also external control. For manual control the slider can be use to set the powerlevel in %, or active control depending on the energy used, for this you need to measure or calculated the current use and feed that as input. Marge can be used to create a little feedback to the grid so that batteries can start charging and control antifeed.
In Case you want to control more than one Inverter add the Sum of the Inverter Power in the config node. Enable and set correct Ip adress in the modbus write/read node.
Added a Dashboard2.0 version;
Check for the last version on github:
https://github.com/hansvanlin/SMA-Tripower-5.0---Active-Power-Control
I used ZonnePlan current hour price as input for the Dynamic Price Control. Create a free personal token at: https://enever.nl/token-aanmaken/ Import sma and zonneplan flows.
Initial version:
[{"id":"4d381f093e6152d7","type":"tab","label":"SMA Sunny Tripower 5.0","disabled":false,"info":"","env":[]},{"id":"f87a84eaf3997bc8","type":"modbus-write","z":"4d381f093e6152d7","name":"SMA Modbus Write 40023 ( Limit )","showStatusActivities":false,"showErrors":false,"showWarnings":true,"unitid":"3","dataType":"HoldingRegister","adr":"40023","quantity":"1","server":"67aa8a7899544f4d","emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":1200,"y":420,"wires":[[],[]]},{"id":"42010d55d522140c","type":"inject","z":"4d381f093e6152d7","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"3","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":250,"y":135,"wires":[["546a95fa24eaeb8b"]]},{"id":"546a95fa24eaeb8b","type":"modbus-getter","z":"4d381f093e6152d7","name":"SMA Modbus (41255) Power","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"3","dataType":"HoldingRegister","adr":"41255","quantity":"2","server":"67aa8a7899544f4d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":515,"y":135,"wires":[["c6a119a3da6f8bee","e35f2cf319a71233"],[]]},{"id":"7ae2fde1fbced2af","type":"ui_text","z":"4d381f093e6152d7","group":"4fb0db5cea9cd881","order":3,"width":4,"height":1,"name":"","label":"Actual Power Limit","format":"{{msg.payload}} %","layout":"row-spread","className":"","style":true,"font":"","fontSize":"12","color":"#ffffff","x":1055,"y":105,"wires":[]},{"id":"c6a119a3da6f8bee","type":"function","z":"4d381f093e6152d7","name":"Power Limit","func":"var limit = msg.payload[0] /100;\n\n\n\nreturn [{ payload: limit }]","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":805,"y":105,"wires":[["7ae2fde1fbced2af"]]},{"id":"ec92a1d03709eeda","type":"ui_slider","z":"4d381f093e6152d7","name":"","label":"","tooltip":"","group":"4fb0db5cea9cd881","order":6,"width":4,"height":1,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":"10","max":"100","step":"5","className":"","x":810,"y":420,"wires":[["c3adf3a742914aaa","191dd49f3ab6321e"]]},{"id":"c0e282528bba806c","type":"ui_text","z":"4d381f093e6152d7","group":"4fb0db5cea9cd881","order":4,"width":2,"height":1,"name":"%","label":"","format":"{{msg.payload}} W","layout":"row-right","className":"","style":true,"font":"","fontSize":"12","color":"#ffffff","x":1095,"y":165,"wires":[]},{"id":"e35f2cf319a71233","type":"function","z":"4d381f093e6152d7","name":"Power Limit %","func":"var pro = msg.payload[0] * 0.5;\n\n\n\nreturn [{ payload: pro }]","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":165,"wires":[["c0e282528bba806c"]]},{"id":"c3adf3a742914aaa","type":"function","z":"4d381f093e6152d7","name":"* 100","func":"var lim = msg.payload *100;\nreturn [{payload: lim}];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":990,"y":420,"wires":[["f87a84eaf3997bc8"]]},{"id":"191dd49f3ab6321e","type":"function","z":"4d381f093e6152d7","name":"* 50","func":"var lim = msg.payload *50;\nreturn [{payload: lim}];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":990,"y":520,"wires":[["e88135e8a1039491"]]},{"id":"e88135e8a1039491","type":"ui_text","z":"4d381f093e6152d7","group":"4fb0db5cea9cd881","order":7,"width":2,"height":1,"name":"set:","label":"","format":"{{msg.payload}} W","layout":"row-spread","className":"","style":true,"font":"","fontSize":"12","color":"#19e119","x":1130,"y":520,"wires":[]},{"id":"5218e7e434cbfdbd","type":"comment","z":"4d381f093e6152d7","name":"Read Modbus values","info":"","x":160,"y":60,"wires":[]},{"id":"2b890f465fbcdfdc","type":"comment","z":"4d381f093e6152d7","name":"Write Modbus Register","info":"","x":160,"y":300,"wires":[]},{"id":"25103bd88bc2ab96","type":"comment","z":"4d381f093e6152d7","name":"Dynamic Control P-limit","info":"","x":320,"y":640,"wires":[]},{"id":"1676718e16852e98","type":"link in","z":"4d381f093e6152d7","name":"actual use in 1","links":["b792982110625bd6"],"x":185,"y":780,"wires":[["7ff1a9a7f80d1877","e10ec800de59a308"]]},{"id":"3e56a6c32a84927f","type":"comment","z":"4d381f093e6152d7","name":"actual use in","info":"","x":110,"y":780,"wires":[]},{"id":"e10ec800de59a308","type":"function","z":"4d381f093e6152d7","name":"Power limit factor","func":"var marge = 375 ;\nvar Limfactor = (msg.payload + marge) / 5000 ;\nreturn [{ payload: Limfactor }];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":330,"y":780,"wires":[["5b3343720f53c318"]]},{"id":"9757adc25ad441bf","type":"function","z":"4d381f093e6152d7","name":"* 100","func":"var lim = msg.payload *100 ;\nvar limit = Math.ceil(lim) ; \nreturn [{payload: limit}];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":470,"y":860,"wires":[["3ba93ece81967f14"]]},{"id":"b7cbe9365ec96ff7","type":"delay","z":"4d381f093e6152d7","name":"","pauseType":"rate","timeout":"6","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":1050,"y":700,"wires":[["ec92a1d03709eeda"]]},{"id":"0f54edbb38c56411","type":"ui_switch","z":"4d381f093e6152d7","name":"Dynamic Control","label":"Dynamic Control","tooltip":"","group":"4fb0db5cea9cd881","order":8,"width":6,"height":1,"passthru":false,"decouple":"false","topic":"state","topicType":"str","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","animate":false,"className":"","x":320,"y":700,"wires":[["0160aa5e3efc4f1a","268493ed71720a3b"]]},{"id":"7ff1a9a7f80d1877","type":"ui_text","z":"4d381f093e6152d7","group":"4fb0db5cea9cd881","order":1,"width":6,"height":1,"name":"Actual","label":"Actual Use","format":"{{msg.payload}} W","layout":"row-spread","className":"","style":true,"font":"","fontSize":"12","color":"#0a95eb","x":310,"y":920,"wires":[]},{"id":"5944b2024e02cd5a","type":"ui_text","z":"4d381f093e6152d7","group":"4fb0db5cea9cd881","order":2,"width":6,"height":1,"name":"Power limit factor","label":"Dynamic Limit","format":"{{msg.payload}} %","layout":"row-spread","className":"","style":true,"font":"","fontSize":"12","color":"#aeb4b7","x":850,"y":860,"wires":[]},{"id":"5b3343720f53c318","type":"function","z":"4d381f093e6152d7","name":"abs","func":"var abs = Math.abs(msg.payload);\n\nreturn [{ payload: abs }]","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":860,"wires":[["9757adc25ad441bf"]]},{"id":"0160aa5e3efc4f1a","type":"function","z":"4d381f093e6152d7","name":"Flow On/OFF","func":"var state = context.get(\"state\") || \"off\";\n\n// Display initial state status\nif (state == \"on\") {\n    node.status({ fill: \"green\", shape: \"dot\", text: state });\n} else {\n    node.status({ fill: \"red\", shape: \"dot\", text: state });\n}\n\nif (msg.topic == \"state\") {\n    context.set(\"state\", msg.payload);\n    state = msg.payload;\n    // update status\n    if (state == \"on\") {\n        node.status({ fill: \"green\", shape: \"dot\", text: state });\n    } else {\n        node.status({ fill: \"red\", shape: \"dot\", text: state });\n    }\n} else {\n    if (state == \"on\") {\n        return msg;\n    }\n}","outputs":1,"noerr":0,"initialize":"","finalize":"// Code added here will be run when the\n// node is being stopped or re-deployed.\n//var max = 100;\n//return [{ payload:max}];","libs":[],"x":620,"y":700,"wires":[["62bc963d8358204a","9c153229b8d0806f"]]},{"id":"733b7b4cf87e4226","type":"comment","z":"4d381f093e6152d7","name":"Manual","info":"","x":710,"y":360,"wires":[]},{"id":"86d20df9e554aa30","type":"inject","z":"4d381f093e6152d7","name":"Daily reset to 100%","props":[{"p":"payload"}],"repeat":"","crontab":"00 00 * * *","once":true,"onceDelay":0.1,"topic":"","payload":"100","payloadType":"num","x":280,"y":420,"wires":[["ec92a1d03709eeda"]]},{"id":"3ba93ece81967f14","type":"function","z":"4d381f093e6152d7","name":"range (min-max)","func":"var min = 10 ;\nvar max = 100 ;\n\nvar limit = msg.payload ;\n\nif (limit > max) {\n    limit = max;\n} else if (limit < min) {\n    limit = min;\n} \n\n\nreturn[{payload:limit}];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":860,"wires":[["0160aa5e3efc4f1a","5944b2024e02cd5a"]]},{"id":"268493ed71720a3b","type":"function","z":"4d381f093e6152d7","name":"reset after off","func":"var state = context.get(\"state\") || \"off\";\nvar max = 100;\n\nif (state == \"off\") {\n    return [{ payload: max }];\n\n}\n\n\n//var max = 100;\n//return [{ payload:max}];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":610,"y":640,"wires":[["ec92a1d03709eeda"]]},{"id":"62bc963d8358204a","type":"smooth","z":"4d381f093e6152d7","name":"","property":"payload","action":"low","count":"20","round":"1","mult":"single","reduce":false,"x":840,"y":700,"wires":[["b7cbe9365ec96ff7","8acbd741879b2dd6"]]},{"id":"8acbd741879b2dd6","type":"debug","z":"4d381f093e6152d7","name":"debug 30","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":960,"y":640,"wires":[]},{"id":"9c153229b8d0806f","type":"debug","z":"4d381f093e6152d7","name":"debug 31","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":820,"y":780,"wires":[]},{"id":"67aa8a7899544f4d","type":"modbus-client","name":"SMA Modbus","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"192.168.178.4","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":3,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true,"showWarnings":true,"showLogs":true},{"id":"4fb0db5cea9cd881","type":"ui_group","name":"SMA  settings","tab":"cccf47e4.857ec8","order":3,"disp":true,"width":"6","collapse":true,"className":""},{"id":"cccf47e4.857ec8","type":"ui_tab","name":"Energy","icon":"battery_charging_60","order":2,"disabled":false,"hidden":false}]
Created 3 years ago
Updated 7 months ago
  • comment (x5)
  • debug (x2)
  • delay (x1)
  • function (x10)
  • inject (x2)
  • link in (x1)
  • modbus-client (x1)
  • modbus-getter (x1)
  • modbus-write (x1)
  • smooth (x1)
  • ui_group (x1)
  • ui_slider (x1)
  • ui_switch (x1)
  • ui_text (x5)
  • SMA
  • active
  • power
  • control
  • modbus
  • inverter
  • tripower
  • energy
  • price
  • limit
