Data from Domoticz to dashboard
Different kinds of data from different sources from Domoticz to Node Red UI
[{"id":"26a1e310.57bcac","type":"tab","label":"Dashboard","disabled":false,"info":""},{"id":"71b58c15.2fc554","type":"mqtt in","z":"26a1e310.57bcac","name":"","topic":"domoticz/out","qos":"2","datatype":"auto","broker":"cb98837a.c9468","x":70,"y":600,"wires":[["c12d99f.7adee68","320f9fb6.0d406"]]},{"id":"c12d99f.7adee68","type":"json","z":"26a1e310.57bcac","name":"","property":"payload","action":"","pretty":false,"x":170,"y":700,"wires":[["d1b12358.5adee","8569b8ad.fae048","43e7efba.1cdf8","7340b424.6adcac","a1e5cf23.e186c"]]},{"id":"d1b12358.5adee","type":"switch","z":"26a1e310.57bcac","name":"Split idx","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"263","vt":"num"},{"t":"eq","v":"262","vt":"num"},{"t":"eq","v":"272","vt":"str"},{"t":"eq","v":"273","vt":"str"},{"t":"eq","v":"275","vt":"str"},{"t":"eq","v":"60","vt":"num"}],"checkall":"true","repair":false,"outputs":6,"x":380,"y":80,"wires":[["d3416223.192d9"],["f702ea1f.4d8e08"],["7e37e16.4dad32"],["8c533565.c59728"],["cfd6f4be.6302e8"],["e9d68869.006208","20f1700a.44e2e"]]},{"id":"e9d68869.006208","type":"function","z":"26a1e310.57bcac","name":"Request data","func":"var msg1 = {};\nvar msg2 = {};\nvar msg3 = {};\n\nrequests1 = {\"command\": \"getdeviceinfo\", \"idx\": 263};\nrequests2 = {\"command\": \"getdeviceinfo\", \"idx\": 262};\nrequests3 = {\"command\": \"getdeviceinfo\", \"idx\": 290};\n\nmsg1.payload = requests1\nmsg2.payload = requests2\nmsg3.payload = requests3\n\nreturn [msg1,msg2, msg3];","outputs":3,"noerr":0,"x":590,"y":260,"wires":[["2be1bc27.e03474"],["2be1bc27.e03474"],["2be1bc27.e03474"]]},{"id":"2be1bc27.e03474","type":"mqtt out","z":"26a1e310.57bcac","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"7686f54.6c3e90c","x":1230,"y":300,"wires":[]},{"id":"d3416223.192d9","type":"function","z":"26a1e310.57bcac","name":"Node Red","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"Node Red (RPi3)\"\nreturn msg;","outputs":1,"noerr":0,"x":580,"y":20,"wires":[["b2e44ce0.1af37","f0a4d776.760a08"]]},{"id":"f702ea1f.4d8e08","type":"function","z":"26a1e310.57bcac","name":"SDS011","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"Node Red SDS011 (RPi2)\"\nreturn msg;","outputs":1,"noerr":0,"x":580,"y":60,"wires":[["b2e44ce0.1af37","3b0e7f.92295182"]]},{"id":"20f1700a.44e2e","type":"function","z":"26a1e310.57bcac","name":"Domoticz","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"Domoticz (RPi3)\"\nreturn msg;","outputs":1,"noerr":0,"x":580,"y":220,"wires":[["b2e44ce0.1af37","e4d2c8a9.dc8b58"]]},{"id":"8569b8ad.fae048","type":"switch","z":"26a1e310.57bcac","name":"Split idx","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"79","vt":"num"},{"t":"eq","v":"216","vt":"num"},{"t":"eq","v":"124","vt":"num"},{"t":"eq","v":"59","vt":"num"},{"t":"eq","v":"105","vt":"num"},{"t":"eq","v":"209","vt":"num"},{"t":"eq","v":"133","vt":"num"},{"t":"eq","v":"204","vt":"num"}],"checkall":"true","repair":false,"outputs":8,"x":380,"y":560,"wires":[["7ad95b0e.ca39d4"],["e606d720.899b18"],["94c771ef.bb986"],["6c7621c8.d7768"],["79906c17.2a56c4"],["361569b7.4df086"],["b66765f4.0e27c8"],["7b7671f6.8d04d"]]},{"id":"e606d720.899b18","type":"function","z":"26a1e310.57bcac","name":"Schuur","func":"var msg1 ={};\nvar msg2 ={};\n\ntemp = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = temp;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Schuur\"\nmsg2.topic=\"Schuur\"\nreturn [msg1,msg2];","outputs":2,"noerr":0,"x":580,"y":460,"wires":[["5ebf6a28.52c464","748d3df4.711a84"],["7634dde9.b69db4"]]},{"id":"94c771ef.bb986","type":"function","z":"26a1e310.57bcac","name":"Zonnescherm","func":"var msg1 ={};\nvar msg2 ={};\n\ntemp = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = temp;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Zonnescherm\"\nmsg2.topic = \"zonnescherm\"\nreturn [msg1,msg2];","outputs":2,"noerr":0,"x":600,"y":500,"wires":[["5ebf6a28.52c464","42c9e0f7.5c922"],["7634dde9.b69db4"]]},{"id":"79906c17.2a56c4","type":"function","z":"26a1e310.57bcac","name":"Woonkamer","func":"var msg1 ={};\nvar msg2 ={};\n\ntemp = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = temp;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Woonkamer\"\nmsg2.topic = \"Woonkamer\"\nreturn [msg1,msg2];","outputs":2,"noerr":0,"x":590,"y":580,"wires":[["f321e27c.6dfff","e27d7cbc.fcd7c"],["917a128f.ba607"]]},{"id":"361569b7.4df086","type":"function","z":"26a1e310.57bcac","name":"Slaapkamer","func":"var msg1 ={};\nvar msg2 ={};\n\ntemp = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = temp;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Slaapkamer\"\nmsg2.topic=\"Slaapkamer\"\nreturn [msg1,msg2];","outputs":2,"noerr":0,"x":590,"y":620,"wires":[["f321e27c.6dfff","5f29fb2.f408b04"],["917a128f.ba607"]]},{"id":"b66765f4.0e27c8","type":"function","z":"26a1e310.57bcac","name":"Badkamer","func":"var msg1 ={};\nvar msg2 ={};\n\ntemp = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = temp;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Badkamer\"\nmsg2.topic = \"Badkamer\"\nreturn [msg1,msg2];","outputs":2,"noerr":0,"x":590,"y":660,"wires":[["f321e27c.6dfff","8f3ca6d1.d72f88"],["917a128f.ba607"]]},{"id":"7b7671f6.8d04d","type":"function","z":"26a1e310.57bcac","name":"Zolder","func":"var msg1 ={};\nvar msg2 ={};\n\ntemp = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = temp;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Zolder\";\nmsg2.topic= \"Zolder\";\n\nreturn [msg1,msg2];","outputs":2,"noerr":0,"x":570,"y":700,"wires":[["f321e27c.6dfff","a0c92a54.6de3b8"],["917a128f.ba607"]]},{"id":"6c7621c8.d7768","type":"function","z":"26a1e310.57bcac","name":"HUE","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\n\nmsg.topic = \"Hue\"\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":540,"wires":[["5ebf6a28.52c464","249b0a26.9afd16"]]},{"id":"43e7efba.1cdf8","type":"switch","z":"26a1e310.57bcac","name":"split idx","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"260","vt":"num"},{"t":"eq","v":"229","vt":"num"},{"t":"eq","v":"261","vt":"num"},{"t":"eq","v":"228","vt":"num"},{"t":"eq","v":"290","vt":"num"}],"checkall":"true","repair":false,"outputs":5,"x":380,"y":820,"wires":[["d2141bfb.397088"],["60d41196.31714"],["78097dd4.7d7934"],["fd374dcb.d724a"],["9739563e.4b5e28"]]},{"id":"d2141bfb.397088","type":"function","z":"26a1e310.57bcac","name":"PM2.5 thuis","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"PM2.5 thuis\"\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":740,"wires":[["b22f105f.e5d68","e6d0cb92.63d0b8"]]},{"id":"78097dd4.7d7934","type":"function","z":"26a1e310.57bcac","name":"PM10 thuis","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"PM10 thuis\"\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":820,"wires":[["55daba36.2fa544","3b7108c8.88ac78"]]},{"id":"60d41196.31714","type":"function","z":"26a1e310.57bcac","name":"PM2.5 buiten","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"PM2.5 buiten\"\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":780,"wires":[["b22f105f.e5d68","be43e1f0.f6022"]]},{"id":"fd374dcb.d724a","type":"function","z":"26a1e310.57bcac","name":"PM10 buiten","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"PM10 buiten\"\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":860,"wires":[["55daba36.2fa544","264d0f47.d8fcb"]]},{"id":"fb8a65c9.a96b78","type":"inject","z":"26a1e310.57bcac","name":"PM request","repeat":"300","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":410,"y":320,"wires":[["d8f67965.3dc208"]]},{"id":"d8f67965.3dc208","type":"function","z":"26a1e310.57bcac","name":"request data","func":"var msg1 = {};\nvar msg2= {};\nvar msg3 = {};\nvar msg4 = {};\nvar msg5 = {};\nvar msg6 = {};\nvar msg7 = {};\n\nrequests1 = {\"command\": \"getdeviceinfo\", \"idx\": 228};\nrequests2 = {\"command\": \"getdeviceinfo\", \"idx\": 229};\nrequests3 = {\"command\": \"getdeviceinfo\", \"idx\": 260};\nrequests4 = {\"command\": \"getdeviceinfo\", \"idx\": 261};\nrequests5 = {\"command\": \"getdeviceinfo\", \"idx\": 272};\nrequests6 = {\"command\": \"getdeviceinfo\", \"idx\": 273};\nrequests7 = {\"command\": \"getdeviceinfo\", \"idx\": 275};\n\nmsg1.payload = requests1\nmsg2.payload = requests2\nmsg3.payload = requests3\nmsg4.payload = requests4\nmsg5.payload = requests5\nmsg6.payload = requests6\nmsg7.payload = requests7\n\nreturn [msg1,msg2,msg3,msg4,msg5,msg6,msg7];","outputs":7,"noerr":0,"x":590,"y":340,"wires":[["2be1bc27.e03474"],["2be1bc27.e03474"],["2be1bc27.e03474"],["2be1bc27.e03474"],["2be1bc27.e03474"],["2be1bc27.e03474"],["2be1bc27.e03474"]]},{"id":"7ad95b0e.ca39d4","type":"function","z":"26a1e310.57bcac","name":"Tuin","func":"var msg1 ={};\nvar msg2 ={};\n\ntemp = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = temp;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Tuin\"\nmsg2.topic=\"Tuin\"\nreturn [msg1,msg2];","outputs":2,"noerr":0,"x":570,"y":420,"wires":[["5ebf6a28.52c464","4d0b6fdd.9240b"],["7634dde9.b69db4"]]},{"id":"7e37e16.4dad32","type":"function","z":"26a1e310.57bcac","name":"CO2","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"CO2 (RPi3)\"\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":100,"wires":[["b2e44ce0.1af37","f258f405.9c5188"]]},{"id":"8c533565.c59728","type":"function","z":"26a1e310.57bcac","name":"GPIO","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"GPIO (RPi2)\"\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":140,"wires":[["b2e44ce0.1af37","78dd6716.04eb58"]]},{"id":"cfd6f4be.6302e8","type":"function","z":"26a1e310.57bcac","name":"Pi Zero","func":"temp = parseFloat(msg.payload.svalue1);\nmsg.payload = temp;\nmsg.topic = \"PiAware (RPi0)\"\nreturn msg;","outputs":1,"noerr":0,"x":580,"y":180,"wires":[["b2e44ce0.1af37","c8ef5885.0c2e38"]]},{"id":"f0a4d776.760a08","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"node_red","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":20,"wires":[[]]},{"id":"3b0e7f.92295182","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"sds011","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":60,"wires":[[]]},{"id":"f258f405.9c5188","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"rpi3","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":100,"wires":[[]]},{"id":"78dd6716.04eb58","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"gpio","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":140,"wires":[[]]},{"id":"c8ef5885.0c2e38","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"zero","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":180,"wires":[[]]},{"id":"e4d2c8a9.dc8b58","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"domoticz","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":220,"wires":[[]]},{"id":"4d0b6fdd.9240b","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"tuin_t","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":400,"wires":[[]]},{"id":"748d3df4.711a84","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"schuur_t","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":460,"wires":[[]]},{"id":"42c9e0f7.5c922","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"zonnescherm_t","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1350,"y":500,"wires":[[]]},{"id":"249b0a26.9afd16","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"hue_t","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":540,"wires":[[]]},{"id":"e27d7cbc.fcd7c","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"woonkamer_t","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1350,"y":580,"wires":[[]]},{"id":"5f29fb2.f408b04","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"slaapkamer_t","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1350,"y":620,"wires":[[]]},{"id":"8f3ca6d1.d72f88","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"badkamer_t","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":660,"wires":[[]]},{"id":"a0c92a54.6de3b8","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"zolder_t","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":700,"wires":[[]]},{"id":"e6d0cb92.63d0b8","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"pm25_binnen","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1350,"y":740,"wires":[[]]},{"id":"be43e1f0.f6022","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"pm25_buiten","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1350,"y":780,"wires":[[]]},{"id":"3b7108c8.88ac78","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"pm10_binnen","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1350,"y":820,"wires":[[]]},{"id":"264d0f47.d8fcb","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"pm10_buiten","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1350,"y":860,"wires":[[]]},{"id":"320f9fb6.0d406","type":"link out","z":"26a1e310.57bcac","name":"DZ/out","links":["8352315f.e8755","aa8135ef.b7cb48","fbb54cee.ef9e7"],"x":135,"y":500,"wires":[]},{"id":"80ee28b2.1ab318","type":"link in","z":"26a1e310.57bcac","name":"Dz/in","links":["fb646294.77c58","ddde15a0.a45558","5e44c8e8.f93c88","e3809685.7f1928","ee9a4a24.0e7998"],"x":1075,"y":360,"wires":[["2be1bc27.e03474"]]},{"id":"9739563e.4b5e28","type":"function","z":"26a1e310.57bcac","name":"Co2","func":"co2 = parseFloat(msg.payload.svalue1);\nmsg.payload = co2;\nmsg.topic = \"CO2\"\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":900,"wires":[["c558d268.66b7a","c2c64f58.b7d0d"]]},{"id":"c2c64f58.b7d0d","type":"change","z":"26a1e310.57bcac","name":"","rules":[{"t":"set","p":"co2","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":900,"wires":[[]]},{"id":"7340b424.6adcac","type":"switch","z":"26a1e310.57bcac","name":"watt","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"92","vt":"num"},{"t":"eq","v":"279","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":960,"wires":[["88434cb6.c970d"],["f316473b.a005f8"]]},{"id":"a1e5cf23.e186c","type":"switch","z":"26a1e310.57bcac","name":"Amp","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"90","vt":"num"},{"t":"eq","v":"277","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":1040,"wires":[["6cf36c2f.dfc0f4"],["8165e23d.7fa7a"]]},{"id":"88434cb6.c970d","type":"function","z":"26a1e310.57bcac","name":"was","func":"var msg1 ={};\nvar msg2 ={};\n\nwatt = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = watt;\nmsg2.payload = humidity;\n\nmsg1.topic = \"wasmachine\"\n\nreturn [msg1];","outputs":1,"noerr":0,"x":570,"y":940,"wires":[["35f74dcf.6ec812"]]},{"id":"f316473b.a005f8","type":"function","z":"26a1e310.57bcac","name":"Droger","func":"var msg1 ={};\nvar msg2 ={};\n\nwatt = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = watt;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Droger\"\n\nreturn [msg1];","outputs":1,"noerr":0,"x":570,"y":980,"wires":[["35f74dcf.6ec812"]]},{"id":"6cf36c2f.dfc0f4","type":"function","z":"26a1e310.57bcac","name":"was","func":"var msg1 ={};\nvar msg2 ={};\n\nwatt = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = watt;\nmsg2.payload = humidity;\n\nmsg1.topic = \"wasmachine\"\n\nreturn [msg1];","outputs":1,"noerr":0,"x":570,"y":1020,"wires":[["e69cb2e5.36576"]]},{"id":"8165e23d.7fa7a","type":"function","z":"26a1e310.57bcac","name":"Droger","func":"var msg1 ={};\nvar msg2 ={};\n\nwatt = parseFloat(msg.payload.svalue1);\nhumidity = parseFloat(msg.payload.svalue2);\n\nmsg1.payload = watt;\nmsg2.payload = humidity;\n\nmsg1.topic = \"Droger\"\n\nreturn [msg1];","outputs":1,"noerr":0,"x":570,"y":1060,"wires":[["e69cb2e5.36576"]]},{"id":"f3588449.6392c8","type":"ui_button","z":"26a1e310.57bcac","name":"","group":"d5af76a0.d97998","order":3,"width":8,"height":2,"passthru":false,"label":"reset","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":1050,"y":120,"wires":[["b2e44ce0.1af37"]]},{"id":"ee8d6d9b.f434","type":"ui_button","z":"26a1e310.57bcac","name":"reset PM","group":"7fe149ef.55ca98","order":4,"width":6,"height":2,"passthru":false,"label":"clear PM graphs","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":1060,"y":800,"wires":[["b22f105f.e5d68","55daba36.2fa544"]]},{"id":"7414e085.6bca1","type":"ui_button","z":"26a1e310.57bcac","name":"","group":"a919668e.8c3c68","order":3,"width":8,"height":2,"passthru":false,"label":"reset temp home","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":1090,"y":600,"wires":[["f321e27c.6dfff"]]},{"id":"dc1d9fc6.533ad","type":"ui_button","z":"26a1e310.57bcac","name":"","group":"a919668e.8c3c68","order":9,"width":8,"height":2,"passthru":false,"label":"reset humidity home","tooltip":"","color":"","bgcolor":"","icon":"eraser","payload":"[]","payloadType":"json","topic":"","x":1100,"y":680,"wires":[["917a128f.ba607"]]},{"id":"b76c3540.17c118","type":"ui_button","z":"26a1e310.57bcac","name":"","group":"a2a898fb.6d8248","order":9,"width":8,"height":2,"passthru":false,"label":"reset humidity garden","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":1100,"y":560,"wires":[["7634dde9.b69db4"]]},{"id":"a525a4c9.553388","type":"ui_button","z":"26a1e310.57bcac","name":"","group":"a2a898fb.6d8248","order":3,"width":8,"height":2,"passthru":false,"label":"reset temp garden","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":1090,"y":480,"wires":[["5ebf6a28.52c464"]]},{"id":"aba3e1f3.d8f56","type":"ui_button","z":"26a1e310.57bcac","name":"","group":"7fe149ef.55ca98","order":10,"width":8,"height":2,"passthru":false,"label":"reset CO2","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":1070,"y":920,"wires":[["c558d268.66b7a"]]},{"id":"e5a56610.819868","type":"ui_button","z":"26a1e310.57bcac","name":"","group":"f7c1598a.e95278","order":4,"width":7,"height":2,"passthru":false,"label":"reset Watt","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":1060,"y":960,"wires":[["35f74dcf.6ec812"]]},{"id":"a1c95f8a.720a9","type":"ui_button","z":"26a1e310.57bcac","name":"","group":"f7c1598a.e95278","order":6,"width":7,"height":2,"passthru":false,"label":"reset Amp","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":1060,"y":1040,"wires":[["e69cb2e5.36576"]]},{"id":"b2e44ce0.1af37","type":"ui_chart","z":"26a1e310.57bcac","name":"","group":"d5af76a0.d97998","order":1,"width":20,"height":12,"label":"Temperature","chartType":"line","legend":"true","xformat":"HH:mm","interpolate":"linear","nodata":"","dot":true,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":830,"y":120,"wires":[[]]},{"id":"f321e27c.6dfff","type":"ui_chart","z":"26a1e310.57bcac","name":"Temperature at home","group":"a919668e.8c3c68","order":1,"width":0,"height":0,"label":"Temperature at home","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"Temperatures","dot":true,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":860,"y":600,"wires":[[]]},{"id":"b22f105f.e5d68","type":"ui_chart","z":"26a1e310.57bcac","name":"","group":"7fe149ef.55ca98","order":1,"width":20,"height":8,"label":"PM2.5","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"PM2.5 data","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":810,"y":760,"wires":[[]]},{"id":"55daba36.2fa544","type":"ui_chart","z":"26a1e310.57bcac","name":"","group":"7fe149ef.55ca98","order":2,"width":20,"height":8,"label":"PM10","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"PM10 data","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":810,"y":840,"wires":[[]]},{"id":"917a128f.ba607","type":"ui_chart","z":"26a1e310.57bcac","name":"Humidity at home","group":"a919668e.8c3c68","order":7,"width":0,"height":0,"label":"Humidity at home","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"Humidity","dot":true,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":850,"y":660,"wires":[[]]},{"id":"5ebf6a28.52c464","type":"ui_chart","z":"26a1e310.57bcac","name":"Temperature Garden","group":"a2a898fb.6d8248","order":1,"width":0,"height":0,"label":"Temperature Garden","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"Temperatures","dot":true,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":860,"y":480,"wires":[[]]},{"id":"7634dde9.b69db4","type":"ui_chart","z":"26a1e310.57bcac","name":"Humidity Garden","group":"a2a898fb.6d8248","order":7,"width":0,"height":0,"label":"Humidity Garden","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"Humidity","dot":true,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":850,"y":540,"wires":[[]]},{"id":"c558d268.66b7a","type":"ui_chart","z":"26a1e310.57bcac","name":"","group":"7fe149ef.55ca98","order":8,"width":20,"height":12,"label":"CO2","chartType":"line","legend":"true","xformat":"HH:mm","interpolate":"linear","nodata":"","dot":true,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":810,"y":900,"wires":[[]]},{"id":"35f74dcf.6ec812","type":"ui_chart","z":"26a1e310.57bcac","name":"","group":"f7c1598a.e95278","order":1,"width":15,"height":15,"label":"Watt","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"Watt","dot":true,"ymin":"","ymax":"","removeOlder":"2","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":810,"y":960,"wires":[[]]},{"id":"e69cb2e5.36576","type":"ui_chart","z":"26a1e310.57bcac","name":"","group":"f7c1598a.e95278","order":2,"width":15,"height":15,"label":"Amp","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"Amp","dot":true,"ymin":"","ymax":"","removeOlder":"2","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":810,"y":1040,"wires":[[]]},{"id":"cb98837a.c9468","type":"mqtt-broker","z":"","name":"Domoticz","broker":"192.168.0.115","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"7686f54.6c3e90c","type":"mqtt-broker","z":"","name":"","broker":"192.168.0.115","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"d5af76a0.d97998","type":"ui_group","z":"","name":"Default","tab":"718b1892.fc1ed8","order":1,"disp":true,"width":"20","collapse":false},{"id":"7fe149ef.55ca98","type":"ui_group","z":"","name":"Group 1","tab":"ba745177.2298c","order":1,"disp":true,"width":"20","collapse":false},{"id":"a919668e.8c3c68","type":"ui_group","z":"","name":"Group 1","tab":"5ebc98d3.642238","order":1,"disp":true,"width":"20","collapse":false},{"id":"a2a898fb.6d8248","type":"ui_group","z":"","name":"Group 1","tab":"21308d89.0e4f52","order":1,"disp":true,"width":"20","collapse":false},{"id":"f7c1598a.e95278","type":"ui_group","z":"","name":"Group 1","tab":"e9bddf8f.8460d","order":1,"disp":true,"width":30,"collapse":false},{"id":"718b1892.fc1ed8","type":"ui_tab","z":"","name":"Pi temp","icon":"dashboard","disabled":false,"hidden":false},{"id":"ba745177.2298c","type":"ui_tab","z":"","name":"Air quality","icon":"dashboard","order":4,"disabled":false,"hidden":false},{"id":"5ebc98d3.642238","type":"ui_tab","z":"","name":"Home","icon":"dashboard","order":2,"disabled":false,"hidden":false},{"id":"21308d89.0e4f52","type":"ui_tab","z":"","name":"Garden","icon":"dashboard","order":3,"disabled":false,"hidden":false},{"id":"e9bddf8f.8460d","type":"ui_tab","z":"","name":"Power usage","icon":"dashboard","order":5,"disabled":false,"hidden":false}]
Created 6 years ago
Rating: 5 1
  • change (x19)
  • function (x25)
  • json (x1)
  • link in (x1)
  • link out (x1)
  • mqtt in (x1)
  • mqtt out (x1)
  • mqtt-broker (x2)
  • switch (x5)
  • ui_button (x9)
  • ui_chart (x10)
  • ui_group (x5)
  • ui_tab (x5)
  • Domoticz
  • MQTT
  • Dashboard
