React Node-RED dashboard
Dashboard UI nodes developed by Material UI. Currently, basic button, chart, switch, text, text input, gauge, slider, and notification nodes are available as the subflow.
Dashboard UI dashboard
Node-RED Flow flow
[{"id":"4102712984e468f8","type":"subflow","name":"chart","info":"[Dashboard page](uikit)","category":"uikit","in":[{"x":100,"y":260,"wires":[{"id":"d4a7d3d12aa45eaa"}]}],"out":[],"env":[{"name":"order","type":"num","value":"4","ui":{"icon":"font-awesome/fa-sort-numeric-asc","type":"spinner","opts":{"min":0,"max":100}}},{"name":"xs","type":"num","value":"12","ui":{"icon":"font-awesome/fa-arrows-h","type":"spinner","opts":{"min":1,"max":12}}},{"name":"label","type":"str","value":"label","ui":{"icon":"font-awesome/fa-i-cursor","type":"input","opts":{"types":["str"]}}}],"meta":{},"color":"#77C6CC","icon":"node-red/status.svg"},{"id":"e1b4f688743401b3","type":"inject","z":"4102712984e468f8","name":"add component","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["b83fcf8e9ef1ce06"]]},{"id":"b83fcf8e9ef1ce06","type":"function","z":"4102712984e468f8","name":"add plot","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nif (global.get('jsx[' + env.get('order') + ']')) {\n  node.warn(\"order conflicted\");\n}\n\nglobal.set('jsx[' + env.get('order') + ']',\n           '<Grid item xs={' + env.get('xs') + '}>'\n           + '<Plot data={plotData[\"' + subflowId + '\"]} config={{staticPlot:true}} layout={{width:\"100%\", height:\"400\", title:\"' + env.get('label') + '\"}} />'\n         + '</Grid>');\n\nreturn msg;","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":120,"wires":[]},{"id":"a4d107362460662d","type":"subflow:54c1e80336f93e12","z":"4102712984e468f8","name":"","x":560,"y":120,"wires":[]},{"id":"1cfc7f21b191796c","type":"comment","z":"4102712984e468f8","name":"Add the UI component to `jsx` in the global context","info":"","x":270,"y":60,"wires":[]},{"id":"95b2c2cdcef1db94","type":"comment","z":"4102712984e468f8","name":"Endpoint for the dashboard","info":"","x":620,"y":60,"wires":[]},{"id":"f329388374f1498c","type":"comment","z":"4102712984e468f8","name":"UI specific handling","info":"","x":170,"y":200,"wires":[]},{"id":"d4a7d3d12aa45eaa","type":"switch","z":"4102712984e468f8","name":"clear?","property":"$count(payload)","propertyType":"jsonata","rules":[{"t":"neq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":210,"y":260,"wires":[["68bab89d34a6f1f4"],["10f6c1dff074dbf2"]]},{"id":"68bab89d34a6f1f4","type":"function","z":"4102712984e468f8","name":"Store data to context","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nvar dataX = global.get('plotData[\"' + subflowId + '\"][0].x') || [];\ndataX.push(new Date().toISOString());\nglobal.set('plotData[\"' + subflowId + '\"][0].x', dataX);\n\nvar dataY = global.get('plotData[\"' + subflowId + '\"][0].y') || [];\ndataY.push(msg.payload);\nglobal.set('plotData[\"' + subflowId + '\"][0].y', dataY);\n\nmsg.payload = global.get('plotData');\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":240,"wires":[["2fcb9b1fd3aee802"]]},{"id":"2fcb9b1fd3aee802","type":"change","z":"4102712984e468f8","name":"Read all context data","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"type\": \"chart\",\t   \"payload\": payload \t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":260,"wires":[["930e2fa9991a78c6"]]},{"id":"10f6c1dff074dbf2","type":"function","z":"4102712984e468f8","name":"Clear context data","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\nglobal.set('plotData[\"' + subflowId + '\"]', undefined);\nmsg.payload = global.get('plotData');\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":280,"wires":[["2fcb9b1fd3aee802"]]},{"id":"930e2fa9991a78c6","type":"websocket out","z":"4102712984e468f8","name":"","server":"caaba1e23b7b4c41","client":"","x":860,"y":260,"wires":[]},{"id":"8994b5c4dba46c76","type":"subflow","name":"gauge","info":"[Dashboard page](uikit)","category":"uikit","in":[{"x":100,"y":260,"wires":[{"id":"f646c546f7c55ca5"}]}],"out":[],"env":[{"name":"order","type":"num","value":"4","ui":{"icon":"font-awesome/fa-sort-numeric-asc","type":"spinner","opts":{"min":0,"max":100}}},{"name":"xs","type":"num","value":"12","ui":{"icon":"font-awesome/fa-arrows-h","type":"spinner","opts":{"min":1,"max":12}}}],"meta":{},"color":"#77C6CC","icon":"node-red/timer.svg"},{"id":"3ca0e773e47d324b","type":"inject","z":"8994b5c4dba46c76","name":"add component","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["0a65bc7dc4acd568"]]},{"id":"0a65bc7dc4acd568","type":"function","z":"8994b5c4dba46c76","name":"add CircularProgress","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nif (global.get('jsx[' + env.get('order') + ']')) {\n  node.warn(\"order conflicted\");\n}\n\nglobal.set('jsx[' + env.get('order') + ']',\n           '<Grid item xs={' + env.get('xs') + '}>'\n         + '<Box sx={{position:\"relative\",display:\"inline-flex\"}}>'\n         + '<CircularProgress variant=\"determinate\" color=\"success\" size=\"180px\" value={Number(data[\"' + subflowId + '\"]) || 0} />'\n         + '<Box sx={{top:0,left:0,bottom:0,right:0,position:\"absolute\",display:\"flex\",alignItems:\"center\",justifyContent:\"center\"}}>'\n         + '<Typography variant=\"h4\">{Number(data[\"' + subflowId + '\"]) || 0} %</Typography>'\n         + '</Box>'\n\n         + '<Box sx={{top:0,left:0,bottom:0,right:0,position:\"absolute\",display:\"flex\",alignItems:\"center\",justifyContent:\"center\"}}>'\n         + '<CircularProgress variant=\"determinate\" color=\"success\" size=\"152px\" value={Number(data[\"' + subflowId + '\"]) || 0} />'\n         + '</Box>'\n\n\n         + '</Box>'\n         + '</Grid>');\n\nreturn msg;","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":120,"wires":[]},{"id":"5a1a7d27ba921bef","type":"subflow:54c1e80336f93e12","z":"8994b5c4dba46c76","name":"","x":580,"y":120,"wires":[]},{"id":"bfc9cacebeea3633","type":"comment","z":"8994b5c4dba46c76","name":"Add the UI component to `jsx` in the global context","info":"","x":270,"y":60,"wires":[]},{"id":"5335b15cf04a7487","type":"comment","z":"8994b5c4dba46c76","name":"Endpoint for the dashboard","info":"","x":640,"y":60,"wires":[]},{"id":"b877cb90d35957e3","type":"websocket out","z":"8994b5c4dba46c76","name":"","server":"caaba1e23b7b4c41","client":"","x":420,"y":260,"wires":[]},{"id":"7066c1bb463eb04e","type":"comment","z":"8994b5c4dba46c76","name":"UI specific handling","info":"","x":170,"y":200,"wires":[]},{"id":"f646c546f7c55ca5","type":"change","z":"8994b5c4dba46c76","name":"create data","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   $reverse($env('NR_NODE_PATH').$split('/'))[1]: $string(payload) \t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":260,"wires":[["b877cb90d35957e3"]]},{"id":"9c0a52e2454bab6f","type":"subflow","name":"slider","info":"[Dashboard page](uikit)","category":"uikit","in":[],"out":[{"x":840,"y":260,"wires":[{"id":"059c4bfd1f783c27","port":0}]}],"env":[{"name":"order","type":"num","value":"6","ui":{"icon":"font-awesome/fa-sort-numeric-asc","type":"spinner","opts":{"min":0,"max":100}}},{"name":"xs","type":"num","value":"4","ui":{"icon":"font-awesome/fa-arrows-h","type":"spinner","opts":{"min":1,"max":12}}},{"name":"label","type":"str","value":"label","ui":{"icon":"font-awesome/fa-i-cursor","type":"input","opts":{"types":["str"]}}}],"meta":{},"color":"#B0DFE3","icon":"font-awesome/fa-sliders"},{"id":"385b7d35500651b6","type":"inject","z":"9c0a52e2454bab6f","name":"add component","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["a2c449c8cfa5c38c"]]},{"id":"a2c449c8cfa5c38c","type":"function","z":"9c0a52e2454bab6f","name":"add Slider","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nif (global.get('jsx[' + env.get('order') + ']')) {\n    node.warn(\"order conflicted\");\n}\n\nglobal.set('jsx[' + env.get('order') + ']',\n           '<Grid item xs={' + env.get('xs') + '}>'\n         + '<Typography>' + env.get('label') + '</Typography>'\n         + '<Slider onChange={(e,v) => ws.send(JSON.stringify({\"id\":\"' + subflowId + '\",\"payload\":v}))} />'\n         + '</Grid>');\n\nreturn msg;","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":120,"wires":[]},{"id":"0631f1904d640c1e","type":"subflow:54c1e80336f93e12","z":"9c0a52e2454bab6f","name":"","x":560,"y":120,"wires":[]},{"id":"190d3807f2b4cf7b","type":"comment","z":"9c0a52e2454bab6f","name":"Add the UI component to `jsx` in the global context","info":"","x":270,"y":60,"wires":[]},{"id":"726db7b798868a73","type":"comment","z":"9c0a52e2454bab6f","name":"Endpoint for the dashboard","info":"","x":620,"y":60,"wires":[]},{"id":"11df2cac00d5b704","type":"websocket in","z":"9c0a52e2454bab6f","name":"","server":"caaba1e23b7b4c41","client":"","x":150,"y":260,"wires":[["b007e747dc67988c"]]},{"id":"059c4bfd1f783c27","type":"change","z":"9c0a52e2454bab6f","name":"Set timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":260,"wires":[[]]},{"id":"015d616a4e3bf693","type":"comment","z":"9c0a52e2454bab6f","name":"UI specific handling","info":"","x":170,"y":200,"wires":[]},{"id":"f29f0c1b62c53d1c","type":"switch","z":"9c0a52e2454bab6f","name":"check subflow id","property":"payload.id","propertyType":"msg","rules":[{"t":"eq","v":"$reverse($env('NR_NODE_PATH').$split('/'))[1]","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":260,"wires":[["059c4bfd1f783c27"]]},{"id":"b007e747dc67988c","type":"json","z":"9c0a52e2454bab6f","name":"","property":"payload","action":"obj","pretty":false,"x":310,"y":260,"wires":[["f29f0c1b62c53d1c"]]},{"id":"c9fb680bbb1d67cc","type":"subflow","name":"switch","info":"[Dashboard page](uikit)","category":"uikit","in":[],"out":[{"x":840,"y":260,"wires":[{"id":"0e58721bf2c05cd1","port":0}]}],"env":[{"name":"order","type":"num","value":"6","ui":{"icon":"font-awesome/fa-sort-numeric-asc","type":"spinner","opts":{"min":0,"max":100}}},{"name":"xs","type":"num","value":"12","ui":{"icon":"font-awesome/fa-arrows-h","type":"spinner","opts":{"min":1,"max":12}}}],"meta":{},"color":"#B0DFE3","icon":"font-awesome/fa-toggle-on"},{"id":"358a4130527d37ff","type":"inject","z":"c9fb680bbb1d67cc","name":"add component","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["840c9e20f5b9f71e"]]},{"id":"840c9e20f5b9f71e","type":"function","z":"c9fb680bbb1d67cc","name":"add Switch","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nif (global.get('jsx[' + env.get('order') + ']')) {\n  node.warn(\"order conflicted\");\n}\n\nglobal.set('jsx[' + env.get('order') + ']',\n           '<Grid item xs={' + env.get('xs') + '}>'\n         + '<Switch onChange={(e) => ws.send(JSON.stringify({\"id\":\"' + subflowId + '\",\"payload\":e.target.checked}))} />'\n         + '</Grid>');\n\nreturn msg;","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":120,"wires":[]},{"id":"2e735c4a9c5e9433","type":"subflow:54c1e80336f93e12","z":"c9fb680bbb1d67cc","name":"","x":560,"y":120,"wires":[]},{"id":"135e261514f1ad24","type":"comment","z":"c9fb680bbb1d67cc","name":"Add the UI component to `jsx` in the global context","info":"","x":270,"y":60,"wires":[]},{"id":"45e79486a584ce56","type":"comment","z":"c9fb680bbb1d67cc","name":"Endpoint for the dashboard","info":"","x":620,"y":60,"wires":[]},{"id":"52fc2e94c2d9bbfe","type":"websocket in","z":"c9fb680bbb1d67cc","name":"","server":"caaba1e23b7b4c41","client":"","x":150,"y":260,"wires":[["7892a151c2fa4416"]]},{"id":"0e58721bf2c05cd1","type":"change","z":"c9fb680bbb1d67cc","name":"Set timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":260,"wires":[[]]},{"id":"de01d4701d291bc5","type":"comment","z":"c9fb680bbb1d67cc","name":"UI specific handling","info":"","x":170,"y":200,"wires":[]},{"id":"8e9eb63f483fa076","type":"switch","z":"c9fb680bbb1d67cc","name":"check subflow id","property":"payload.id","propertyType":"msg","rules":[{"t":"eq","v":"$reverse($env('NR_NODE_PATH').$split('/'))[1]","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":260,"wires":[["0e58721bf2c05cd1"]]},{"id":"7892a151c2fa4416","type":"json","z":"c9fb680bbb1d67cc","name":"","property":"payload","action":"obj","pretty":false,"x":310,"y":260,"wires":[["8e9eb63f483fa076"]]},{"id":"1bd86210b503b896","type":"subflow","name":"notification","info":"[Dashboard page](uikit)","category":"uikit","in":[{"x":100,"y":260,"wires":[{"id":"45ab401d043df784"}]}],"out":[],"env":[{"name":"order","type":"num","value":"99","ui":{"icon":"font-awesome/fa-sort-numeric-asc","type":"spinner","opts":{"min":0,"max":100}}}],"meta":{},"color":"#77C6CC","icon":"node-red/envelope.svg"},{"id":"c671c12db131dc9e","type":"inject","z":"1bd86210b503b896","name":"add component","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["bbe11882af4c1919"]]},{"id":"bbe11882af4c1919","type":"function","z":"1bd86210b503b896","name":"add Snackbar","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nif (global.get('jsx[' + env.get('order') + ']')) {\n    node.warn(\"order conflicted\");\n}\n\nglobal.set('jsx[' + env.get('order') + ']',\n           '<Snackbar message={data[\"' + subflowId + '\"]} open={data[\"' + subflowId + '\"]!==undefined} autoHideDuration={3000} onClose={function () { var tmp = {...data}; delete tmp[\"' + subflowId + '\"]; setData(tmp); }} />');\n\nreturn msg;","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":360,"y":120,"wires":[]},{"id":"8db9db7ed8d34a32","type":"subflow:54c1e80336f93e12","z":"1bd86210b503b896","name":"","x":560,"y":120,"wires":[]},{"id":"2eb6a23ac95610aa","type":"comment","z":"1bd86210b503b896","name":"Add the UI component to `jsx` in the global context","info":"","x":270,"y":60,"wires":[]},{"id":"d2ef4f394ab68802","type":"comment","z":"1bd86210b503b896","name":"Endpoint for the dashboard","info":"","x":620,"y":60,"wires":[]},{"id":"8f7137cf51e096bd","type":"websocket out","z":"1bd86210b503b896","name":"","server":"caaba1e23b7b4c41","client":"","x":420,"y":260,"wires":[]},{"id":"568134e56a4b9c50","type":"comment","z":"1bd86210b503b896","name":"UI specific handling","info":"","x":170,"y":200,"wires":[]},{"id":"45ab401d043df784","type":"change","z":"1bd86210b503b896","name":"create data","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   $reverse($env('NR_NODE_PATH').$split('/'))[1]: $string(payload) \t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":260,"wires":[["8f7137cf51e096bd"]]},{"id":"eceae5246a022264","type":"subflow","name":"text input","info":"[Dashboard page](uikit)","category":"uikit","in":[],"out":[{"x":840,"y":260,"wires":[{"id":"56af47fb510e7ad0","port":0}]}],"env":[{"name":"order","type":"num","value":"6","ui":{"icon":"font-awesome/fa-sort-numeric-asc","type":"spinner","opts":{"min":0,"max":100}}},{"name":"xs","type":"num","value":"4","ui":{"icon":"font-awesome/fa-arrows-h","type":"spinner","opts":{"min":1,"max":12}}},{"name":"label","type":"str","value":"label","ui":{"icon":"font-awesome/fa-i-cursor","type":"input","opts":{"types":["str"]}}}],"meta":{},"color":"#B0DFE3","icon":"font-awesome/fa-text-width"},{"id":"f0a3065f48935431","type":"inject","z":"eceae5246a022264","name":"add component","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["82bcdf899a6a7165"]]},{"id":"82bcdf899a6a7165","type":"function","z":"eceae5246a022264","name":"add TextField","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nif (global.get('jsx[' + env.get('order') + ']')) {\n  node.warn(\"order conflicted\");\n}\n\nglobal.set('jsx[' + env.get('order') + ']',\n           '<Grid item xs={' + env.get('xs') + '}>'\n         + '<TextField fullWidth label=\"' + env.get('label') + '\" variant=\"standard\" onChange={(e) => ws.send(JSON.stringify({\"id\":\"' + subflowId + '\",\"payload\":e.target.value}))} />'\n         + '</Grid>');\n\nreturn msg;","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":360,"y":120,"wires":[]},{"id":"ae8721aba548d910","type":"subflow:54c1e80336f93e12","z":"eceae5246a022264","name":"","x":560,"y":120,"wires":[]},{"id":"1ca26faaaa27afd0","type":"comment","z":"eceae5246a022264","name":"Add the UI component to `jsx` in the global context","info":"","x":270,"y":60,"wires":[]},{"id":"920b0187184deda2","type":"comment","z":"eceae5246a022264","name":"Endpoint for the dashboard","info":"","x":620,"y":60,"wires":[]},{"id":"d6f6c31cbe3a0485","type":"websocket in","z":"eceae5246a022264","name":"","server":"caaba1e23b7b4c41","client":"","x":150,"y":260,"wires":[["f64b5c4fc72ff9b9"]]},{"id":"56af47fb510e7ad0","type":"change","z":"eceae5246a022264","name":"Set timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":260,"wires":[[]]},{"id":"dc7f44e04a7451a8","type":"comment","z":"eceae5246a022264","name":"UI specific handling","info":"","x":170,"y":200,"wires":[]},{"id":"5556b55a273722df","type":"switch","z":"eceae5246a022264","name":"check subflow id","property":"payload.id","propertyType":"msg","rules":[{"t":"eq","v":"$reverse($env('NR_NODE_PATH').$split('/'))[1]","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":260,"wires":[["56af47fb510e7ad0"]]},{"id":"f64b5c4fc72ff9b9","type":"json","z":"eceae5246a022264","name":"","property":"payload","action":"obj","pretty":false,"x":310,"y":260,"wires":[["5556b55a273722df"]]},{"id":"aec0d9b3a72479a3","type":"subflow","name":"text","info":"[Dashboard page](uikit)","category":"uikit","in":[{"x":100,"y":260,"wires":[{"id":"5e64d43f85e220d5"}]}],"out":[],"env":[{"name":"order","type":"num","value":"4","ui":{"icon":"font-awesome/fa-sort-numeric-asc","type":"spinner","opts":{"min":0,"max":100}}},{"name":"xs","type":"num","value":"12","ui":{"icon":"font-awesome/fa-arrows-h","type":"spinner","opts":{"min":1,"max":12}}},{"name":"label","type":"str","value":"label","ui":{"icon":"font-awesome/fa-i-cursor","type":"input","opts":{"types":["str"]}}}],"meta":{},"color":"#77C6CC","icon":"font-awesome/fa-text-width"},{"id":"8f3ee5dbe2a9ff34","type":"inject","z":"aec0d9b3a72479a3","name":"add component","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["17953ff2f5fa284c"]]},{"id":"17953ff2f5fa284c","type":"function","z":"aec0d9b3a72479a3","name":"add plot","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nglobal.set('init[' + env.get('order') + ']',\n           'setTimeout(function () { setData({...data, ...{\"' + subflowId + '\":\"' + env.get('label') + '\"}})}, Math.random()*100);');\n\nif (global.get('jsx[' + env.get('order') + ']')) {\n  node.warn(\"order conflicted\");\n}\n\nglobal.set('jsx[' + env.get('order') + ']',\n           '<Grid item xs={' + env.get('xs') + '}>'\n         + '<Typography display=\"flex\" alignItems=\"center\" minHeight=\"0.8\">{data[\"' + subflowId + '\"]}</Typography>'\n         + '</Grid>');\n\nreturn msg;","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":120,"wires":[]},{"id":"75f084451f29062c","type":"subflow:54c1e80336f93e12","z":"aec0d9b3a72479a3","name":"","x":560,"y":120,"wires":[]},{"id":"69ed19aefd522b59","type":"comment","z":"aec0d9b3a72479a3","name":"Add the UI component to `jsx` in the global context","info":"","x":270,"y":60,"wires":[]},{"id":"f82d05f49f9f0670","type":"comment","z":"aec0d9b3a72479a3","name":"Endpoint for the dashboard","info":"","x":620,"y":60,"wires":[]},{"id":"37310f234624a1fe","type":"websocket out","z":"aec0d9b3a72479a3","name":"","server":"caaba1e23b7b4c41","client":"","x":420,"y":260,"wires":[]},{"id":"496ec17de92941f8","type":"comment","z":"aec0d9b3a72479a3","name":"UI specific handling","info":"","x":170,"y":200,"wires":[]},{"id":"5e64d43f85e220d5","type":"change","z":"aec0d9b3a72479a3","name":"create data","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   $reverse($env('NR_NODE_PATH').$split('/'))[1]: $string(payload) \t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":260,"wires":[["37310f234624a1fe"]]},{"id":"54c1e80336f93e12","type":"subflow","name":"endpoint","info":"","category":"deprecated","in":[],"out":[],"env":[],"meta":{},"color":"#DDAA99"},{"id":"bf132f77860c7bfc","type":"http in","z":"54c1e80336f93e12","name":"","url":"/uikit","method":"get","upload":false,"swaggerDoc":"","x":140,"y":260,"wires":[["ee2530bd1bea6bd6"]]},{"id":"3fc876517efca407","type":"http response","z":"54c1e80336f93e12","name":"","statusCode":"","headers":{},"x":610,"y":260,"wires":[]},{"id":"d77fb6198dd418e2","type":"template","z":"54c1e80336f93e12","name":"HTML","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<html>\n<head>\n  <title>{{{env.NR_FLOW_NAME}}}</title>\n  <script src=\"https://unpkg.com/react/umd/react.development.js\"></script>\n  <script src=\"https://unpkg.com/react-dom/umd/react-dom.development.js\"></script>\n  <script src=\"https://unpkg.com/@mui/material/umd/material-ui.development.js\"></script>\n  <script src=\"https://unpkg.com/babel-standalone/babel.min.js\"></script>\n  <script src=\"https://unpkg.com/plotly.js-dist/plotly.js\"></script>\n  <script src=\"https://unpkg.com/react-plotly.js/dist/create-plotly-component.min.js\"></script>\n  <link rel=\"stylesheet\" href=\"https://fonts.googleapis.com/icon?family=Material+Icons\">\n  <script type=\"text/babel\">\n    var data, setData;\n    var plotData, setPlotData;\n    var ws = new WebSocket('ws' + (location.protocol === 'https:' ? 's' : '') + '://' + location.host + '/ws4uikit');\n    ws.onmessage = function (e) {\n      var json = JSON.parse(e.data);\n      if (json.type === 'chart') {\n        setPlotData(json.payload);\n      } else {\n        setData({...data, ...json});\n      }\n      console.log(json);\n    };\n    ws.onclose = function (e) {\n      setTimeout(function () { window.location.reload(); }, 300);\n    };\n    function App() {\n      [data, setData] = React.useState({});\n      [plotData, setPlotData] = React.useState([]);\n      var { Button, Switch, Typography, TextField, CircularProgress, Slider, Snackbar, Grid, Box, AppBar, Toolbar } = MaterialUI;\n      var Plot = createPlotlyComponent.default(Plotly);\n      return (<div>{{{payload}}}</div>);\n    };\n    var root = ReactDOM.createRoot(document.getElementById('root'));\n    root.render(<App />);\n    setTimeout(function () { {{{init}}} }, 100);\n  </script>\n</head>\n<body><div id=\"root\" /></body>\n</html>","output":"str","x":470,"y":260,"wires":[["3fc876517efca407"]]},{"id":"ee2530bd1bea6bd6","type":"function","z":"54c1e80336f93e12","name":"create jsx","func":"var init = '';\nif (global.get('init')) {\n    for (var i = 0; i < global.get('init').length; i++) {\n        var tmp = global.get('init[' + i + ']');\n        if (tmp) {\n            init += tmp;\n        }\n    }\n}\nmsg.init = init;\n\nvar jsx = '';\nif (global.get('jsx')) {\n    for (var i = 0; i < global.get('jsx').length; i++) {\n        var tmp = global.get('jsx[' + i + ']');\n        if (tmp) {\n            jsx += tmp;\n        }\n    }\n}\nmsg.payload = '<Grid container spacing={1}><AppBar position=\"static\"><Toolbar><Typography>'\n            + env.get('NR_FLOW_NAME').replace(/</g, '&lt;').replace(/>/g, '&gt;')\n            + '</Typography></Toolbar></AppBar>' + jsx + '</Grid>';\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":260,"wires":[["d77fb6198dd418e2"]]},{"id":"d256fb23a6046d16","type":"inject","z":"54c1e80336f93e12","name":"clear context","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.1","topic":"","payload":"","payloadType":"date","x":150,"y":120,"wires":[["f1b250323f03ff6f"]]},{"id":"f1b250323f03ff6f","type":"change","z":"54c1e80336f93e12","name":"","rules":[{"t":"delete","p":"init","pt":"global"},{"t":"delete","p":"jsx","pt":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":120,"wires":[[]]},{"id":"415ffaca442298e7","type":"comment","z":"54c1e80336f93e12","name":"Clear global context after deploying flow immediately","info":"","x":280,"y":60,"wires":[]},{"id":"86619e9c23d0d00c","type":"comment","z":"54c1e80336f93e12","name":"Generate HTML with JSX generated from `jsx` in global context","info":"","x":310,"y":200,"wires":[]},{"id":"a2656ed66f101c58","type":"http in","z":"54c1e80336f93e12","name":"","url":"/export","method":"get","upload":false,"swaggerDoc":"","x":150,"y":320,"wires":[["4e7ca24d2928f980"]]},{"id":"b02775cb637a114d","type":"template","z":"54c1e80336f93e12","name":"index.js","field":"indexJs","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"import React from 'react';\nimport ReactDOM from 'react-dom/client';\nimport { Button, Switch, Typography, TextField, CircularProgress, Slider, Snackbar, Grid, Box, AppBar, Toolbar } from '@mui/material';\nimport Plot from 'react-plotly.js';\n\nfunction App() {\n    var data, setData;\n    var plotData, setPlotData;\n    [data, setData] = React.useState({});\n    [plotData, setPlotData] = React.useState([]);\n    var ws = new WebSocket('ws://localhost:1880/ws4uikit');\n    ws.onmessage = function (e) {\n        var json = JSON.parse(e.data);\n        if (json.type === 'chart') {\n            setPlotData(json.payload);\n        } else {\n            setData({...data, ...json});\n        }\n    };\n    ws.onclose = function (e) {\n        setTimeout(function () { window.location.reload(); }, 300);\n    };\n    return (<div>{{{payload}}}</div>);\n    setTimeout(function () { {{{init}}} }, 100);\n}\n\nconst root = ReactDOM.createRoot(document.getElementById('root'));\nroot.render(<React.StrictMode><App /></React.StrictMode>);","output":"str","x":480,"y":320,"wires":[["d432e22b7bf6d605"]]},{"id":"b871b4ef2140202f","type":"function","z":"54c1e80336f93e12","name":"generate zip","func":"var zip = new JSZip();\nzip.file(\"dashboard-app/src/index.js\", msg.indexJs);\nzip.file(\"dashboard-app/public/index.html\", msg.indexHtml);\nzip.file(\"dashboard-app/package.json\", msg.packageJson);\nzip.generateAsync({ type: \"nodebuffer\" }).then(function (content) {\n    msg.payload = content;\n    node.send(msg);\n});","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"JSZip","module":"jszip"}],"x":530,"y":380,"wires":[["258fc2ba5a704c14"]]},{"id":"258fc2ba5a704c14","type":"http response","z":"54c1e80336f93e12","name":"","statusCode":"","headers":{"Content-Type":"application/zip","Content-Disposition":"attachment"},"x":690,"y":380,"wires":[]},{"id":"a539cd72fa502b41","type":"template","z":"54c1e80336f93e12","name":"package.json","field":"packageJson","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n  \"name\": \"dashboard-app\",\n  \"version\": \"0.0.1\",\n  \"dependencies\": {\n    \"@emotion/styled\": \"11.10.4\",\n    \"@mui/material\": \"5.10.10\",\n    \"plotly.js\": \"2.16.1\",\n    \"react\": \"18.2.0\",\n    \"react-dom\": \"18.2.0\",\n    \"react-plotly.js\": \"2.6.0\",\n    \"react-scripts\": \"5.0.1\"\n  },\n  \"scripts\": {\n    \"start\": \"react-scripts start\",\n    \"build\": \"react-scripts build\"\n  },\n  \"browserslist\": {\n    \"production\": [\n      \">0.2%\",\n      \"not dead\",\n      \"not op_mini all\"\n    ],\n    \"development\": [\n      \"last 1 chrome version\",\n      \"last 1 firefox version\",\n      \"last 1 safari version\"\n    ]\n  }\n}","output":"str","x":340,"y":380,"wires":[["b871b4ef2140202f"]]},{"id":"d432e22b7bf6d605","type":"template","z":"54c1e80336f93e12","name":"index.html","field":"indexHtml","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<html><body><div id=\"root\"></div></body></html>","output":"str","x":150,"y":380,"wires":[["a539cd72fa502b41"]]},{"id":"4e7ca24d2928f980","type":"function","z":"54c1e80336f93e12","name":"create jsx","func":"var init = '';\nif (global.get('init')) {\n    for (var i = 0; i < global.get('init').length; i++) {\n        var tmp = global.get('init[' + i + ']');\n        if (tmp) {\n            init += tmp;\n        }\n    }\n}\nmsg.init = init;\n\nvar jsx = '';\nif (global.get('jsx')) {\n    for (var i = 0; i < global.get('jsx').length; i++) {\n        var tmp = global.get('jsx[' + i + ']');\n        if (tmp) {\n            jsx += tmp;\n        }\n    }\n}\nmsg.payload = '<Grid container spacing={1}><AppBar position=\"static\"><Toolbar><Typography>'\n    + env.get('NR_FLOW_NAME').replace(/</g, '&lt;').replace(/>/g, '&gt;')\n    + '</Typography></Toolbar></AppBar>' + jsx + '</Grid>';\n\nmsg.payload = jsBeautify.html(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"jsBeautify","module":"js-beautify"}],"x":320,"y":320,"wires":[["b02775cb637a114d"]]},{"id":"f8178bddf53d614e","type":"subflow","name":"button","info":"[Dashboard page](uikit)","category":"uikit","in":[],"out":[{"x":840,"y":260,"wires":[{"id":"f14fd69dd2a8089e","port":0}]}],"env":[{"name":"order","type":"num","value":"2","ui":{"icon":"font-awesome/fa-sort-numeric-asc","type":"spinner","opts":{"min":0,"max":100}}},{"name":"xs","type":"num","value":"12","ui":{"icon":"font-awesome/fa-arrows-h","type":"spinner","opts":{"min":1,"max":12}}},{"name":"label","type":"str","value":"button","ui":{"icon":"font-awesome/fa-i-cursor","type":"input","opts":{"types":["str"]}}}],"meta":{},"color":"#B0DFE3","icon":"font-awesome/fa-hand-o-up"},{"id":"f404448243cedfbd","type":"inject","z":"f8178bddf53d614e","name":"add component","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["3213262b32656a24"]]},{"id":"3213262b32656a24","type":"function","z":"f8178bddf53d614e","name":"add button","func":"var subflowId = env.get('NR_NODE_PATH').split('/').reverse()[1];\n\nif (global.get('jsx[' + env.get('order') + ']')) {\n    node.warn(\"order conflicted\");\n}\n\nglobal.set('jsx[' + env.get('order') + ']',\n           '<Grid item xs={' + env.get('xs') + '}>'\n         + '<Button onClick={(e) => ws.send(JSON.stringify({\"id\":\"' + subflowId + '\"}))} variant=\"contained\">'\n         + env.get('label') + '</Button>'\n         + '</Grid>');\n\nreturn msg;","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":120,"wires":[]},{"id":"3d871d2d35c179f3","type":"subflow:54c1e80336f93e12","z":"f8178bddf53d614e","name":"","x":560,"y":120,"wires":[]},{"id":"77aceb3d16160020","type":"comment","z":"f8178bddf53d614e","name":"Add the UI component to `jsx` in the global context","info":"","x":270,"y":60,"wires":[]},{"id":"373adb8feecec29c","type":"comment","z":"f8178bddf53d614e","name":"Endpoint for the dashboard","info":"","x":620,"y":60,"wires":[]},{"id":"725a49427164fe74","type":"websocket in","z":"f8178bddf53d614e","name":"","server":"caaba1e23b7b4c41","client":"","x":150,"y":260,"wires":[["c4bc5bdb273139d1"]]},{"id":"f14fd69dd2a8089e","type":"change","z":"f8178bddf53d614e","name":"Set timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":260,"wires":[[]]},{"id":"d927a7a65390015f","type":"comment","z":"f8178bddf53d614e","name":"UI specific handling","info":"","x":170,"y":200,"wires":[]},{"id":"a0c9983555158280","type":"switch","z":"f8178bddf53d614e","name":"check subflow id","property":"payload.id","propertyType":"msg","rules":[{"t":"eq","v":"$reverse($env('NR_NODE_PATH').$split('/'))[1]","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":260,"wires":[["f14fd69dd2a8089e"]]},{"id":"c4bc5bdb273139d1","type":"json","z":"f8178bddf53d614e","name":"","property":"payload","action":"obj","pretty":false,"x":310,"y":260,"wires":[["a0c9983555158280"]]},{"id":"caaba1e23b7b4c41","type":"websocket-listener","path":"/ws4uikit","wholemsg":"false"},{"id":"3dfeef8155126dc8","type":"subflow:f8178bddf53d614e","z":"02d02da715c60b44","name":"","env":[{"name":"order","value":"20","type":"num"},{"name":"xs","value":"2","type":"num"},{"name":"label","value":"apply","type":"str"}],"x":210,"y":460,"wires":[["20743d8a3cc5ebf8"]]},{"id":"4484b6de34d4dd97","type":"comment","z":"02d02da715c60b44","name":"Dashboard UI: http://localhost:1880/uikit","info":"","x":320,"y":100,"wires":[]},{"id":"832bd8ab0bda88dc","type":"subflow:aec0d9b3a72479a3","z":"02d02da715c60b44","name":"","env":[{"name":"order","value":"9","type":"num"},{"name":"xs","value":"1","type":"num"},{"name":"label","value":"alert","type":"str"}],"x":550,"y":340,"wires":[]},{"id":"a3253d399cacc370","type":"subflow:eceae5246a022264","z":"02d02da715c60b44","name":"","env":[{"name":"order","value":"19","type":"num"},{"name":"xs","value":"2","type":"num"},{"name":"label","value":"alert message","type":"str"}],"x":220,"y":400,"wires":[["2b96d9d64e154f82"]]},{"id":"89e0ea68b669ee5f","type":"subflow:1bd86210b503b896","z":"02d02da715c60b44","name":"","x":610,"y":460,"wires":[]},{"id":"2b96d9d64e154f82","type":"change","z":"02d02da715c60b44","name":"","rules":[{"t":"set","p":"textInput","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":400,"wires":[[]]},{"id":"20743d8a3cc5ebf8","type":"change","z":"02d02da715c60b44","name":"","rules":[{"t":"set","p":"errorMessage","pt":"flow","to":"textInput","tot":"flow"},{"t":"set","p":"payload","pt":"msg","to":"'\"' & $flowContext('textInput') & '\" is applied.'","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":460,"wires":[["89e0ea68b669ee5f"]]},{"id":"e249937c95fd7e93","type":"subflow:c9fb680bbb1d67cc","z":"02d02da715c60b44","name":"","env":[{"name":"order","value":"10","type":"num"},{"name":"xs","value":"1","type":"num"}],"x":210,"y":340,"wires":[["31db4b325d6bb143"]]},{"id":"e50fc03bbbd10684","type":"subflow:9c0a52e2454bab6f","z":"02d02da715c60b44","name":"","env":[{"name":"order","value":"1","type":"num"},{"name":"label","value":"value","type":"str"}],"x":210,"y":160,"wires":[["4ef7b97f68c4fe6d","ab802bfd236aba7c","e231797a03125ed3"]]},{"id":"4ef7b97f68c4fe6d","type":"switch","z":"02d02da715c60b44","name":"> 90","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"90","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":250,"y":280,"wires":[["3cf7a70ec42e0b3f"]]},{"id":"50e3f611f5c4262c","type":"change","z":"02d02da715c60b44","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"errorMessage","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":280,"wires":[["89e0ea68b669ee5f"]]},{"id":"ab802bfd236aba7c","type":"subflow:8994b5c4dba46c76","z":"02d02da715c60b44","name":"","env":[{"name":"order","value":"2","type":"num"},{"name":"xs","value":"4","type":"num"},{"name":"label","value":"test","type":"str"}],"x":390,"y":160,"wires":[]},{"id":"e231797a03125ed3","type":"subflow:4102712984e468f8","z":"02d02da715c60b44","name":"","env":[{"name":"order","value":"3","type":"num"},{"name":"label","value":"Time series data","type":"str"}],"x":390,"y":220,"wires":[]},{"id":"31db4b325d6bb143","type":"change","z":"02d02da715c60b44","name":"","rules":[{"t":"set","p":"switch","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"'alert: ' & payload","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":340,"wires":[["832bd8ab0bda88dc"]]},{"id":"3cf7a70ec42e0b3f","type":"switch","z":"02d02da715c60b44","name":"","property":"switch","propertyType":"flow","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":390,"y":280,"wires":[["50e3f611f5c4262c"]]}]
Created 4 years, 4 months ago
Updated 3 years, 8 months ago
  • change (x13)
  • comment (x27)
  • function (x13)
  • http in (x2)
  • http response (x2)
  • inject (x9)
  • json (x4)
  • switch (x7)
  • template (x4)
  • websocket in (x4)
  • websocket out (x4)
  • websocket-listener (x1)
  • subflow (x9)
  • subflow:1bd86210b503b896 (x1)
  • subflow:4102712984e468f8 (x1)
  • subflow:54c1e80336f93e12 (x8)
  • subflow:8994b5c4dba46c76 (x1)
  • subflow:9c0a52e2454bab6f (x1)
  • subflow:aec0d9b3a72479a3 (x1)
  • subflow:c9fb680bbb1d67cc (x1)
  • subflow:eceae5246a022264 (x1)
  • subflow:f8178bddf53d614e (x1)
  • dashboard
  • react
