"Are you sure?", confirm an action triggered on the Dashboard with whatsapp. Whin use case.
On this flow you will see how to get a whatsapp with two buttons (yes / no) that will ask you for confirmation before a kill switch on you node-red Dashboard changes state.
It is useful if your node-red dashboard has a switch that triggers an automation, and you don't want it to happen without your active action.
This example is an alternative to a pop-up message shown on the dashboard which was the original solution suggested on the community forum.
You can see a demo of the flow running here: https://youtu.be/ePGRRq4VTz4
This flow is inspired on this thread: https://discourse.nodered.org/t/are-you-sure-pop-ups/13458/25; it is an alternative implementation using node-red-contrib-whin nodes.
Feb-2022 by inUntil
[{"id":"6ae2622fe539cb5b","type":"ui_switch","z":"42ea5846ccd51a87","name":"Kill Switch - whin","label":"Kill Switch","tooltip":"you have to confirm on whatsapp.","group":"d15dc202ba5c70ad","order":18,"width":"4","height":"1","passthru":false,"decouple":"true","topic":"","topicType":"str","style":"","onvalue":"0","onvalueType":"num","onicon":"fa-2x fa-bolt","oncolor":"yellow","offvalue":"1","offvalueType":"num","officon":"fa-2x fa-power-off","offcolor":"gray","animate":true,"x":430,"y":150,"wires":[["316a4c6f89e06775","740412fc04728eed"]]},{"id":"94be09694b3b9b7f","type":"function","z":"42ea5846ccd51a87","name":"feedback to ui","func":"//only accept YES msg's\nif (msg.payload.whin == 'YES') {\n    msg.payload = msg.payload.ui;\n    node.send(msg);\n}\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1305,"y":100,"wires":[["6ae2622fe539cb5b"]]},{"id":"316a4c6f89e06775","type":"change","z":"42ea5846ccd51a87","name":"prepare join","rules":[{"t":"set","p":"topic","pt":"msg","to":"ui","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":100,"wires":[["4e9e8b9036fb5ccc"]]},{"id":"84230657bb262ecb","type":"comment","z":"42ea5846ccd51a87","name":"credits","info":"this flow is inspired on this thread:\n\nhttps://discourse.nodered.org/t/are-you-sure-pop-ups/13458/25\n\nit is an alternative implementation, based on node-red-contrib-whin\n\nFeb-2022 by inUntil","x":450,"y":225,"wires":[]},{"id":"108b995d75b8ae17","type":"whin-confirm","z":"42ea5846ccd51a87","name":"whin confirm","auth":"1dd48adf4bee331d","x":830,"y":175,"wires":[["d527236c8370eed5"]]},{"id":"740412fc04728eed","type":"change","z":"42ea5846ccd51a87","name":"question and TTL","rules":[{"t":"set","p":"ttl","pt":"msg","to":"20000","tot":"num"},{"t":"set","p":"payload","pt":"msg","to":"DID YOU LIKE IT?","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":175,"wires":[["108b995d75b8ae17"]]},{"id":"4e9e8b9036fb5ccc","type":"join","z":"42ea5846ccd51a87","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1150,"y":100,"wires":[["94be09694b3b9b7f"]]},{"id":"d527236c8370eed5","type":"change","z":"42ea5846ccd51a87","name":"prepare join","rules":[{"t":"set","p":"topic","pt":"msg","to":"whin","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":995,"y":175,"wires":[["4e9e8b9036fb5ccc"]]},{"id":"2c3d329496048e74","type":"comment","z":"42ea5846ccd51a87","name":"Passes the original value along","info":"","x":855,"y":75,"wires":[]},{"id":"c0360ef897a22090","type":"comment","z":"42ea5846ccd51a87","name":"Asks for confirmation on whatsapp","info":"","x":915,"y":225,"wires":[]},{"id":"d15dc202ba5c70ad","type":"ui_group","name":"","tab":"c8377355.8e04f","order":2,"disp":true,"width":"6","collapse":false},{"id":"1dd48adf4bee331d","type":"whin-config","name":"demo config","phone":"YOUR_PHONE","token":"YOUR_WHIN_TOKEN"},{"id":"c8377355.8e04f","type":"ui_tab","name":"whin confirm - demo","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
Created 5 years, 2 months ago
Rating: 1 1
  • change (x3)
  • comment (x3)
  • join (x1)
  • ui_group (x1)
  • ui_switch (x1)
  • whin-config (x1)
  • whin-confirm (x1)
  • whatsapp
  • dashboard
  • confirm
  • switch
