Rounded Corners in Dashboard 2.0 Groups
This flow shows a demonstration of how to render rounded corners on a Dashboard 2.0 Group:
Screenshot 2023-11-17 at 16 13 26
[{"id":"009dbde0f6a7e3a0","type":"tab","label":"Rounded Corners Example","disabled":false,"info":"","env":[]},{"id":"027ae44031380a15","type":"ui-markdown","z":"009dbde0f6a7e3a0","group":"39bf532634d939ce","name":"","order":0,"width":0,"height":0,"content":"# Rounded Corners Example\n\n1. Add a `ui-template` node\n2. Choose the \"CSS (Single Page)\" or \"CSS (All Pages)\" option, whichever is appropriate for your use case.\n3. In the \"Template\" text input write:\n\n```css\n.nrdb-ui-group .v-card {\n    border-radius: 24px;\n}\n```\n\n4. Deploy","className":"","x":150,"y":80,"wires":[[]]},{"id":"94c3f04762aa91b9","type":"ui-template","z":"009dbde0f6a7e3a0","group":"6a1709cc60dbf88d","dashboard":"c2e1aa56f50f03bd","page":"7028098c1453a838","name":"","order":0,"width":0,"height":0,"head":"","format":".nrdb-ui-group .v-card {\n    border-radius: 24px;\n}","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"page:style","className":"","x":150,"y":120,"wires":[[]]},{"id":"39bf532634d939ce","type":"ui-group","name":"Rounded Corners Example","page":"7028098c1453a838","width":"6","height":"1","order":-1,"disp":false,"className":""},{"id":"6a1709cc60dbf88d","type":"ui-group","name":"Array/Object Data","page":"830014393540ffda","width":"9","height":"1","order":-1,"disp":true},{"id":"7028098c1453a838","type":"ui-page","name":"Reddit Support","ui":"c2e1aa56f50f03bd","path":"/reddit","layout":"grid","theme":"129e99574def90a3","order":-1,"className":""},{"id":"830014393540ffda","type":"ui-page","name":"Data Visualisation Examples","ui":"c2e1aa56f50f03bd","path":"/graphs","layout":"grid","theme":"129e99574def90a3","order":-1,"className":"test"},{"id":"129e99574def90a3","type":"ui-theme","name":"Another Theme","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"}}]
Created 3 years, 3 months ago
Rating: 1 1
  • dashboard-2.0
