TheThingsNetwork gateway monitor with Telegram alarms
Description
This a flow to monitor the status of LoRaWan gateways connected to The Things Network (TTN) using the undocumented NOC API. Periodically inject a message with the gateway EUI as payload and connect the output to a Telegram bot.
  • You will need to edit/add inject nodes with the name of the gateway in the topic and the EUI in the payload. Configure it to check the status every X minutes.
  • Create a telegram bot (using the @BotFather) and configure the token in the telegram configuration node.
  • You will also need to add the chatId to send the notification to in the "telegram payload" function node. To get the chatId use another bot like @my_id_bot.
[{"id":"96beb4bd.b0d418","type":"comment","z":"f2a3fe14.e7db8","name":"Gateway Management","info":"","x":160,"y":240,"wires":[]},{"id":"efe2cc40.4ab8b","type":"inject","z":"f2a3fe14.e7db8","name":"ttn-gw01","topic":"ttn-gw01","payload":"eui-0000000000000001","payloadType":"str","repeat":"300","crontab":"","once":true,"onceDelay":0.1,"x":140,"y":320,"wires":[["fc377781.1447e8"]]},{"id":"a99602aa.eb307","type":"http request","z":"f2a3fe14.e7db8","name":"request","method":"GET","ret":"obj","url":"","tls":"","x":520,"y":380,"wires":[["bb2b60e2.5f72b"]]},{"id":"fc377781.1447e8","type":"template","z":"f2a3fe14.e7db8","name":"build url","field":"url","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"http://noc.thethingsnetwork.org:8085/api/v2/gateways/{{payload}}","output":"str","x":360,"y":380,"wires":[["a99602aa.eb307"]]},{"id":"bb2b60e2.5f72b","type":"function","z":"f2a3fe14.e7db8","name":"status","func":"var status = 'offline';\n\nif (200 == msg.statusCode) {\n    if (!(\"error\" in msg.payload)) {\n        var last = (new Date(msg.payload.timestamp)).getTime() / 1000;\n        var now = new Date();\n        var current = (now.getTime() + (now.getTimezoneOffset() * 60)) / 1000;        \n        var difference = current - last;\n        msg.last = last;\n        msg.current = current;\n        msg.delta = difference;\n        if (difference < 180) status = 'online';\n    }\n}\n\nmsg.status = status;\nmsg.payload = msg.topic + \"-\" + status;\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":380,"wires":[["401526f4.b52348","7a0405b1.bd2e3c"]]},{"id":"7a0405b1.bd2e3c","type":"rbe","z":"f2a3fe14.e7db8","name":"has_changed","func":"rbei","gap":"","start":"","inout":"out","property":"payload","x":380,"y":460,"wires":[["8406037c.072cd"]]},{"id":"401526f4.b52348","type":"debug","z":"f2a3fe14.e7db8","name":"status","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":810,"y":380,"wires":[]},{"id":"8406037c.072cd","type":"template","z":"f2a3fe14.e7db8","name":"message template","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Gateway {{ topic }} status has changed to {{ status }}.\n","output":"str","x":590,"y":460,"wires":[["25622438.bdc0ec","4711b876.27f488"]]},{"id":"25622438.bdc0ec","type":"debug","z":"f2a3fe14.e7db8","name":"status","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":770,"y":520,"wires":[]},{"id":"6fe755d7.2e338c","type":"inject","z":"f2a3fe14.e7db8","name":"ttn-gw02","topic":"ttn-gw02","payload":"eui-0000000000000002","payloadType":"str","repeat":"300","crontab":"","once":true,"onceDelay":0.1,"x":140,"y":380,"wires":[["fc377781.1447e8"]]},{"id":"e906e0bd.383b1","type":"inject","z":"f2a3fe14.e7db8","name":"ttn-gw03","topic":"ttn-gw03","payload":"eui-0000000000000003","payloadType":"str","repeat":"300","crontab":"","once":true,"onceDelay":0.1,"x":140,"y":440,"wires":[["fc377781.1447e8"]]},{"id":"78b71800.62f598","type":"telegram sender","z":"f2a3fe14.e7db8","name":"telegram","bot":"c559e4a3.56fef8","x":1000,"y":460,"wires":[[]]},{"id":"4711b876.27f488","type":"template","z":"f2a3fe14.e7db8","name":"telegram payload","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n    \"chatId\": -220000000,\n    \"type\": \"message\",\n    \"content\": \"{{payload}}\"\n}\n\n","output":"json","x":810,"y":460,"wires":[["78b71800.62f598"]]},{"id":"c559e4a3.56fef8","type":"telegram bot","z":"","botname":"Telegram bot","usernames":"","chatids":"","baseapiurl":"","pollinterval":"300"}]
Created 8 years, 9 months ago
  • debug (x2)
  • http request (x1)
  • inject (x3)
  • rbe (x1)
  • template (x3)
  • thethingsnetwork
  • ttn
  • gateway
  • monitor
  • lorawan
  • telegram
  • alarms
  • notifications
  • offline
  • online
