Live Debug
Send msg or msg property to a separate web page. You can set the property to send, delete any message, pause the message stream and copy any message. The webpage url is http://your_node-red_ip:port/debug, e.g. http://192.168.1.50:1880/debug. None of the messages are truncated.
Usage: Place the subflow as you would a debug node, or inline. Set the msg property you want to send, default is msg.
[{"id":"3decb5f518882686","type":"subflow","name":"live debug","info":"<A href=\"http://localhost:1880/debug\">localhost/debug</a>","category":"","in":[{"x":240,"y":160,"wires":[{"id":"45dbf990.ba2408"}]}],"out":[{"x":560,"y":160,"wires":[{"id":"45dbf990.ba2408","port":1}]}],"env":[{"name":"debug_name","type":"str","value":"Debug","ui":{"label":{"en-US":"Name"},"type":"input","opts":{"types":["str"]}}},{"name":"debug_property","type":"str","value":"msg","ui":{"label":{"en-US":"Property Path"},"type":"input","opts":{"types":["str"]}}},{"name":"pass_debug_property","type":"bool","value":"false","ui":{"label":{"en-US":"Pass Property Path"},"type":"input","opts":{"types":["bool"]}}}],"meta":{},"color":"#DDAA99"},{"id":"45dbf990.ba2408","type":"function","z":"3decb5f518882686","name":"format time nicely","func":"let msg1 = {payload: RED.util.cloneMessage(msg)};\nmsg1.payload.debug_property = msg.debug_property || env.get(\"debug_property\") || \"msg\"\ntry {\n  msg1.payload.debug_property_array = RED.util.normalisePropertyExpression(msg1.payload.debug_property)\n}\ncatch(error){\n  msg.payload = error;\n  msg1.payload.error = error;\n}\nmsg1.payload.debug_name = env.get(\"debug_name\") || msg._msgid || \"name error\"\nmsg1.payload.pass_debug_property = env.get(\"pass_debug_property\") || false\nreturn [msg1,msg];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":120,"wires":[["50da04b3.af25fc"],[]]},{"id":"50da04b3.af25fc","type":"websocket out","z":"3decb5f518882686","name":"","server":"985ecbc7.67a138","client":"","x":680,"y":120,"wires":[]},{"id":"1787be40.e87842","type":"http in","z":"3decb5f518882686","name":"","url":"/debug","method":"get","upload":false,"swaggerDoc":"","x":330,"y":40,"wires":[["1857548e.e7a8ab"]]},{"id":"1857548e.e7a8ab","type":"template","z":"3decb5f518882686","name":"Simple Web Page","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<!DOCTYPE HTML>\n<html>\n    <head>\n        <style>\n            span.debug_name {\n                color: black;\n            }\n            span.debug_error{\n                color: red;\n            }\n            span.debug_date{\n                color:blue;\n            }\n            pre[id^='json_data_']{\n                font-size:20px;\n                background-color: ghostwhite;\n                border: 1px solid silver;\n                padding: 10px 20px;\n                margin: 20px; \n                white-space: pre-wrap;\n            }\n            .json-key {\n                color: olive;\n            }\n            .json-value {\n                color: navy;\n            }\n            .json-string {\n                color: brown;\n            }\n\n        </style>\n    <title>Debug Messages</title>\n    <script type=\"text/javascript\">\n        var ws;\n        var wsUri = \"ws:\";\n        var loc = window.location;\n        console.log(loc);\n        if (loc.protocol === \"https:\") { wsUri = \"wss:\"; }\n        // This needs to point to the web socket in the Node-RED flow\n        wsUri += \"//\" + loc.host + loc.pathname.replace(\"debug\",\"ws/debug\");\n\n        function wsConnect() {\n            console.log(\"connect\",wsUri);\n            ws = new WebSocket(wsUri);\n            ws.onmessage = function(msg) {\n                segments = document.getElementById('json_data').innerHTML;\n                var paused = document.getElementById('paused').innerText === \"Pause\";\n                var data;\n                var line = \"\";\n                var error = \"\";\n                var date = new Date().toISOString();\n                // parse the incoming message as a JSON object\n                try { \n                    data = JSON.parse(msg.data);\n                } catch (json_error) {\n                    data = {error: [\"json parse error\", json_error]};\n                };   \n                if(!data.error){\n                    var debug_name = data.debug_name ;\n                    var debug_property = data.debug_property_array;\n                    var original_property = data.debug_property;\n                    if(!data.pass_debug_property) delete data.debug_property;\n                    delete data.pass_debug_property;\n                    delete data.debug_property_array;\n                    delete data.debug_name;\n                    debug_property.slice(1).forEach((prop, index) => {\n                        if(data[prop]) {                    \n                            data = data[prop];\n                        }else{\n                           error = \"Property path Error on or after - \" + debug_property[index];\n                        }\n                    });\n\n                    line = `<div id=\"element${date}\">\n                    <hr/>\n                    <span class=\"debug_name\">${debug_name}</span> <span class=\"debug_date\">${date}</span> \n                    <span class=\"debug_orginal\">${original_property}</span> <span class=\"debug_error\">${error}</span> \n                     <button title=\"copy\" alt=\"copy\" onclick=\"copy_text('json_data_${date}')\"> &#10066; </button>\n                    <button title=\"delete\" alt=\"delete\" onclick=\"delete_text('element${date}')\"> &#10060; </button> \n                    <span class=\"json_data\">\n                    <pre id=\"json_data_${date}\"><code id=data>${library.json.prettyPrint(data)}</code></pre></span> \n                    </div>`;\n                }else{\n                    line = `<div id=\"element${date}\">\n                    <hr/>\n                    <span class=\"debug_error\">Error: ${JSON.stringify(data.error)}</span> <span class=\"debug_date\">${date}</span>                  \n                    <button title=\"delete\" alt=\"delete\" onclick=\"delete_text('element${date}')\"> &#10060; </button> \n                    </div>`;\n                }\n            // append line to segment\n            if(paused){\n                document.getElementById('json_data').innerHTML = line + segments;\n            }\n            }\n            ws.onopen = function() {\n                // update the status div with the connection status\n                document.getElementById('status').innerHTML = \"connected\";\n                //ws.send(\"Open for data\");\n                console.log(\"connected\");\n            }\n            ws.onclose = function() {\n                // update the status div with the connection status\n                document.getElementById('status').innerHTML = \"not connected\";\n                // in case of lost connection tries to reconnect every 3 secs\n                setTimeout(wsConnect,3000);\n            }\n        }\n        function copy_text(input) {\n            // Get the text field\n            var copyText = document.getElementById(input).innerText;\n            var dummy = document.createElement(\"textarea\");\n            document.body.appendChild(dummy);\n            dummy.value = copyText;\n            dummy.select();\n            document.execCommand(\"copy\");\n            document.body.removeChild(dummy);\n            alert(\"Copied  Data to Clipboard\\n\\n\" + copyText)\n        }\n        function delete_text(input) {\n            // Get the text field\n            document.getElementById(input).innerHTML = \"\";\n        }\n        if (!library) var library = {};\n            library.json = {\n                replacer: function(match, pIndent, pKey, pVal, pEnd) {\n                    var key = '<span class=json-key>\"';\n                    var val = '<span class=json-value>';\n                    var str = '<span class=json-string>';\n                    var r = pIndent || '';\n                    if (pKey)\n                        r = r + key + pKey.replace(/[\": ]/g, '') + '\"</span>: ';\n                    if (pVal)\n                        r = r + (pVal[0] == '\"' ? str : val) + pVal + '</span>';\n                        return r + (pEnd || '');\n                    },\n                    prettyPrint: function(obj) {\n                        var jsonLine = /^( *)(\"[\\w]+\": )?(\"[^\"]*\"|[\\w.+-]*)?([,[{])?$/mg;\n                        return JSON.stringify(obj, null, 4)\n                            .replace(/&/g, '&amp;').replace(/\\\\\"/g, '&quot;')\n                            .replace(/</g, '&lt;').replace(/>/g, '&gt;')\n                            .replace(jsonLine, library.json.replacer);\n                    }\n                    \n                };\n        function pause() {\n            var element_paused = document.getElementById(\"paused\");\n            paused = (element_paused.innerText === \"Resume\") ? \"Pause\" : \"Resume\";\n            element_paused.innerText = paused;\n        }\n    \n    </script>\n    </head>\n    <body onload=\"wsConnect();\" onunload=\"ws.disconnect();\">\n        <font face=\"Arial\">\n        <h1>Debug Messages <button id=\"paused\" value=\"pause\" onclick=\"pause()\">Pause</button> </h1>\n        <div id=\"json_data\"></div>\n        <hr/>\n        <div id=\"status\">unknown</div>\n        </font>\n    </body>\n</html>\n","x":550,"y":40,"wires":[["42a28745.bd5d78"]]},{"id":"42a28745.bd5d78","type":"http response","z":"3decb5f518882686","name":"","x":730,"y":40,"wires":[]},{"id":"985ecbc7.67a138","type":"websocket-listener","z":"65617ffeb779f51c","path":"/ws/debug","wholemsg":"false"},{"id":"3f4abb584169f0cc","type":"subflow:3decb5f518882686","z":"b9860b4b9de8c8da","name":"","x":160,"y":1980,"wires":[[]]}]
Created 3 years, 9 months ago
  • http in (x1)
  • http response (x1)
  • template (x1)
  • websocket out (x1)
  • websocket-listener (x1)
  • subflow (x1)
  • subflow:3decb5f518882686 (x1)
  • debug
  • copy
  • msg
  • delete
  • pause
