Rocker Switch
This UI-template adds a 3D-looking rocker switch demo and source : https://codepen.io/marcusconnor/pen/QJNvMa
[{"id":"c412591f.e22b28","type":"ui_template","z":"2efb9720.d1e188","group":"","name":"Rocker Switch","order":1,"width":4,"height":3,"format":"<table style=\"width: 100%; text-align: center;\">\n   <tr>\n      <td>\n         <span style=\"vertical-align: middle;font-weight: bold;\">Label</span>\n      </td>\n    </tr>\n    <tr>\n      <td> \n        <label class=\"rocker rocker-mid\">\n        <input type=\"checkbox\" ng-model=\"msg.payload\" ng-change=\"send(msg)\" checked>\n        <md-tooltip md-direction=\"top\">Enable or disable something important!</md-tooltip>\n        <span class=\"switch-left\">On</span>\n        <span class=\"switch-right\">Off</span>\n  </label>\n      </td>\n   </tr>\n</table>\n\n<style>\n    html {\n  box-sizing: border-box;\n  font-family: 'Arial', sans-serif;\n  font-size: 100%;\n}\n*, *:before, *:after {\n  box-sizing: inherit;\n  margin:0;\n  padding:0;\n}\n\n/* Switch starts here */\n.rocker {\n  display: inline-block;\n  position: relative;\n  /*\n  SIZE OF SWITCH\n  ==============\n  All sizes are in em - therefore\n  changing the font-size here\n  will change the size of the switch.\n  See .rocker-small below as example.\n  */\n  font-size: 0.38em;\n  font-weight: bold;\n  text-align: center;\n  text-transform: uppercase;\n  color: #888;\n  width: 7em;\n  height: 4em;\n  overflow: hidden;\n  border-bottom: 0.5em solid #eee;\n}\n\n.rocker-small {\n  font-size: 0.38em; /* Sizes the switch */\n  margin: 0em;\n}\n\n.rocker-mid {\n  font-size: 1.1em; /* Sizes the switch */\n  margin: 0em;\n}\n\n.rocker::before {\n  content: \"\";\n  position: absolute;\n  top: 0.5em;\n  left: 0;\n  right: 0;\n  bottom: 0;\n  background-color: #999;\n  border: 0.5em solid #eee;\n  border-bottom: 0;\n}\n\n.rocker input {\n  opacity: 0;\n  width: 0;\n  height: 0;\n}\n\n.switch-left,\n.switch-right {\n  cursor: pointer;\n  position: absolute;\n  display: flex;\n  align-items: center;\n  justify-content: center;\n  height: 2.5em;\n  width: 3em;\n  transition: 0.2s;\n}\n\n.switch-left {\n  height: 2.4em;\n  width: 2.75em;\n  left: 0.85em;\n  bottom: 0.4em;\n  background-color: #ddd;\n  transform: rotate(15deg) skewX(15deg);\n}\n\n.switch-right {\n  right: 0.5em;\n  bottom: 0;\n  background-color: #bd5757;\n  color: #fff;\n}\n\n.switch-left::before,\n.switch-right::before {\n  content: \"\";\n  position: absolute;\n  width: 0.4em;\n  height: 2.45em;\n  bottom: -0.45em;\n  background-color: #ccc;\n  transform: skewY(-65deg);\n}\n\n.switch-left::before {\n  left: -0.4em;\n}\n\n.switch-right::before {\n  right: -0.375em;\n  background-color: transparent;\n  transform: skewY(65deg);\n}\n\ninput:checked + .switch-left {\n  background-color: #0084d0;\n  color: #fff;\n  bottom: 0px;\n  left: 0.5em;\n  height: 2.5em;\n  width: 3em;\n  transform: rotate(0deg) skewX(0deg);\n}\n\ninput:checked + .switch-left::before {\n  background-color: transparent;\n  width: 3.0833em;\n}\n\ninput:checked + .switch-left + .switch-right {\n  background-color: #ddd;\n  color: #888;\n  bottom: 0.4em;\n  right: 0.8em;\n  height: 2.4em;\n  width: 2.75em;\n  transform: rotate(-15deg) skewX(-15deg);\n}\n\ninput:checked + .switch-left + .switch-right::before {\n  background-color: #ccc;\n}\n\n/* Keyboard Users */\ninput:focus + .switch-left {\n  color: #333;\n}\n\ninput:checked:focus + .switch-left {\n  color: #fff;\n}\n\ninput:focus + .switch-left + .switch-right {\n  color: #fff;\n}\n\ninput:checked:focus + .switch-left + .switch-right {\n  color: #333;\n}\n</style>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":561,"y":942,"wires":[]}]
Created 7 years, 9 months ago
Updated 7 years, 4 months ago
Rating: 5 3
  • ui_template (x1)
  • switch
  • rocker
  • button
  • ui
  • template
