Pollenwarnung
This flow shows the current pollen situation in Germany, divided into 26 regions across Germany.
Current pollen data is retrieved from the DWD and then displayed on the dashboard. The DWD makes the data available daily at 11:00 am.
The specific region can be selected via a pull-down menu.
Despite this description being written in English, the output on the dashboard is in German.
[{"id":"c7c2ef31.04449","type":"comment","z":"ce22bfd3.2e565","name":"Pollen Warning","info":"Germany only\n\nThis flow retrieves current pollen data from the DWD and displays it on the dashboard. ","x":120,"y":220,"wires":[]},{"id":"a686ea99.920ca8","type":"comment","z":"ce22bfd3.2e565","name":"possible values","info":"\"-1\"        \"keine Werte vorhanden\"\n\nid1         \"0\"\nid1_desc    \"keine Belastung\"\nid2         \"0-1\"\nid2_desc    \"keine bis geringe Belastung\"\nid3         \"1\"\nid3_desc    \"geringe Belastung\"\nid4         \"1-2\"\nid4_desc    \"geringe bis mittlere Belastung\"\nid5         \"2\"\nid5_desc    \"mittlere Belastung\"\nid6         \"2-3\"\nid6_desc    \"mittlere bis hohe Belastung\"\nid7         \"3\"\nid7_desc    \"hohe Belastung\"","x":1480,"y":180,"wires":[]},{"id":"aaf84384.0e07","type":"function","z":"ce22bfd3.2e565","name":"Erle","func":"msg.payload = msg.payload.content[msg.select].Pollen.Erle.today;\nmsg.topic   = node.name; \n\nreturn msg;","outputs":1,"noerr":0,"x":1230,"y":160,"wires":[["df5e75f2.0c9bc8"]]},{"id":"d32cfa41.cdbe88","type":"function","z":"ce22bfd3.2e565","name":"Ambrosia","func":"msg.payload = msg.payload.content[msg.select].Pollen.Ambrosia.today;\nmsg.topic   = node.name; \n\nreturn msg;","outputs":1,"noerr":0,"x":1240,"y":200,"wires":[["df5e75f2.0c9bc8"]]},{"id":"a17d0108.2d7d4","type":"function","z":"ce22bfd3.2e565","name":"Roggen","func":"msg.payload = msg.payload.content[msg.select].Pollen.Roggen.today;\nmsg.topic   = node.name; \n\nreturn msg;","outputs":1,"noerr":0,"x":1240,"y":240,"wires":[["df5e75f2.0c9bc8"]]},{"id":"a97267f3.ca40e8","type":"function","z":"ce22bfd3.2e565","name":"Esche","func":"msg.payload = msg.payload.content[msg.select].Pollen.Esche.today;\nmsg.topic   = node.name; \n\nreturn msg;","outputs":1,"noerr":0,"x":1230,"y":280,"wires":[["df5e75f2.0c9bc8"]]},{"id":"7687fcfd.9ab444","type":"function","z":"ce22bfd3.2e565","name":"Hasel","func":"msg.payload = msg.payload.content[msg.select].Pollen.Hasel.today;\nmsg.topic   = node.name; \n\nreturn msg;","outputs":1,"noerr":0,"x":1230,"y":320,"wires":[["df5e75f2.0c9bc8"]]},{"id":"8544b6b5.dd3ff8","type":"function","z":"ce22bfd3.2e565","name":"Beifuß","func":"msg.payload = msg.payload.content[msg.select].Pollen.Beifuss.today;\nmsg.topic   = node.name; \n\nreturn msg;","outputs":1,"noerr":0,"x":1230,"y":360,"wires":[["df5e75f2.0c9bc8"]]},{"id":"77af9b09.61a164","type":"function","z":"ce22bfd3.2e565","name":"Birke","func":"msg.payload = msg.payload.content[msg.select].Pollen.Birke.today;\nmsg.topic   = node.name; \n\nreturn msg;","outputs":1,"noerr":0,"x":1230,"y":400,"wires":[["df5e75f2.0c9bc8"]]},{"id":"6592703e.60be7","type":"http request","z":"ce22bfd3.2e565","name":"Data from DWD","method":"GET","ret":"obj","paytoqs":false,"url":"https://opendata.dwd.de/climate_environment/health/alerts/s31fg.json","tls":"","proxy":"","authType":"basic","x":960,"y":260,"wires":[["a7ea0e5c.20b22","20576a57.35e966","aaf84384.0e07","d32cfa41.cdbe88","a17d0108.2d7d4","a97267f3.ca40e8","7687fcfd.9ab444","8544b6b5.dd3ff8","77af9b09.61a164"]]},{"id":"df5e75f2.0c9bc8","type":"switch","z":"ce22bfd3.2e565","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"0-1","vt":"str"},{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"1-2","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"2-3","vt":"str"},{"t":"eq","v":"3","vt":"str"}],"checkall":"true","repair":false,"outputs":7,"x":1450,"y":260,"wires":[["14bdaaec.de81e5"],["e5bde0af.2835a"],["32415787.508998"],["f33b9c49.9b458"],["697c6360.aa55bc"],["5dc78855.3ebb58"],["84b26e8c.0cd91"]]},{"id":"a7ea0e5c.20b22","type":"ui_text","z":"ce22bfd3.2e565","group":"5a92396f.316998","order":10,"width":0,"height":0,"name":"Last Update","label":"Letztes Update: ","format":"{{msg.payload.last_update}}","layout":"row-center","x":1250,"y":480,"wires":[]},{"id":"89968405.2c6218","type":"change","z":"ce22bfd3.2e565","name":"","rules":[{"t":"set","p":"select","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":260,"wires":[["6592703e.60be7"]]},{"id":"20576a57.35e966","type":"function","z":"ce22bfd3.2e565","name":"Gräser","func":"msg.payload = msg.payload.content[msg.select].Pollen.Graeser.today;\nmsg.topic   = node.name; \n\nreturn msg;","outputs":1,"noerr":0,"x":1230,"y":120,"wires":[["df5e75f2.0c9bc8"]]},{"id":"2ea2d59f.026bfa","type":"change","z":"ce22bfd3.2e565","name":"Set default to Hessen","rules":[{"t":"set","p":"payload","pt":"msg","to":"16","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":260,"wires":[["494e0bff.d785d4"]]},{"id":"14bdaaec.de81e5","type":"change","z":"ce22bfd3.2e565","name":"Convert for Dashboard","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":140,"wires":[["4078faa2.060644"]],"outputLabels":["== 0"]},{"id":"e5bde0af.2835a","type":"change","z":"ce22bfd3.2e565","name":"Convert for Dashboard","rules":[{"t":"set","p":"payload","pt":"msg","to":"0.5","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":180,"wires":[["4078faa2.060644"]],"outputLabels":["== 1"]},{"id":"32415787.508998","type":"change","z":"ce22bfd3.2e565","name":"Convert for Dashboard","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":220,"wires":[["4078faa2.060644"]],"outputLabels":["== 2"]},{"id":"f33b9c49.9b458","type":"change","z":"ce22bfd3.2e565","name":"Convert for Dashboard","rules":[{"t":"set","p":"payload","pt":"msg","to":"1.5","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":260,"wires":[["4078faa2.060644"]],"outputLabels":["== 3"]},{"id":"697c6360.aa55bc","type":"change","z":"ce22bfd3.2e565","name":"Convert for Dashboard","rules":[{"t":"set","p":"payload","pt":"msg","to":"2","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":300,"wires":[["4078faa2.060644"]],"outputLabels":["== 4"]},{"id":"5dc78855.3ebb58","type":"change","z":"ce22bfd3.2e565","name":"Convert for Dashboard","rules":[{"t":"set","p":"payload","pt":"msg","to":"2.5","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":340,"wires":[["4078faa2.060644"]],"outputLabels":["== 5"]},{"id":"84b26e8c.0cd91","type":"change","z":"ce22bfd3.2e565","name":"Convert for Dashboard","rules":[{"t":"set","p":"payload","pt":"msg","to":"3","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":380,"wires":[["4078faa2.060644"]],"outputLabels":["== 6"]},{"id":"494e0bff.d785d4","type":"ui_dropdown","z":"ce22bfd3.2e565","name":"Pulldown Menu","label":"","tooltip":"Region auswählen","place":"Region auswählen","group":"5a92396f.316998","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"Schleswig-Holstein und Hamburg: Inseln und Marschen","value":"0","type":"str"},{"label":"Schleswig-Holstein und Hamburg: Geest","value":"1","type":"str"},{"label":"Mecklenburg-Vorpommern","value":"2","type":"str"},{"label":"Niedersachsen: Bremen und westliches Gebiet","value":"3","type":"str"},{"label":"Niedersachsen: östliches Gebiet","value":"4","type":"str"},{"label":"NRW: rheinisch-westfälisches Tiefland","value":"5","type":"str"},{"label":"NRW: Ostwestfalen","value":"6","type":"str"},{"label":"NRW: Mittelgebirge","value":"7","type":"str"},{"label":"Brandenburg und Berlin","value":"8","type":"str"},{"label":"Sachsen-Anhalt: Tiefland","value":"9","type":"str"},{"label":"Sachsen-Anhalt: Harz","value":"10","type":"str"},{"label":"Thüringen: Tiefland","value":"11","type":"str"},{"label":"Thüringen: Mittelgebirge","value":"12","type":"str"},{"label":"Sachsen: Tiefland","value":"13","type":"str"},{"label":"Sachsen: Mittelgebirge","value":"14","type":"str"},{"label":"Hessen: Nordhessen und hessisches Mittelgebirge","value":"15","type":"str"},{"label":"Hessen: Rhein-Main","value":"16","type":"str"},{"label":"Saarland","value":"17","type":"str"},{"label":"Rheinland-Pfalz: Rhein, Pfalz, Nahe und Mosel","value":"18","type":"str"},{"label":"Rheinland-Pfalz: Mittelgebirge","value":"19","type":"str"},{"label":"Baden-Württemberg: Oberrhein und unteres Neckartal","value":"20","type":"str"},{"label":"Baden-Württemberg: Hohenlohe, mittlerer Neckar und Oberschwaben","value":"21","type":"str"},{"label":"Baden-Württemberg: Mittelgebirge","value":"22","type":"str"},{"label":"Bayern: Allgäu, Oberbayern und Bayrischer Wald","value":"23","type":"str"},{"label":"Bayern: Donauniederungen","value":"24","type":"str"},{"label":"Bayern: nahe der Donau, oberer Bayrischer Wald, oberes Mainfranken","value":"25","type":"str"},{"label":"Bayern: Mainfranken","value":"26","type":"str"}],"payload":"","topic":"","x":560,"y":260,"wires":[["89968405.2c6218"]]},{"id":"4239eb28.49a3e4","type":"inject","z":"ce22bfd3.2e565","name":"Daily at 11:15","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"15 11 * * *","once":false,"onceDelay":0.1,"x":120,"y":260,"wires":[["2ea2d59f.026bfa"]]},{"id":"4078faa2.060644","type":"switch","z":"ce22bfd3.2e565","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Gräser","vt":"str"},{"t":"eq","v":"Erle","vt":"str"},{"t":"eq","v":"Ambrosia","vt":"str"},{"t":"eq","v":"Roggen","vt":"str"},{"t":"eq","v":"Esche","vt":"str"},{"t":"eq","v":"Hasel","vt":"str"},{"t":"eq","v":"Beifuß","vt":"str"},{"t":"eq","v":"Birke","vt":"str"}],"checkall":"true","repair":false,"outputs":8,"x":1970,"y":260,"wires":[["eec049b5.08b138"],["8ed47d2d.421fc"],["e2199dee.9ab44"],["693cdd2b.031ff4"],["2873c547.850c4a"],["6cd69e5b.c6769"],["c1e4d90a.c15bd8"],["bbb1722d.4b163","7b7c20a6.3b625"]]},{"id":"eec049b5.08b138","type":"ui_gauge","z":"ce22bfd3.2e565","name":"Gräser","group":"5a92396f.316998","order":7,"width":"5","height":"4","gtype":"donut","title":"","label":"{{msg.topic}}","format":"{{value}}","min":0,"max":"3","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":2190,"y":120,"wires":[]},{"id":"8ed47d2d.421fc","type":"ui_gauge","z":"ce22bfd3.2e565","name":"Erle","group":"5a92396f.316998","order":5,"width":"5","height":"4","gtype":"donut","title":"","label":"{{msg.topic}}","format":"{{value}}","min":0,"max":"3","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":2190,"y":160,"wires":[]},{"id":"e2199dee.9ab44","type":"ui_gauge","z":"ce22bfd3.2e565","name":"Ambrosia","group":"5a92396f.316998","order":2,"width":"5","height":"4","gtype":"donut","title":"","label":"{{msg.topic}}","format":"{{value}}","min":0,"max":"3","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":2200,"y":200,"wires":[]},{"id":"693cdd2b.031ff4","type":"ui_gauge","z":"ce22bfd3.2e565","name":"Roggen","group":"5a92396f.316998","order":9,"width":"5","height":"4","gtype":"donut","title":"","label":"{{msg.topic}}","format":"{{value}}","min":0,"max":"3","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":2200,"y":240,"wires":[]},{"id":"2873c547.850c4a","type":"ui_gauge","z":"ce22bfd3.2e565","name":"Esche","group":"5a92396f.316998","order":6,"width":"5","height":"4","gtype":"donut","title":"","label":"{{msg.topic}}","format":"{{value}}","min":0,"max":"3","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":2190,"y":280,"wires":[]},{"id":"6cd69e5b.c6769","type":"ui_gauge","z":"ce22bfd3.2e565","name":"Hasel","group":"5a92396f.316998","order":8,"width":"5","height":"4","gtype":"donut","title":"","label":"{{msg.topic}}","format":"{{value}}","min":0,"max":"3","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":2190,"y":320,"wires":[]},{"id":"c1e4d90a.c15bd8","type":"ui_gauge","z":"ce22bfd3.2e565","name":"Beifuß","group":"5a92396f.316998","order":3,"width":"5","height":"4","gtype":"donut","title":"","label":"{{msg.topic}}","format":"{{value}}","min":0,"max":"3","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":2190,"y":360,"wires":[]},{"id":"bbb1722d.4b163","type":"ui_gauge","z":"ce22bfd3.2e565","name":"Birke","group":"5a92396f.316998","order":4,"width":"5","height":"4","gtype":"donut","title":"","label":"{{msg.topic}}","format":"{{value}}","min":0,"max":"3","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":2190,"y":400,"wires":[]},{"id":"7b7c20a6.3b625","type":"debug","z":"ce22bfd3.2e565","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":2190,"y":500,"wires":[]},{"id":"5a92396f.316998","type":"ui_group","z":"","name":"POLLEN","tab":"ee3ac985.61ca48","order":3,"disp":true,"width":"10","collapse":false},{"id":"ee3ac985.61ca48","type":"ui_tab","z":"","name":"Außen","icon":"wb_sunny","order":1,"disabled":false,"hidden":false}]
Created 7 years, 11 months ago
  • change (x9)
  • comment (x2)
  • function (x8)
  • http request (x1)
  • switch (x2)
  • Pollen
  • Germany
