System statistics of Raspberry Pi
The flow reads and presents system details and statistics of Raspberry Pi (RasPi, RPi). Tested on RasPi 1 mode B and RasPi 3 mode B. The flow has 3 groups respectively:
  1. CPU (Current load + temperature, graphs of load and temperature).
  2. RAM (Currently used, use history graph).
  3. Storage / SD-card (Currently used, graph of total, free and used).
The data refreshes every 5 minutes.
Required OS nodes:
npm install node-red-contrib-os
Screenshot: http://revolushen.com/pub/projects/node_red_raspi_system_view.jpg
[{"id":"9f3346aa.d4fc48","type":"tab","label":"System","disabled":false,"info":""},{"id":"6129eac0.5bdec4","type":"inject","z":"9f3346aa.d4fc48","name":"5 min tick","topic":"","payload":"","payloadType":"date","repeat":"300","crontab":"","once":true,"onceDelay":"1","x":110,"y":460,"wires":[["ab1a2405.584fd8","7805af15.1b74f","f2adaf57.d9a","57db43b6.37f54c","e91a3069.06e26"]]},{"id":"f4fc2799.51b558","type":"ui_gauge","z":"9f3346aa.d4fc48","name":"","group":"2631142d.86f8fc","order":1,"width":"3","height":"3","gtype":"gage","title":"CPU load","label":"%","format":"{{ msg.payload }}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"60","seg2":"80","x":760,"y":600,"wires":[]},{"id":"23830467.dd874c","type":"ui_gauge","z":"9f3346aa.d4fc48","name":"","group":"4a3f1d17.42abc4","order":2,"width":"6","height":"4","gtype":"wave","title":"Used","label":"%","format":"{{msg.payload}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"60","seg2":"80","x":750,"y":260,"wires":[]},{"id":"10934589.87f3ca","type":"ui_chart","z":"9f3346aa.d4fc48","name":"","group":"2631142d.86f8fc","order":3,"width":"6","height":"4","label":"Load, %","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#ff8000","#aec7e8","#0080ff","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":780,"y":640,"wires":[[],[]]},{"id":"95df7e14.b6609","type":"ui_chart","z":"9f3346aa.d4fc48","name":"","group":"4a3f1d17.42abc4","order":1,"width":"6","height":"6","label":"Storage","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":760,"y":300,"wires":[[],[]]},{"id":"e2fad608.df29c8","type":"ui_gauge","z":"9f3346aa.d4fc48","name":"","group":"8e72d94d.e2b8c8","order":2,"width":"0","height":"0","gtype":"donut","title":"RAM usage","label":"%","format":"{{msg.payload.memusage}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"60","seg2":"80","x":750,"y":480,"wires":[]},{"id":"542d167b.24a938","type":"ui_chart","z":"9f3346aa.d4fc48","name":"","group":"8e72d94d.e2b8c8","order":3,"width":0,"height":0,"label":"","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"100","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":740,"y":520,"wires":[[],[]]},{"id":"48b90ddd.e18714","type":"ui_gauge","z":"9f3346aa.d4fc48","name":"","group":"2631142d.86f8fc","order":2,"width":"3","height":"3","gtype":"gage","title":"CPU Temp","label":"°C","format":"{{ msg.payload }}","min":0,"max":"100","colors":["#0080ff","#ffffff","#ca3838"],"seg1":"70","seg2":"85","x":760,"y":680,"wires":[]},{"id":"597cae13.db6de","type":"function","z":"9f3346aa.d4fc48","name":"extract","func":"msg.payload = msg.payload.memusage;\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":520,"wires":[["542d167b.24a938"]]},{"id":"ba1907da.0fcf28","type":"function","z":"9f3346aa.d4fc48","name":"convert_uptime","func":"var d = Math.floor(msg.payload.uptime / 86400);\nvar h = Math.floor((msg.payload.uptime % 86400) / 3600);\nvar m = Math.floor(((msg.payload.uptime % 86400) % 3600) / 60);\nvar s = ((msg.payload.uptime % 86400) % 3600) % 60;\nmsg.payload = d + ':' + h + ':' + m + ':' + s;\nreturn msg;","outputs":1,"noerr":0,"x":560,"y":400,"wires":[["fb58a432.8d29b8"]]},{"id":"ab1a2405.584fd8","type":"exec","z":"9f3346aa.d4fc48","command":"/opt/vc/bin/vcgencmd measure_temp | egrep -o \"[0-9]+\\.[0-9]+?\"","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"read_T","x":420,"y":680,"wires":[["48b90ddd.e18714","72d1796e.c403e8","1c785e0a.f62f52"],[],[]]},{"id":"7805af15.1b74f","type":"Memory","z":"9f3346aa.d4fc48","name":"","x":340,"y":480,"wires":[["e2fad608.df29c8","597cae13.db6de"]]},{"id":"f2adaf57.d9a","type":"Uptime","z":"9f3346aa.d4fc48","name":"Uptime","x":340,"y":400,"wires":[["ba1907da.0fcf28"]]},{"id":"72d1796e.c403e8","type":"ui_chart","z":"9f3346aa.d4fc48","name":"","group":"2631142d.86f8fc","order":4,"width":"6","height":"3","label":"Temperature, °C","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":800,"y":719,"wires":[[],[]]},{"id":"1c785e0a.f62f52","type":"debug","z":"9f3346aa.d4fc48","name":"","active":true,"tosidebar":false,"console":true,"tostatus":false,"complete":"payload","x":760,"y":760,"wires":[]},{"id":"fb58a432.8d29b8","type":"ui_text","z":"9f3346aa.d4fc48","group":"8e72d94d.e2b8c8","order":1,"width":0,"height":0,"name":"","label":"Uptime, d:h:m:s","format":"{{ msg.payload }}","layout":"row-spread","x":760,"y":400,"wires":[]},{"id":"2f0ed260.6ef01e","type":"debug","z":"9f3346aa.d4fc48","name":"Voyer","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","x":300,"y":80,"wires":[]},{"id":"57db43b6.37f54c","type":"exec","z":"9f3346aa.d4fc48","command":"top -d 0.5 -b -n2 | grep Cpu | tail -1 | awk '{print 100-$8}'","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"cpu_load","x":420,"y":600,"wires":[["f4fc2799.51b558","10934589.87f3ca"],[],[]]},{"id":"e91a3069.06e26","type":"exec","z":"9f3346aa.d4fc48","command":"df -m | grep root","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"read_sd_usage","x":320,"y":300,"wires":[["527cb653.bbcfe8"],[],[]]},{"id":"527cb653.bbcfe8","type":"function","z":"9f3346aa.d4fc48","name":"convert","func":"var msg1,msg2,msg3;\n\nl = msg.payload.split(/(\\s+)/).filter( function(e) { return e.trim().length > 0; } );\nmsg1 = {topic: 'Total', payload: Math.round(l[1] / 1000)};\nmsg2 = {topic: 'Free', payload: Math.round(l[3] / 1000)};\nmsg3 = {topic: 'Used%', payload: l[4].slice(0, -1)};\n\nreturn [msg1, msg2, msg3];","outputs":3,"noerr":0,"x":540,"y":280,"wires":[["95df7e14.b6609"],["95df7e14.b6609"],["95df7e14.b6609","23830467.dd874c"]]},{"id":"b8be909f.8f951","type":"ui_button","z":"9f3346aa.d4fc48","name":"Next","group":"c552b4f6.efaca8","order":3,"width":"1","height":"1","passthru":false,"label":"","color":"","bgcolor":"","icon":"arrow_forward","payload":"+1","payloadType":"str","topic":"","x":530,"y":60,"wires":[["386574b8.d2a82c"]]},{"id":"386574b8.d2a82c","type":"ui_ui_control","z":"9f3346aa.d4fc48","name":"Control tabs","x":730,"y":80,"wires":[[]]},{"id":"c0fec75d.6684b8","type":"ui_button","z":"9f3346aa.d4fc48","name":"Prev","group":"c552b4f6.efaca8","order":1,"width":"1","height":"1","passthru":false,"label":"","color":"","bgcolor":"","icon":"arrow_back","payload":"-1","payloadType":"str","topic":"","x":530,"y":100,"wires":[["386574b8.d2a82c"]]},{"id":"433c8c9d.526bc4","type":"ui_button","z":"9f3346aa.d4fc48","name":"Refresh","group":"c552b4f6.efaca8","order":2,"width":"1","height":"1","passthru":false,"label":"","color":"","bgcolor":"","icon":"replay","payload":"{tab:\"\"}","payloadType":"str","topic":"","x":520,"y":20,"wires":[["386574b8.d2a82c"]]},{"id":"d9e2f2b.e50341","type":"inject","z":"9f3346aa.d4fc48","name":"1 min tick","topic":"","payload":"","payloadType":"date","repeat":"60","crontab":"","once":true,"onceDelay":"60","x":490,"y":140,"wires":[["78da90fa.fd1c4"]]},{"id":"78da90fa.fd1c4","type":"function","z":"9f3346aa.d4fc48","name":"date_time","func":"var d_obj = new Date().toString().slice(0, -18); \nmsg.payload = d_obj.slice(0, -6) + '<br>' + d_obj.slice(-5); \nreturn msg;","outputs":1,"noerr":0,"x":640,"y":140,"wires":[["ca66052d.983ce8"]]},{"id":"ca66052d.983ce8","type":"ui_text","z":"9f3346aa.d4fc48","group":"c552b4f6.efaca8","order":0,"width":0,"height":0,"name":"Date time","label":"","format":"{{ msg.payload }}","layout":"col-center","x":780,"y":140,"wires":[]},{"id":"c7e500f1.0b382","type":"comment","z":"9f3346aa.d4fc48","name":"UI controls","info":"","x":720,"y":20,"wires":[]},{"id":"2631142d.86f8fc","type":"ui_group","z":"","name":"CPU","tab":"2248aa46.11d1c6","order":2,"disp":true,"width":"6","collapse":true},{"id":"4a3f1d17.42abc4","type":"ui_group","z":"","name":"SD card","tab":"2248aa46.11d1c6","order":4,"disp":true,"width":"6","collapse":true},{"id":"8e72d94d.e2b8c8","type":"ui_group","z":"","name":"Memory","tab":"2248aa46.11d1c6","order":3,"disp":true,"width":"6","collapse":true},{"id":"c552b4f6.efaca8","type":"ui_group","z":"","name":"Buttons","tab":"2248aa46.11d1c6","order":1,"disp":false,"width":"3","collapse":false},{"id":"2248aa46.11d1c6","type":"ui_tab","z":"","name":"System","icon":"settings","order":2}]
Created 9 years, 2 months ago
Updated 9 years, 1 month ago
Rating: 2 1
  • debug (x2)
  • exec (x3)
  • function (x4)
  • inject (x2)
  • Memory (x1)
  • Uptime (x1)
  • ui_button (x3)
  • ui_chart (x4)
  • ui_gauge (x4)
  • ui_group (x4)
  • ui_text (x2)
  • ui_ui_control (x1)
  • system
  • raspberrypi
  • raspi
  • rpi
  • storage
  • cpu
  • ram
  • memory
  • sdcard
  • usage
