Send openHAB 2 events to pushover
This Flow send openHAB 2 Events to Pushover.
Two door and one window and one Testbutton for check Pushover.
Details see http://blog.wenzlaff.de/?p=12499 (German).
[{"id":"c486d98b.e3b238","type":"tab","label":"Pushover Benachrichtigungen","disabled":false,"info":""},{"id":"fd2bf97a.f97078","type":"pushover","z":"c486d98b.e3b238","name":"","device":"","title":"openHAB 2","priority":0,"sound":"magic","url":"http://www.wenzlaff.info","url_title":"Homeautomatisation","html":false,"x":1110,"y":180,"wires":[]},{"id":"2cc1f817.99e8a8","type":"inject","z":"c486d98b.e3b238","name":"","topic":"","payload":"Test Pushover","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":730,"y":80,"wires":[["fd2bf97a.f97078"]]},{"id":"72297b5e.1f94b4","type":"comment","z":"c486d98b.e3b238","name":"Testen: Versende eine Test-Pushover Nachricht","info":"","x":700,"y":40,"wires":[]},{"id":"e8109cdb.1badf","type":"openhab2-in","z":"c486d98b.e3b238","name":"Terrassentür im Wohnzimmer","controller":"69d3086d.60bbd","itemname":"terrasseKontakt","x":160,"y":160,"wires":[["fa7154d0.ae0808"],[]]},{"id":"74eb5306.bf9834","type":"debug","z":"c486d98b.e3b238","name":"Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1070,"y":580,"wires":[]},{"id":"fa7154d0.ae0808","type":"rbe","z":"c486d98b.e3b238","name":"Nur bei Änderung des Wert weiter","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":380,"y":220,"wires":[["cff49725.3165"]]},{"id":"b8199b02.9a85d","type":"template","z":"c486d98b.e3b238","name":"Geöffnet","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Die Terrassentür wurde geöffnet.","output":"str","x":740,"y":180,"wires":[["74eb5306.bf9834","fd2bf97a.f97078"]]},{"id":"cff49725.3165","type":"switch","z":"c486d98b.e3b238","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":220,"wires":[["b8199b02.9a85d"],["c2a6896c.a5dad"]]},{"id":"c2a6896c.a5dad","type":"template","z":"c486d98b.e3b238","name":"Geschlossen","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Die Terrassentür wurde geschlossen.","output":"str","x":750,"y":260,"wires":[["74eb5306.bf9834","fd2bf97a.f97078"]]},{"id":"201dbe01.05f36a","type":"comment","z":"c486d98b.e3b238","name":"openHAB 2 Ereignisse die zu Pushover Nachrichten führen","info":"","x":250,"y":40,"wires":[]},{"id":"67bcc451.5ee09c","type":"comment","z":"c486d98b.e3b238","name":"(c) 2019 Thomas Wenzlaff   www.wenzlaff.de","info":"","x":210,"y":100,"wires":[]},{"id":"121fdc72.eadf8c","type":"openhab2-in","z":"c486d98b.e3b238","name":"Haustür im Flur","controller":"69d3086d.60bbd","itemname":"flurKontakt","x":120,"y":320,"wires":[["24e56612.1b76b2"],[]]},{"id":"24e56612.1b76b2","type":"rbe","z":"c486d98b.e3b238","name":"Nur bei Änderung des Wert weiter","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":380,"y":380,"wires":[["4b35625e.4fa0e4"]]},{"id":"4b35625e.4fa0e4","type":"switch","z":"c486d98b.e3b238","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":380,"wires":[["896dc6c7.fea9b"],["ffe03fb9.a6e338"]]},{"id":"ffe03fb9.a6e338","type":"template","z":"c486d98b.e3b238","name":"Geschlossen","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Die Haustür wurde geschlossen.","output":"str","x":750,"y":420,"wires":[["74eb5306.bf9834","fd2bf97a.f97078"]]},{"id":"896dc6c7.fea9b","type":"template","z":"c486d98b.e3b238","name":"Geöffnet","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Die Haustür wurde geöffnet.","output":"str","x":740,"y":340,"wires":[["74eb5306.bf9834","fd2bf97a.f97078"]]},{"id":"7dda5f05.0ae358","type":"openhab2-in","z":"c486d98b.e3b238","name":"Fenster im Arbeitszimmer","controller":"69d3086d.60bbd","itemname":"arbeitszimmerFensterKontakt","x":150,"y":480,"wires":[["511eb303.1ba71c"],[]]},{"id":"511eb303.1ba71c","type":"rbe","z":"c486d98b.e3b238","name":"Nur bei Änderung des Wert weiter","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":380,"y":540,"wires":[["53fe33f5.67bb6c"]]},{"id":"53fe33f5.67bb6c","type":"switch","z":"c486d98b.e3b238","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":540,"wires":[["83414a68.031a2"],["2a78623a.49899e"]]},{"id":"83414a68.031a2","type":"template","z":"c486d98b.e3b238","name":"Geöffnet","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Das Fenster im Arbeitszimmer wurde geöffnet.","output":"str","x":740,"y":500,"wires":[["fd2bf97a.f97078","74eb5306.bf9834"]]},{"id":"2a78623a.49899e","type":"template","z":"c486d98b.e3b238","name":"Geschlossen","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Das Fenster im Arbeitszimmer geschlossen.","output":"str","x":750,"y":580,"wires":[["fd2bf97a.f97078","74eb5306.bf9834"]]},{"id":"69d3086d.60bbd","type":"openhab2-controller","z":"","name":"OpenHab2","protocol":"http","host":"localhost","port":"8080","path":"","username":"","password":""}]
Created 8 years, 6 months ago
Rating: 5 2
  • comment (x3)
  • rbe (x3)
  • switch (x3)
  • template (x6)
  • openHAB
  • openhab2
  • "openHAB2"
  • home
  • homeautomatisierung
  • flow
  • wenzlaff.de
  • www.wenzlaff.de
