Wifi Settings UI Dashboard
With this flow you will be able to setup your wifi network from your Node-Red Dashboard.
ATTENTION: This flows completely overwrite the content of /etc/wpa_supplicant/wpa_supplicant.conf so please make a backup of that file before using it.
If your WIFI country is different then IT (Italy) you have to go updateWpasupplicant node and update the country there (in a future release of this that could be a settings file)
Schermata da 2020-05-14 16-49-07
Buy Me A Coffee
Enjoy :)
[{"id":"f0a27113.452c7","type":"tab","label":"WIFI Management","disabled":false,"info":""},{"id":"ec32ffa8.3f6f6","type":"exec","z":"f0a27113.452c7","command":"sudo iwlist wlan0 scan | grep ESSID | sed 's/ESSID://g;s/\"//g;s/^ *//;s/ *$//'","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"scan","x":430,"y":80,"wires":[["e0d66c7a.647c9"],[],[]]},{"id":"e0d66c7a.647c9","type":"function","z":"f0a27113.452c7","name":"parseOptions","func":"var ssids = msg.payload.split('\\n').filter(s => !!s)\n\nssids = [...new Set(ssids)];\n\nmsg.options = ssids\nmsg.payload = null\n\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":67,"wires":[["617d9746.cbcbd8"]]},{"id":"a44c56bf.408c08","type":"inject","z":"f0a27113.452c7","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":260,"y":221,"wires":[["ec32ffa8.3f6f6","80ce12b.e5edff","9aa43ac5.df3728"]]},{"id":"617d9746.cbcbd8","type":"ui_dropdown","z":"f0a27113.452c7","name":"","label":"Wifi","tooltip":"","place":"Select a WIFI","group":"4d0f060d.dee7e8","order":2,"width":0,"height":0,"passthru":false,"multiple":false,"options":[],"payload":"","topic":"","x":830,"y":67,"wires":[["fc8462e2.6bc6e"]]},{"id":"f50dd378.27c7f","type":"ui_button","z":"f0a27113.452c7","name":"","group":"4d0f060d.dee7e8","order":1,"width":0,"height":0,"passthru":false,"label":"Scan","tooltip":"","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":230,"y":181,"wires":[["ec32ffa8.3f6f6"]]},{"id":"49307dfc.36fce4","type":"ui_ui_control","z":"f0a27113.452c7","name":"onTab","events":"all","x":130,"y":80,"wires":[["ee0231ae.607de"]]},{"id":"ee0231ae.607de","type":"switch","z":"f0a27113.452c7","name":"ifWifi","property":"name","propertyType":"msg","rules":[{"t":"eq","v":"Wifi","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":271,"y":80,"wires":[["ec32ffa8.3f6f6","80ce12b.e5edff","9aa43ac5.df3728"]]},{"id":"80ce12b.e5edff","type":"exec","z":"f0a27113.452c7","command":"ifconfig wlan0","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"getInfo","x":430,"y":181,"wires":[["8a86d9a3.7ccca8"],[],[]]},{"id":"8a86d9a3.7ccca8","type":"function","z":"f0a27113.452c7","name":"parseInfo","func":"var ip = msg.payload.match(/inet ([0-9\\.]+)/)[1]\nvar mask = msg.payload.match(/netmask ([0-9\\.]+)/)[1]\nvar broadcast = msg.payload.match(/broadcast ([0-9\\.]+)/)[1]\n\n\nnode.send({topic: 'ip', payload: ip})\nnode.send({topic: 'mask', payload: mask})\nnode.send({topic: 'broadcast', payload: broadcast})","outputs":1,"noerr":0,"x":640,"y":168,"wires":[["446ce308.eaab1c"]]},{"id":"446ce308.eaab1c","type":"switch","z":"f0a27113.452c7","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"ip","vt":"str"},{"t":"eq","v":"mask","vt":"str"},{"t":"eq","v":"broadcast","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":810,"y":181,"wires":[["d1ea316d.10c3d"],["8cadebd5.bedfe8"],["3592ebde.5596b4"]]},{"id":"d1ea316d.10c3d","type":"ui_text","z":"f0a27113.452c7","group":"a1e7431b.229d5","order":3,"width":0,"height":0,"name":"","label":"IP","format":"{{msg.payload || '---'}}","layout":"row-spread","x":990,"y":141,"wires":[]},{"id":"8cadebd5.bedfe8","type":"ui_text","z":"f0a27113.452c7","group":"a1e7431b.229d5","order":4,"width":0,"height":0,"name":"","label":"Netmask","format":"{{msg.payload || '---'}}","layout":"row-spread","x":1000,"y":181,"wires":[]},{"id":"3592ebde.5596b4","type":"ui_text","z":"f0a27113.452c7","group":"a1e7431b.229d5","order":5,"width":0,"height":0,"name":"","label":"Broadcast","format":"{{msg.payload || '---'}}","layout":"row-spread","x":1000,"y":221,"wires":[]},{"id":"4e417c79.0e9454","type":"ui_form","z":"f0a27113.452c7","name":"","label":"Update","group":"4d0f060d.dee7e8","order":3,"width":0,"height":0,"options":[{"label":"SSID","value":"ssid","type":"text","required":true,"rows":null},{"label":"Password","value":"password","type":"password","required":true,"rows":null}],"formValue":{"ssid":"","password":""},"payload":"","submit":"UPDATE","cancel":"RESET","topic":"","x":1120,"y":67,"wires":[["562a8ec7.a7e76"]]},{"id":"fc8462e2.6bc6e","type":"function","z":"f0a27113.452c7","name":"","func":"\nmsg.payload = {ssid: msg.payload}\n\nreturn msg;","outputs":1,"noerr":0,"x":970,"y":67,"wires":[["4e417c79.0e9454"]]},{"id":"562a8ec7.a7e76","type":"function","z":"f0a27113.452c7","name":"getPassphrase","func":"var data = msg.payload\n\nvar command = `wpa_passphrase \"${data.ssid}\" \"${data.password}\" | sed '/#psk=\".*\"/d'`\n \nmsg.payload = command\n\nreturn msg","outputs":1,"noerr":0,"x":1320,"y":67,"wires":[["50f3b384.d92f4c"]]},{"id":"50f3b384.d92f4c","type":"exec","z":"f0a27113.452c7","command":"","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":1481,"y":67,"wires":[["201a9fb.244ff6"],[],[]]},{"id":"201a9fb.244ff6","type":"function","z":"f0a27113.452c7","name":"updateWpasupplicant","func":"var template = `sudo tee /etc/wpa_supplicant/wpa_supplicant.conf <<EOF\nctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev\nupdate_config=1\ncountry=IT\n\n${msg.payload}\nEOF\\n\n`\n\nmsg.payload = template\n\nreturn msg;","outputs":1,"noerr":0,"x":1680,"y":60,"wires":[["d288a86d.e0ba48"]]},{"id":"d288a86d.e0ba48","type":"exec","z":"f0a27113.452c7","command":"","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"updateConf","x":1270,"y":180,"wires":[["ecc743df.05dd"],[],[]]},{"id":"ecc743df.05dd","type":"exec","z":"f0a27113.452c7","command":"sudo wpa_cli -i wlan0 reconfigure","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"reconfigure","x":1450,"y":167,"wires":[["2e12d3e8.51947c"],[],[]]},{"id":"2e12d3e8.51947c","type":"function","z":"f0a27113.452c7","name":"showMessage","func":"\nmsg.payload = msg.payload.trim() === 'OK' ? \"Wifi configuration updated successfully\" : \"Error while updating wifi configuration\"\n\nreturn msg;","outputs":1,"noerr":0,"x":1650,"y":154,"wires":[["aa9d6712.91e718"]]},{"id":"aa9d6712.91e718","type":"ui_toast","z":"f0a27113.452c7","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"","name":"","x":1720,"y":220,"wires":[]},{"id":"d4e866c7.6c3958","type":"ui_button","z":"f0a27113.452c7","name":"","group":"a1e7431b.229d5","order":1,"width":"0","height":"0","passthru":false,"label":"Back","tooltip":"","color":"","bgcolor":"","icon":"arrow_back","payload":"Menu","payloadType":"str","topic":"","x":130,"y":300,"wires":[["49307dfc.36fce4"]]},{"id":"9aa43ac5.df3728","type":"exec","z":"f0a27113.452c7","command":"iwgetid","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"getCurrentSSID","x":460,"y":260,"wires":[["6cff487b.f73b08"],[],[]]},{"id":"4e1b74b8.84f51c","type":"ui_text","z":"f0a27113.452c7","group":"a1e7431b.229d5","order":2,"width":0,"height":0,"name":"","label":"SSID","format":"{{msg.payload || '---'}}","layout":"row-spread","x":810,"y":260,"wires":[]},{"id":"6cff487b.f73b08","type":"function","z":"f0a27113.452c7","name":"parseInfo","func":"var ssid = msg.payload.match(/ESSID:\"([^\"]+)\"/)[1]\n\n\nnode.send({topic: 'ssid', payload: ssid})\n","outputs":1,"noerr":0,"x":640,"y":247,"wires":[["4e1b74b8.84f51c"]]},{"id":"4d0f060d.dee7e8","type":"ui_group","z":"","name":"Update","tab":"907bbe60.b555f","order":2,"disp":false,"width":"6","collapse":false},{"id":"a1e7431b.229d5","type":"ui_group","z":"","name":"Settings","tab":"907bbe60.b555f","order":1,"disp":false,"width":"6","collapse":false},{"id":"907bbe60.b555f","type":"ui_tab","z":"","name":"Wifi","icon":"wifi","disabled":false,"hidden":false}]
Created 7 years, 1 month ago
Updated 6 years, 9 months ago
Rating: 5 6
  • exec (x6)
  • function (x7)
  • switch (x2)
  • node-red-dashboard
  • robertsLando
  • wifi
  • raspberry
  • wpa_supplicant
  • dashboard
