Trading info from beleggen
Flow to get trading info from beleggen.nl
[{"id":"9301c2da.919978","type":"inject","z":"9080bff.bbf72c","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":252,"y":144,"wires":[["89ae9697.4e0c2"]]},{"id":"89ae9697.4e0c2","type":"http request","z":"9080bff.bbf72c","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"https://www.beleggen.nl/koersen/aex.aspx","tls":"","persist":false,"proxy":"","authType":"","x":351,"y":144,"wires":[["2b322f4a.48a2a"]],"l":false},{"id":"8b771417.d1bfc","type":"debug","z":"9080bff.bbf72c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":550,"y":144,"wires":[]},{"id":"2b322f4a.48a2a","type":"html","z":"9080bff.bbf72c","name":"","property":"payload","outproperty":"payload","tag":".tableissue tbody tr","ret":"text","as":"single","x":399,"y":144,"wires":[["849ac71c.43d37"]],"l":false},{"id":"849ac71c.43d37","type":"function","z":"9080bff.bbf72c","name":"","func":"m = msg.payload\nkoersen = []\n\nfor(x=0;x<m.length;x++){\n    \n    str = m[x]\n    tmp = str.replace(/,/g,\".\")\n    tmp = tmp.replace(/\\s\\s+/g, ',');\n    obj = tmp.split(\",\")\n    \n    fonds = obj[0]\n    koers = parseFloat(obj[1])\n    plusmin = parseFloat(obj[2])\n    pct = parseFloat(obj[3])\n    open = parseFloat(obj[4])\n    hoog = parseFloat(obj[5])\n    laag = parseFloat(obj[6])\n    tijd = obj[7]\n    \n    koersen.push({fonds:fonds,koers:koers,plusmin:plusmin,pct:pct,open:open,hoog:hoog,laag:laag,tijd:tijd})\n    \n}\n\nreturn {payload:koersen}","outputs":1,"noerr":0,"x":447,"y":144,"wires":[["8b771417.d1bfc"]],"l":false}]
Created 6 years, 2 months ago
  • html (x1)
  • http request (x1)
  • trading
  • flow
