DHT11 Humidity and Temperature with extract csv data
DHT11 Sensor reads temperature and humidity data
ESP32 processes and publishes sensor data via MQTT
MQTT broker handles message transmission
Node-red dashboard visualizes real-time data
Extract csv data of humidity and temperature
[{"id":"9bb602cdccf2781b","type":"ui_gauge","z":"972cf1a3ce413cb4","name":"","group":"d015aad33e1aa10a","order":4,"width":11,"height":7,"gtype":"gage","title":"Humidity Gauge","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":440,"y":100,"wires":[]},{"id":"aeb7d0eac6a03df0","type":"ui_gauge","z":"972cf1a3ce413cb4","name":"","group":"d015aad33e1aa10a","order":2,"width":10,"height":7,"gtype":"gage","title":"Temperature Gauge","label":"°C","format":"{{value}}","min":"-20","max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":380,"y":420,"wires":[]},{"id":"9cb7d379ce43eac9","type":"ui_chart","z":"972cf1a3ce413cb4","name":"","group":"d015aad33e1aa10a","order":26,"width":10,"height":6,"label":"Temperature Chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":410,"y":500,"wires":[[]]},{"id":"a8e8bbc9bed2aa75","type":"ui_chart","z":"972cf1a3ce413cb4","name":"","group":"d015aad33e1aa10a","order":28,"width":11,"height":6,"label":"Humidity Chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":440,"y":180,"wires":[[]]},{"id":"afc6f0c36edee809","type":"mqtt in","z":"972cf1a3ce413cb4","name":"ESP32 Temp","topic":"esp32/sensor/temperature","qos":"0","datatype":"auto-detect","broker":"31f4229f4c4a5c39","nl":false,"rap":true,"rh":0,"inputs":0,"x":110,"y":480,"wires":[["aeb7d0eac6a03df0","9cb7d379ce43eac9","d1c03f2504d5dc59","bc144b27d0938f1e"]]},{"id":"bbe1f177696e2091","type":"mqtt in","z":"972cf1a3ce413cb4","name":"ESP32 Hum","topic":"esp32/sensor/humidity","qos":"0","datatype":"auto-detect","broker":"31f4229f4c4a5c39","nl":false,"rap":true,"rh":0,"inputs":0,"x":130,"y":240,"wires":[["9bb602cdccf2781b","a8e8bbc9bed2aa75","442591a7f8e0864a","67b757868f8d5536"]]},{"id":"442591a7f8e0864a","type":"function","z":"972cf1a3ce413cb4","name":"Add timestamp","func":"var timestamp = new Date().toISOString(); // Get the current timestamp in ISO 8601 format\nvar value = msg.payload; // Get the input value\n\n// Create the output message\nmsg.payload = timestamp + \", \" + value;\n\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":260,"wires":[["c8860f665249d749"]]},{"id":"d1c03f2504d5dc59","type":"function","z":"972cf1a3ce413cb4","name":"Add timestamp","func":"var timestamp = new Date().toISOString(); // Get the current timestamp in ISO 8601 format\nvar value = msg.payload; // Get the input value\n\n// Create the output message\nmsg.payload = timestamp + \", \" + value;\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":560,"wires":[["ac60a664cc541ff2"]]},{"id":"c8860f665249d749","type":"file","z":"972cf1a3ce413cb4","name":"Humidity Data","filename":"D:\\Portofolio Github\\Dashboard DHT22 - Predictive Maintenance Github/Humidity.csv","filenameType":"str","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":800,"y":220,"wires":[[]],"info":"var timestamp = new Date().toISOString(); // Get the current timestamp in ISO 8601 format\r\nvar value = msg.payload; // Get the input value\r\n\r\n// Create the output message\r\nmsg.payload = timestamp + \", \" + value;\r\n\r\nreturn msg;"},{"id":"ac60a664cc541ff2","type":"file","z":"972cf1a3ce413cb4","name":"Temperature Data","filename":"D:\\Portofolio Github\\Dashboard DHT22 - Predictive Maintenance Github/Temperature.csv","filenameType":"str","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":770,"y":500,"wires":[[]],"info":"var timestamp = new Date().toISOString(); // Get the current timestamp in ISO 8601 format\r\nvar value = msg.payload; // Get the input value\r\n\r\n// Create the output message\r\nmsg.payload = timestamp + \", \" + value;\r\n\r\nreturn msg;"},{"id":"b81977d38c8e1381","type":"comment","z":"972cf1a3ce413cb4","name":"Data from device to file csv","info":"","x":170,"y":40,"wires":[]},{"id":"bc144b27d0938f1e","type":"debug","z":"972cf1a3ce413cb4","name":"Data Temperature","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":390,"y":360,"wires":[]},{"id":"67b757868f8d5536","type":"debug","z":"972cf1a3ce413cb4","name":"Data Humidity","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":440,"y":40,"wires":[]},{"id":"d015aad33e1aa10a","type":"ui_group","name":"Dashboard Temperature & Humidity","tab":"84308f73a723df19","order":1,"disp":true,"width":24,"collapse":false,"className":""},{"id":"31f4229f4c4a5c39","type":"mqtt-broker","name":"","broker":"broker.emqx.io","port":1883,"clientid":"","autoConnect":true,"usetls":false,"protocolVersion":4,"keepalive":60,"cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"84308f73a723df19","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false},{"id":"75e33e3527a5bfb6","type":"global-config","env":[],"modules":{"node-red-dashboard":"3.6.6"}}]
Copyright OpenJS Foundation and Node-RED contributors. All rights reserved. The OpenJS Foundation has registered trademarks and uses trademarks. For a list of trademarks of the OpenJS Foundation, please see our Trademark Policy and Trademark List. Trademarks and logos not indicated on the list of OpenJS Foundation trademarks are trademarks™ or registered® trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them.
