node-red-contrib-iiot-opcua - Browse and Read
v1.0.x Example:
  • Server
  • Brower
  • Client (read)
[{"id":"4b36432f.1ed3cc","type":"tab","label":"IIoT Browse And Read","disabled":false,"info":""},{"id":"23c062ba.dec65e","type":"OPCUA-IIoT-Browser","z":"4b36432f.1ed3cc","connector":"31ab10c.c0f77f","nodeId":"","name":"","showStatusActivities":false,"showErrors":false,"x":330,"y":120,"wires":[["7654330.d1c53cc","648b0815.6f39f8","d7954a0.3cb07b8","91213573.3bfb78"]]},{"id":"7654330.d1c53cc","type":"ui_template","z":"4b36432f.1ed3cc","group":"95160375.96b4e","name":"","order":0,"width":0,"height":0,"format":"<div layout=\"column\" layout-align=\"space-between\">\n    <div layout=\"row\" layout-align=\"space-around center\">\n        <p>{{msg.payload.endpoint}}</p>\n    </div>\n    <div layout=\"row\" layout-align=\"space-around center\">\n        <p>{{msg.payload.browseTopic}} with {{msg.payload.browserResultCount}} references</p>\n    </div>\n    <div layout=\"row\" layout-align=\"space-between center\">\n        <h1>Results</h1>\n    </div>\n    <div layout=\"row\" layout-align=\"space-between center\">\n        <select ng-model=\"item\" ng-options=\"item.displayName.text for item in msg.payload.browserItems\">\n            <option value=\"\">-- Root --</option>\n        </select>\n        <button ng-click=\"send({payload: {actiontype: 'browse', root: item}})\">Browse</button>\n    </div>\n    <div layout=\"row\" layout-align=\"space-around center\">\n        <div>\n            <ul>\n                <li ng-repeat=\"item in msg.payload.browserItems\">\n                  {{item.displayName.text}} ( {{item.nodeId}} - {{item.browseName}})\n                </li>\n            </ul>\n        </div>\n    </div>\n</div>","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":330,"y":60,"wires":[["23c062ba.dec65e","3c2e5b7c.f1f214"]]},{"id":"648b0815.6f39f8","type":"debug","z":"4b36432f.1ed3cc","name":"","active":false,"console":"false","complete":"true","x":510,"y":220,"wires":[]},{"id":"3dcd6539.7ff07a","type":"OPCUA-IIoT-Inject","z":"4b36432f.1ed3cc","injectType":"read","payload":"","payloadType":"date","topic":"","repeat":"","crontab":"","once":true,"startDelay":"","name":"Root","addressSpaceItems":[{"name":"BiancoRoyal","nodeId":"ns=4;i=1234","datatypeName":""}],"x":140,"y":120,"wires":[["23c062ba.dec65e","5c7889b4.5b6a38"]]},{"id":"d7954a0.3cb07b8","type":"OPCUA-IIoT-Response","z":"4b36432f.1ed3cc","name":"","x":520,"y":100,"wires":[["748a193b.03ac78"]]},{"id":"748a193b.03ac78","type":"debug","z":"4b36432f.1ed3cc","name":"","active":false,"console":"false","complete":"true","x":760,"y":100,"wires":[]},{"id":"91213573.3bfb78","type":"OPCUA-IIoT-Read","z":"4b36432f.1ed3cc","attributeId":"13","maxAge":"0","depth":1,"connector":"31ab10c.c0f77f","name":"Read browsed NodeIds","justValue":true,"multipleRequest":true,"metaDataInject":false,"showStatusActivities":false,"showErrors":false,"x":570,"y":160,"wires":[["56437d8e.54ce54"]]},{"id":"56437d8e.54ce54","type":"OPCUA-IIoT-Response","z":"4b36432f.1ed3cc","name":"","x":760,"y":160,"wires":[["d8ad1459.8d1fd8"]]},{"id":"d8ad1459.8d1fd8","type":"debug","z":"4b36432f.1ed3cc","name":"","active":true,"console":"false","complete":"true","x":920,"y":160,"wires":[]},{"id":"5c7889b4.5b6a38","type":"debug","z":"4b36432f.1ed3cc","name":"","active":false,"console":"false","complete":"true","x":330,"y":220,"wires":[]},{"id":"3c2e5b7c.f1f214","type":"debug","z":"4b36432f.1ed3cc","name":"","active":false,"console":"false","complete":"true","x":510,"y":60,"wires":[]},{"id":"31ab10c.c0f77f","type":"OPCUA-IIoT-Connector","z":"","endpoint":"opc.tcp://localhost:55388/","keepSessionAlive":true,"loginEnabled":true,"name":"LOCAL SERVER","showStatusActivities":false,"showErrors":false},{"id":"95160375.96b4e","type":"ui_group","z":"","name":"Default","tab":"852ae1.eacca52","disp":true,"width":"10"},{"id":"852ae1.eacca52","type":"ui_tab","z":"4b36432f.1ed3cc","name":"Node-RED OPC UA IIoT","icon":"dashboard"}]
Created 9 years, 5 months ago
Updated 9 years, 3 months ago
  • debug (x5)
  • OPCUA-IIoT-Browser (x1)
  • OPCUA-IIoT-Connector (x1)
  • OPCUA-IIoT-Inject (x1)
  • OPCUA-IIoT-Read (x1)
  • OPCUA-IIoT-Response (x2)
  • ui_group (x1)
  • ui_template (x1)
  • opcua
  • opc
  • ua
  • iiot
  • iot
  • information
  • model
  • OT
  • IT
  • rami4.0
