Rest
Rest
[{"id":"2f95e587.302f6a","type":"change","z":"6a32c4d1.8c37e4","name":"","rules":[{"t":"delete","p":"headers","pt":"msg"},{"t":"set","p":"headers","pt":"msg","to":"{\t    \"Accept\": \"application/json\",\t    \"Content-Type\": \"application/json\",\t    \"Authorization\": $flowContext('mailroute-api-key')\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":4200,"wires":[["e403fab4.7cd128"]]},{"id":"3ddbbae4.830b56","type":"inject","z":"6a32c4d1.8c37e4","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":140,"y":4160,"wires":[["e7385cba.f3325"]]},{"id":"e403fab4.7cd128","type":"http request","z":"6a32c4d1.8c37e4","name":"","method":"GET","ret":"txt","url":"","tls":"","x":570,"y":4180,"wires":[["7ec73a54.23a274"]]},{"id":"7ec73a54.23a274","type":"json","z":"6a32c4d1.8c37e4","name":"","pretty":false,"x":649.0000343322754,"y":4155.000413894653,"wires":[["db8b73b7.5f5f4"]]},{"id":"788ab243.258bbc","type":"switch","z":"6a32c4d1.8c37e4","name":"","property":"payload.meta.next","propertyType":"msg","rules":[{"t":"null"},{"t":"else"}],"checkall":"false","outputs":2,"x":910,"y":4180,"wires":[["9d358f5c.6e362"],["dbc80fbf.2d03b"]]},{"id":"dccc8e77.6f654","type":"debug","z":"6a32c4d1.8c37e4","name":"","active":true,"console":"false","complete":"false","x":1250,"y":4100,"wires":[]},{"id":"dbc80fbf.2d03b","type":"change","z":"6a32c4d1.8c37e4","name":"","rules":[{"t":"set","p":"url","pt":"msg","to":"$replace(url, /(limit=)(.+)(&offset=)(.+)/, \"$1\" & $string(payload.meta.limit) & \"$3\" & $string(payload.meta.offset + payload.meta.limit))","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":4200,"wires":[["6faae389.342f5c"]]},{"id":"e7385cba.f3325","type":"change","z":"6a32c4d1.8c37e4","name":"Set url, reset wblist","rules":[{"t":"set","p":"url","pt":"msg","to":"\"https://admin.mailroute.net/api/v1/\" & $flowContext('mailroute-api-path') & \"?limit=20&offset=0\"","tot":"jsonata"},{"t":"delete","p":"wbrules","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":4180,"wires":[["2f95e587.302f6a"]]},{"id":"6faae389.342f5c","type":"switch","z":"6a32c4d1.8c37e4","name":"Offset > total?","property":"payload.meta.offset","propertyType":"msg","rules":[{"t":"lte","v":"payload.meta.total_count","vt":"msg"},{"t":"else"}],"checkall":"false","outputs":2,"x":1280,"y":4240,"wires":[["436c23a4.e12ffc"],[]]},{"id":"db8b73b7.5f5f4","type":"function","z":"6a32c4d1.8c37e4","name":"Merge","func":"var wbrules = flow.get('wbrules') || []\n\nwbrules = wbrules.concat(msg.payload.objects)\n//Array.prototype.push.apply(wbrules, msg.payload.objects)\n\nflow.set('wbrules', wbrules)\n\nreturn msg;","outputs":1,"noerr":0,"x":770,"y":4180,"wires":[["788ab243.258bbc"]]},{"id":"9d358f5c.6e362","type":"change","z":"6a32c4d1.8c37e4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"wbrules","tot":"flow"},{"t":"set","p":"filename","pt":"msg","to":"$globalContext('user-home-folder') & \"/Downloads/wblist.csv\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1060,"y":4160,"wires":[["dccc8e77.6f654","90630247.fbb5a"]]},{"id":"b4d88961.3abf88","type":"comment","z":"6a32c4d1.8c37e4","name":"Mailroute Query API - Loop through all whitelist entries for an account","info":"Mailroute is a cloud service that pre-filters\nemail traffic. It has a number of settings including\na whitelist that allows you to force allow or \nblock for email from a specific domain or email\naddress.\n\nThis flow is an example of the API and an example\nof looping through an API that returns a limited\nset of records.\n\nThe flow returns an array of objects detailing\nall of the entries in the white-/black-list.\n\nIt also writes to a CSV file.\n\n## Flow Inputs\n\nNOTE that a separate flow is used to set three flow \nvariables containing information that you would not\nwant public. You will need to set these yourself:\n\n- (flow) mailroute-api-key - \n  The API key required for authorisation.\n  Obtain from the Mailroute Settings\n\n  Format is:\n  `ApiKey <apiUser>:<apiKey>`\n  \n- (flow) mailroute-api-path - \n  The sub-path that you want to use within\n  the API end-points.\n  See the [Mailroute API Documentation](https://support.mailroute.net/hc/en-us/sections/205312008-API)\n  for details.\n\n  To get the global whitelist entries:\n  `wblist/`\n  \n  To get the whitelist entries for a specific mail user:\n  `email_account/<userEmailAddress>/wblist/`\n\n- (global) user-home-folder - \n  Set to either the HOME or HOMEPATH environment\n  variable (dependent on command shell running\n  Node-RED)\n\n## Output Data Format\n\nOutput data from the API is JSON. But it is limited\nto 20 records at a time. This flow loops through\nto get all records and returns an array.\n\n- *email*: Domain or email address to block/allow.\n- *wb*: B = Block, A = Allow","x":310,"y":4120,"wires":[]},{"id":"d1b158de.0f8958","type":"file","z":"6a32c4d1.8c37e4","name":"","filename":"","appendNewline":true,"createDir":false,"overwriteFile":"true","x":1310,"y":4140,"wires":[]},{"id":"90630247.fbb5a","type":"csv","z":"6a32c4d1.8c37e4","name":"","sep":",","hdrin":"","hdrout":true,"multi":"one","ret":"\\n","temp":"domain,email,email_account,id,mail_addr,resource_url,wb","x":1250,"y":4180,"wires":[["d1b158de.0f8958"]]},{"id":"436c23a4.e12ffc","type":"link out","z":"6a32c4d1.8c37e4","name":"Loop-Out","links":["8fd170c.c8a909"],"x":1433.079969406128,"y":4278.531560897827,"wires":[]},{"id":"8fd170c.c8a909","type":"link in","z":"6a32c4d1.8c37e4","name":"Loop-In","links":["436c23a4.e12ffc"],"x":296.076397895813,"y":4228.302665710449,"wires":[["2f95e587.302f6a"]]}]
Created 9 years, 6 months ago
  • change (x4)
  • csv (x1)
  • file (x1)
  • http request (x1)
  • json (x1)
  • link in (x1)
  • link out (x1)
  • switch (x2)
