XML2JSON Viewer
XML2JSON Viewer for Test Purpose
[{"id":"87fc889c.4dc108","type":"xml","z":"9b34b2d0.13426","name":"XML to Object (No JSon)","property":"payload","attr":"","chr":"","x":574,"y":460,"wires":[["8ef14803.e62838","7d78c49.0f8b33c"]]},{"id":"d11f7ac8.3032c8","type":"inject","z":"9b34b2d0.13426","name":"XML String - BBPS - Customer OU Request","topic":"","payload":"<?xml version=\"1.0\"encoding=\"UTF-8\"?><bbps:BillFetchRequest xmlns:bbps=\"http://bbps.org/schema\"><Head ver=\"1.0\" ts=\"2015-02-16T22:02:35+05:30\" origInst=\"OU01\" refId=\"HENSVVR4QOS7X1UGPY7JGUV444PL9T2C3QM\" /><Analytics><Tag name=\"FETCHREQUESTSTART\" value=\"2015-02-16T22:02:00+05:30\" /><Tag name=\"FETCHREQUESTEND\" value=\"2015-02-16T22:02:35+05:30\" /></Analytics><Txn ts=\"2015-02-16T22:02:35+05:30\" msgId=\"8ENSVVR4QOS7X1UGPY7JGUV444PL9T2C3QX\"><RiskScores><Score provider=\"OU01\" type=\"TXNRISK\" value=\"030\" /><Score provider=\"BBPS\" type=\"TXNRISK\" value=\"030\" /></RiskScores></Txn><Customer mobile=\"9830098300\"><Tag name=\"EMAIL\" value=\"[email protected]\" /><Tag name=\"AADHAAR\" value=\"123456789012\" /><Tag name=\"PAN\" value=\"BXXCG7754K\" /></Customer><Agent id=\"OU01AI34INT001123456\"><Device><Tag name=\"MOBILE\" value=\"9830098300\" /><Tag name=\"GEOCODE\" value=\"12.9667,77.5667\" /><Tag name=\"POSTAL_CODE\" value=\"400063\" /><Tag name=\"IP\" value=\"124.170.23.22\" /><Tag name=\"INITIATING_CHANNEL\" value=\"INT/INTB/MOB/MOBB/KIOSK/ATM/BNKBRNCH/AGT/BSC\" /><Tag name=\"TERMINAL_ID\" value=\"1234556\" /><Tag name=\"IMEI\" value=\"123456789012345\" /><Tag name=\"IFSC\" value=\"ABCD0001234\" /><Tag name=\"MAC\" value=\"00-0D-60-07-2A-FO\" /><Tag name=\"OS\" value=\"iOS\" /><Tag name=\"APP\" value=\"AGENTAPP\" /></Device></Agent><BillDetails><Biller id=\"VODA00000MUM03\" /><CustomerParams><Tag name=\"RefFld1\" value=\"\" /><Tag name=\"RefFld2\" value=\"\" /><Tag name=\"RefFld3\" value=\"\" /></CustomerParams></BillDetails></bbps:BillFetchRequest>","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":234,"y":400,"wires":[["87fc889c.4dc108","776a68c1.c29c38"]]},{"id":"8ef14803.e62838","type":"debug","z":"9b34b2d0.13426","name":"Javascript Object from XML string","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":980,"y":420,"wires":[]},{"id":"7d78c49.0f8b33c","type":"debug","z":"9b34b2d0.13426","name":"Accessing value of a specific attribute of a tag ","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload[\"bbps:BillFetchRequest\"].Txn[0].$.msgId","targetType":"msg","x":1020,"y":480,"wires":[]},{"id":"75139548.fe6e3c","type":"debug","z":"9b34b2d0.13426","name":"JSon Object from XML String","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":960,"y":340,"wires":[]},{"id":"776a68c1.c29c38","type":"function-npm","z":"9b34b2d0.13426","name":"function-npm node for using fast-xml-parser","func":"var xmlData = msg.payload;\n\nvar parser = require('fast-xml-parser');\nvar he = require('he');\n\nvar options = {\n    attributeNamePrefix : \"@_\",\n    attrNodeName: \"attr\", //default is 'false'\n    textNodeName : \"#text\",\n    ignoreAttributes : false,\n    ignoreNameSpace : false,\n    allowBooleanAttributes : false,\n    parseNodeValue : true,\n    parseAttributeValue : true,\n    trimValues: false,\n    cdataTagName: \"__cdata\", //default is 'false'\n    cdataPositionChar: \"\\\\c\",\n    parseTrueNumberOnly: false,\n    arrayMode: true, //\"strict\"\n    attrValueProcessor: (val, attrName) => he.decode(val, {isAttributeValue: true}),//default is a=>a\n    tagValueProcessor : (val, tagName) => he.decode(val), //default is a=>a\n    stopNodes: [\"parse-me-as-string\"]\n};\n\n//if( parser.validate(xmlData) === true) { //optional (it'll return an object in case it's not valid)\n//    var jsonObj = parser.parse(xmlData,options);\n//}\n\n// Intermediate obj\nvar tObj = parser.getTraversalObj(xmlData,options);\nvar jsonObj = parser.convertToJson(tObj,options);\n\nmsg.payload = jsonObj;\n\nreturn msg;","outputs":1,"noerr":0,"x":634,"y":340,"wires":[["75139548.fe6e3c"]]}]
Created 5 years, 2 months ago
  • debug (x3)
  • xml (x1)
  • function-npm (x1)
