Airplane Emergency Message With Twitter And Pushover
7700 - Luftnotfall (emergency; seven-seven - going to heaven / falling from heaven / pray to heaven)
7600 - Funkausfall (radio failure; seven-six - hear nix / radio nix / need a radio fix)
7500 – Flugzeugentführung (hijacking; seven-five - man with a knife)
See http://blog.wenzlaff.de/?p=9738
[{"id":"b1463674.fcf8e","type":"tab","label":"Flugnotfall","disabled":false,"info":""},{"id":"f12f52b6.5691d","type":"comment","z":"b1463674.fcf8e","name":"http://www.kleinhirn.eu","info":"","x":1040,"y":460,"wires":[]},{"id":"13c00892.15e197","type":"http request","z":"b1463674.fcf8e","name":"Server abfragen","method":"GET","ret":"obj","url":"http://10.0.7.32/dump1090/data/aircraft.json","tls":"","x":220,"y":160,"wires":[["20a9c05c.e34b48"]]},{"id":"7d9662e9.de4454","type":"inject","z":"b1463674.fcf8e","name":"Alle 10 Sekunden","topic":"","payload":"","payloadType":"str","repeat":"10","crontab":"","once":true,"onceDelay":"","x":170,"y":100,"wires":[["13c00892.15e197"]]},{"id":"20a9c05c.e34b48","type":"function","z":"b1463674.fcf8e","name":"Notfallmeldung ermitteln","func":"var m = [];\nfor (var i in msg.payload.aircraft) \n\n    if (msg.payload.aircraft[i].squawk === \"7500\" || msg.payload.aircraft[i].squawk === \"7600\" || msg.payload.aircraft[i].squawk === \"7700\")\n    \n{\n    m.push({payload:msg.payload.aircraft[i]});\n}\nreturn [m];","outputs":"1","noerr":0,"x":290,"y":220,"wires":[["305f869a.e3ede2"]]},{"id":"305f869a.e3ede2","type":"function","z":"b1463674.fcf8e","name":"Notfallmeldung aufbereiten","func":"var newMsg = { payload: \"Luftnotfall SQUAWK \" + msg.payload.squawk + \" von Flug \" + msg.payload.flight + \" gemeldet! Siehe: https://www.flightradar24.com/\" + msg.payload.flight };\nreturn newMsg;","outputs":1,"noerr":0,"x":300,"y":280,"wires":[["f7f42c47.27bd5"]]},{"id":"3dfdeeba.fd18a2","type":"debug","z":"b1463674.fcf8e","name":"Debug Meldung","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":720,"y":460,"wires":[]},{"id":"3d2fe651.34b1d2","type":"twitter out","z":"b1463674.fcf8e","twitter":"","name":"Tweet versenden","x":730,"y":400,"wires":[]},{"id":"20f4847c.24771c","type":"comment","z":"b1463674.fcf8e","name":"Flugnotfall Benachrichtigung per Pushover und Twitter. Siehe http://www.wenzlaff.info","info":"","x":360,"y":40,"wires":[]},{"id":"f7f42c47.27bd5","type":"rbe","z":"b1463674.fcf8e","name":"Prüfen ob Meldung schon versendet","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":450,"y":340,"wires":[["3d2fe651.34b1d2","3dfdeeba.fd18a2","96d08eec.1c1fb"]]},{"id":"96d08eec.1c1fb","type":"pushover","z":"b1463674.fcf8e","name":"Pushover System","device":"","title":"Flugnotfall","priority":0,"sound":"","url":"","url_title":"","x":730,"y":340,"wires":[]},{"id":"42e949b6.a7f4c","type":"comment","z":"b1463674.fcf8e","name":"7500 – Flugzeugentführung (hijacking; seven-five - man with a knife)","info":"","x":700,"y":140,"wires":[]},{"id":"43074b25.b7b65c","type":"comment","z":"b1463674.fcf8e","name":"7600 - Funkausfall (radio failure; seven-six - hear nix / radio nix / need a radio fix)","info":"","x":740,"y":180,"wires":[]},{"id":"a7972162.4ccd18","type":"comment","z":"b1463674.fcf8e","name":"7700 - Luftnotfall (emergency; seven-seven - going to heaven / falling from heaven / pray to heaven)","info":"","x":800,"y":220,"wires":[]},{"id":"f3573ce4.17118","type":"comment","z":"b1463674.fcf8e","name":"https://github.com/IT-Berater/de.wenzlaff.dump1090","info":"","x":950,"y":40,"wires":[]}]
Created 9 years, 5 months ago
Updated 8 years, 6 months ago
Rating: 5 2
  • comment (x6)
  • function (x2)
  • http request (x1)
  • rbe (x1)
  • Notfall
  • Transponder
  • 1090
  • Raspberry
  • Pi
  • DUMP-1090
