IoT PLC Integration
This flow is a basic example of integrating IoT with PLC for Smart Factories
[{"id":"e267b548965a7a6d","type":"s7 in","z":"c1e71160f19e64f3","endpoint":"48669d354896b173","mode":"single","variable":"Temperature","diff":false,"name":"Read Temperature","x":230,"y":100,"wires":[["d9cb9d8c6010d2f4"]]},{"id":"d9cb9d8c6010d2f4","type":"debug","z":"c1e71160f19e64f3","name":"Debug Read","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":460,"y":100,"wires":[]},{"id":"7f0f8184d48f8a7f","type":"inject","z":"c1e71160f19e64f3","name":"Inject Write Value","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"42.5","payloadType":"num","x":220,"y":180,"wires":[["ab11fbc7403f38b5"]]},{"id":"ab11fbc7403f38b5","type":"s7 out","z":"c1e71160f19e64f3","endpoint":"48669d354896b173","variable":"","name":"Write Temperature","x":460,"y":180,"wires":[]},{"id":"48669d354896b173","type":"s7 endpoint","transport":"iso-on-tcp","port":"102","rack":"0","slot":"1","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","adapter":"","cycletime":"1000","timeout":"2000","name":"S7-1200 Connection"}]
Created 1 month, 1 week ago
Rating: 1 1
  • s7 endpoint (x1)
  • s7 in (x1)
  • s7 out (x1)
  • PLC
  • IoT
  • SmartPlant
  • SmartFactory
  • IIoT
