Wekan to Habitica Todos
NodeRED Wekan to Habitica Todos
A Node-RED flow that integrates a Wekan Kanban Board and Habitica in two ways:
  • Creates Habitica todos when new Wekan cards are created
  • "Scores" (marks complete and issues reward for) Habitica todos in Habitica when their matching cards are moved to a "Completed" column in Wekan.
An image of the Node-RED UI populated with the "NodeRED Wekan to Habitica Todos" flow
To Use:
  1. Install Node-RED & Wekan somewhere
  2. Copy the contents of Node-REDFlowExport.json to your clipboard and import into your Node-RED instance
  3. Complete setup per the instructions in the flow comment:
    • Create a webhook on a board in your Wekan instance. Set the URL to yourNodeREDInstance.com/nodered/POSTcards
    • Get the id of your 'completed' column in Wekan using the inspector. It will look something like this: id="js-list-w3hpri5SCfJoE9CTD". We only need the last part, after js-list-.
    • Enter the list id in the if statement conditional of the Build score task request Formula node.
    • Fill in your credentials in the Habitica Creds node. ID & Client should both be your user ID, and key should be your API key. This information can be found in the API section of your Habitica user settings.
    • Hit "Deploy," test, and enjoy.
Further customization:
  • Task difficulty can be set by changing the value of "priority" in the Build create task request node:
Value Difficulty
0.1 Trivial
1 Easy
1.5 Medium
2 Hard
  • Gold reward for completing the task can be set by adding the property "value" in the Build create task request node and setting to a positive number.
  • Refer to the Habitics API Docs for more info.
[{"id":"3dc2e06f.e9ba8","type":"tab","label":"Wekan => Habitica","disabled":false,"info":""},{"id":"953f8efa.551c18","type":"function","z":"3dc2e06f.e9ba8","name":"Build create task request","func":"const text = msg.payload[\"card\"];\nconst alias = msg.payload[\"cardId\"];\nconst act = msg.payload[\"description\"];\nconst todo = \"todo\"\n\nflow.set(\"sendURL\",`https://habitica.com/api/v3/tasks/user`);\n\nif (act == \"act-createCard\") {\n    msg.payload = {\n        \"text\": text,\n        \"type\": todo,\n        \"alias\": alias,\n        \"priority\": 1.5\n    }\n    return msg\n} else {\n    return console.error(\"Action type incorrect\")\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":340,"wires":[["322920ca.10b14"]]},{"id":"4d198882.5869e8","type":"http request","z":"3dc2e06f.e9ba8","name":"Send request","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":970,"y":320,"wires":[["e9c70b6d.5a0c88"]]},{"id":"59f5c229.32d94c","type":"switch","z":"3dc2e06f.e9ba8","name":"Case: Move / Create","property":"payload[\"description\"]","propertyType":"msg","rules":[{"t":"eq","v":"act-moveCard","vt":"str"},{"t":"neq","v":"act-moveCard","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":360,"y":320,"wires":[["d55fb99.a191548"],["953f8efa.551c18"]]},{"id":"d55fb99.a191548","type":"function","z":"3dc2e06f.e9ba8","name":"Build score task request","func":"const alias = msg.payload[\"cardId\"];\nconst act = msg.payload[\"description\"];\nconst list = msg.payload[\"listId\"];\n\nflow.set(\"sendURL\",`https://habitica.com/api/v3/tasks/${alias}/score/up`);\n\nif (act == \"act-moveCard\" && list == \"w3hpri5SCfJoE9CTD\") {\n    msg.payload = {\"alias\": alias};\n    return msg; \n} else {\n    return console.error(\"Action type or list ID incorrect.\")\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":300,"wires":[["322920ca.10b14"]]},{"id":"e9c70b6d.5a0c88","type":"debug","z":"3dc2e06f.e9ba8","name":"Log response","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1040,"y":360,"wires":[]},{"id":"1645ddfc.cbcfca","type":"http in","z":"3dc2e06f.e9ba8","name":"Receive Wekan POST","url":"/POSTcards","method":"post","upload":false,"swaggerDoc":"","x":140,"y":320,"wires":[["59f5c229.32d94c","cafd75c0.f46778"]]},{"id":"322920ca.10b14","type":"change","z":"3dc2e06f.e9ba8","name":"Set URL","rules":[{"t":"set","p":"url","pt":"msg","to":"sendURL","tot":"flow"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":320,"wires":[["ebec297c.108cb8"]]},{"id":"cafd75c0.f46778","type":"http response","z":"3dc2e06f.e9ba8","name":"POST response","statusCode":"","headers":{},"x":340,"y":360,"wires":[]},{"id":"ebec297c.108cb8","type":"credentials","z":"3dc2e06f.e9ba8","name":"Habitica Creds","props":[{"value":"headers.x-api-user","type":"msg"},{"value":"headers.x-api-key","type":"msg"},{"value":"headers.x-api-client","type":"msg"}],"x":820,"y":360,"wires":[["4d198882.5869e8"]]},{"id":"a3888bbd.072d8","type":"comment","z":"3dc2e06f.e9ba8","name":"README","info":"## About this Flow\n\nThis flow receives an outgoing webhook from your Wekan instance, and calls a POST request to the Habitica API to create or score a to-do. \n\nWhen cards are created in Wekan, a todo by the same name will be created in Habitica. When a card is moved to a list of your choosing, the matching todo will be scored in Habitica. \n\n### To Use:\n\n1. Create a webhook in your Wekan instance. Set the URL to yourNodeREDInstance.com/nodered/POSTcards\n2. Get the id of your 'completed' column in Wekan using the inspector. It will look something like this: `id=\"js-list-w3hpri5SCfJoE9CTD\"`. We only need the last part, after `js-list-`.\n3. Enter the list id in the `if` statement conditional of the `Build score task request` Formula node.\n4. Fill in your credentials in the `Habitica Creds` node. ID & Client should both be your user ID, and key should be your API key. This information can be found in the [API](https://habitica.com/user/settings/api) section of your Habitica user settings.\n5. Hit \"Deploy,\" test, and enjoy/","x":100,"y":260,"wires":[]}]
Created 5 years, 7 months ago
Rating: 5 1
  • change (x1)
  • function (x2)
  • http in (x1)
  • http request (x1)
  • http response (x1)
  • switch (x1)
  • wekan
  • habitica
  • http
  • webhook
  • productivity
