Sample flow to send and recieve message from a rabbitmq server
Uses the node-red-contrib-amqp node to send and listen to messages published to a queue in RabbitMQ and display it in debug output.
Install node-red https://nodered.org/docs/getting-started/installation
Install node-red-contrib-amqp https://www.npmjs.com/package/node-red-contrib-amqp
Install RabbitMQ https://www.rabbitmq.com/download.html
start the rabbitmq server.
if you click on the inject node you can see that message is being sent to rabbitmq and listen to the rabbitmq and shows in the debug window.
You can send any type of data in the inject node by adjusting the input please note that the queue name in both input and output node must be same.
[{"id":"a2c0fe79.167fe8","type":"amqp in","z":"31021ae3.1b765e","name":"","topic":"","iotype":"4","ioname":"new_test","server":"1dde2dd.ec1ec52","x":137.5,"y":255,"wires":[["88eed72c.68c1f"]]},{"id":"1dde2dd.ec1ec52","type":"amqp-server","z":"","host":"localhost","port":"5672","vhost":"","keepalive":"30","usetls":false,"verifyservercert":true,"usetopology":false,"topology":"{\n\t\"exchanges\": [\n\t\t{\"name\": \"exchange1\", \"type\": \"direct\", \"options\": {\"durable\": false}},\n\t\t{\"name\": \"exchange2\"}\n\t],\n\t\"queues\": [\n\t\t{\"name\": \"queue1\", \"options\": {\"messageTtl\": 60000}},\n\t\t{\"name\": \"queue2\"}\n\t],\n\t\"bindings\": [\n\t\t{\"source\": \"exchange1\", \"queue\": \"queue1\", \"pattern\": \"debug\", \"args\": {}},\n\t\t{\"source\": \"exchange1\", \"exchange\": \"exchange2\", \"pattern\": \"error\"},\n\t\t{\"source\": \"exchange2\", \"queue\": \"queue2\"}\n\t]\n}"}]
Created 9 years, 7 months ago
Updated 9 years, 3 months ago
Rating: 5 1
  • amqp in (x1)
  • amqp-server (x1)
  • Rabbitmq
  • Amqp
